| 06-Process placement configuration | 86.24 KB |
Process placement policy and optimization
Configuring process placement policy
Configuring a location affinity
Configuring a location type affinity
Configuring a process affinity
The switch operates in IRF or standalone (the default) mode. For more information about the IRF mode, see IRF Configuration Guide.
Overview
Process placement enables placing processes to specific CPUs (also called "nodes") on the main processing units (MPUs) in your system for optimal distribution of CPU and memory resources.
Process
A process comprises a set of codes and provides specific functionality. For example, an AAA process provides AAA functions.
Each process runs in a protected memory space to prevent problems with one process from impacting the entire system.
1:N process redundancy
The system backs up each active process running on one node to all the other nodes. Typically, a CPU is a node. When an active process fails, one of its standby processes promptly takes over without impacting any other service.
This 1:N process redundancy improves service availability and enables the system to quickly regain reliability after the device status changes including insertion and removal of cards, IRF split, and removal of an IRF member.
Process placement policies
For an active process running on only the global active MPU, it does not support placement optimization (by displaying a configuration failure prompt). When such an active process fails, the system automatically restarts the process. The standby processes are used for active/standby switchover and ISSU.
Some active processes can run on either the global active or standby MPU. When such an active process fails, the system uses a placement policy to select a new active process among standby processes.
The system provides a default process placement policy that takes effect for all processes. You can modify the default placement policy in the view you enter with the placement program default command. You can also configure a placement policy for a specific process in the view you enter with the placement program program-name [ instance instance-name ] command. A placement policy for a process takes precedence over the default process placement policy.
By default, the default process placement policy defines the following rules:
· The active process runs on the CPU of the active MPU, and the standby processes run on the CPUs of the standby MPUs. (In standalone mode.)
· The active process runs on the CPU of the global active MPU, and the standby processes run on the CPUs of the global standby MPUs. (In IRF mode.)
· A process runs at the location where it ran the last time and does not move to any other location during startup or operation.
· The addition of a new node does not impact current active processes. A new active process selects one node with sufficient CPU and memory resources. (You can use the display cpu-usage and display memory commands to view CPU and memory usage information.)
Optimizing process placement
You can configure the following settings for a process placement policy to optimize process placement:
· affinity location-set—Location affinity, the preference for the process to run on a specific node.
· affinity location-type—Location type affinity, the preference for the process to run on a particular type of node. For more information about node types, see "Configuring a location type affinity."
· affinity program—Process affinity, the preference for the process to run on the same node as a particular process.
· affinity self—Self affinity, the preference for one instance of the process to run on the same node as any other instance of the process.
Affinities fall into positive affinities (attract) and negative affinities (repulse), all represented by integers in the range of 1 to 100000.
· The higher the attract value, the stronger the preference.
· The higher the repulse value, the weaker the preference.
After you apply new placement policies, the system makes placement decisions based on the new policies, node resources, and topology status. If the new location for an active process is different from the current node, the system changes the state of the process to standby, and uses the standby process on the preferred location as the new active process.
· Configuring process placement on a device with only one CPU does not change the location of processes.
· Configuring process placement on a device with multiple CPUs places specific active processes to specific CPUs. In case of multiple CPUs, the system performs 1:N process redundancy, where N must be less than the number of CPUs. The number of standby processes and their CPU locations depend on the function module. The system by default automatically determines the location for each active process, and there is no need to optimize process placement. If optimization is needed, work with H3C/HP engineers to avoid service interruption.
· Process placement applies to MPUs only. The configuration does not take effect on an interface card even if it has a CPU and is configured as location affinity for a process.
Configuration task list
To optimize process placement, perform the following tasks:
Tasks at a glance |
Configuring process placement policy: · (Optional.) Configuring a location affinity · (Optional.) Configuring a location type affinity · (Optional.) Configuring a process affinity · (Optional.) Configuring a self affinity |
(Required.) Optimizing process placement |
Step |
Command |
Remarks |
1. Enter system view. |
system-view |
N/A |
2. Enter placement process view. |
Enter default placement process view: ·
Enter placement process view: |
Use either command. Settings in default placement process view take effect for all processes. Settings in placement process view take effect for the specified process only. |
3. Set the location affinity (in standalone mode). |
affinity location-set { slot slot-number [ cpu cpu-number ] }&<1-5> { attract strength | default | none | repulse strength } |
By default, no location affinity is set. |
4. Set the location affinity (in IRF mode). |
affinity location-set { chassis chassis-number slot slot-number [ cpu cpu-number ] }&<1-5> { attract strength | default | none | repulse strength } |
The following location types are available:
· current—Current location of the active process, which can be displayed with the display placement program command.
· paired—Locations of standby processes.
· primary—Active MPU. (Standalone mode.)
· primary—Global active MPU. (IRF mode.)
To configure a location type affinity:
Step |
Command |
Remarks |
system-view |
N/A |
3. Set the location type affinity. |
affinity location-type { current | paired | primary } { attract strength | repulse strength | default | none } |
By default, no location type affinity is set. |
Step |
Command |
Remarks |
system-view |
N/A |
3. Configure the affinity to another process. |
affinity program program-name { attract strength | repulse strength | default | none } |
By default, no process affinity is set. |
Perform this task to configure the preference for one instance of a process to run on the same node as any other instance of the process. The self affinity setting does not take effect for a process that has only one instance.
To configure a self affinity:
Step |
Command |
Remarks |
system-view |
N/A |
3. Configure a self affinity. |
affinity self { attract strength | repulse strength | default | none } |
By default, no self affinity is set. |
Step |
Command |
system-view |
2. Optimize process placement. |
placement reoptimize |
Displaying process placement
Task |
Command |
Display process placement policy information. |
display placement policy program { program-name | all | default } |
Display the location of a process. |
display placement program { program-name | all } |
Display the running processes on a specific location (in standalone mode). |
display placement location { slot slot-number [ cpu cpu-number ] | all } |
Display the running processes on a specific location (in IRF mode). |
display placement location { chassis chassis-number slot slot-number [ cpu cpu-number ] | all } |
Display the predicted location of a process after process placement optimization. |
display placement reoptimize program { program-name [ instance instance-name ] | all } |
