H3C S9500 Command Manual-Release1648[v1.24]-05 MPL VPN Volume
HomeSupportSwitchesS9500 SwitchesReference GuidesCommand ReferencesH3C S9500 Command Manual-Release1648[v1.24]-05 MPL VPN Volume
05-MPLS OAM Commands
05-MPLS OAM Commands 97.79 KB
Chapter 1  MPLS OAM Configuration Commands
&  Note:
Currently, the H3C S9500 series routing switches do not support the FFD mode.
1.1  MPLS OAM Configuration Commands
1.1.1  mpls oam
mpls oam
undo mpls oam
View
None
Use the mpls oam command to enable OAM globally.
Use the undo mpls oam command to disable OAM.
When you execute the mpls oam command, the system will clear all the current OAM configurations. As a result, all OAM configuration query operations do not take effect.
OAM instances can be configured only after the OAM function is enabled globally.
By default, OAM is disabled.
# Enable OAM globally.
<H3C> system view
[H3C] mpls oam
1.1.2  mpls oam ingress
mpls oam ingress lsp-name lsp-name lsp-id lsp-id [ type { cv | ffd [ frequency ffd-fre ] } ] [ backward-lsp { share | lsp-name rev-lsp-name } ]
undo mpls oam ingress { all | lsp-name lsp-name }
View
lsp-name: Name of the static LSP, which is used for OAM configuration on the ingress node.
lsp-id: ID of the static LSP, which is used for setting trail termination source identifier (TTSI).
type: Specifies the type of OAM verification packet: connectivity verification (CV) or fast failure detection (FFD). By default, the packet type is CV.
ffd-fre: Transmission frequency only specific to FFD packet, which defaults to 100ms.
share: Sets the backward LSP to share LSP.
rev-lsp-name: Name of the reverse static LSP. For a share backward LSP, the name is not specified.
Use the mpls oam ingress command to configure OAM and modify OAM parameters for a specified static LSP.
Use the undo mpls oam ingress command to remove the OAM instance of the specified LSP. If the all argument is specified, the system will clear all configurations on the ingress node.
&  Note:
The ingress node and the egress node should have the same backward LSP configuration: share or exclusive.
# Configure OAM on the ingress node.
<H3C> system view
[H3C] mpls oam ingress lsp-name pe1-pe2 lsp-id 1 type ffd backward-lsp lsp-name pe2-pe1
1.1.3  mpls oam ingress enable
mpls oam ingress enable { all | lsp-name lsp-name }
undo mpls oam ingress enable { all | lsp-name lsp-name }
View
all: Specifies to verify all the OAM-enabled LSPs.
lsp-name: Name of the OAM-enabled LSP to be verified.
Use the mpls oam ingress enable command to enable the OAM verification function for a specified LSP or all LSPs on the ingress node. If OAM is disabled, the configuration of the LSP will be reserved, that is, OAM instance configured for the LSP will be retained.
Use the undo mpls oam ingress enable command to disable the OAM verification function.
By default, the OAM verification function is disabled.
# Enable the OAM verification function on the ingress node.
<H3C> system view
[H3C] mpls oam ingress enable lsp-name pe1-pe2
1.1.4  mpls oam egress
mpls oam egress lsp-name lsp-name lsr-id lsr-id lsp-id lsp-id [ type { cv | ffd [ frequency ffd-fre ] } ] [ backward-lsp rev-lsp-name [ private | share ] ]
undo mpls oam egress { all | lsp-name lsp-name }
View
lsp-name: Name of the static LSP, which is used for OAM configuration on the egress node.
lsp-id: LSP ID of the egress node, which should be the same as that on the ingress node.
lsr-id: LSR ID of the egress node, which should be the same as that on the ingress node.
ffd-fre: Transmission frequency only specific to FFD packet, in the range of 50, 100, 200 and 500 (in ms). By default, it is 100 ms.
rev-lsp-name: Name of the backward LSP to be bound.
private: Specifies to use the reverse channel exclusively.
share: Specifies to use the reverse channel with others.
all: Clear all OAM configurations on the egress node.
Use the mpls oam egress command to configure OAM for an LSP on the egress node.
Use the undo mpls oam egress command to remove the configuration.
&  Note:
The detection frequency configured for the OAM instance on the egress node must be the same as on the ingress node.
# Configure OAM on the egress node.
<H3C> system view
[H3C] mpls oam egress pe1-pe2 lsr-id 3.3.3.3 lsp-id 2 ffd 50 backward-lsp pe2-pe1 private
1.1.5  mpls oam egress enable
mpls oam egress enable { all | lsp-name lsp-name }
undo mpls oam egress enable { all | lsp-name lsp-name }
View
Use the mpls oam egress enable command to enable the OAM verification function for a specified LSP or all LSPs on the egress node.
Use the undo mpls oam egress enable command to disable the OAM verification function.
# Enable and disable the OAM verification function on the egress node.
<H3C> system view
[H3C] mpls oam egress enable lsp-name pe1-pe2
[H3C] undo mpls oam egress enable lsp-name pe1-pe2
1.1.6  display mpls oam ingress
display mpls oam ingress { all | lsp-name lsp-name } [ verbose | slot slot-id ]
View
User view/system view/MPLS view
all: Displays the current state and configuration information of all the OAM-enabled LSPs.
lsp-name: Name of the specified LSP with OAM enabled.
verbose: Displays detailed information, including enable state, OAM verification packet type, FFD packet transmission frequency, LSP ID, and defect state.
Use the display mpls oam ingress command to display the current state and configuration information of a specified LSP or all LSPs with OAM enabled on the ingress node.
By default, the system displays detailed information.
# Display detailed information of LSPs with OAM enabled on the ingress node.
<H3C> display mpls oam ingress all verbose
Verbose information about the 1th oam at the ingress
lsp basic information:                oam basic information:
Lsp-name        : pe1-pe2              Oam-Index         : 64
Lsp signal status   : Down               Oam select board    : 2
                                              Enable-state        : Manual enable
Lsp ingress lsr-id  : 20.1.1.1          Ttsi/lsr-id         : 20.1.1.1
                                              Ttsi/lsp-id         : 1
oam detect information:                   oam backward information:
Type              : FFD                      Share attribute     : Share
Frequency        : 100 ms                   Lsp-name        : --
Detect-state    : Start                    Lsp-inLabel         : --
Defect-state    : non-defect              Lsp-state           : --
Total Oam Num:                    1
Total Start Oam Num:              1
Total Defect Oam Num:             0
Table 1-1 Description on the fields of the display mpls oam ingress command
LSP basic information
Lsp-name
Name of the LSP
Lsp signal status
State of the LSP
Lsp ingress lsr-id
Ingress LSR ID of the LSP
OAM basic information
Oam-Index
OAM index
Oam select board
Main process unit for processing OAM instances
Enable-state
Enable state of OAM instance
Ttsi/lsr-id
LSR ID in TTSI
Ttsi/lsp-id
LSP ID in TTSI
Information about OAM verification
Packet type: CV/FFD/BDI
Frequency
Detect-state
Verification state: start/stop
Defect-state
Defect sate
Information about the backward LSP
Share attribute
Share attribute of the backward LSP: share or exclusive
Lsp-name
Lsp-inLabel
Ingress label of the backward LSP
Lsp-state
State of the backward LSP
Total Oam Num
Total number of OAM instances
Total Start Oam Num
Total number of OAM instances which verification starts
Total number of OAM instances which have defects
# Display the status and configuration information of LSPs with OAM enabled on slot 10 of the ingress node.
<H3C> display mpls oam ingress lsp-name 20.0.0.1_1 slot 10
Verbose information about the 1st OAM at ingress
Lsp-name            : 20.0.0.1_1          Oam-Index           : 2053
Lsp signal status   : Up                  Oam select board    : 10
Lsp ingress lsr-id  : 20.0.0.5            Enable-state        : Manual enable
                                          Ttsi/lsr-id         : 20.0.0.5
                                          Ttsi/lsp-id         : 4
Type                : CV                  Share attribute     : Private
Frequency           : 1 s                 Lsp-name            : 20.0.0.511
Detect-state        : Start               Lsp-inLabel         : 3
Defect-state        : No-defect           Lsp-state           : Up
oam statistic information:
Send cv-packet      : 3039
Send ffd-packet     : 0
Send autopro-packet : 0
Receive bdi-packet  : 2
Table 1-2 Description on the fields of the display mpls oam ingress command
Lsp-name
Name of the LSP
Lsp signal status
State of the LSP
Lsp ingress lsr-id
Oam-Index
OAM index
Oam select board
Enable-state
State of the OAM instance
Ttsi/lsr-id
LSR ID in TTSI
Ttsi/lsp-id
LSP ID in TTSI
Frequency
Detect-state
Defect-state
Defect sate
Share attribute
Lsp-name
Lsp-inLabel
Lsp-state
OAM statistics information
Send cv-packet
Number of cv-packets sent
Send ffd-packet
Number of ffd-packets sent
Send autopro-packet
Number of autopro-packet sent
Receive bdi-packet
Number of bdi-packets received
1.1.7  display mpls oam egress
display mpls oam egress { all | lsp-name lsp-name } [ verbose | slot slot-id ]
View
verbose: Displays detailed information, including enable state, OAM verification packet type, FFD packet transmission frequency, LSP ID, backward LSP name, backward LSP use mode.
Use the display mpls oam egress command to display the current state and configuration information of a specified LSP or all LSPs with OAM enabled on the egress node.
# Display detailed information of LSPs with OAM enabled on the egress node.
<H3C> display mpls oam egress all verbose
Verbose information about the 1st OAM at egress
Lsp-name              : pe1-pe2             Oam-Index         : 1024
Lsp signal status   : Up                  Oam select board    : 2
Lsp incoming Label  : 30                  Enable-state        : --
Lsp ingress lsr-id  : 20.1.1.1           Auto-protocol      : Disable
           Auto-overtime (s)   : 0
                                              Ttsi/lsp-id         : 1
Type                  : CV                   Share attribute     : Share
Frequency            : 1 s                  Lsp-name         : pe2-pe1
Detect-state        : Start                Lsp-state          : Down
Total Oam Num:                  1
Table 1-3 Description on the fields of the display mpls oam egress command
Lsp-name
Name of the LSP
Lsp signal status
State of the LSP
Lsp incoming Label
Ingress label of the LSP
Lsp ingress lsr-id
Oam-Index
OAM index
Oam select board
Enable-state
Enable state of OAM instances
Ttsi/lsr-id
LSR ID in TTSI
Ttsi/lsp-id
LSP ID in TTSI
Information of OAM verification
Packet type: CV/FFD
Frequency
Detect-state
Verification sate: start/stop
Defect-state
Defect state
backward lsp name
Share attribute
Lsp-state
Total Oam Num
Total Start Oam Num
#  Display the status and configuration information of LSPs with OAM enabled on slot 10 of the egress node.
<H3C> display mpls oam egress lsp-name 20.0.0.5_0 slot 10
Lsp-name            : 20.0.0.5_0          Oam-Index           : 2050
Lsp incoming Label  : 3                   Enable-state        : Manual enable
Lsp ingress lsr-id  : 20.0.0.2            Auto-protocol       : Disable
                                          Ttsi/lsr-id         : 20.0.0.2
                                          Ttsi/lsp-id         : 1
Frequency           : 1 s                 Lsp-name            : 20.0.0.2_0
Detect-state        : Start               Lsp-state           : Up
Send bdi-packet     : 381
Receive cv-packet   : 2704
Receive ffd-packet  : 0
Receive autopro-packet: 0
Table 1-4 Description on the fields of the display mpls oam egress command
Lsp-name
Name of the LSP
Lsp signal status
State of the LSP
Lsp incoming Label
Lsp ingress lsr-id
Oam-Index
OAM index
Oam select board
Enable-state
Ttsi/lsr-id
LSR ID in TTSI
Ttsi/lsp-id
LSP ID in TTSI
Packet type: CV/FFD
Frequency
Detect-state
Defect-state
Defect state
backward lsp name
Share attribute
Lsp-state
Send bdi-packet t
Receive cv-packet
Number of ffd-packets received
Receive ffd-packet
Number of autopro-packets received
1.1.8  display mpls oam ingress send-packet
display mpls oam ingress send-packet { all | cv | ffd | ap-fdi | error } slot slot-id
View
all: Displays all OAM packets sent from the ingress node.
cv: Displays CV packets sent from the ingress node.
ffd: Displays FFD packets sent from the ingress node.
ap-fdi: Displays auto protocol packets sent from the ingress node.
error: Displays wrong packets sent from the ingress node.
slot-id: Number of the slot where the interface board resides.
Use the display mpls oam ingress send-packet command to display the statistics of OAM packets sent from the ingress node.
# Display OAM packets sent from the ingress node.
<H3C> display mpls oam ingress send-packet all slot 2
CV Packet           FFD Packet          AP-FDI Packet       Error Packet
 4784                 0                    0                    0
Table 1-5 Description on the fields of display mpls oam ingress send-packet
CV Packet
Number of CV packets sent from the ingress node
FFD Packet
Number of FFD packets sent from the ingress node
AP-FDI Packet
Number of auto protocol FDI packets sent from the ingress node
Error Packet
Number of wrong packets sent from the ingress node
1.1.9  display mpls oam ingress receive-packet
display mpls oam ingress receive-packet { all | bdi | error } slot slot-id
View
all: Displays all OAM packets received on the ingress node.
bdi: Displays BDI packets received on the ingress node.
error: Displays wrong packets received on the ingress node.
slot-id: Number of the slot where the specified interface board resides.
Use the display mpls oam ingress receive-packet command to display the statistics of OAM packets received on the ingress node.
# Display the statistics of OAM packets received on the ingress node.
<H3C> display mpls oam ingress receive-packet all slot 2
BDI Packet          Error Packet
0
Table 1-6 Description on the fields of display mpls oam ingress receive-packet
BDI Packet
Number of BDI packets received on the ingress node
Error Packet
Number of wrong packets received on the ingress node
1.1.10  display mpls oam egress send-packet
display mpls oam egress send-packet { all | cv | bdi | error } slot slot-id
View
Use view/system view/MPLS view
all: Displays all OAM packets sent from the egress node.
bdi: Displays BDI packets sent from the egress node.
error: Displays wrong packets sent from the egress node.
Use the display mpls oam egress send-packet command to display the statistics of OAM packets sent from the egress node.
# Display OAM packets sent from the egress node.
<H3C> display mpls oam egress send-packet all slot 2
0
Table 1-7 Description on the fields of display mpls oam egress send-packet
BDI Packet
Number of BDI packets sent from the egress node
Error Packet
Number of wrong packets sent from the egress node
1.1.11  display mpls oam egress receive-packet
display mpls oam egress receive-packet { all | cv | ffd | fdi | ap-fdi | error } slot slot-id
View
all: Displays all OAM packets received on the egress node.
cv: Displays CV packets received on the egress node.
ffd: Displays FFD packets received on the egress node.
ap-fdi: Displays auto protocol FDI packets received on the egress node.
error: Displays wrong packets received on the egress node.
Use the display mpls oam egress receive-packet command to display the statistics of OAM packets received on the egress node.
# Display the statistics of OAM packets received on the egress node.
<H3C> display mpls oam egress receive-packet all slot 2
CV Packet      FFD Packet     FDI Packet     AP-FDI Packet  Error Packet
-------------------------------------------------------------------------- 3764            0               0               0               0
Table 1-8 Description on the fields of display mpls oam egress receive-packet
CV Packet
Number of CV packets received on the egress node
FFD Packet
Number of FFD packets received on the egress node
AP-FDI Packet
Number of auto protocol FDI packets received on the egress node
Error Packet
Number of wrong packets received on the egress node
1.1.12  reset mpls oam packet-statistics ingress
reset mpls oam packet-statistics ingress { all | lsp-name lsp-name}
View
all: Specifies to clear the statistics of all OAM packets on the ingress node.
lsp-name lsp-name: Specifies to clear the statistics of OAM packets for a specified LSP. lsp-name is the name of the specified LSP.
Use the reset mpls oam packet-statistics ingress command to clear the statistics of all OAM packets or the OAM packets for a specified LSP on the ingress node.
# Clear the statistics of all OAM packets on the ingress node.
<H3C> reset mpls oam packet-statistics ingress all
1.1.13  reset mpls oam packet-statistics egress
reset mpls oam packet-statistics egress { all | lsp-name lsp-name}
View
all: Specifies to clear the statistics of all OAM packets on the egress node.
Use the reset mpls oam packet-statistics egress command to clear the statistics of all OAM packets or the OAM packets for a specified LSP on the egress node.
# Clear the statistics of all OAM packets on the egress node.
<H3C> reset mpls oam packet-statistics egress all
1.1.14  reset mpls oam packet-statistics slot
reset mpls oam packet-statistics slot slot-id
View
Use the reset mpls oam packet-statistics slot command to clear the statistics of OAM packets on the specified interface board.
# Clear the statistics of OAM packets on the specified interface board in Slot 2.
<H3C> reset mpls oam packet-statistics slot 2
1.1.15  debugging mpls oam
debugging mpls oam { all | bdi | cv | decode | defect-detect | error | fdi | ffd | hsb | timer | main | packet | process}
undo debugging mpls oam { all | bdi | cv | decode | defect-detect | error | fdi | ffd | hsb | timer | main | packet | process }
View
all: Enables all types of debugging.
bdi: Displays debug messages related to BDI packets.
cv: Displays debug messages related to CV packets.
decode: Displays debug messages related to decode.
defect-detect: Displays debugging information about defect verification.
error: Displays debug messages related to wrong packets.
fdi: Displays debug messages related to FDI packets.
ffd: Displays debug messages related to FFD packets.
hsb: Displays debug messages related to hot backup.
timer: Displays debug messages related to timer.
main: Displays debug messages related to main process unit.
packet: Displays debug messages related to OAM packets.
process: Displays debug messages related to debug process.
Use the debugging mpls oam command to enable debugging for OAM.
Use the undo command to disable debugging for OAM.
# Enable debugging for OAM.
<H3C> debugging mpls oam cv
1.2  MPLS Protection Group Configuration Commands
1.2.1  debugging mpls protect-switch
debugging mpls protect-switch { all | error | process | timer }
undo debugging mpls protect-switch
View
error: Displays debugging messages related to wrong packets.
process: Displays debugging messages related to debug process.
timer: Displays debugging messages related to timer.
Use the debugging mpls protect-switch command to enable debugging for a protection groups.
Use the undo debugging mpls protect-switch command to disable debugging for protection groups.
# Enable all types of debugging for protection groups.
<H3C> debugging mpls protect-switch all
1.2.2  display mpls protect-switch
display mpls protect-switch { all | protect-id } [ brief | verbose ]
View
protect-id: Specifies a protection group.
all: Displays information about all protection groups.
brief: Displays brief information.
verbose: Displays detailed information.
Use the display mpls protect-switch command to display the information of the specified protection group, including ID and state of the primary LSP, ID and state of the secondary LSP, switch back mode, WTR time, Holdoff time, active LSP.
# Display information about the specified protection group.
<H3C> display mpls protect-switch 1 verbose
                 Protection-Switching Information
PG-ID                          :  16
Working LSP                    :  12
Working LSP Token              :  0
Working LSP User Plane Status     :  No-defect
Working LSP Ctrl Plane Status      :  Up
Protect LSP                     :  15
Protect LSP Token               :  4
Protect LSP User Plane Status      :  No-defect
Protect LSP Ctrl Plane Status       :  Up
Switching  Result               :  Working LSP
Revertive Mode                 :  Revertive
Holdoff Time(unit 100ms)         :  100
Wait to Restore Time(unit 30s)     :  60
Current Command Priority       :  ----
Table 1-9 Description on the fields of the display mpls protect-switch command
PG-ID
ID of the protection group
Working LSP
Primary LSP
Working LSP Token
Primary LSP Token
State of the user plane of the primary LSP
State of the control plane of the primary LSP
Protect LSP
Secondary LSP
Protect LSP Token
Secondary LSP Token
State of the user plane of the secondary LSP
State of the control plane of the secondary LSP
Switching  Result
Protection switching results
Revertive Mode
Switch back mode: revertive or non-revertive
Protection switching delay at the step of 100ms
Switch back time specific to revertive mode at the step of 30s
Priority of the current command
1.2.3  mpls protect-switch
mpls protect-switch manual { work-lsp | protect-lsp } protect-id
View
manual work-lsp: Manually switches data flows to the secondary LSP for transmission.
manual protect-lsp: Manually switches data flows to the primary LSP for transmission.
Use the mpls protect-switch command to run a protection switching command on the specified protection group.
# Run a protection switching command on the protection group pg1.
<H3C> system-view
[H3C] mpls protect-switch manual work-lsp pg1
1.2.4  mpls protect-switch work-lsp
mpls protect-switch protect-id work-lsp w-lsp-name protect-lsp p-lsp-name [ holdoff holdofftime ] [ mode revertive ] [ wtr wtrtime ]
mpls protect-switch protect-id work-lsp w-lsp-name protect-lsp p-lsp-name [ holdoff holdofftime ] mode non-revertive
undo mpls protect-switch protect-id
View
protect-id: ID of the protection group.
w-lsp-name: Name of the primary LSP.
p-lsp-name: Name of the secondary LSP.
holdofftime: Protection switching delay at the step of 100 ms. The default value is 0 ms and the maximum value is 10s.
mode: Specifies a switch back mode (after the primary LSP recovered from a fault, data flows will switch from the secondary LSP back to the primary LSP): revertive or non-revertive. The default mode is non-revertive.
wtrtime: Switch back time specific to revertive mode at the step of 30s. By default, it is 24 (12 min).
Use the mpls protect-switch command to create a protection group.
Use the undo mpls protect-switch command to delete a protection group.
&  Note:
In a protection group, the primary and secondary LSPs must have the same FEC, but different egress labels.
# Create a protection group.
<H3C> system-view
[H3C] mpls protect-switch 1 work-lsp pe1-pe2 protect-lsp pe1-pe3 holdoff 3 mode revertive wtr 25
1.2.5  static-lsp ingress
static-lsp ingress lsp-name destination dest-addr { addr-mask | mask-length } nexthop next-hop-add } out-label out-label-value [ backup ]
undo static-lsp ingress lsp-name
View
lsp-name: Name of the LSP.
dest-addr: Destination IP address.
addr-mask: Mask.
mask-length: Mask length.
next-hop-addr: IP address of the next hop.
out-label-value: Egress label value.
backup: Configures a secondary LSP.
Use the static-lsp ingress command to configure a static LSP or a secondary static LSP.
Use the undo static-lsp ingress command to remove the configuration.
&  Note:
The secondary static LSP only takes effect after the protection group is configured. If the protection group is not specified, no entry will be generated by the secondary static LSP.
# Configure a secondary static LSP.
<H3C> system-view
[H3C-mpls] static-lsp ingress pe1-pe2 destination 3.3.3.3 32 nexthop 12.1.1.2 out-label 30 backup
1.3  MPLS LSP Ping Configuration Commands
1.3.1  debugging mpls lspc
debugging mpls lspc { all | packet | error | event }
undo debugging mpls lspc { all | packet | error | event }
View
all: Enables all types of debugging for LSPC.
packet: Enables debugging for LSPC packets.
event: Enables debugging for LSPC events.
error: Enables debugging for LSPC errors.
Use the debugging mpls lspc command to enable debugging for MPLS lspc.
# Enable all types of debugging for MPLS lspc.
<H3C> debugging mpls lspc all
1.3.2  lsp ping
ping lsp [ [ -c count | -s packet-size | -t time-out | -h ttl-value | -v | -a source-ip | -exp exp-value | -m interval | -r reply-mode ]*] ipv4 dest-address dest-mask [ ip-address ]
View
-c count: Number of Echo request packets sent.
-s packet-size: Length of the sent packet, in byte.
-t time-out: Time to wait for Echo response, in millisecond.
-h ttl-value: TTL value of the sent Echo request packet.
-v: Detailed information.
-a source-ip: Source IP address of the sent Echo request packet.
-exp exp-value: EXP value of the sent Echo request packet.
-m interval: Interval to send the next packet, in millisecond.
-r reply-mode: Response mode, in the range of 1 to 2, with 1 being no response and 2 being response with the IPv4/IPv6 UDP packet.
ipv4 dest-address dest-mask: Destination IP address and mask of LDP IPv4 LSP.
ip-address: Destination address in IP header of the MPLS Ping packet, with a prefix of 127/8.
Use the ping lsp command to receive and send Echo request and response packets over an LSP. Its functions are similar to the common ping command. The difference is that the former command is executed on an LSP.
# Configure LSP ping.
<H3C> system-view
[H3C] ping lsp –c 1000 –s 2000 –t 1000 ipv4 3.3.3.3 32 127.0.0.1
1.3.3  lsp tracert
tracert lsp [ [ -a source-ip | -t time-out | -h ttl-value | -exp exp-value | -r reply-mode ]*] ipv4 dest-address dest-mask [ ip-address ]
View
-t time-out: Time to wait Echo response packet, in millisecond.
-r reply-mode: Response mode in the range of 1 to 2, with 1 being no response and 2 being response with the IPv4/IPv6 UDP packet.
Use the tracert lsp command to run Tracert function on the LSP.
Its functions are similar to the common Tracert command. The difference is that the former command is executed on an LSP.
# Run Tracert on the LSP.
<H3C> system-view
[H3C] tracert lsp –a 1.1.1.1 –t 100 ipv4 3.3.3.3 32 127.0.0.1
