H3C S5120-SI Series Ethernet Switches Command Reference-Release 1101-6W105
HomeSupportSwitchesS5120 SeriesReference GuidesCommand ReferencesH3C S5120-SI Series Ethernet Switches Command Reference-Release 1101-6W105
16-IP Routing Basics Commands
16-IP Routing Basics Commands 72.1 KB
The term “router” in this document refers to a router in a generic sense or a Layer 3 switch.
IP Routing Basics Configuration Commands
display ip routing-table
display ip routing-table [ verbose | | { begin | exclude | include } regular-expression ]
View
Default Level
1: Monitor level
verbose: Displays detailed routing table information, including that for inactive routes. With this keyword absent, the command displays only brief information about active routes.
|: Uses a regular expression to filter output information. For details about regular expressions, refer to the section CLI Display in Basic System Configuration.
begin: Displays route entries starting from the one specified by the regular expression.
exclude: Displays route entries not matching the regular expression.
include: Displays route entries matching the regular expression.
regular-expression: Regular expression, a string of 1 to 256 case-sensitive characters used for specifying routing entries.
Use the display ip routing-table command to display brief information about active routes in the routing table.
This command displays brief information about a routing table, with a routing entry contained in one line. The information displayed includes destination IP address/mask length, protocol, priority, cost, next hop and outbound interface. This command only displays the routes currently in use, that is, the optimal routes.
Use the display ip routing-table verbose command to display detailed information about all routes in the routing table.
This command displays detailed information about all active and inactive routes, including the statistics of the entire routing table and information for each route.
# Display brief information about active routes in the routing table.
<Sysname> display ip routing-table
Routing Tables: Public
         Destinations : 5        Routes : 5
0.0.0.0/32          Static 60   0            1.1.1.1         Vlan1
192.168.0.0/24      Direct 0    0            192.168.0.53    Vlan1
192.168.0.53/32     Direct 0    0            127.0.0.1       InLoop0
Table 1-1 display ip routing-table command output description
Destinations
Number of destination addresses
Routes
Number of routes
Destination/Mask
Destination address/mask length
Proto
Protocol that presents the route
Pre
Priority of the route
Cost
Cost of the route
Nexthop
Address of the next hop on the route
Outbound interface for packets to be forwarded along the route
# Display detailed information about all routes in the routing table.
<Sysname> display ip routing-table verbose
Routing Table : Public
  Destination: 0.0.0.0/32
     Protocol: Static          Process ID: 0
   Preference: 60                    Cost: 0
      NextHop: 1.1.1.1          Interface: Vlan-interface1
    BkNextHop: 0.0.0.0        BkInterface:
  RelyNextHop: 0.0.0.0          Neighbor : 0.0.0.0
    Tunnel ID: 0x0                  Label: NULL
        State: Active Adv             Age: 00h00m14s
          Tag: 0
  Destination: 127.0.0.0/8
     Protocol: Direct          Process ID: 0
   Preference: 0                     Cost: 0
      NextHop: 127.0.0.1        Interface: InLoopBack0
        State: Active NoAdv           Age: 04h20m03s
          Tag: 0
  Destination: 127.0.0.1/32
          Tag: 0
  Destination: 192.168.0.0/24
      NextHop: 192.168.0.53     Interface: Vlan-interface1
        State: Active Adv             Age: 04h12m07s
          Tag: 0
  Destination: 192.168.0.53/32
        State: Active NoAdv           Age: 04h12m07s
          Tag: 0
Displayed first are statistics for the whole routing table, followed by detailed description of each route (in sequence).
Table 1-2 display ip routing-table verbose command output description
Destination
Protocol
Process ID
Process ID
Preference
Cost
Cost of the route
NextHop
BkNexthop
Backup next hop
BkInterface
Backup outbound interface
RelyNextHop
The next hop address obtained through routing recursion
Neighbour
Neighboring address determined by Routing Protocol
Tunnel ID
Tunnel ID
Label
Label
Route status:
Active
This is an active unicast route.
Adv
This route can be advertised.
Delete
This route is deleted.
Gateway
This is an indirect route.
Holddown
Number of holddown routes.
Int
The route was discovered by an Interior Gateway Protocol (IGP).
NoAdv
The route is not advertised when the router advertises routes based on policies.
NotInstall
Normally, among routes to a destination, the route with the highest priority is installed into the core routing table and advertised, while a NotInstall route cannot be installed into the core routing table but may be advertised.
Reject
The packets matching a Reject route will be dropped. Besides, the router sends ICMP unreachable messages to the sources of the dropped packets. The Reject routes are usually used for network testing.
Static
A static route is not lost when you perform the save operation and then restart the router. Routes configured manually are marked as static.
Unicast
Unicast routes
Inactive
Inactive routes
Invalid
Invalid routes
WaitQ
The route is the WaitQ during route recursion.
TunE
Tunnel
GotQ
The route is in the GotQ during route recursion.
Age
Time for which the route has been in the routing table, in the sequence of hour, minute, and second from left to right.
Tag
Route tag
display ip routing-table acl
display ip routing-table acl acl-number [ verbose ]
View
Default Level
1: Monitor level
acl-number: Basic ACL number, in the range of 2000 to 2999.
verbose: Displays detailed routing table information, including that for inactive routes. With this argument absent, the command displays only brief information about active routes.
Use the display ip routing-table acl command to display information about routes permitted by a specified basic ACL.
This command is intended for the follow-up display of routing policies.
If the specified ACL does not exist or it has no rules configured, the entire routing table is displayed.
# Define basic ACL 2000 and set the route filtering rules.
[Sysname] acl number 2000
[Sysname-acl-basic-2000] rule permit source 10.1.0.0 0.0.255.255
[Sysname-acl-basic-2000] rule deny source any
# Display brief information about active routes permitted by basic ACL 2000.
[Sysname-acl-basic-2000] display ip routing-table acl 2000
Routes Matched by Access list : 2000
Summary Count : 6
Destination/Mask    Proto  Pre  Cost         NextHop       Interface
10.1.1.0/24         Direct 0    0            10.1.1.2      Vlan1
10.1.1.2/32         Direct 0    0            127.0.0.1     InLoop0
10.1.2.0/24         Direct 0    0            10.1.2.1      Vlan2
10.1.2.1/32         Direct 0    0            127.0.0.1     InLoop0
10.1.3.0/24         Direct 0    0            10.1.3.1      Vlan1
10.1.3.1/32         Direct 0    0            127.0.0.1     InLoop0
For detailed description of the above output, see Table 1-1.
# Display detailed information about both active and inactive routes permitted by basic ACL 2000.
<Sysname> display ip routing-table acl 2000 verbose
Summary Count: 6
Destination: 10.1.1.0/24
      NextHop: 10.1.1.2         Interface: Vlan-interface1
  RelyNextHop: 0.0.0.0          Neighbour: 0.0.0.0
        State: Active Adv             Age: 1d00h25m32s
          Tag: 0
Destination: 10.1.1.2/32
        State: Active NoAdv           Age: 1d00h41m34s
          Tag: 0
Destination: 10.1.2.0/24
      NextHop: 10.1.2.1         Interface: Vlan-interface2
        State: Active Adv             Age: 1d00h05m42s
          Tag: 0
Destination: 10.1.2.1/32
        State: Active NoAdv           Age: 1d00h05m42s
          Tag: 0
Destination: 10.1.3.0/24
      NextHop: 10.1.3.1         Interface: Vlan-interface1
        State: Active Adv             Age: 1d00h05m31s
          Tag: 0
Destination: 10.1.3.1/32
        State: Active NoAdv           Age: 1d00h05m32s
          Tag: 0
For the description of the command output above, see Table 1-2.
display ip routing-table ip-address
display ip routing-table ip-address [ mask-length | mask ] [ longer-match ] [ verbose ]
display ip routing-table ip-address1 { mask-length | mask } ip-address2 { mask-length | mask } [ verbose ]
View
Default Level
1: Monitor level
ip-address: Destination IP address, in dotted decimal format.
mask-length: IP address mask length in the range 0 to 32.
mask: IP address mask in dotted decimal format.
longer-match: Displays the route with the longest mask.
verbose: Displays detailed routing table information, including both active and inactive routes. With this argument absent, the command displays only brief information about active routes.
Use the display ip routing-table ip-address command to display information about routes to a specified destination address.
Executing the command with different parameters yields different output:
l          display ip routing-table ip-address
The system ANDs the input destination IP address with the subnet mask in each route entry; and ANDs the destination IP address in each route entry with its corresponding subnet mask.
If the two operations yield the same result for an entry and this entry is active, it is displayed.
l          display ip routing-table ip-address mask
The system ANDs the input destination IP address with the input subnet mask; and ANDs the destination IP address in each route entry with the input subnet mask.
If the two operations yield the same result for an entry and the entry is active with a subnet mask less than or equal to the input subnet mask, the entry is displayed.
Only route entries that exactly match the input destination address and mask are displayed.
l          display ip routing-table ip-address longer-match
If the two operations yield the same result for multiple entries that are active, the one with longest mask length is displayed.
l          display ip routing-table ip-address mask longer-match
If the two operations yield the same result for multiple entries with a mask less than or equal to the input subnet mask, the one that is active with longest mask length is displayed.
Use the display ip routing-table ip-address1 { mask-length | mask } ip-address2 { mask-length | mask } command to display route entries with destination addresses within a specified range.
# Display route entries for the destination IP address 11.1.1.1.
[Sysname] display ip routing-table 11.1.1.1
Summary Count : 4
0.0.0.0/0           Static 60   0            0.0.0.0         NULL0
11.0.0.0/8          Static 60   0            0.0.0.0         NULL0
11.1.0.0/16         Static 60   0            0.0.0.0         NULL0
11.1.1.0/24         Static 60   0            0.0.0.0         NULL0
For detailed description about the output, see Table 1-1.
# Display route entries by specifying a destination IP address and the longer-match keyword.
[Sysname] display ip routing-table 11.1.1.1 longer-match
Summary Count : 1
# Display route entries by specifying a destination IP address and mask.
[Sysname] display ip routing-table 11.1.1.1 24
Summary Count : 3
# Display route entries by specifying a destination IP address and mask and the longer-match keyword.
[Sysname] display ip routing-table 11.1.1.1 24 longer-match
Summary Count : 1
# Display route entries for destination addresses in the range 1.1.1.0 to 5.5.5.0.
<Sysname> display ip routing-table 1.1.1.0 24 5.5.5.0 24
1.1.1.0/24          Direct 0    0            1.1.1.1       Vlan1
1.1.1.1/32          Direct 0    0            127.0.0.1     InLoop0
2.2.2.0/24          Direct 0    0            2.2.2.1       Vlan2
3.3.3.0/24          Direct 0    0            3.3.3.1       Vlan2
3.3.3.1/32          Direct 0    0            127.0.0.1     InLoop0
4.4.4.0/24          Direct 0    0            4.4.4.1       Vlan1
4.4.4.1/32          Direct 0    0            127.0.0.1     InLoop0
display ip routing-table protocol
display ip routing-table protocol protocol [ inactive | verbose ]
View
Default Level
1: Monitor level
protocol: Routing protocol. It can be direct, or static.
inactive: Displays information about only inactive routes. With this argument absent, the command displays information about both active and inactive routes.
verbose: Displays detailed routing table information. With this argument absent, the command displays brief routing table information.
Use the display ip routing-table protocol command to display routing information of a specified routing protocol.
# Display brief information about direct routes.
<Sysname> display ip routing-table protocol direct
Public Routing Table : Direct
Summary Count : 6
Direct Routing table Status : < Active>
Summary Count :  6
2.2.2.2/32          Direct 0    0          127.0.0.1       InLoop0
192.168.80.0/24     Direct 0    0          192.168.80.10   Vlan1
192.168.80.10/32    Direct 0    0          127.0.0.1       InLoop0
Direct Routing table Status : < Inactive>
Summary Count : 0
# Display brief information about static routes.
<Sysname> display ip routing-table protocol static
Public Routing Table : Static
Summary Count : 2
Static Routing table Status : < Active>
Summary Count :  0
Static Routing table Status : < Inactive>
Summary Count : 2
1.2.3.0/24          Static  60   0          1.2.4.5      Vlan10
3.0.0.0/8           Static  60   0           2.2.2.2     Vlan1
display ip routing-table statistics
View
Default Level
1: Monitor level
None
Use the display ip routing-table statistics command to display the route statistics of the network routing table.
# Display route statistics in the routing table.
<Sysname> display ip routing-table statistics
Proto      route       active      added       deleted       freed
DIRECT     24          4           25          1             0
STATIC     4           1           4           0             0
Total      28          5           29          1             0
Table 1-3 display ip routing-table statistics command output description
Proto
Origin of the routes.
route
Number of routes from the origin
active
Number of active routes from the origin
added
Number of routes added into the routing table since the router started up or the routing table was last cleared
deleted
Number of routes marked as deleted, which will be freed after a period.
freed
Number of routes that got freed, that is, got removed permanently.
Total
Total number
reset ip routing-table statistics protocol
reset ip routing-table statistics protocol { protocol | all }
View
Default Level
2: System level
protocol: Clears statistics for the IPv4 routing protocol, which can be direct or static.
all: Clears statistics for all IPv4 routing protocols.
Use the reset ip routing-table statistics protocol command to clear routing statistics for the routing table.
# Clear all routing statistics information.
<Sysname> reset ip routing-table statistics protocol all
