H3C S9500 Operation Manual-Release1648[v1.24]-04 IP Multicast Volume
HomeSupportSwitchesS9500 SwitchesConfigure & DeployConfiguration GuidesH3C S9500 Operation Manual-Release1648[v1.24]-04 IP Multicast Volume
00-1Cover
00-1Cover 68.99 KB
H3C S9500 Series Routing Switches
Operation Manual
Hangzhou H3C Technologies Co., Ltd.
http://www.h3c.com
Manual Version: T2-08165E-20081225-C-1.24
Product Version: S9500-CMW310-R1648
Copyright © 2007-2008, Hangzhou H3C Technologies Co., Ltd. and its licensors
All Rights Reserved
No part of this manual may be reproduced or transmitted in any form or by any means without prior written consent of Hangzhou H3C Technologies Co., Ltd.
Trademarks
H3C, Adobe Systems, Aolynk, , H3Care, , TOP G, , IRF, NetPilot, Neocean, NeoVTL, SecPro, SecPoint, SecEngine, SecPath, Comware, Secware, Storware, NQA, VVG, V2G, VnG, PSPT, XGbus, N-Bus, TiGem, InnoVision and HUASAN are trademarks of Hangzhou H3C Technologies Co., Ltd.
All other trademarks that may be mentioned in this manual are the property of their respective owners.
Notice
The information in this document is subject to change without notice. Every effort has been made in the preparation of this document to ensure accuracy of the contents, but all statements, information, and recommendations in this document do not constitute the warranty of any kind, express or implied.
Technical Support
[email protected]
http://www.h3c.com
About This Manual
Organization
H3C S9500 Series Routing Switches Configuration Manual is organized as follows:
Part
00 Product Overview
includes Obtaining the Documentation, Product Features, and Features.
01 Access Volume
includes Ethernet Port Configuration, POS Port Configuration, Link Aggregation Configuration, Port Isolation Configuration, VLAN Configuration, MAC Address Table Management Configuration, GVRP Configuration, QinQ Configuration, Ethernet Port Loopback Detection Configuration, DLDP Configuration, Ethernet OAM Configuration, Smart Link and Monitor Link Configuration, MSTP Configuration, BPDU Tunnel Configuration, HVRP Configuration, RRPP Configuration and RPR Configuration.
02 IP Services Volume
includes ARP Configuration, IP Address Configuration, VRRP Configuration, DHCP Configuration, DNS Configuration, UDP Helper Configuration, NAT Configuration, IP Performance Configuration and URPF Configuration.
03 IP Routing Volume
includes IP Routing Protocol Overview, Static Route Configuration, RIP Configuration, OSPF Configuration, ISIS Configuration, BGP Configuration, IP Route Policy Configuration, Route Capacity Configuration and Recursive Routing Configuration.
includes Multicast Overview, Common Multicast Configuration, IGMP Snooping Configuration, IGMP Configuration, PIM Configuration, Multicast VLAN Configuration, MSDP Configuration and MBGP Configuration.
05 MPLS VPN Volume
includes MPLS Configuration, MPLS VLL Configuration, MPLS VPLS Configuration, MPLS L3VPN Configuration, MPLS OAM Configuration and MPLS Hybrid Insertion Configuration.
06 QoS ACL Volume
includes QoS Configuration and ACL Configuration.
07 Security Volume
includes Protocol Port Security Configuration, 802.1X Configuration , AAA RADIUS HWTACACS Configuration ,Password Control Configuration, SSH Configuration, IDS Linkage Configuration, Portal Configuration, VBAS Configuration and Traffic Accounting Configuration.
08 System Volume
includes Command Line Interface Configuration, Login and User Interface Configuration, FTP and TFTP Configuration, HA Configuration, NQA Configuration, NetStream Configuration, NTP Configuration, RMON Configuration, SNMP Configuration, Packet Statistics Accounting Configuration, Device Management Configuration, Configuration File Management Configuration, File System Management Configuration, Cluster Management Configuration, System Maintenance and Debugging Configuration, Information Center Configuration, PoE Configuration, Clock Module Configuration, ACSEI Server Configuration and OAP Module Configuration.
09 Acronyms
Offers the acronyms used in this manual.
Conventions
The manual uses the following conventions:
I. Command conventions
Convention
Boldface
The keywords of a command line are in Boldface.
italic
Command arguments are in italic.
Items (keywords or arguments) in square brackets [ ] are optional.
{ x | y | ... }
Alternative items are grouped in braces and separated by vertical bars. One is selected.
[ x | y | ... ]
Optional alternative items are grouped in square brackets and separated by vertical bars. One or none is selected.
{ x | y | ... } *
Alternative items are grouped in braces and separated by vertical bars. A minimum of one or a maximum of all can be selected.
[ x | y | ... ] *
Optional alternative items are grouped in square brackets and separated by vertical bars. Many or none can be selected.
&<1-n>
The argument(s) before the ampersand (&) sign can be entered 1 to n times.
A line starting with the # sign is comments.
II. GUI conventions
Convention
Button names are inside angle brackets. For example, click <OK>.
Window names, menu items, data table and field names are inside square brackets. For example, pop up the [New User] window.
Multi-level menus are separated by forward slashes. For example, [File/Create/Folder].
III. Symbols
Convention
  Warning
Means reader be extremely careful. Improper operation may cause bodily injury.
  Caution
Means reader be careful. Improper operation may cause data loss or damage to equipment.
&  Note
Means a complementary description.
Related Documentation
In addition to this manual, each H3C S9500 Series Routing Switches documentation set includes the following:
Manual
H3C S9500 Series Routing Switches  Installation Manual
It introduces the installation procedure, commissioning, maintenance and monitoring of the S9500 series routing switches.
H3C S9500 Series Routing Switches  Command Manual
It includes Feature List and Command Index, Access Volume, IP Service Volume, IP Routing Volume, IP Multicast Volume, MPLS VPN Volume, QoS ACL Volume, Security Volume, and System Volume.
Obtaining Documentation
You can access the most up-to-date H3C product documentation on the World Wide Web at this URL: http://www.h3c.com.
The following are the columns from which you can obtain different categories of product documentation:
[Products & Solutions]: Provides information about products and technologies.
[Technical Support & Document > Technical Documents]: Provides several categories of product documentation, such as installation and operation.
[Technical Support & Document > Product Support > Software]: Provides the documentation released with the software version.
Documentation Feedback
We appreciate your comments.
