H3C S5120-SI Series Ethernet Switches Command Reference-Release 1101-6W105
HomeSupportSwitchesS5120 SeriesReference GuidesCommand ReferencesH3C S5120-SI Series Ethernet Switches Command Reference-Release 1101-6W105
28-Device Management Commands
28-Device Management Commands 134.31 KB
boot-loader
boot-loader file file-url { main | backup }
View
Default Level
2: System level
file file-url: Specifies a file name, a string of 1 to 63 characters, If you enter a relative path here, the system automatically converts it to an absolute path. The absolute path should contain no more than 63 characters; otherwise, the command cannot be successfully executed. The file name is in the format of [drive:/]file-name, where
l          The items in square brackets [ ] are optional.
l          drive specifies the storage medium of the file. The value is the name of the storage medium. If a device has only one storage medium, you can execute this command without providing this argument.
l          file-name specifies the filename, which is usually suffixed by .bin. Suffixes vary with devices.
main: Specifies a file as a main boot file. A main boot file is used to boot a device.
backup: Specifies a file as a backup boot file. A backup boot file is used to boot a device only when a main boot file is unavailable.
Use the boot-loader command to specify a boot file for the next boot.
Related commands: display boot-loader.
# Specify the main boot file for the next device boot as test.bin. (The output of this command varies with devices.)
<Sysname> boot-loader file test.bin main
  This command will set the boot file. Continue? [Y/N]:y
The specified file will be used as the main boot file at the next reboot on sl
ot 1!
bootrom
bootrom update file file-url
View
Default Level
2: System level
update file file-url: Upgrades Boot ROM, where file-url is a string of 1 to 63 characters and represents name of the file to be upgraded. See boot-loader.
Use the bootrom command to upgrade the Boot ROM program on a device(s).
# Read the Boot ROM program.
<Sysname> bootrom update file a.btm
This command will update bootrom file, Continue? [Y/N]:y
  Now updating bootrom, please wait...
  BootRom file updating finished!
bootrom-update security-check enable
undo bootrom-update security-check enable
View
Default Level
2: System level
None
Use the bootrom-update security-check enable command to enable the validity check function.
Use the undo bootrom-update security-check enable command to disable the validity check function.
By default, the validity check function is enabled at the time of upgrading Boot ROM.
After the validity check function is enabled, the device will strictly check whether the Boot ROM upgrade files are valid and can match the hardware.
# Enable the validity check function when upgrading Boot ROM.
[Sysname] bootrom-update security-check enable
display boot-loader
display boot-loader
View
Default Level
2: System level
None
Use the display boot-loader command to display information of the boot file.
Related commands: boot-loader.
# Display the file adopted for the current and next boot of the device. (The output of this command varies with devices.)
<Sysname> display boot-loader
The current boot app is:  flash:/test.bin
The main boot app is:     flash:/test.bin
The backup boot app is:   flash:/test.bin
Table 1-1 display boot-loader command output description
Boot file used for the device for the current device boot
Main boot file used for the next device boot of the device
Backup boot file used for the next device boot of the device
display cpu-usage
display cpu-usage [ number [ offset ] [ verbose ] [ from-device ] ]
View
Default Level
1: Monitor level
entry-number: Number of entries to be displayed, in the range of 1 to 60.
offset: Offset between the serial number of the first CPU usage statistics record to be displayed and that of the last CPU usage record to be displayed. It is in the range of 0 to 59. For example, the idx of the latest statistics record is 12, if the offset is set to 3, the system will display the statistics records from the one with the idx of 9. idx represents the serial number of the period for the statistics, and its value ranges from 0 to 60 cyclically. The system makes CPU usage statistics periodically; after each period, the system records the average CPU usage during this period, and the idx value is added by 1 automatically.
verbose: Specifies to display detailed information of CPU usage statistics. If this keyword is not provided, the system displays the brief information of the CPU usage statistics; if this keyword is provided, the system displays the average CPU usage statistics for each task in the specified period.
from-device: Displays external storage media such as flash and hard disk. The device currently does not support the from-device keyword.
Use the display cpu-usage command to display the CPU usage statistics.
The system takes statistics of CPU usage at intervals (usually every 60 seconds) and saves the statistical results in the history record area. The maximum number of records that can be saved depends on the device model. display cpu-usage entry-number indicates the system displays entry-number records from the newest (last) record. display cpu-usage entry-number offset indicates the system displays number records from the last but offset record.
Equivalent to the display cpu-usage 1 0 verbose command, the display cpu-usage command displays detailed information of the last CPU usage statistics record.
# Display information of the current CPU usage statistics.
<Sysname> display cpu-usage
Unit CPU usage:
       1% in last 5 seconds
       1% in last 1 minute
       1% in last 5 minutes
# Display the last fifth and sixth records of the CPU usage statistics history.
<Sysname> display cpu-usage 2 4
===== CPU usage info (no:  0  idx: 58) =====
CPU Usage Stat. Cycle: 60 (Second)
CPU Usage            : 3%
CPU Usage Stat. Time : 2006-07-10  10:56:55
CPU Usage Stat. Tick : 0x1d9d(CPU Tick High) 0x3a659a70(CPU Tick Low)
Actual Stat. Cycle   : 0x0(CPU Tick High) 0x95030517(CPU Tick Low)
===== CPU usage info (no:  1  idx: 57) =====
CPU Usage            : 3%
CPU Usage Stat. Time : 2006-07-10  10:55:55
CPU Usage Stat. Tick : 0x1d9c(CPU Tick High) 0xa50e5351(CPU Tick Low)
Actual Stat. Cycle   : 0x0(CPU Tick High) 0x950906af(CPU Tick Low)
Table 1-2 display cpu-usage command output description
Unit CPU usage
After the device boots, the system calculates and records the average CPU usage in every five seconds.
This field displays the average CPU usage in the last five seconds.
1% in last 1 minute
After the device boots, the system calculates and records the average CPU usage in every one minute.
This field displays the average CPU usage in the last minute.
After the device boots, the system calculates and records the average CPU usage in every five minutes.
This field displays the average CPU usage in the last five minutes.
CPU usage info (no:  idx:)
Information of CPU usage records (no: The (no+1)th record is currently displayed. no numbers from 0, a smaller number equals a newer record. idx: index of the current record in the history record table). If only the information of the current record is displayed, no and idx are not displayed.
CPU usage measurement interval, in seconds. For example, if the value is 41, it indicates that the average CPU usage during the last 41 seconds is calculated. The value range of this field is 1 to 60.
CPU Usage
Average CPU usage in a measurement interval, in percentage
CPU usage statistics time in seconds, that is, the system time when the command is executed
System runtime in ticks, represented by a 64-bit hexadecimal. CPU Tick High represents the most significant 32 bits and the CPU Tick Low the least significant 32 bits.
Actual Stat. Cycle
Actual CPU usage measurement interval in ticks, represented by a 64-bit hexadecimal. CPU Tick High represents the most significant 32 bits and the CPU Tick Low the least significant 32 bits. Owing to the precision of less than one second, the actual measurement periods of different CPU usage records may differ slightly.
display cpu-usage history
display cpu-usage history [ task task-id ]
View
Default Level
1: Monitor level
task task-id: Displays the history statistics of the CPU usage of the specified task, where task-id represents the task number. If the task-id argument is not provided, the system displays the history statistics of the CPU usage of the entire system (the CPU usage of the entire system is the sum of CPU usages of all tasks).
Use the display cpu-usage history command to display the history statistics of the CPU usage in a chart.
If no argument is provided, the system displays the CPU usage of the whole system.
The system takes statistics of the CPU usage at an interval and saves the statistical results in the history record area. You can use the display cpu-usage history command to display the CPU usage statistics records in the last 60 minutes. The statistical results are displayed through geographical coordinates. In the output information:
l          Latitude indicates the CPU usage, which is displayed based on the step. For example, if the step of the CPU usage is 5%, then the actual statistics value 53% is displayed as 55%, and actual statistics value 52% is displayed as 50%.
l          Longitude indicates the time.
l          Consecutive pond marks (#) indicate the CPU usage at a certain moment. The value of the latitude corresponding to the # mark on the top of a moment is the CPU usage at this moment.
# Display the CPU usage statistics of the whole system.
<Sysname> display cpu-usage history
100%|
 95%|
 90%|
 85%|
 80%|
 75%|
 70%|
 65%|
 60%|
 55%|
 50%|
 45%|
 40%|
 35%|
 30%|
 25%|
 20%|
 15%|             #
 10%|            ###  #
  5%|           ########
              10        20        30        40        50        60  (minutes)
                      cpu-usage last 60 minutes(SYSTEM)
The above output information indicates the CPU usage of the whole system in the last 60 minutes: 5% in the twelfth minute, 10% in the thirteenth minute, 15% in the fourteenth minute, 10% in the fifteenth minute, 5% in the sixteenth and seventeenth minute, 10% in the eighteenth minute, 5% in the nineteenth minute, and 2% or lower than 2% at other times.
# Display the CPU usage statistics of task 6.
<Sysname> display cpu-usage history task 6
100%|
 95%|
 90%|
 85%|
 80%|
 75%|
 70%|
 65%|
 60%|
 55%|
 50%|
 45%|
 40%|
 35%|
 30%|
 25%|
 20%|
 15%|
 10%|
  5%|                   #
                      cpu-usage last 60 minutes(T03M)
The above output information indicates the CPU usage of task 6 (with the task name T03M) in the last 60 minutes: 5% in the twentieth minute, and 2% or lower than 2% at other times.
display device
display device [verbose ]
View
Default Level
2: System level
verbose: Displays detailed information.
Use the display device command to display information about the device.
# Display information of the device. (The output of this command varies with devices.)
<Sysname> display device
SubSNo PortNum PCBVer  FPGAVer CPLDVer BootRomVer AddrLM Type       State
0      52      Ver.B   NULL    001     119        IVL    LS51LTSS   Normal
Table 1-3 display device command output description
SubSNo
Number of the slot in which the subcard resides
PortNum
Maximum number of ports that a subcard supports
AddrLM
Address learning mode
Brd Status
Card status, which can be the following values:
l      Absent: No card is in the slot.
l      Fault: Error occurred, and the card cannot start normally.
l      Normal: The card is an interface card and functions normally.
display device manuinfo
View
Default Level
3: Manage level
None
Use the display device manuinfo command to display electrical label information about the device.
Electrical label information is also called permanent configuration data or archive information, which is written to the storage medium of the device during debugging or test of a device. The information includes name of the device serial number, and vendor name. This command displays part of the electrical label information of the device.
# Display electrical label information. (The output of this command varies with devices.)
DEVICE_NAME          : S5120-28P-SI
DEVICE_SERIAL_NUMBER : DPPMWWB123456
MAC_ADDRESS          : 000F-E26A-58EA
MANUFACTURING_DATE   : 2007-11-10
VENDOR_NAME          : H3C
Table 1-4 display device manuinfo command output description
DEVICE_NAME
Device name
Device serial number
MAC_ADDRESS
MAC address of the device
MANUFACTURING_DATE
Manufacturing date of the device
VENDOR_NAME
Vendor name
display environment
display environment
View
Default Level
1: Monitor level
None
Use the display environment command to display the temperature information, including the current temperature and temperature thresholds.
# Display the temperature information of the device.
<Sysname> display environment
System temperature information (degree centigrade):
Sensor    Temperature  LowerLimit  WarningLimit  AlarmLimit ShutdownLimit
hotspot 1      45        NA              85          95         NA
display fan
display fan [ fan-id ]
View
Default Level
1: Monitor level
fan-id: Displays the operating state of the specified fan, where fan-id represents the built-in fan number.
Use the display fan command to display the operating state of built-in fans.
# Display the operating state of all fans in a device.
<Sysname> display fan
 Fan  1 State: Normal
display memory
display memory
View
Default Level
1: Monitor level
None
Use the display memory command to display the usage of the memory of a device.
# Display the usage of the memory of a device.
<Sysname> display memory
System Total Memory(bytes): 83947760
Total Used Memory(bytes): 24881784
Used Rate: 16%
Table 1-5 display memory command output description
Total size of the system memory (in bytes)
Size of the memory used (in bytes)
Used Rate
Percentage of the memory used to the total memory
display power
display power [ power-id ]
View
Default Level
1: Monitor level
None
Use the display power command to display the PSU information of a device.
# Display the PSU information of the device.
<Sysname> display power
 Power   0 State: Normal
Table 1-6 display power command output description
Power
PSU number
PSU state:
l      Normal
l      Absent
l      Fault
display reboot-type
display reboot-type
View
Default Level
2: System level
None
Use the display reboot-type command to display the reboot mode of the device.
# Display the reboot mode of the device.
<Sysname> display reboot-type
  The rebooting type this time is: Cold
The above information indicates that the last reboot mode of the device is Cold boot (cold boot is to restart a device by powering it on). (The display of Warm represents a warm boot, which means to restart a device by using the commands like reboot).
display schedule job
View
Default Level
1: Monitor level
None
Use the display schedule job command to display the detailed configurations of the scheduled automatic execution function.
# Display the detailed configurations of the current scheduled automatic execution function.
<Sysname> display schedule job
Specified command: execute 1.bat
Specified view: system view
Executed time: at 12:00 10/31/2007 (in 0 hours and 16 minutes)
If you modify the system time within 16 minutes, the configurations of scheduled automatic execution of the batch file will become invalid, and then when you execute the display schedule job command again, the system displays nothing.
display schedule reboot
View
Default Level
3: Manage level
None
Use the display schedule reboot command to display the device reboot time set by the user.
Related commands: schedule reboot at and schedule reboot delay.
# Display the reboot time of a device.
<Sysname> display schedule reboot
System will reboot at 16:00:00 03/10/2006 (in 2 hours and 5 minutes).
The above information indicates the system will reboot at 16:00:00 on March 10, 2006 (in two hours and five minutes).
display system-failure
View
Default Level
3: Manage level
None
Use the display system-failure command to display the exception handling method.
Related commands: system-failure.
# Display the exception handling method.
<Sysname> display system-failure
 System failure handling method: reboot
display transceiver alarm
View
Default Level
2: System level
interface [ interface-type interface-number ]: Displays the current alarm information of the pluggable transceiver plugged in the specified interface. interface-type interface-number represents interface type and interface number. If it is not specified, the command displays the current alarm information of the pluggable transceiver in all the interfaces.
Use the display transceiver alarm command to display the current alarm information of a single or all transceivers.
If no error occurs, None is displayed.
Table 1-7 shows the alarm information that may occur for the four types of commonly used transceivers.
Table 1-7 display transceiver alarm command output description
Remarks
GBIC/SFP
RX loss of signal
Incoming (RX) signal is lost.
RX power high
Incoming (RX) power level is high.
RX power low
Incoming (RX) power level is low.
TX fault
Transmit (TX) fault
TX bias high
TX bias current is high.
TX bias low
TX bias current is low.
TX power high
TX power is high.
TX power low
TX power is low.
Temp high
Temperature is high.
Temp low
Temperature is low.
Voltage high
Voltage is high.
Voltage low
Voltage is low.
Transceiver info I/O error
Transceiver information read and write error
Transceiver info checksum error
Transceiver information checksum error
Transceiver type and port configuration mismatch
Transceiver type does not match port configuration.
Transceiver type not supported by port hardware
Transceiver type is not supported on the port.
XFP
RX loss of signal
RX not ready
RX is not ready
RX CDR loss of lock
RX clock cannot be recovered.
RX power high
RX power is high.
RX power low
RX power is low.
TX not ready
TX is not ready.
TX fault
TX fault
TX CDR loss of lock
TX clock cannot be recovered.
TX bias high
TX bias low
TX power high
TX power is high.
TX power low
TX power is low.
Module not ready
Module is not ready.
APD supply fault
APD (Avalanche Photo Diode) supply fault
TEC fault
TEC (Thermoelectric Cooler) fault
Wavelength unlocked
Wavelength of optical signal exceeds the manufacturer’s tolerance.
Temp high
Temp low
Temperature is low.
Voltage high
Voltage is high.
Voltage low
Voltage is low.
XENPAK
WIS local fault
WIS (WAN Interface Sublayer) local fault
Receive optical power fault
PMA/PMD receiver local fault
PMA/PMD (Physical Medium Attachment/Physical Medium Dependent) receiver local fault
PCS receive local fault
PCS (Physical Coding Sublayer) receiver local fault
PHY XS receive local fault
PHY XS (PHY Extended Sublayer) receive local fault
RX power high
RX power is high.
RX power low
RX power is low.
Laser bias current fault
Laser temperature fault
Laser output power fault
TX fault
TX fault
TX bias high
TX bias low
TX power high
TX power is high.
TX power low
TX power is low.
Temp high
Temp low
Temperature is low.
# Display the alarm information of the pluggable transceiver plugged in interface GigabitEthernet1/0/25. (The output of this command varies with devices.)
<Sysname> display transceiver alarm interface GigabitEthernet1/0/25
GigabitEthernet1/0/25 transceiver current alarm information:
  RX loss of signal
  RX power low
Table 1-8 display transceiver alarm command output description
Current alarm information of the transceiver
RX loss of signal
RX power low
display transceiver diagnosis
View
Default Level
2: System level
interface [ interface-type interface-number ]: Displays the currently measured value of digital diagnosis parameters of the H3C customized anti-spoofing pluggable optical transceiver plugged in the specified interface. interface-type interface-number represents interface type and interface number. If it is not specified, the command displays the currently measured value of digital diagnosis parameters of H3C customized anti-spoofing pluggable optical transceivers in all the interfaces.
Use the display transceiver diagnosis command to display the currently measured value of digital diagnosis parameters of H3C customized anti-spoofing pluggable optical transceivers.
# Display the currently measured value of the digital diagnosis parameters of the H3C customized anti-spoofing pluggable optical transceiver plugged in interface GigabitEthernet1/0/25. (The output of this command varies with devices.)
<Sysname> display transceiver diagnosis interface GigabitEthernet1/0/25
GigabitEthernet1/0/25 transceiver diagnostic information:
    Temp(°C)  Voltage(V)  Bias(mA)  RX power(dBM)  TX power(dBM)
    36        3.31        6.13      -35.64          -5.19
Table 1-9 display transceiver diagnosis command output description
Digital diagnosis information of the transceiver plugged in the interface
Temp.(°C)
Digital diagnosis parameter-temperature, in °C, with the precision to 1°C.
Voltage(V)
Digital diagnosis parameter-voltage, in V, with the precision to 0.01 V.
Bias(mA)
Digital diagnosis parameter-bias current, in mA, with the precision to 0.01 mA.
RX power(dBM)
Digital diagnosis parameter-RX power, in dBM, with the precision to 0.01 dBM.
TX power(dBM)
Digital diagnosis parameter-TX power, in dBM, with the precision to 0.01 dBM.
display transceiver
View
Default Level
2: System level
interface [ interface-type interface-number ]: Displays main parameters of the pluggable transceiver plugged in the specified interface. interface-type interface-number represents interface type and interface number. If it is not specified, the command displays main parameters of the pluggable transceiver(s) in all the interfaces.
Use the display transceiver command to display main parameters of a single or all pluggable transceivers.
# Display main parameters of the pluggable transceiver plugged in interface GigabitEthernet1/0/25. (The output of this command varies with devices.)
<Sysname> display transceiver interface GigabitEthernet1/0/25
GigabitEthernet1/0/25 transceiver information:
  Transceiver Type              : 1000_BASE_SX_SFP
  Connector Type                : LC
  Wavelength(nm)                : 850
  Transfer Distance(m)          : 550(50um),270(62.5um)
  Digital Diagnostic Monitoring : YES
  Vendor Name                   : H3C
  Ordering Name                 : SFP-GE-SX-MM850
Table 1-10 display transceiver command output description
Pluggable transceiver information
Transceiver Type
Pluggable transceiver type
Connector Type
Type of the connectors of the transceiver:
l      Optical connectors, including SC (SC connector, developed by NTT) and LC (LC connector, 1.25 mm/RJ-45 optical connector developed by Lucent).
l      Other connectors, including RJ-45 and CX 4.
Wavelength(nm)
l      Optical transceiver: central wavelength of the laser sent, in nm. If the transceiver supports multiple wavelengths, every two wavelength values are separated by a comma.
l      Electrical transceiver: displayed as N/A.
Transfer distance(xx)
Transfer distance, with xx representing km for single-mode transceivers and m for other transceivers. If the transceiver supports multiple transfer medium, every two values of the transfer distance are separated by a comma. The corresponding transfer medium is included in the bracket following the transfer distance value. The following are the transfer media:
l      9 um: 9/125 um single-mode fiber
l      50 um: 50/125 um multi-mode fiber
l      62.5 um: 62.5/125 um multi-mode fiber
l      TP: Twisted pair
l      CX4: CX4 cable
Whether the digital diagnosis function is supported, where:
l      YES: supported
l      NO: not supported
Vendor Name
Vendor name or name of the vendor who customizes the transceiver:
l      H3C customized anti-spoofing transceiver: H3C is displayed.
l      Other transceivers: The vendor name is displayed.
Ordering Name
Pluggable transceiver model
display transceiver manuinfo
View
Default Level
2: System level
interface [ interface-type interface-number ]: Displays part of the electrical label information of the H3C customized anti-spoofing pluggable transceiver plugged in the specified interface. interface-type interface-number represents interface type and interface number. If it is not specified, the command displays part of the electrical label information of the H3C customized anti-spoofing pluggable transceiver(s) in all the interfaces.
Use the display transceiver manuinfo command to display part of the electrical label information of a single or all H3C customized anti-spoofing pluggable transceivers.
# Display the electrical label information of the H3C customized anti-spoofing pluggable transceiver plugged in interface GigabitEthernet1/0/25. (The output of this command varies with devices.)
<Sysname> display transceiver manuinfo interface GigabitEthernet1/0/25
GigabitEthernet1/0/25 transceiver manufacture information:
  Manu. Serial Number  : 213410A0000054000251
  Manufacturing Date   : 2006-09-01
  Vendor Name          : H3C
Table 1-11 display transceiver manuinfo command output description
Manu. Serial Number
Serial number generated during debugging and testing of the customized transceivers
Manufacturing Date
Debugging and testing date. The date takes the value of the system clock of the computer that performs debugging and testing.
Vendor Name
Name of the vendor who customizes the transceiver, that is, H3C.
reboot
reboot
View
Default Level
2: System level
None
Use the reboot command to reboot the device.
l          Device reboot may result in the interruption of the ongoing services. Use these commands with caution.
l          If a main boot file fails or does not exist, the device cannot be rebooted with the reboot command. In this case, you can re-specify a main boot file to reboot the device, or you can power off the device, then power it on and the system automatically uses the backup boot file to restart the device.
l          If you are performing file operations when the device is to be rebooted, the system does not execute the command for the sake of security.
# If the current configuration does not change, reboot the device.
<Sysname> reboot
Now rebooting, please wait...
# If the current configuration changes, reboot the device.
<Sysname> reboot
 This command will reboot the device. Current configuration will be lost in next startup if you continue. Continue? [Y/N]:y
reset unused porttag
View
Default Level
1: Monitor level
None
Use the reset unused porttag command to clear the 16-bit index saved but not used in the current system.
# Clear the 16-bit index saved but not used in the current system.
<Sysname> reset unused porttag
Current operation will delete all unused port tag(s). Continue? [Y/N]:y
<Sysname>
schedule job
schedule job { at time1 [ date ] | delay time2 } view view command
undo schedule job
View
Default Level
3: Manage level
at time1 [ date ]: Specifies the execution time of a specified command.
l          time1: Execution time of the command, in the format of hh:mm (hour/minute). The hh value ranges from 0 to 23, and the mm value ranges from 0 to 59.
l          date: Execution date of the command, in the format of MM/DD/YYYY (month/day/year) or YYYY/MM/DD (year/month/day). The YYYY value ranges from 2000 to 2035, the MM value ranges from 1 to 12, and the DD value range depends on a specific month.
delay time2: Specifies the execution waiting time of a specified command. time2 represents the waiting time, which can be in the following format:
l          hh:mm (hour/minute): The hh value ranges from 0 to 720, and the mm value ranges from 0 to 59. The value of hh:mm cannot exceed 720:00.
l          mm (minute): It ranges from 0 to 432000, with 0 indicating that a command is executed immediately without any delay.
view view: Specifies the view in which a command is executed. view represents the view name, and it takes the following values at present:
l          shell, represents user view.
l          system, represents system view.
command: The command string to be automatically executed at the scheduled time.
Use the schedule job command to automatically execute a specified command at the scheduled time.
Use the undo schedule job command to remove the configuration.
Note the following:
l          If you provide both the time1 and date arguments, the execution time must be a future time.
l          If you only provide the time1 argument, when time1 is earlier than the current system time, the specified command is executed at time1 of the next day; when time1 is later than the current system time, the specified command is executed at time1 of the current day.
l          No matter whether you use the at or delay keyword, the difference between the execution time of a command and the current system time cannot exceed 720 hours (namely, 30 days).
l          At present, you can specify only user view and system view. To automatically execute the specified commands in other views or automatically execute multiple commands at a time, you can configure the system to automatically execute a batch file at a specified time (note that you must provide a complete file path for the system to execute the batch file.).
l          The system does not check the view and command arguments. Therefore, ensure the correctness of the command argument (including the correct format of command and the correct relationship between the command and view arguments.).
l          After the specified automatic execution time is reached, the system executes the specified commands without displaying any information except system information such as log, trap and debug.
l          When the system is executing the specified command, you do not need to input any information. If there is information for you to confirm, the system automatically inputs Y or Yes; if certain characters need to be input, the system automatically inputs a default character string, and inputs an empty character string when there is no default character string.
l          For the commands used to switch user interfaces, such as telnet, ftp, and ssh2, the commands used to switch views, such as system-view, quit and interface ethernet, and the commands used to modify status of the user that is executing commands, such as super, the operation interface, command view and status of the current user are not changed after the automatic execution function is performed.
l          If you modify the system time after the automatic execution function is configured, the scheduled automatic execution configuration turns invalid automatically.
l          Only the latest configuration takes effect if you execute the schedule job command repeatedly.
# Configure that the device will execute the batch file 1.bat in system view in 60 minutes (supposing that the current time is 11:43).
<Sysname> schedule job delay 60 view system execute 1.bat
Info: Command execute 1.bat in system view will be executed at 12:43 10/31/2007 (in 1 hours and 0 minutes).
# Configure that the device will execute the batch file 1.bat in system view at 12:00 in the current day (supposing that the current time is 11:43).
<Sysname> schedule job at 12:00 view system execute 1.bat
Info: Command execute 1.bat in system view will be executed at 12:00 10/31/2007 (in 0 hours and 16 minutes).
schedule reboot at
schedule reboot at hh:mm [ date ]
undo schedule reboot
View
Default Level
3: Manage level
hh:mm: Reboot time of a device, in the format of hh:mm (hours:minutes). The value of the hh argument ranges from 0 to 23, and the value of the mm argument ranges from 0 to 59.
date: Reboot date of a device, in the format mm/dd/yyyy (month/day/year) or in the format yyyy/mm/dd (year/month/day) The yyyy value ranges from 2000 to 2035, the mm value ranges from 1 to 12, and the dd value depends on a specific month.
Use the schedule reboot at command to enable the scheduled reboot function and specify a specific reboot time and date.
By default, the scheduled reboot function is disabled.
There are two cases if no specific reboot date is specified:
l          When the specified reboot time is later than the current time, the device will be rebooted at the reboot time of the current day.
l          When the specified reboot time is earlier than the current time, the device will be rebooted at the reboot time the next day.
Note that:
l          The precision of the device timer is 1 minute. One minute before the reboot time, the device will prompt “REBOOT IN ONE MINUTE” and will be rebooted in one minute.
l          The difference between the reboot date and the current date cannot exceed 30 x 24 hours (namely, 30 days).
l          After you execute the above command, the device will prompt you to confirm the configuration. You must enter Y or y to make the configuration take effect. The original configuration will be overwritten at the same time.
l          If a date (month/day/year or year/month/day) later than the current date is specified for the schedule reboot at command, the device will be rebooted at the reboot time.
l          If you use the clock command after the schedule reboot at command to adjust the system time, the reboot time set by the schedule reboot at command will become invalid.
This command reboots the device in a future time, thus resulting in service interruption. Please use it with caution.
# Configure the device to reboot at 12:00 AM (supposing that the current time is 11:43).
<Sysname> schedule reboot at 12:00
Reboot system at 12:00 06/06/2006(in 0 hour(s) and 16 minute(s))
 confirm? [Y/N]:
# If you have used the terminal logging command to enable the log display function on the terminal before setting a reboot time, the system will automatically display related log information after you enter <y>. By default, the log display function is enabled.
<Sysname>
%Jun  6 11:43:11:629 2006 Sysname CMD/4/REBOOT:
vty0(192.168.1.54): Set schedule reboot parameters at 11:43:11 06/06/2006, and system will reboot at 12:00 06/06/2006.
schedule reboot delay { hh:mm | mm }
View
Default Level
3: Manage level
hh:mm: Device reboot wait time, in the format of hh:mm (hours:minutes). The value of the hh argument ranges from 0 to 720, and the value of the mm argument ranges from 0 to 59, and the value of the hh:mm argument cannot exceed 720:00.
mm: Device reboot wait time in minutes, in the range of 0 to 43,200.
Use the schedule reboot delay command to enable the scheduled reboot function and set a reboot wait time.
Note that:
l          The reboot wait time can be in the format of hh:mm (hours:minutes) or mm (absolute minutes). The absolute minutes cannot exceed 30 x 24 x 60 minutes, namely, 30 days.
l          After you execute the above command, the device will prompt you to confirm the configuration. You must enter <Y> or <y> to make the configuration take effect. The original configuration will be overwritten at the same time.
l          If you use the clock command after the schedule reboot delay command to adjust the system time, the reboot wait time set by the schedule reboot delay command will become invalid.
This command reboots the device after the specified delay time, thus resulting in service interruption. Please use it with caution.
# Configure the device to reboot in 88 minutes (supposing the current time is 11:48).
<Sysname> schedule reboot delay 88
Reboot system at 13:16 06/06/2006(in 1 hour(s) and 28 minute(s)). confirm? [Y/N]:
# If you have used the terminal logging command to enable the log display function on the terminal before setting a reboot time, the system will automatically display related log information after you enter y. By default, the log display function is enabled on the terminal.
<Sysname>
%Jun  6 11:48:44:860 2006 Sysname CMD/4/REBOOT:
vty0(192.168.1.54): Set schedule reboot parameters at 11:48:44 06/06/2006, and system will reboot at 13:16 06/06/2006.
system-failure
system-failure { maintain | reboot }
undo system-failure
View
Default Level
3: Manage level
maintain: Specifies that when the system detects any software abnormality, it maintains the current situation, and does not take any measure to recover itself.
reboot: Specifies that when the system detects any software abnormality, it recovers itself through automatic reboot.
Use the system-failure command to configure the exception handling method.
By default, the system adopts the reboot method to handle exceptions.
# Set the exception handling method to reboot.
[Sysname] system-failure reboot
