H3C S3600 Operation Manual-Release 1602(V1.02)
HomeSupportSwitchesS3600 SeriesConfigure & DeployConfiguration GuidesH3C S3600 Operation Manual-Release 1602(V1.02)
37-FTP-SFTP-TFTP Operation
37-FTP-SFTP-TFTP Operation 223.26 KB
FTP and SFTP Configuration
When configuring FTP and SFTP, go to these sections for information you are interested in:
l          Introduction to FTP and SFTP
l          FTP Configuration
l          SFTP Configuration
FTP banner is newly added. For details, see section Configuring the banner for an FTP server.
Introduction to FTP
File Transfer Protocol (FTP) is commonly used in IP-based networks to transmit files. Before World Wide Web comes into being, files are transferred through command lines, and the most popular application is FTP. At present, although E-mail and Web are the usual methods for file transmission, FTP still has its strongholds.
As an application layer protocol, FTP is used for file transfer between remote server and local client. FTP uses TCP ports 20 and 21 for data transfer and control command transfer respectively. Basic FTP operations are described in RFC 959.
FTP-based file transmission is performed in the following two modes:
l          Binary mode for program file transfer
l          ASCII mode for text file transfer
An H3C S3600 series Ethernet switch can act as an FTP client or the FTP server in FTP-employed data transmission:
Table 1-1 Roles that an H3C S3600 series Ethernet switch acts as in FTP
Item
Remarks
FTP server
An Ethernet switch can operate as an FTP server to provide file transmission services for FTP clients. You can log in to a switch operating as an FTP server by running an FTP client program on your PC to access files on the FTP server.
The prerequisite is that a route exists between the switch and the PC.
FTP client
In this case, you need to establish a connection between your PC and the switch through a terminal emulation program or Telnet, execute the ftp X.X.X.X command on your PC. (X.X.X.X is the IP address of an FTP server or a host name), and enter your user name and password in turn. A switch can operate as an FTP client, through which you can access files on the FTP server.
l          With an S3600 series Ethernet switch serving as an FTP server, the seven-segment digital LED on the front panel of the switch rotates clockwise when an FTP client is uploading files to the FTP server (the S3600 switch), and stops rotating when the file uploading is finished, as shown in Figure 1-1.
l          With an S3600 series Ethernet switch serving as an FTP client, the seven-segment digital LED on the front panel of the switch rotates clockwise when the FTP client (the S3600 switch) is downloading files from an FTP server, and stops rotating when the file downloading is finished, as shown in Figure 1-1.
Figure 1-1 Clockwise rotating of the seven-segment digital LED
Introduction to SFTP
Secure FTP (SFTP) is established based on an SSH2 connection. It allows a remote user to log in to a switch to manage and transmit files, providing a securer guarantee for data transmission. In addition, since the switch can be used as a client, you can log in to remote devices to transfer files securely.
FTP Configuration
Complete the following tasks to configure FTP:
Remarks
FTP Configuration: A Switch Operating as an FTP Server
Creating an FTP user
Required
Enabling an FTP server
Required
Configuring connection idle time
Optional
Specifying the source interface and source IP address for an FTP server
Optional
Disconnecting a specified user
Optional
Optional
Displaying FTP server information
Optional
FTP Configuration: A Switch Operating as an FTP Client
Basic configurations on an FTP client
Specifying the source interface and source IP address for an FTP client
Optional
Configure the user name and password for the FTP user and set the service type to FTP. To use FTP services, a user must provide a user name and password for being authenticated by the FTP server. Only users that pass the authentication have access to the FTP server.
Follow these steps to create an FTP user:
To do…
Use the command…
Remarks
Enter system view
Add a local user and enter local user view
local-user user-name
Required
By default, no local user is configured.
Configure a password for the specified user
password { simple | cipher } password
Optional
By default, no password is configured.
Configure the service type as FTP
service-type ftp
Required
By default, no service is configured.
Follow these steps to enable an FTP server:
To do…
Use the command…
Remarks
Enter system view
Enable the FTP server function
ftp server enable
Required
Disabled by default.
l          Only one user can access an H3C S3600 series Ethernet switch at a given time when the latter operates as an FTP server.
l          Operating as an FTP server, an H3C S3600 series Ethernet switch cannot receive a file whose size exceeds its storage space. The clients that attempt to upload such a file will be disconnected with the FTP server due to lack of storage space on the FTP server.
l          When you log in to a Fabric consisting of multiple switches through an FTP client, after the FTP client passes authentication, you can log in to the master device of the Fabric.
l          You cannot access an H3C S3600 series switch operating as an FTP server through Microsoft Internet Explorer. To do so, use other client software.
To protect unused sockets against attacks, the S3600 Ethernet switch provides the following functions:
l          TCP 21 is enabled only when you start the FTP server.
l          TCP 21 is disabled when you shut down the FTP server.
After the idle time is configured, if the server does not receive service requests from a client within a specified time period, it terminates the connection with the client, thus preventing a user from occupying the connection for a long time without performing any operation.
Follow these steps to configure connection idle time:
To do…
Use the command…
Remarks
Enter system view
Configure the connection idle time for the FTP server
ftp timeout minutes
Optional
30 minutes by default
You can specify the source interface and source IP address for an FTP server to enhance server security. After this configuration, FTP clients can access this server only through the IP address of the specified interface or the specified IP address.
Source interface refers to the existing VLAN interface or Loopback interface on the device. Source IP address refers to the IP address configured for the interface on the device. Each source interface corresponds to a source IP address. Therefore, specifying a source interface for the FTP server is the same as specifying the IP address of this interface as the source IP address.
Follow these steps to specify the source interface and source IP address for an FTP server:
To do…
Use the command…
Remarks
Enter system view
Specify the source interface for an FTP server
ftp-server source-interface interface-type interface-number
Use either command
Not specified by default.
Specifying the source IP address for an FTP server
ftp-server source-ip ip-address
l          The specified interface must be an existing one. Otherwise a prompt appears to show that the configuration fails.
l          The value of the ip-address argument must be an IP address on the device where the configuration is performed. Otherwise a prompt appears to show that the configuration fails.
l          You can specify only one source interface or source IP address for the FTP at one time. That is, only one of the commands ftp-server source-interface and ftp-server source-ip can be valid at one time. If you execute both of them, the new setting will overwrite the original one.
l          If the switch (FTP server) is the command switch or member switch in a cluster, do not use the ftp-server source-ip command to specify the private IP address of the cluster as the source IP address of the FTP server. Otherwise, FTP does not take effect.
On the FTP server, you can disconnect a specified user from the FTP server to secure the network.
Follow these steps to disconnect a specified user:
To do…
Use the command…
Remarks
Enter system view
On the FTP server, disconnect a specified user from the FTP server
ftp disconnect user-name
Required
With an H3C S3600 series Ethernet switch acting as the FTP server, if a network administrator attempts to disconnect a user that is uploading/downloading data to/from the FTP server the S3600 Ethernet switch will disconnect the user after the data transmission is completed.
Displaying a banner: With a banner configured on the FTP server, when you access the FTP server through FTP, the configured banner is displayed on the FTP client. Banner falls into the following two types:
l          Login banner: After the connection between an FTP client and an FTP server is established, the FTP server outputs the configured login banner to the FTP client terminal.
Figure 1-2 Process of displaying a login banner
l          Shell banner: After the connection between an FTP client and an FTP server is established and correct user name and password are provided, the FTP server outputs the configured shell banner to the FTP client terminal.
Figure 1-3 Process of displaying a shell banner
Follow these steps to configure the banner display for an FTP server:
To do…
Use the command…
Remarks
Enter system view
Configure a login banner
header login text
Required
Use either command or both.
By default, no banner is configured.
Configure a shell banner
header shell text
For details about the header command, refer to the Login part of the manual.
To do…
Use the command…
Remarks
Display the information about FTP server configurations on a switch
display ftp-server
Available in any view
Display the source IP address set for an FTP server
display ftp-server source-ip
Display the login FTP client on an FTP server
display ftp-user
By default a switch can operate as an FTP client. In this case, you can connect the switch to the FTP server to perform FTP-related operations (such as creating/removing a directory) by executing commands on the switch.
Follow these steps to perform basic configurations on an FTP client:
To do…
Use the command…
Remarks
Enter FTP client view
ftp [ cluster | remote-server [ port-number ] ]
Specify to transfer files in ASCII characters
ascii
Use either command.
By default, files are transferred in ASCII characters.
Specify to transfer files in binary streams
binary
Set the data transfer mode to passive
passive
Optional
passive by default.
Change the working directory on the remote FTP server
cd pathname
Optional
Change the working directory to be the parent directory
cdup
Get the local working path on the FTP client
lcd
Display the working directory on the FTP server
pwd
Create a directory on the remote FTP server
mkdir pathname
Remove a directory on the remote FTP server
rmdir pathname
Delete a specified file
delete remotefile
Query a specified file on the FTP server
dir [ remotefile ] [ localfile ]
Optional
If no file name is specified, all the files in the current directory are displayed.
The difference between these two commands is that the dir command can display the file name, directory as well as file attributes; while the Is command can display only the file name and directory.
ls [ remotefile ] [ localfile ]
Download a remote file from the FTP server
get remotefile [ localfile ]
Optional
Upload a local file to the remote FTP server
put localfile [ remotefile ]
Rename a file on the remote server
rename remote-source remote-dest
 Log in with the specified user name and password
user username [ password ]
Connect to a remote FTP server
open { ip-address | server-name } [ port ]
Terminate the current FTP connection without exiting FTP client view
disconnect
close
Terminate the current FTP connection and return to user view
bye
Display the online help about a specified command concerning FTP
remotehelp [ protocol-command ]
Enable the verbose function
verbose
Optional
Enabled by default.
You can specify the source interface and source IP address for a switch acting as an FTP client, so that it can connect to a remote FTP server.
Follow these steps to specify the source interface and source IP address for an FTP client:
To do…
Use the command…
Remarks
Specify the source interface used for the current connection
ftp { cluster | remote-server } source-interface interface-type interface-number
Optional
Specify the source IP address used for the current connection
ftp { cluster | remote-server } source-ip ip-address
Optional
Enter system view
Specify an interface as the source interface the FTP client uses every time it connects to an FTP server
ftp source-interface interface-type interface-number
Use either command
Specify an IP address as the source IP address the FTP client uses every time it connects to an FTP server
ftp source-ip ip-address
Display the source IP address used by an FTP client every time it connects to an FTP server
display ftp source-ip
l          The value of the ip-address argument must be the IP address of the device where the configuration is performed. Otherwise a prompt appears to show that the configuration fails.
l          The source interface/source IP address set for one connection is prior to the fixed source interface/source IP address set for each connection. That is, for a connection between an FTP client and an FTP server, if you specify the source interface/source IP address used for the connection this time, and the specified source interface/source IP address is different from the fixed one, the former will be used for the connection this time.
l          Only one fixed source interface or source IP address can be set for the FTP client at one time. That is, only one of the commands ftp source-interface and ftp source-ip can be valid at one time. If you execute both of them, the new setting will overwrite the original one.
Configuration Example: A Switch Operating as an FTP Server
Network requirements
A switch operates as an FTP server and a remote PC as an FTP client. The application switch.bin of the switch is stored on the PC. Upload the application to the remote switch through FTP and use the boot boot-loader command to specify switch.bin as the application for next startup. Reboot the switch to upgrade the switch application and download the configuration file config.cfg from the switch, thus to back up the configuration file.
l          Create a user account on the FTP server with the username switch and password hello.
l          The IP addresses 1.1.1.1 for a VLAN interface on the switch and 2.2.2.2 for the PC have been configured. Ensure that a route exists between the switch and the PC.
Network diagram
Figure 1-4 Network diagram for FTP configurations: a switch operating as an FTP server
Configuration procedure
1)        Configure Switch A (the FTP server)
# Log in to the switch and enable the FTP server function on the switch. Configure the user name and password used to access FTP services, and specify the service type as FTP (You can log in to a switch through the Console port or by telnetting the switch. See the Login module for detailed information.)
# Configure the FTP username as switch, the password as hello, and the service type as FTP.
<Sysname>
[Sysname] ftp server enable
[Sysname] local-user switch
[Sysname-luser-switch] password simple hello
[Sysname-luser-switch] service-type ftp
2)        Configure the PC (FTP client)
Run an FTP client application on the PC to connect to the FTP server. Upload the application named switch.bin to the root directory of the Flash memory of the FTP server, and download the configuration file named config.cfg from the FTP server. The following takes the command line window tool provided by Windows as an example:
# Enter the command line window and switch to the directory where the file switch.bin is located. In this example it is in the root directory of C:\.
C:\>
# Access the Ethernet switch through FTP. Input the username switch and password hello to log in and enter FTP view.
C:\> ftp 1.1.1.1
Connected to 1.1.1.1.
220 FTP service ready.
User (1.1.1.1:(none)): switch
331 Password required for switch.
Password:
230 User logged in.
ftp>
# Upload file switch.bin.
ftp> put switch.bin
200 Port command okay.
150 Opening ASCII mode data connection for switch.bin.
226 Transfer complete.
ftp: 75980 bytes received in 5.55 seconds 13.70Kbytes/sec.
# Download file config.cfg.
ftp> get config.cfg
150 Opening ASCII mode data connection for config.cfg.
ftp: 3980 bytes received in 8.277 seconds 0.48Kbytes/sec.
This example uses the command line window tool provided by Windows. When you log in to the FTP server through another FTP client, refer to the corresponding instructions for operation description.
l          If available space on the Flash memory of the switch is not enough to hold the file to be uploaded, you need to delete files not in use from the Flash memory to make room for the file, and then upload the file again. The files in use cannot be deleted. If you have to delete the files in use to make room for the file to be uploaded, you can only delete/download them through the Boot ROM menu.
l          H3C series switch is not shipped with FTP client application software. You need to purchase and install it by yourself.
3)        Configure Switch A (FTP server)
# After uploading the application, use the boot boot-loader command to specify the uploaded file (switch.bin) to be the startup file used when the switch starts the next time, and restart the switch. Thus the switch application is upgraded.
<Sysname> boot boot-loader switch.bin
<Sysname> reboot
For information about the boot boot-loader command and how to specify the startup file for a switch, refer to the System Maintenance and Debugging part of this manual.
FTP Banner Display Configuration Example
Configure the Ethernet switch as an FTP server and the remote PC as an FTP client. After a connection between the FTP client and the FTP server is established and login succeeds, the banner is displayed on the FTP client.
l          An FTP user with username switch and the password hello has been configured on the FTP server.
l          Configure the login banner of the switch as “login banner appears” and the shell banner as “shell banner appears”.
Network diagram
Figure 1-5 Network diagram for FTP banner display configuration
1)        Configure the switch (FTP server)
# Configure the login banner of the switch as “login banner appears” and the shell banner as “shell banner appears”. For detailed configuration of other network requirements, see section Configuration Example: A Switch Operating as an FTP Server.
[Sysname] header login %login banner appears%
[Sysname] header shell %shell banner appears%
# Access the Ethernet switch through FTP. Enter the username switch and the password hello to log in to the switch, and then enter FTP view. Login banner appears after FTP connection is established. Shell banner appears after the user passes the authentication.
C:\> ftp 1.1.1.1
220-login banner appears
Password:
230-shell banner appears
230 User logged in.
ftp>
A switch operates as an FTP client and a remote PC as an FTP server. The switch application named switch.bin is stored on the PC. Download it to the switch through FTP and use the boot boot-loader command to specify switch.bin as the application for next startup. Reboot the switch to upgrade the switch application, and then upload the switch configuration file named config.cfg to directory switch of the PC to back up the configuration file.
l          Create a user account on the FTP server with the username switch and password hello, and grant the user switch read and write permissions for the directory switch on the PC.
l          Configure the IP address 1.1.1.1 for a VLAN interface on the switch, and 2.2.2.2 for the PC. Ensure a route exists between the switch and the PC.
Network diagram
Figure 1-6 Network diagram for FTP configurations: a switch operating as an FTP client
1)        Configure the PC (FTP server)
Perform FTP server–related configurations on the PC, that is, create a user account on the FTP server with username switch and password hello. (For detailed configuration, refer to the configuration instruction relevant to the FTP server software.)
2)        Configure the switch (FTP client)
# Log in to the switch. (You can log in to a switch through the Console port or by telnetting the switch. See the Login module for detailed information.)
<Sysname>
# Connect to the FTP server using the ftp command in user view. You need to provide the IP address of the FTP server, the user name and the password as well to enter FTP view.
<Sysname> ftp 2.2.2.2
Trying ...
Press CTRL+K to abort
Connected.
User(none):admin
331 Password required for admin.
Password:
230 User logged in.
[ftp]
# Enter the authorized directory on the FTP server.
[ftp] cd switch
# Execute the put command to upload the configuration file named config.cfg to the FTP server.
[ftp] put config.cfg
# Execute the get command to download the file named switch.bin to the Flash memory of the switch.
[ftp] get switch.bin
# Execute the quit command to terminate the FTP connection and return to user view.
[ftp] quit
<Sysname>
# After downloading the file, use the boot boot-loader command to specify the downloaded file (switch.bin) to be the application for next startup, and then restart the switch. Thus the switch application is upgraded.
<Sysname> reboot
For information about the boot boot-loader command and how to specify the startup file for a switch, refer to the System Maintenance and Debugging module of this manual.
SFTP Configuration
Complete the following tasks to configure SFTP:
Remarks
SFTP Configuration: A Switch Operating as an SFTP Server
Enabling an SFTP server
Required
Optional
Supported SFTP client software
SFTP Configuration: A Switch Operating as an SFTP Client
Basic configurations on an SFTP client
Specifying the source interface or source IP address for an SFTP client
Optional
Before enabling an SFTP server, you need to enable the SSH server function and specify the service type of the SSH user as SFTP or all. For details, see the SSH server configuration part of SSH Operation Manual of this manual.
Follow these steps to enable an SFTP server:
To do…
Use the command…
Remarks
Enter system view
Enable an SFTP server
sftp server enable
Required
To do…
Use the command…
Remarks
Enter system view
Configure the connection idle time for the SFTP server
ftp timeout time-out-value
Optional
10 minutes by default.
An H3C S3600 series Ethernet switch operating as an SFTP server can interoperate with SFTP client software, including SSH Tectia Client v4.2.0 (SFTP), v5.0, and WINSCP.
SFTP client software supports the following operations: logging in to a device; uploading a file; downloading a file; creating a directory; modify a file name or a directory name; browsing directory structure; and manually terminating a connection.
For configurations on client software, see the corresponding configuration manual.
l          Currently an H3C S3600 series Ethernet switch operating as an SFTP server supports the connection of only one SFTP user. When multiple users attempt to log in to the SFTP server or multiple connections are enabled on a client, only the first user can log in to the SFTP user. The subsequent connection will fail.
l          When you upload a large file through WINSCP, if a file with the same name exists on the server, you are recommended to set the packet timeout time to over 600 seconds, thus to prevent the client from failing to respond to device packets due to timeout. Similarly, when you delete a large file from the server, you are recommended to set the client packet timeout time to over 600 seconds.
By default a switch can operate as an SFTP client. In this case you can connect the switch to the SFTP server to perform SFTP-related operations (such as creating/removing a directory) by executing commands on the switch.
Follow these steps to perform basic configurations on an SFTP client:
To do…
Use the command…
Remarks
Enter system view
Enter SFTP client view
sftp { host-ip | host-name } [ port-num ] [ identity-key { dsa | rsa } | prefer_kex { dh_group1 | dh_exchange_group } | prefer_ctos_cipher { 3des | des | aes128 } | prefer_stoc_cipher { 3des | des | aes128 } | prefer_ctos_hmac { sha1 | sha1_96 | md5 | md5_96 } | prefer_stoc_hmac { sha1 | sha1_96 | md5 | md5_96 } ] *
Required
Change the working directory on the remote SFTP server
cd pathname
Optional
cdup
Display the working directory on the SFTP server
pwd
Create a directory on the remote SFTP server
mkdir pathname
Remove a directory on the remote SFTP server
rmdir pathname
delete remotefile
Optional
Both commands have the same effect.
remove remote-file
Query a specified file on the SFTP server
Optional
If no file name is provided, all the files in the current directory are displayed.
Download a remote file from the SFTP server
Optional
Upload a local file to the remote SFTP server
Exit SFTP client view and return to system view
bye
The three commands have the same effect.
exit
Display the online help about a specified command concerning SFTP
help [ all | command-name ]
Optional
If you specify to authenticate a client through public key on the server, the client needs to read the local private key when logging in to the SFTP server. Since both RSA and DSA are available for public key authentication, you need to use the identity-key key word to specify the algorithms to get correct local private key; otherwise you will fail to log in.  For details, see SSH Operation Manual.
You can specify the source interface or source IP address for a switch acting as an FTP client, so that it can connect to a remote SFTP server.
Follow these steps to specify the source interface or source IP address for an SFTP client:
To do…
Use the command…
Remarks
Enter system view
Specify an interface as the source interface of the specified SFTP client
sftp source-interface interface-type interface-number
Use either command
Specify an IP address as the source IP address of the specified SFTP client
sftp source-ip ip-address
Display the source IP address used by the current SFTP client
display sftp source-ip
Optional
SFTP Configuration Example
As shown in Figure 1-7, establish an SSH connection between the SFTP client (switch A) and the SFTP server (switch B). Log in to switch B through switch A to manage and transmit files. An SFTP user with the username client001 and password abc exists on the SFTP server.
Network diagram
Figure 1-7 Network diagram for SFTP configuration
1)        Configure the SFTP server (switch B)
# Create key pairs.
[Sysname] public-key local create rsa
[Sysname] public-key local create dsa
# Create a VLAN interface on the switch and assign to it an IP address, which is used as the destination address for the client to connect to the SFTP server.
[Sysname-Vlan-interface1] ip address 192.168.0.1 255.255.255.0
[Sysname-Vlan-interface1] quit
# Specify the SSH authentication mode as AAA.
[Sysname] user-interface vty 0 4
[Sysname-ui-vty0-4] authentication-mode scheme
# Configure the protocol through which the remote user logs in to the switch as SSH.
[Sysname-ui-vty0-4] protocol inbound ssh
[Sysname-ui-vty0-4] quit
# Create a local user client001.
[Sysname] local-user client001
[Sysname-luser-client001] password simple abc
[Sysname-luser-client001] service-type ssh
[Sysname-luser-client001] quit
# Configure the authentication mode as password. Authentication timeout time, retry number, and update time of the server key adopt the default values.
[Sysname] ssh user client001 authentication-type password
# Specify the service type as SFTP.
[Sysname] ssh user client001 service-type sftp
# Enable the SFTP server.
[Sysname] sftp server enable
2)        Configure the SFTP client (switch A)
# Configure the IP address of the VLAN interface on switch A. It must be in the same segment with the IP address of the VLAN interface on switch B. In this example, configure it as 192.168.0.2.
[Sysname-Vlan-interface1] ip address 192.168.0.2 255.255.255.0
# Connect to the remote SFTP server. Enter the username client001 and the password abc, and then enter SFTP client view.
[Sysname] sftp 192.168.0.1
Input Username: client001
Trying 192.168.0.1 ...
Connected to 192.168.0.1 ...
The Server is not authenticated. Do you continue to access it?(Y/N):y
Do you want to save the server's public key?(Y/N):n
Enter password:
sftp-client>
# Display the current directory of the server. Delete the file z and verify the result.
sftp-client> dir
-rwxrwxrwx   1 noone    nogroup      1759 Aug 23 06:52 config.cfg
-rwxrwxrwx   1 noone    nogroup       225 Aug 24 08:01 pubkey2
-rwxrwxrwx   1 noone    nogroup       283 Aug 24 07:39 pubkey1
drwxrwxrwx   1 noone    nogroup         0 Sep 01 06:22 new
-rwxrwxrwx   1 noone    nogroup       225 Sep 01 06:55 pub
-rwxrwxrwx   1 noone    nogroup         0 Sep 01 08:00 z
Received status: End of file
Received status: Success
sftp-client> delete z
The following files will be deleted:
/z
Are you sure to delete it?(Y/N):y
This operation may take a long time.Please wait...
File successfully Removed
sftp-client> dir
# Add a directory new1, and then check whether the new directory is successfully created.
sftp-client> mkdir new1
New directory created
sftp-client> dir
drwxrwxrwx   1 noone    nogroup         0 Sep 02 06:30 new1
# Rename the directory new1 as new2, and then verify the result.
sftp-client> rename new1 new2
File successfully renamed
sftp-client> dir
drwxrwxrwx   1 noone    nogroup         0 Sep 02 06:33 new2
# Download the file pubkey2 from the server and rename it as public.
sftp-client> get pubkey2 public
This operation may take a long time, please wait...
Remote  file:/pubkey2 --->  Local file: public..
Downloading file successfully ended
# Upload file pu to the server and rename it as puk, and then verify the result.
sftp-client> put pu puk
Local file: pu --->  Remote file: /puk
Uploading file successfully ended
sftp-client> dir
-rwxrwxrwx   1 noone    nogroup       283 Sep 02 06:35 pub
-rwxrwxrwx   1 noone    nogroup       283 Sep 02 06:36 puk
sftp-client>
# Exit SFTP.
sftp-client> quit
Bye
[Sysname]
TFTP Configuration
When configuring TFTP, go to these sections for information you are interested in:
l          Introduction to TFTP
l          TFTP Configuration
Compared with FTP, Trivial File Transfer Protocol (TFTP) features simple interactive access interface and no authentication control. Therefore, TFTP is applicable in the networks where client-server interactions are relatively simple. TFTP is implemented based on UDP. It transfers data through UDP port 69. Basic TFTP operations are described in RFC 1986.
TFTP transmission is initiated by clients, as described in the following:
l          To download a file, a client sends Read Request packets to the TFTP server, then receives data from the TFTP server, and sends acknowledgement packets to the TFTP server.
l          To upload a file, a client sends Write Request packets to the TFTP server, then sends data to the TFTP server, and receives acknowledgement packets from the TFTP server.
An H3C S3600 series Ethernet switch can act as a TFTP client only.
When an S3600 series Ethernet switch serving as a TFTP client downloads files from the TFTP server, the seven-segment digital LED on the front panel of the switch rotates clockwise, and it stops rotating when the file downloading is finished, as shown in Figure 1-1.
When you download a file that is larger than the free space of the switch’s flash memory:
l          If the TFTP server supports file size negotiation, file size negotiation will be initiated between the switch and the server and the file download operation will be aborted if the free space of the switch’s flash memory is found to be insufficient.
l          If the TFTP server does not support file size negotiation, the switch will receive data from the server until the flash memory is full. If there is more data to be downloaded, the switch will prompt that the space is insufficient and delete the data partially downloaded. File download fails.
TFTP-based file transmission can be performed in the following modes:
l          Binary mode for program file transfer.
l          ASCII mode for text file transfer.
Before performing TFTP-related configurations, you need to configure IP addresses for the TFTP client and the TFTP server, and make sure a route exists between the two.
TFTP Configuration
Complete the following tasks to configure TFTP:
Remarks
TFTP Configuration: A Switch Operating as a TFTP Client
Basic configurations on a TFTP client
Specifying the source interface or source IP address for an FTP client
Optional
TFTP server configuration
For details, see the corresponding manual
By default a switch can operate as a TFTP client. In this case you can connect the switch to the TFTP server to perform TFTP-related operations (such as creating/removing a directory) by executing commands on the switch.
Follow these steps to perform basic configurations on a TFTP client:
To do…
Use the command…
Remarks
Download a file from a TFTP server
tftp tftp-server get source-file [ dest-file ]
Optional
Upload a file to a TFTP server
tftp tftp-server put source-file [ dest-file ]
Optional
Enter system view
Set the file transmission mode
tftp { ascii | binary }
Optional
Binary by default.
Specify an ACL rule used by the specified TFTP client to access a TFTP server
tftp-server acl acl-number
Optional
You can specify the source interface and source IP address for a switch operating as a TFTP client, so that it can connect with a remote TFTP server through the IP address of the specified interface or the specified IP address.
Follow these steps to specify the source interface and source IP address for a TFTP client:
To do…
Use the command…
Remarks
tftp tftp-server source-interface interface-type interface-number { get source-file [ dest-file ] | put source-file-url [ dest-file ] }
Optional
tftp tftp-server source-ip ip-address { get source-file [ dest-file ] | put source-file-url [ dest-file ] }
Optional
Enter system view
Specify an interface as the source interface a TFTP client uses every time it connects to a TFTP server
tftp source-interface interface-type interface-number
Use either command
Specify an IP address as the source IP address a TFTP client uses every time it connects to a TFTP server
tftp source-ip ip-address
Display the source IP address used by a TFTP client every time it connects to a TFTP server
display tftp source-ip
Optional
l          The specified interface must be an existing one; otherwise a prompt appears to show that the configuration fails.
l          The value of the ip-address argument must be an IP address on the device where the configuration is performed, and otherwise a prompt appears to show that the configuration fails.
l          The source interface/source IP address set for one connection is prior to the fixed source interface/source IP address set for each connection. That is, for a connection between a TFTP client and a TFTP server, if you specify the source interface/source IP address only used for the connection this time, and the specified source interface/source IP address is different from the fixed one, the former will be used for the connection this time.
l          You may specify only one source interface or source IP address for the TFTP client at one time. That is, only one of the commands tftp source-interface and tftp source-ip can be effective at one time. If both commands are configured, the one configured later will overwrite the original one.
TFTP Configuration Example
A switch operates as a TFTP client and a PC as the TFTP server. The application named switch.bin is stored on the PC. Download it (switch.bin) to the switch through TFTP, and use the boot boot-loader command to specify switch.bin as the application for next startup. Reboot the switch to upload the configuration file named config.cfg to the work directory on the PC to back up the configuration file.
l          The TFTP working directory is configured on the TFTP server.
l          Configure the IP addresses of a VLAN interface on the switch and the PC as 1.1.1.1 and 2.2.2.2 respectively. The port through which the switch connects with the PC belongs to the VLAN.
Network diagram
Figure 2-1 Network diagram for TFTP configurations
1)        Configure the TFTP server (PC)
Start the TFTP server and configure the working directory on the PC.
2)        Configure the TFTP client (switch).
<Sysname>
# Enter system view
[Sysname]
# Configure the IP address of a VLAN interface on the switch to be 1.1.1.1, and ensure that the port through which the switch connects with the PC belongs to this VLAN. (This example assumes that the port belongs to VLAN 1.)
[Sysname] interface Vlan-interface 1
[Sysname-Vlan-interface1] ip address 1.1.1.1 255.255.255.0
# Download the switch application named switch.bin from the TFTP server to the switch.
<Sysname> tftp 2.2.2.2 get switch.bin switch.bin
# Upload the switch configuration file named config.cfg to the TFTP server.
<Sysname> tftp 2.2.2.2 put config.cfg config.cfg
# After downloading the file, use the boot boot-loader command to specify the downloaded file (switch.bin) to be the startup file used when the switch starts the next time, and restart the switch. Thus the switch application is upgraded.
<Sysname> reboot
