05-Layer 2 - WAN Configuration Guide
HomeSupportSwitchesS9500E SeriesConfigure & DeployConfiguration GuidesH3C S9500E Configuration Guide-Release1728-6W17005-Layer 2 - WAN Configuration Guide
03-Modem Management Configuration
03-Modem Management Configuration 62.86 KB
This chapter describes how to manage and control the modem connected to the switch.
Configuration procedure
To manage your modem:
Step
Remarks
1.     Enter system view.
N/A
2.     Enter user interface view.
user-interface { first-num1 [ last-num1 ] | aux first-num2 [ last-num2 ] }
N/A
3.     Enable modem call-in/call-out.
modem { both | call-in | call-out }
Only modem call-in is supported.
Modem call-in and call-out are denied by default.
4.     Set the maximum interval allowed between picking up the handset and dialing when a user tries to establish a connection.
modem timer answer time
Optional.
60 seconds by default.
1.     Configure the modem to work in auto-answer mode.
modem auto-answer
Optional.
By default, non-auto answer mode applies.
IMPORTANT IMPORTANT:
Make sure you set the same answer mode as on the modem. If a different answer mode is set, the modem might operate improperly.
2.     Return to system view.
N/A
3.     Enable modem callback.
service modem-callback
Optional.
Disabled by default.
Troubleshooting
Symptom
Modem is in abnormal status (for example, the dial tone or busy tone keeps humming).
Solution
·           Run the shutdown command and undo shutdown command on the switch’s physical interface connected to the modem, and check whether the modem has recovered.
·           If the modem still cannot work properly, re-power the modem.
