H3C S3100 Series Ethernet Switches Command Manual-Release 22XX Series(V1.00)
HomeSupportSwitchesS3100 SeriesReference GuidesCommand ReferencesH3C S3100 Series Ethernet Switches Command Manual-Release 22XX Series(V1.00)
41-ARP and IP Attack Defense Commands
41-ARP and IP Attack Defense Commands 51.22 KB
ARP and IP Attack Defense Configuration Commands
arp anti-attack valid-check enable
undo arp anti-attack valid-check enable
View
None
Use the arp anti-attack valid-check enable command to enable ARP source MAC address consistency check.
Use the undo arp anti-attack valid-check enable command to disable this function.
By default, ARP source MAC address consistency check is disabled.
# Enable ARP source MAC address consistency check.
<sysname> system-view
[sysname] arp anti-attack valid-check enable
arp filter source
arp filter source ip-address
undo arp filter source
View
Ethernet port view
ip-address: IP address of the gateway.
Use the arp filter source command to configure ARP packet filtering based on the gateway’s IP address on the current port. After that, ARP packets with the gateway’s IP address as the sender IP address are considered invalid and discarded.
Use the undo arp filter source command to remove the configuration.
By default, ARP packet filtering based on the gateway’s IP address is disabled.
Note that:
l          This command should be configured on a port directly connected to hosts.
l          If you execute this command repeatedly, the last configured command takes effect.
l          Among S3100 series switches, only S3100-EI series switches support the two commands.
# Configure ARP packet filtering based on the gateway’s IP address 192.168.0.1/24 on Ethernet 1/0/1.
[sysname] interface Ethernet1/0/1
[sysname-Ethernet1/0/1] arp filter source 192.168.0.1
arp filter binding
undo arp filter binding
View
Ethernet port view
mac-address: MAC address of the gateway.
Use the arp filter binding command to configure ARP packet filtering based on the gateway’s IP and MAC addresses on the current port. After that, the port will discard ARP packets with the gateway’s IP address as the sender IP address but with the sender MAC address different from that of the gateway.
Use the undo arp filter binding command to remove the configuration.
By default, ARP packet filtering based on the gateway’s IP and MAC addresses are disabled.
Note that:
l          This command should be configured on a cascaded port or upstream port of an access switch.
# Configure ARP packet filtering based on the gateway’s IP address 192.168.100.1/24 and MAC address 000d-88f8-528c on Ethernet 1/0/2.
[sysname] interface Ethernet1/0/2
[sysname-Ethernet1/0/2] arp filter binding 192.168.100.1 000d-88f8-528c
arp max-learning-num
arp max-learning-num number
undo arp max-learning-num
View
VLAN interface view
number: Maximum number of dynamic ARP entries that can be learned by the interface. it ranges from 1 to 256.
Use the arp max-learning-num command to configure the maximum number of dynamic ARP entries that can be learned by the current VLAN interface.
Use the undo arp max-learning-num command to remove the configuration.
By default, the maximum number of dynamic ARP entries that can be learned by a VLAN interface is not configured.
Note that:
# Configure the maximum number of dynamic ARP entries that can be learned by VLAN-interface 40 as 50.
[sysname] interface vlan-interface 40
[sysname-Vlan-interface40] arp max-learning-num 50
ip source static import dot1x
undo ip source static import dot1x
View
None
Use the ip source static import dot1x command to enable using IP-MAC bindings of authenticated 802.1x clients for ARP attack detection. The IP-MAC bindings of authenticated 802.1x clients are used for ARP attack detection after IP-MAC static bindings and DHCP snooping entries are checked.
Use the undo ip source static import dot1x command to disable the function.
By default, this function is disabled.
Note that:
l          This command should be used in cooperation with the arp detection enable command.
# Enable the switch to record IP-MAC bindings of authenticated 802.1x clients.
[sysname] ip source static import dot1x
ip check dot1x enable
undo ip check dot1x enable
View
Ethernet port view
None
Use the ip check dot1x enable command to enable IP filtering based on IP-MAC bindings of authenticated 802.1x clients.
Use the undo ip check dot1x enable command to disable the function.
By default, IP filtering based on IP-MAC bindings of authenticated 802.1x clients is disabled.
Note that:
l          The ip check dot1x enable and the ip check source ip-address mac-address commands are mutually exclusive.
# Enable IP filtering based on IP-MAC bindings of authenticated 802.1x clients on Ethernet 1/0/2.
[sysname] interface ethernet1/0/2
[sysname-Ethernet1/0/2] ip check dot1x enable
