H3C S9500E Routing Switch Series Installation Guide-6PW107
HomeSupportSwitchesS9500E SeriesInstall & UpgradeInstallation GuidesH3C S9500E Routing Switch Series Installation Guide-6PW107
09-Appendix A Technical Specifications
09-Appendix A Technical Specifications 160.95 KB
Environment requirements
Temperature
Range
Operating temperature
·       Long term:
0°C to 45°C (32°F to 113°F)
·       Short term:
–10°C to +55°C (14°F to 131°F) (up to 96 hours of continuous operation within less than 15 days in one year)
Operating humidity (noncondensing)
5% to 95%
Storage temperature
–40°C to +70°C (–40°F to +158°F)
Operating altitude
Available altitude: ≤ 4000 m (13123.36 ft)
Certificated altitude: ≤ 3000 m (9842.52 ft)
Power consumption, weight, and dimensions
Switches
Table 1 Switch specifications
Switch model
Max. system input power consumption
Max. power consumption for cards and fans
Weight
Dimensions (H × W × D)
Height (RU)
S9505E
1690 W (AC)
1510 W (DC)
1435 W
Net weight: 40 kg (88.18 lb)
Full configuration: ≤ 80 kg (176.37 lb)
486 × 442 × 450 mm (19.13 × 17.40 × 17.72 in)
11 RU
S9508E
2510 W (AC)
2250 W (DC)
2135 W
Net weight: 50 kg (110.23 lb)
Full configuration: ≤ 100 kg (220.46 lb)
620 × 442 × 450 mm (24.41 × 17.40 × 17.72 in)
14 RU
S9508E-V
2530 W (AC)
2270 W (DC)
2150 W
Net weight: 58 kg (127.87 lb)
Full configuration: ≤110 kg (242.50 lb)
975 × 436 × 451 mm (38.39 × 17.17 × 17.76 in)
22 RU
S9512E
3650 W (AC)
3270 W (DC)
3100 W
Net weight: 60 kg (132.28 lb)
Full configuration: ≤ 120 kg (264.55 lb)
753 × 442 × 450 mm (29.65 × 17.40 × 17.72 in)
17 RU
Max. system input power consumption refers to the maximum input power consumption of the chassis when the chassis is fully configured with cards that have the maximum power consumption.
Max. power consumption for cards and fans refers to the maximum power consumption of all cards and fans that have the maximum power consumption in the fully configured chassis. For example, the max power consumption of cards and fans for the S9505E is the maximum power consumption of two LSR1SRP2D1 MPUs, five LSR1LN2BNL1 base cards, 10 LSR1DTCP8L1 subcards and one fan tray.
Net weight refers to the weight of the chassis (with filler panels installed), excluding fan trays, cards, and power supplies.
Full configuration refers to the maximum weight of the switch when all cards and power supplies are installed to the switch.
Rack Unit (RU) refers to the height of the chassis in the rack. 1 RU = 44.45 mm (1.75 in).
Cards
Table 2 Card specifications
Card model
Power consumption
Net weight
LSR2GT24LEB1
40 W to 72 W
3.02 kg (6.66 lb)
40 × 400 × 380 mm (1.57 × 15.75 × 14.96 in)
LSR1GT24LEC1
44 W to 85 W
3.10 kg (6.83 lb)
LSR2GT48LEB1
54 W to 115 W
3.22 kg (7.10 lb)
LSR1GT48LEC1
68 W to 125 W
3.15 kg (6.94 lb)
LSR2GP24LEB1
33 W to 70 W
3.07 kg (6.77 lb)
LSR1GP24LEC1
43 W to 75 W
3.17 kg (6.99 lb)
LSR1GP48LEB1
43 W to 100 W
3.39 kg (7.47 lb)
LSR1GP48LEC1
63 W to 115 W
3.48 kg (7.67 lb)
LSR1GP48LEF1
65 W to 130 W
3.48 kg (7.67 lb)
LSR2GV48REB1
52 W to 95 W
3.32 kg (7.32 lb)
LSR1XP2LEB1
36 W to 50 W
2.94 kg (6.48 lb)
LSR1XP2LEC1
46 W to 60 W
3.02 kg (6.66 lb)
LSR1XP4LEB1
52 W to 75 W
3.08 kg (6.79 lb)
LSR1XP4LEC1
78 W to 95 W
3.17 kg (6.99 lb)
LSR1XP4LEF1
80 W to 110 W
3.19 kg (7.03 lb)
LSR1XP16REB1
80 W to 135 W
3.32 kg (7.32 lb)
LSR1XP16REC1
88 W to 155 W
3.43 kg (7.56 lb)
LSR1SRP2B1
79 W to 95 W
3.41 kg (7.52 lb)
LSR1SRP2C1
88 W to 105 W
3.55 kg (7.83 lb)
LSR1SRP2B2
52 W to 65 W
3.14 kg (6.92 lb)
LSR1SRP2C2
62 W to 75 W
3.29 kg (7.25 lb)
LSR1SRP2D1
93 W to 110 W
3.65 kg (8.05 lb)
LSR1LN1BNL1
80 W to 95 W
3.31 kg (7.30 lb)
LSR1LN2BNL1
148 W to 165 W
4.25 kg (9.37 lb)
LSR1DRUP1L1
Maximum power consumption: 18 W
0.39 kg (0.86 lb)
18 × 165 × 142 mm (0.71 × 6.50 × 5.59 in)
LSR1DPUP1L1
0.37 kg (0.82 lb)
LSR1DRSP2L1
Maximum power consumption: 20 W
0.37 kg (0.82 lb)
LSR1DPSP4L1
0.33 kg (0.73 lb)
LSR1DTCP8L1
Maximum power consumption: 30 W
0.36 kg (0.79 lb)
LSR1WCM2A1
80 W to 105 W
3.52 kg (7.76 lb)
LSR1FW2A1
73 W to 105 W
3.52 kg (7.76 lb)
LSR1IPS1A1
73 W to 105 W
3.52 kg (7.76 lb)
LSR1NSM1A1
73 W to 105 W
3.52 kg (7.76 lb)
LSR1LB1A1
73 W to 105 W
3.52 kg (7.76 lb)
LSR1ACG1A1
73 W to 105 W
3.52 kg (7.76 lb)
Fan trays
Table 3 Fan tray specifications
Fan tray
Power consumption
Net weight
A single fan tray of S9505E/S9512E
12 W to 90 W
3.97 kg (8.75 lb)
299.5 × 95 × 412.7 mm (11.79 × 3.74 × 16.25 in)
A single fan tray of S9508E
16 W to 115 W
5.84 kg (12.87 lb)
454.7 × 95 × 412.7 mm (17.90 × 3.74 × 16.25 in)
A single fan tray of S9508E-V
16 W to 130 W
4.85 kg (10.69 lb)
64 × 403.2 × 405.4 mm (2.52 × 15.87 × 15.96 in)
The S9505E/S9512E and S9508E adopt the vertical fan tray slot. The S9508E-V adopts the horizontal fan tray slot.
Power supplies
Table 4 Power supply weight
Model
Max. output power
Net weight
NEPS3500-A
3500 W AC power frame
3500 W (when two sub power supplies are installed)
3.90 kg (8.60 lb) (excluding sub power supplies)
NEPS1800-A
1800 W AC sub power supply
1200 W (100 VAC to 120 VAC)
1800 W (200 VAC to 240 VAC)
2.25 kg (4.96 lb)
NEPS2000-D
2000 W DC power supply
2000 W
6.36 kg (14.02 lb)
NEPS3500-D
3500 W DC power supply
3500 W
6.14 kg (13.54 lb)
Switch ordering guide
Model
Power supply
Card slot mode
MPU slots
LPU slots
Power supply slots
 fan trays
Remarks
S9505E
AC/DC
Horizontal
2
5
2
1
H3C recommends configuring two MPUs and two power supplies for 1+1 redundancy.
S9508E
AC/DC
Horizontal
2
8
2
1
S9508E-V
AC/DC
Vertical
2
8
2
1
S9512E
AC/DC
Horizontal
2
12
2
2
The LPU slots are for Ethernet interface cards, base cards, and OAA cards. For card specifications, see "Card specifications and compatibility."
Category
Card model
Applicable S9500E chassis
MPUs
LSR1SRP2B1
N/A
S9508E, S9508E-V, and S9512E
LSR1SRP2C1
N/A
LSR1SRP2B2
N/A
S9505E
LSR1SRP2C2
N/A
S9505E
LSR1SRP2D1
N/A
All S9500E models
LSR2GT24LEB1
Standard
24-port 1000 Mbps copper Ethernet interface card
All S9500E models
LSR1GT24LEC1
Enhanced
All S9500E models
LSR2GT48LEB1
Standard
48-port 1000 Mbps copper Ethernet interface card
All S9500E models
LSR1GT48LEC1
Enhanced
All S9500E models
LSR2GP24LEB1
Standard
24-port 1000 Mbps fiber Ethernet interface card
All S9500E models
LSR1GP24LEC1
Enhanced
All S9500E models
LSR1GP48LEB1
Standard
48-port 1000 Mbps fiber Ethernet interface card
All S9500E models
LSR1GP48LEC1
Enhanced
All S9500E models
LSR1GP48LEF1
Advanced
All S9500E models
LSR2GV48REB1
Standard
All S9500E models
LSR1XP2LEB1
Standard
2-port 10 Gbps fiber Ethernet interface card
All S9500E models
LSR1XP2LEC1
Enhanced
All S9500E models
LSR1XP4LEB1
Standard
4-port 10 Gbps fiber Ethernet interface card
All S9500E models
LSR1XP4LEC1
Enhanced
All S9500E models
LSR1XP4LEF1
Advanced
All S9500E models
LSR1XP16REB1
Standard
16-port 10 Gbps fiber Ethernet interface card
All S9500E models
LSR1XP16REC1
Enhanced
All S9500E models
Base cards
LSR1LN1BNL1
Single-line base card
All S9500E models
LSR1LN2BNL1
Dual-line base card
All S9500E models
Subcards
LSR1DRUP1L1
1-port OC-192c/STM-64c RPR fiber interface card
All S9500E models
LSR1DPUP1L1
1-port OC-192c/STM-64c POS fiber interface card
All S9500E models
LSR1DRSP2L1
2-port OC-48c/STM-16c RPR fiber interface card
All S9500E models
LSR1DPSP4L1
4-port OC-48c/STM-16c POS fiber interface card
All S9500E models
LSR1DTCP8L1
8-port OC-3c/OC-12c POS fiber interface card
All S9500E models
OAA cards
LSR1FW2A1
Firewall card
All S9500E models
LSR1IPS1A1
1000 Mbps IPS card
All S9500E models
LSR1WCM2A1
Wireless controller module
All S9500E models
LSR1NSM1A1
NetStream card
All S9500E models
LSR1LB1A1
Load balancing (LB) card
All S9500E models
LSR1ACG1A1
Application control gateway (ACG) card
All S9500E models
·       You must install the subcards to the base cards before installing them to your switch.
·       The LSR1GP48LEF1 and LST1XP4LEF1 are supported by Release B1323 or above. The LSR1XP16REC1 is supported by Release B1331 or above.
For more information about the S9500E card LEDs, see "Appendix B LEDs."
For more information about the S9500E cards, see the corresponding datasheet of the cards.
MPUs
Table 5 MPU specifications
Item
Specifications
LSR1SRP2B1
LSR1SRP2C1
LSR1SRP2B2
LSR1SRP2C2
LSR1SRP2D1
CPU
MPC8548
MPC8548+MPC8544
MPC8548
MPC8548+MPC8544
MPC8548+MPC8544
Applicable switches
S9508E
S9508E-V
S9512E
S9508E
S9508E-V
S9512E
S9505E
S9505E
All S9500E series switches
Boot ROM
4 MB
Flash
128 MB
NVRAM
1 MB
SDRAM (DDR2)
1 GB (expandable to 2 GB)
CF card
256 MB (expandable to 512 MB or 1 GB)
Interfaces
·       1 console port
·       1 AUX port
·       1 network management port
·       1 CF card slot
·       2 USB ports
·       4 SMB coaxial clock interface (supported only by LSR1SRP2D1)
Table 6 Ethernet interface card specifications
Model
Interface type and number
Supported interface modules
LSR2GT24LEB1
Sixteen 10/100/1000 Mbps auto-sensing RJ-45 copper ports and eight Combo interfaces
GE SFP module
LSR1GT24LEC1
GE SFP module
LSR2GT48LEB1
Forty-eight 10/100/1000 Mbps auto-sensing RJ-45 copper ports
N/A
LSR1GT48LEC1
N/A
LSR2GP24LEB1
Sixteen 1000 Mbps SFP/LC fiber ports and eight Combo interfaces
GE SFP module
LSR1GP24LEC1
GE SFP module
LSR1GP48LEB1
Forty-eight 1000 Mbps SFP/LC fiber ports
GE SFP module
LSR1GP48LEC1
GE SFP module
LSR1GP48LEF1
GE SFP module
LSR2GV48REB1
N/A
LSR1XP2LEB1
Two 10-GE XFP fiber ports
10-GE XFP module
LSR1XP2LEC1
10-GE XFP module
LSR1XP4LEB1
Four 10-GE XFP fiber ports
10-GE XFP module
LSR1XP4LEC1
10-GE XFP module
LSR1XP4LEF1
10-GE XFP module
LSR1XP16REB1
Sixteen 10-GE SFP+ fiber ports
·       10-GE SFP+ module
·       10-GE SFP+ cable
LSR1XP16REC1
·       10-GE SFP+ module
·       10-GE SFP+ cable
Each combo interface comprises a copper port and a fiber port. The two ports cannot work at the same time.
Base cards
A base card provides external interfaces and supports relevant software configurations only after a subcard is installed to it.
Table 7 Base card specifications
Model
Number of subcard slots
Supported subcards
LSR1LN1BNL1
1
·       LSR1DRUP1L1
·       LSR1DPUP1L1
·       LSR1DPSP4L1
·       LSR1DRSP2L1
·       LSR1DTCP8L1
LSR1LN2BNL1
2
Subcards
You can install the following subcards to the base card LSR1LN1BNL1 or LSR1LN2BNL1.
Table 8 Subcard specifications
Model
Connector
Interface transmission rate
Supported transceiver modules
LSR1DPUP1L1
One OC-192c/STM-64c POS fiber port
XFP/LC
9953.28 Mbps
10G XFP module
LSR1DRUP1L1
One OC-192c/STM-64c RPR fiber port
One mate copper port
XFP/LC
9953.28 Mbps
10G XFP module
LSR1DRSP2L1
Two OC-48c/STM-16c RPR fiber ports
Two OC-48c/STM-16c SFP mate fiber ports
SFP/LC
2488.32 Mbps
2.5G SFP module
LSR1DPSP4L1
Four OC-48c/STM-16c POS fiber ports
SFP/LC
2488.32 Mbps
2.5G SFP module
LSR1DTCP8L1
Eight OC-3c/OC-12c POS/GE fiber ports
SFP/LC
155.52 Mbps
622.08 Mbps
155M POS SFP module
622M POS SFP module
The LSR1DTCP8L1 subcard supports two types of interface transmission rates. You can configure an interface rate as OC-3c (155.52 Mbps) or OC-12c (622.08 Mbps), and then select an SFP module supporting the same rate.
OAA cards
CAUTION
CAUTION:
The software upgrade of OAA cards must be performed though console ports or Ethernet ports on the OAA cards, rather than the MPU.
Table 9 OAA card specifications
Model
Interfaces
LST1FW2A1
·       One console port
·       One CF card slot
·       Two USB ports
·       Two 10/100/1000 BASE-T copper ports
·       Two GE combo interfaces
GE SFP modules
LSR1IPS1A1
·       One console port
·       One CF card slot
·       Two USB ports
GE SFP modules
LSR1NSM1A1
·       One console port
·       One CF card slot
·       Two USB ports
GE SFP modules
LSR1LB1A1
·       One console port
·       One CF card slot
·       Two USB ports
GE SFP modules
LSR1ACG1A1
·       One console port
·       One CF card slot
·       Two USB ports
GE SFP modules
LSR1WCM2A1
·       One console port
·       One 10/100/1000 BASE-T copper interface
·       Two USB ports
N/A
Power components
Select AC or DC power supplies according to the power supply mode of your switch.
·           Make sure the maximum output power of the power supplies exceeds the system power consumption. H3C recommends reserving a certain power de-rating value. For the maximum output power of a single power supply, see Table 10.
·           H3C recommends you to configure N+1 or N+M power supply redundancy.
·           To use AC power supply, select the specific 16 A AC power cords. For the 16A AC power cords used in different countries or regions, see Table 11.
·           An NEPS3500-A AC power frame can function properly only after you install one or two NEPS1800-A AC sub power supplies to it.
Table 10 Electrical parameters of power supplies
Model
Rated input voltage range
Max. input voltage range
Max. input current
Max. output power
NEPS3500-A
N/A
N/A
N/A
3500 W (when installed with two AC sub power supplies)
NEPS1800-A
100 VAC to 120 VAC; 50 Hz or 60 Hz
200 VAC to 240 VAC; 50 Hz or 60 Hz
90 VAC to 264 VAC; 50 Hz or 60 Hz
20 A
NEPS2000-D
–48 VDC to –60 VDC
–40 VDC to –72 VDC
60 A
2000 W
NEPS3500-D
–48 VDC to –60 VDC
–40 VDC to –72 VDC
80 A
3500 W
Table 11 16A AC power cords used in different countries or regions
No.
Specifications
1
Connector type
Code (Length)
Countries or regions where the type of power cords conforms to local safety regulations and can be used legally
Other countries or regions using this type of power cords
Countries or regions seldom using this type of power cords
I type
04043396 (3 m, i.e., 9.8 ft)
Mainland China
Connector outline
Power cord outline
Connector outline
040433962WX_VD
040433961WX_VD
2
Connector type
Code (Length)
B type
0404A063 (3 m, i.e., 9.8 ft)
Canada and U.S.A
Mexico, Argentina, Brazil, Columbia, Venezuela, Thailand, Peru, and Philippines
Connector outline
Power cord outline
Connector outline
3
Connector type
Code (Length)
F type
0404A061 (3 m, i.e., 9.8 ft)
Holland, Denmark, Sweden, Finland, Norway, Germany, France, Austria, Belgium, and Italy
Indonesia, Turkey, Russia, and CIS
Connector outline
Power cord outline
Connector outline
0404A0611WX_V00
0404A061WX_V00
040433961WX_VD
4
Connector type
Code (Length)
G type
0404A060 (3 m, i.e., 9.8 ft)
U.K.
Malaysia, Singapore, Hong Kong, and Egypt
Connector outline
Power cord outline
Connector outline
0404A0601WX_V00
5
Connector type
Code (Length)
B type
0404A062 (3 m, i.e., 9.8 ft)
Japan
Connector outline
Power cord outline
Connector outline
0404A062WX_V00
040433961WX_VD
6
Connector type
Code (Length)
I type
0404A01A (3 m, i.e., 9.8 ft)
Australia
Connector outline
Power cord outline
Connector outline
0404A01AWX_V00
0404A01A1WX_V00
040433961WX_VD
