| 02-PPP Configuration | 175.38 KB |
Table of Contents
Configuring PAP Authentication
Configuring CHAP Authentication
Enabling the Generating of PPP Accounting Statistics
Troubleshooting PPP Configuration
Configuring a Dialer Interface
Resetting/Terminating a PPPoE Session
Displaying and Maintaining PPPoE
PPPoE Client Configuration Example
l The models listed in this document are not applicable to all regions. Please consult your local sales office for the models applicable to your region.
l Support of the H3C WA series WLAN access points (APs) for features may vary by AP model. For more information, see Feature Matrix.
l The interface types and the number of interfaces vary by AP model.
This chapter includes these sections:
l Troubleshooting PPP Configuration
Introduction to PPP
PPP
Point-to-Point Protocol (PPP) is a link layer protocol that carries network layer packets over point-to-point links. It gains popularity because it provides user authentication, supports synchronous/asynchronous communication, and allows for easy extension.
PPP contains a set of protocols, including a link control protocol (LCP), a network control protocol (NCP), and authentication protocols such as Password Authentication Protocol (PAP) and Challenge Handshake Authentication Protocol (CHAP). Among these protocols,
l The LCP is responsible for establishing, tearing down, and monitoring data links.
l The NCP is used for negotiating the packet format and type of data links.
l PAP and CHAP are for network security.
PAP authentication
PAP is a two-way handshake authentication protocol using plain text passwords. It operates as follows.
1) The requester sends its username and password to the authenticator.
2) The authenticator then checks the local user list to see if the username and password are correct and returns an acknowledgement or negative acknowledge.
Figure 1-1 PAP Authentication
During PAP authentication, the password is transmitted on the link in plain text. In addition, the authenticatee sends the username and the password repeatedly through the established PPP link until the authentication is over. Therefore, PAP is not a secure authentication protocol. It cannot prevent attacks.
CHAP authentication
CHAP is a three-way handshake authentication protocol using cipher text password.
Currently, two types of CHAP authentication exist: one-way CHAP authentication and two-way CHAP authentication. In one-way CHAP authentication, one side of the link acts as the authenticator and the other acts as the authenticatee. In two-way authentication, each side serves as both the authenticator and the authenticatee. Normally, one-way CHAP authentication is adopted.
In one-way CHAP authentication, the authenticator may or may not be configured with a username. It is recommended that you configure a username for the authenticator, which makes it easier to identify the authenticator.
When the authenticator is configured with a username, CHAP authentication is performed as follows:
1) The authenticator initiates an authentication by sending a randomly-generated packet (Challenge) to the authenticatee. The packet carries the local username with it.
2) When the authenticatee receives the authentication request, it searches the local user list for the password of the username carried in the received packet, encrypts the packet using the MD5 algorithm, with the packet ID and the password as the parameters, and then sends the encrypted packet and the local username to the authenticator (Response).
3) The authenticator encrypts the original randomly-generated packet using the MD5 algorithm, with the password of the authenticatee it maintains as the parameter, compares the encrypted packet with the one received from the authenticatee, and returns an Acknowledge or Not Acknowledge packet depending on the comparison result.
When the authenticator is not configured with a username, the CHAP authentication is performed as follows:
2) When the authenticatee receives the authentication request, it encrypts the packet using the MD5 algorithm, with the packet ID and the default CHAP password as the parameters, and then sends the encrypted packet and its own username to the authenticator (Response).
Figure 1-2 CHAP Authentication
How PPP Works
Figure 1-3 illustrates the PPP operating mechanism.
1) A PPP link is in the Establish phase when it is about to be established. In this phase, LCP negotiation is performed, where LCP-related settings are determined, including operating mode (SP or MP), the authentication mode, and the Maximum Transmission Unit (MTU). If the negotiation is successful, the link enters the Opened state, indicating that the underlying layer link has been established.
2) If the authentication (the remote authenticates the local or the local authenticates the remote) is configured, the PPP link goes to the Authenticate phase, where CHAP or PAP authentication is performed.
3) If the authenticate fails to pass the authentication, the link goes to the Terminate phase, where the link is torn down and LCP goes down. If the authenticatee passes the authentication, the link goes to the Network phase. In this phase, NCP negotiation is performed, the LCP state remains Opened, and the state of IP Control Protocol (IPCP) transitions from Initial to Request.
4) NCP negotiation supports the negotiation of IPCP, through which the IP addresses of both sides can be determined. NCP negotiation also determines and configures the network layer protocol to be used. Note that a PPP link can carry a network layer protocol only after the NCP negotiation is successful.
5) After the NCP negotiation is performed, the PPP link remains active until an LCP or NCP frame closes it explicitly or some external events take place (for example, the intervention of a user).
Figure 1-3 PPP operation flow chart
For more information about PPP, see RFC 1661.
Configuring PPP
Configuring PPP
Follow these steps to configure PPP:
To do... |
Use the command... |
Remarks |
Enter system view |
system-view |
Enter interface view |
Configure PPP as the data link layer protocol |
link-protocol ppp |
Optional By default, PPP is used. |
Set the polling interval |
timer hold seconds |
Optional 10 seconds by default |
Configure PPP authentication mode |
Configure PAP authentication |
For more information, see Configuring PAP Authentication. |
Optional Select either authentication mode By default, PPP authentication is disabled. |
Configure CHAP authentication |
For more information, see Configuring CHAP Authentication. |
Configure PPP negotiation |
For more information, see Configuring PPP Negotiation. |
Optional |
Enable the generating of PPP accounting statistics |
For more information, see Enabling the Generating of PPP Accounting Statistics |
Optional |
This document only discusses local authentication. For more information about remote AAA authentication, see AAA in the Security Configuration Guide.
Configuring the authenticator
Follow these steps to configure the authenticator:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Configure the local device to authenticate the peer using PAP |
ppp authentication-mode pap [ [ call-in ] domain isp-name ] |
Required By default, PPP authentication is not performed. |
Quit to system view |
quit |
Create a local user account |
local-user username |
Required This command also leads you to local user view. |
Configure a password for the local user |
password { cipher | simple } password |
Required |
Configure service type of the local user as well as other attributes |
service-type ppp [ callback-nocheck | callback-number callback-number | call-number call-number [ :subcall-number ] ] |
Required |
quit |
Create an ISP domain or enter an existing ISP domain view |
domain isp-name |
Optional |
Configure to authenticate domain users locally |
authentication ppp local |
Optional |
For more information about local user and domain configuration, see AAA in the Security Configuration Guide.
Configuring the authenticatee
Follow these steps to configure the authenticatee:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Configure the PAP username and password sent by the local device to the peer when the local device is authenticated by the peer using PAP |
ppp pap local-user username password { cipher | simple } password |
Required By default, when being authenticated by the peer using PAP, the local device sends null username and password to the peer. |
According to whether the authenticator is configured with a username or not, the configuration of CHAP authentication falls into the following two types:
Configuring CHAP authentication when the authenticator name is configured
1) Configuring the authenticator
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Configure the local device to authenticate the peer using CHAP |
ppp authentication-mode chap [ [ call-in ] domain isp-name ] |
Assign a username to the CHAP authenticator |
ppp chap user username |
Required The username you assign to the authenticator here must be the same as the local username you assign to the authenticator on the authenticatee. |
quit |
Create a local user account for the authenticatee and enter local user view |
Required |
Configure the password for the local user |
Required |
Configure the service type of the local user and other attributes |
Required |
quit |
Create an ISP domain, or enter an existing ISP domain view |
domain isp-name |
Optional |
Configure to authenticate the domain user locally |
Optional |
2) Configuring the authenticatee
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Assign a username to the CHAP authenticatee |
Required The username you assign to the authenticatee here must be the same as the local username you assign to the authenticatee on the authenticator. |
Create a local user account for the authenticator and set the password |
quit |
Create a local user account and enter local user view |
Required |
Set the password |
Required |
Configuring CHAP authentication when no authenticator name is configured
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
quit |
Required |
Required |
Required |
quit |
domain isp-name |
Optional |
Optional |
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Set the default CHAP authentication password |
ppp chap password { cipher | simple } password |
Required |
Introduction to PPP negotiation parameters
PPP negotiation parameters that can be configured include: negotiation timeout time, IP address negotiation mode, and DNS server address negotiation mode.
Negotiation timeout time determines the interval to send request packets. During PPP negotiation, if no response is received from the peer during a specific period after the local AP sends a packet, the AP sends another one. The period is known as negotiation timeout time, which ranges from 1 to 10 seconds.
IP address negotiation can be implemented in the following two modes.
l The AP operates as the client. You can configure the local interface to operate in this mode if it uses PPP at the data link layer but it does not have an IP address, whereas the peer is configured with an IP address, after which the interface can receive an IP address allocated by its peer. This configuration applies to the situations where you access the Internet through ISP.
l The AP operates as the server. In this case, you must configure a local IP address pool in domain view or system view to specify the range of the IP addresses to be allocated, and then bind the address pool to the interface.
PPP address negotiation can also determine the DNS server address. You can configure the AP to allocate the DNS server address to the peer or receive the DNS server address from the peer. Normally, for a PPP link between a PC and the AP, the DNS server address is usually allocated by the AP, through which the PC can access the Internet directly by using domain names. For a PPP link established between the AP and the access server of a carrier, the DNS server address is usually allocated by the access server, through which the AP can resolve domain names through the DNS server address allocated by the access server.
Currently, the AP can only operate as a client.
Configuring PPP negotiation parameters
Follow these steps to configure PPP negotiation parameters:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Configure the negotiation timeout time |
ppp timer negotiate seconds |
Optional 3 seconds by default |
Configure the IP address negotiation |
ip address ppp-negotiate |
Optional |
Introduction to PPP accounting statistics
PPP can generate traffic-based accounting statistics on each PPP link. The statistics include the amount of the inbound and outbound information (in terms of bytes and the number of the packets) on a link. The information can be used by AAA application modules for accounting and control purpose.
Enabling the generating of PPP accounting statistics
Following these steps to enable the generating of PPP accounting statistics:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
ppp account-statistics enable |
Required Disabled by default. |
Symptom 1: PPP authentication fails and the link cannot be brought up.
Solution: This problem may arise if the parameters for authentication are incorrect.
Enable the debugging of PPP, and you can see the information showing that LCP went up upon a successful LCP negotiation but went down after PAP or CHAP negotiation.
Check the PPP authentication settings at the local and peer ends to make sure that they are consistent. See the part talking about PPP authentication configuration for reference.
Symptom 2: Physical link is down.
Solution: The physical link is down when:
l The interface is not brought up.
l The interface is shut down by the administrator.
l LCP negotiation fails.
Execute the display interface command to check the state of the interface. The output information can be:
l serial number is administratively down, line protocol is down, which indicates that the interface is shut down by the administrator.
l serial number is down, line protocol is down, which indicates that the interface is not activated or the physical layer has not gone up yet.
l serial number is up, line protocol is up, which indicates that LCP negotiation succeeded.
l serial number is up, line protocol is down, which indicates that the interface is active, but LCP negotiation failed.
l Displaying and Maintaining PPPoE
Introduction to PPPoE
PPPoE
Currently, the AP cannot operate as a PPPoE server, and whether it can operate as a PPPoE client depends on the AP model.
Point-to-Point Protocol over Ethernet (PPPoE) uses the client/server model. It establishes point-to-point links over Ethernet, and encapsulates PPP packets in Ethernet frames.
APs configured as PPPoE clients can access the Internet through a remote access device, and access control and accounting can be implemented on a per-AP basis.
PPPoE undergoes two phases: discovery and PPP session, as described below:
l Discovery phase, where a PPPoE session is initiated. In this phase, the host obtains the MAC address of the access end and generates the PPPoE session ID. When the discovery phase ends, the PPPoE session ID between the host and the server is determined, and the PPP session phase begins.
l PPP session phase, where PPP packets are encapsulated in Ethernet frames before being sent to the peer. In the frame, the session ID must be the one determined in the discovery phase, the MAC address must be that of the peer, and the PPP packet section begins from the Protocol ID field. In Session phase, either end of the link can terminate the session by sending PPPoE Active Discovery Terminate (PADT) packets.
For more information about PPPoE, see RFC 2516.
Figure 2-1 Network diagram for PPPoE configuration
Configuring a PPPoE Client
PPPoE client configuration includes dialer interface configuration and PPPoE session configuration.
Before establishing a PPPoE session, you must first create a dialer interface and configure a dialer bundle on the interface. Each PPPoE session uniquely corresponds to a dialer bundle and each dialer bundle uniquely corresponds to a dialer interface. Thus, a PPPoE session uniquely corresponds to a dialer interface.
Follow these steps to configure a dialer interface:
To do... |
Remarks |
Enter system view |
system-view |
Configure a dialer rule |
dialer-rule dialer-group { protocol-name { permit | deny } | acl acl-number } |
Required |
Create a dialer interface |
interface dialer number |
Required |
Create a dialer user |
dialer user username |
Required |
Assign an IP address to the interface |
ip address { address mask | ppp-negotiate } |
Required |
Create a dialer bundle on the interface |
dialer bundle bundle-number |
Required |
Create a dialer group on the interface |
dialer-group group-number |
Required |
You can also configure PPP authentication or set other parameters on the dialer interface as needed.
Configuring a PPPoE Session
PPPoE sessions fall into these categories: permanent PPPoE session, packet-triggered PPPoE session, and diagnostic PPPoE session.
l A permanent PPPoE session is established immediately when the line is physically up. It remains valid till a user terminates it explicitly.
l A packet-triggered PPPoE session is established when there is a demand for data transmitting. It is terminated when idled for a specific period of time. That is, a packet-triggered PPPoE session may not be established even if the line is physically up.
l A diagnostic PPPoE session is established immediately after the AP configuration is complete. The AP automatically terminates and then tries to re-establish diagnostic PPPoE sessions at a pre-configured interval, and by doing so, monitors the status of the PPPoE links.
You can establish a PPPoE session on a VLAN interface.
Follow these steps to configure a PPPoE session:
To do... |
Remarks |
Enter system view |
system-view |
Enter VLAN interface view |
interface ethernet interface-number |
Create a PPPoE session, and specify a dialer bundle for the session |
pppoe-client dial-bundle-number number [ no-hostuniq ] [ diagnose [ interval seconds ] | idle-timeout seconds [ queue-length packets ] ] |
Required |
You can establish multiple PPPoE sessions on a VLAN interface, in other words, a VLAN interface can belong to multiple dialer bundles at the same time. However, a dialer bundle can have only one VLAN interface. A PPPoE session uniquely corresponds to a dialer bundle and vise versa.
Follow these steps to reset/terminate a PPPoE session:
To do… |
Use the command… |
Remarks |
Reset a PPPoE session on a PPPoE client |
reset pppoe-client { all | dial-bundle-number number } |
Available in user view |
Terminate a PPPoE session on a PPPoE client |
undo pppoe-client dial-bundle-number number |
Available in VLAN interface view |
To do… |
Use the command… |
Remarks |
Display the statistics and state information about a PPPoE client |
display pppoe-client session { packet | summary } [ dial-bundle-number number ] |
Available in any view |
PPPoE Configuration Example
Network requirements
As shown in Figure 2-2, Ethernet 1/0/1 on Router A and VLAN-interface 1 on AP are connected to each other. It is required that Router A authenticates AP using PAP or CHAP.
Figure 2-2 Network diagram for PPPoE client configuration
Configuration procedure
l Configuring PAP authentication:
1) Configure Router A as the PPPoE server
# Add a PPPoE user.
[RouterA] local-user user2
[RouterA-luser-user2] password simple hello
[RouterA-luser-user2] service-type ppp
[RouterA-luser-user2] quit
# Configure virtual template 1.
[RouterA] interface virtual-template 1
[RouterA-Virtual-Template1] ppp authentication-mode pap
[RouterA-Virtual-Template1] ip address 1.1.1.1 255.0.0.0
[RouterA-Virtual-Template1] remote address 1.1.1.2
[RouterA-Virtual-Template1] quit
# Configure the PPPoE server.
[RouterA] interface ethernet 1/0/1
[RouterA-Ethernet1/0/1] pppoe-server bind virtual-template 1
2) Configure AP as the PPPoE client.
<AP> system-view
[AP] dialer-rule 1 ip permit
[AP] interface dialer 1
[AP-Dialer1] dialer user user2
[AP-Dialer1] dialer-group 1
[AP-Dialer1] dialer bundle 1
[AP-Dialer1] ip address ppp-negotiate
[AP-Dialer1] ppp pap local-user user2 password simple hello
[AP-Dialer1] quit
# Configure the PPPoE session.
[AP] interface Vlan-interface 1
[AP-Vlan-interface1] pppoe-client dial-bundle-number 1
l Configuring CHAP authentication:
# Add a PPPoE user.
[RouterA-Virtual-Template1] ppp authentication-mode chap
[RouterA-Virtual-Template1] ppp chap user user2
<AP> system-view
[AP-Dialer1] ppp chap user user2
[AP-Dialer1] quit
[AP] local-user user2
[AP-luser-user1] password simple hello
[AP-luser-user1] quit
