H3C S7500 Series Ethernet Switches Installation Manual-(V1.02)
HomeSupportSwitchesS7500 SeriesInstall & UpgradeInstallation GuidesH3C S7500 Series Ethernet Switches Installation Manual-(V1.02)
02-Chapter 2 Line Processing Units
02-Chapter 2 Line Processing Units 2.28 MB
Table of Contents
Chapter 2 Line Processing Units. 2-1
2.1 Introduction to LPUs. 2-1
2.2 LS81FT48E. 2-1
2.2.1 Technical Specifications. 2-1
2.2.2 Panel and LEDs. 2-2
2.2.3 Matching Cable. 2-3
2.3 LS81FT48F. 2-3
2.3.1 Technical Specifications. 2-3
2.3.2 Panel and LEDs. 2-4
2.3.3 Matching Cable. 2-5
2.4 LS81FP48. 2-5
2.4.1 Technical Specifications. 2-6
2.4.2 Panel and LEDs. 2-6
2.4.3 Matching Cable. 2-7
2.5 LS81GT8UE. 2-8
2.5.1 Technical Specifications. 2-8
2.5.2 Panel and LEDs. 2-9
2.5.3 Matching Cable. 2-10
2.6 LS82GT20. 2-11
2.6.1 Technical Specifications. 2-11
2.6.2 Panel and LEDs. 2-12
2.6.3 Matching Cable. 2-12
2.7 LS82GT20A. 2-13
2.7.1 Technical Specifications. 2-13
2.7.2 Panel and LEDs. 2-14
2.7.3 Matching Cable. 2-14
2.8 LS81GT48. 2-15
2.8.1 Technical Specifications. 2-15
2.8.2 Panel and LEDs. 2-16
2.8.3 Matching Cable. 2-16
2.9 LS81GT48A. 2-17
2.9.1 Technical Specifications. 2-17
2.9.2 Panel and LEDs. 2-18
2.9.3 Matching Cable. 2-19
2.10 LS81GT48B. 2-19
2.10.1 Technical Specifications. 2-19
2.10.2 Panel and LEDs. 2-20
2.10.3 Matching Cable. 2-21
2.11 LS81T12P. 2-21
2.11.1 Technical Specifications. 2-21
2.11.2 Panel and LEDs. 2-22
2.11.3 Matching Cable. 2-23
2.12 LS81T12PE. 2-25
2.12.1 Technical Specifications. 2-25
2.12.2 Panel and LEDs. 2-26
2.12.3 Matching Cable. 2-27
2.13 LS81P12T. 2-27
2.13.1 Technical Specifications. 2-27
2.13.2 Panel and LEDs. 2-28
2.13.3 Matching Cable. 2-29
2.14 LS81P12TE. 2-29
2.14.1 Technical Specifications. 2-29
2.14.2 Panel and LEDs. 2-30
2.14.3 Matching Cable. 2-31
2.15 LS81T16P. 2-31
2.15.1 Technical Specifications. 2-31
2.15.2 Panel and LEDs. 2-32
2.15.3 Matching Cable. 2-33
2.16 LS81T32P. 2-33
2.16.1 Technical Specifications. 2-33
2.16.2 Panel and LEDs. 2-35
2.16.3 Matching Cable. 2-36
2.17 LS81GP8UB. 2-36
2.17.1 Technical Specifications. 2-36
2.17.2 Panel and LEDs. 2-37
2.17.3 Matching Cable. 2-38
2.18 LS82GP20. 2-38
2.18.1 Technical Specifications. 2-38
2.18.2 Panel and LEDs. 2-39
2.18.3 Matching Cable. 2-40
2.19 LS82GP20A. 2-40
2.19.1 Technical Specifications. 2-40
2.19.2 Panel and LEDs. 2-41
2.19.3 Matching Cable. 2-42
2.20 LS81GP48. 2-42
2.20.1 Technical Specifications. 2-43
2.20.2 Panel and LEDs. 2-44
2.20.3 Matching Cable. 2-44
2.21 LS81TGX1C. 2-45
2.21.1 Technical Specifications. 2-45
2.21.2 Panel and LEDs. 2-46
2.21.3 Matching Cable. 2-47
2.22 LS81TGX2. 2-47
2.22.1 Technical Specifications. 2-47
2.22.2 Panel and LEDs. 2-48
2.22.3 Matching Cable. 2-49
2.23 LS81TGX4. 2-50
2.23.1 Technical Specifications. 2-50
2.23.2 Panel and LEDs. 2-51
2.23.3 Matching Cable. 2-52
2.24 LS81VSNP (without Port) 2-52
2.24.1 Technical Specifications. 2-52
2.24.2 Panel and LEDs. 2-53
The modular design of the S700 series provides a reasonable system architecture as well as standard, mutually independent function modules. Currently, the S7500 series provide autosensing 10/100/1000 Mbps Ethernet electrical ports, 100 Mbps Ethernet (single mode/multi-mode) optical ports, GBIC/SFP (single mode/multi-mode) optical ports, and 10GE optical ports.
The following sections introduce the specifications and performance of LPUs in detail.
2.2  LS81FT48E
Figure 2-1 LS81FT48E appearance
The LS81FT48E provides forty-eight autosensing 10/100Base-TX Ethernet ports.
Table 2-1 LS81FT48E specifications
Item
Specification
CPU
MPC8241, 200 MHz
Boot ROM
512 KB
SDRAM
128 MB
Dimensions (H x W x D)
40.1 × 376.7 × 354.5 mm (1.6 × 14.8 × 14 in.)
Maximum power consumption
35 W
Connector
RJ-45
Number of ports
48
Port speed
l      10/100 Mbps half-duplex/full-duplex
l      MDI/MDI-X autosensing
Matching cable and maximum transmission distance
Category-5 twisted pair with a maximum transmission distance of 100 m (328.1 ft)
Compliant standards
IEEE 802.3
IEEE 802.3u
IEEE 802.3ad
IEEE 802.3x
IEEE 802.1p
IEEE 802.1D
IEEE 802.1Q
IEEE 802.1X
IEEE 802.1s
IEEE 802.1w
Figure 2-2 LS81FT48E panel
(1) Silkscreen of the LPU name
(2) Captive screw
(3) LPU edge (purple)
(4) Ejector lever
(5) 10/100Base-TX Ethernet port status LED
(6) 10/100Base-TX Ethernet port
Figure 2-3 Partially amplified view of the LS81FT48E panel
Each 10/100Base-TX Ethernet port has a green LED.
Table 2-2 LED description of the LS81FT48E
LED
Status
Meaning
LINK/ACT
OFF
No link is present.
ON
A link is present.
Blinking
Data is being transmitted/received.
The 10/100Base-TX Ethernet ports use category-5 twisted pairs and RJ-45 connectors, with a maximum transmission distance of 100 m (328.1 ft).
2.3  LS81FT48F
Figure 2-4 LS81FT48F appearance
The LS81FT48F provides forty-eight autosensing 10/100Base-TX Ethernet ports. All the ports support PoE, that is, they can supply power to remote PDs through Ethernet twisted pairs.
Table 2-3 LS81FT48F specifications
Item
Specification
CPU
MPC8241, 200 MHz
Boot ROM
512 KB
SDRAM
128 MB
35 W
Connector
RJ-45
Number of ports
48
Port speed
Category-5 twisted pair, with a maximum transmission distance of 100 m (328.1 ft)
Maximum PoE distance
100 m (328.1 ft)
Maximum power each port can provide
15.4 W
Compliant standard
IEEE 802.3
IEEE 802.3u
IEEE 802.3x
IEEE 802.3ad
IEEE 802.1p
IEEE 802.1D
IEEE 802.1Q
IEEE 802.1X
IEEE 802.1s
IEEE 802.1w
IEEE 802.3af
Figure 2-5 LS81FT48F panel
(2) Captive screw
(4) Ejector lever
(6) 10/100Base-TX Ethernet port (supporting PoE)
Figure 2-6 Partially amplified view of the LS81FT48F panel
Table 2-4 LED description of the LS81FT48F
LED
Status
Meaning
LINK/ACT
OFF
No link is present.
ON
A link is present.
Blinking
2.4  LS81FP48
Figure 2-7 LS81FP48 appearance
The LS81FP48 provides forty-eight 100Base-FX-SFP ports operating in the full-duplex mode.
Table 2-5 LS81FP48 specifications
Item
Specification
CPU
MPC8241, 200 MHz
Boot ROM
512 KB
SDRAM
128 MB
60 W
Connector
LC
Number of ports
48
Port speed
100 Mbps full-duplex
SFP module
l      SFP-FE-SX-MM1310-A
l      SFP-FE-LX-SM1310-A
l      SFP-FE-LH40-SM1310
l      SFP-FE-LH80-SM1550
l      SFP-FE-LX-SM1310-BIDI
l      SFP-FE-LX-SM1550-BIDI
Compliant standard
l      IEEE 802.3
l      IEEE 802.1p
l      IEEE 802.1Q
l      IEEE 802.1D
l      IEEE 802.3x
l      IEEE 802.3ad
l      IEEE 802.1X
l      IEEE 802.1s
l      IEEE 802.1w
Figure 2-8 LS81FP48 panel
(2) Captive screw
(4) Ejector lever
(5) 100Base-FX-SFP port status LED
(6) 100Base-FX-SFP port
Figure 2-9 Partially amplified view of the LS81FP48 panel
Each 100Base-FX-SFP port has a green LED.
Table 2-6 LED description of the LS81FP48
LED
Status
Meaning
LINK/ACT
OFF
No link is present.
ON
A link is present.
Blinking
Table 2-7 Cables for 100Base-FX-SFP ports of the LS81FP48
SFP module
Central wavelength
Connector
Matching cable
Maximum transmission distance
SFP-FE-SX-MM1310-A
1,310 nm
LC
50 µm/125 µm multimode optical fiber cable
2 km (1.2 mi)
62.5 µm/125 µm multimode optical fiber cable
SFP-FE-LX-SM1310-A
1,310 nm
LC
9 µm/125 µm single mode optical fiber cable
15 km (9.3 mi)
SFP-FE-LH40-SM1310
1,310 nm
LC
40 km (24.9 mi)
SFP-FE-LH80-SM1550
1,550 nm
LC
80 km (49.7 mi)
1,550 nm (receive)/1310 nm (transmit)
LC
9µm/125µm single mode optical fiber cable
15 km (9.3 mi)
1310 (transmit)/1550 (receive)
LC
15 km (9.3 mi)
2.5  LS81GT8UE
Figure 2-10 LS81GT8UE appearance
The LS81GT8UE provides eight autosensing 10/100/1000Base-T Ethernet ports.
Table 2-8 LS81GT8UE specifications
Item
Specification
CPU
MPC850, 50 MHz
Boot ROM
512 KB
SDRAM
64 MB
11 W
Connector
RJ-45
Number of ports
8
Port speed
l      10/100/1000 Mbps half-duplex/full-duplex
Compliant standard
l      IEEE 802.3
l      IEEE 802.3u
l      IEEE 802.3ab
l      IEEE 802.3x
l      IEEE 802.1D
l      IEEE 802.1Q
l      IEEE 802.1X
l      IEEE 802.1s
l      IEEE 802.1w
&  Note:
l      The LS81GT8UE can only be used together with Salience III or Salience III Edge SRPUs.
l      If a Salience III or Salience III Edge SRPU is used, the LS81GT8UE cannot be inserted in the last LPU slot of the S7506 or the S7506R (slot 6 for the S7506 and slot 7 for the S7506R), but can be inserted in any LPU slot of the S7503.
Figure 2-11 LS81GT8UE panel
(1) Ethernet port number
(2) 10/100/1000Base-T Ethernet port status LED (LINK)
(3) 10/100/1000Base-T Ethernet  port status LED (ACT)
(4) Silkscreen of the LPU name
(5) Captive screw
(6) LPU edge (purple)
(7) Ejector lever
(8) 10/100/1000Base-T Ethernet port (Gigabit)
Figure 2-12 Partially amplified view of the LS81GT8UE panel
Each 10/100/1000Base-T Ethernet port has two LEDs.
Table 2-9 LED description of the LS81GT8UE
LED
Status
Meaning
LINK
OFF
No link is present.
ON
A link is present.
ACT
OFF
No data is being transmitted/received.
Blinking
The ports use category-5 twisted pairs and RJ-45 connectors, with a maximum transmission distance of 100 m (328.1 ft).
2.6  LS82GT20
Figure 2-13 LS82GT20 appearance
The LS82GT20 provides twenty autosensing 10/100/1000Base-T Ethernet ports.
Table 2-10 LS82GT20 specifications
Item
Specification
CPU
MPC8241, 200 MHz
Boot ROM
512 KB
SDRAM
64 MB
45 W
Connector
RJ-45
Number of ports
20
Port speed
l      1000 Mbps full-duplex
Compliant standard
l      IEEE 802.3
l      IEEE 802.3u
l      IEEE 802.3ab
l      IEEE 802.3x
l      IEEE 802.1p
l      IEEE 802.1D
l      IEEE 802.1Q
l      IEEE 802.1X
l      IEEE 802.1w
l      IEEE 802.1ad
l      IEEE 802.1s
Figure 2-14 LS82GT20 panel
(2) Captive screw
(4) Ejector lever
(5) 10/100/1000Base-T Ethernet port
(6) 10/100/1000Base-T Ethernet port status LED
Figure 2-15 Partially amplified view of the LS82GT20 panel
Each 10/100/1000Base-T Ethernet port has a LED.
Table 2-11 LED description of the LS82GT20
LED
Status
Meaning
LINK/ACT
OFF
No link is present.
ON
A link is present.
Blinking
2.7  LS82GT20A
Figure 2-16 LS82GT20A appearance
The LS82GT20A provides twenty autosensing 10/100/1000Base-T Ethernet ports.
Table 2-12 LS82GT20A specifications
Item
Specification
CPU
MPC8241, 200 MHz
Boot ROM
512 KB
SDRAM
128 MB
Dimensions (W x D)
45 W
Connector
RJ-45
Number of ports
20
Port speed
Compliant standard
l      IEEE 802.3
l      IEEE 802.3u
l      IEEE 802.3ab
l      IEEE 802.3x
l      IEEE 802.1p
l      IEEE 802.1D
l      IEEE 802.1Q
l      IEEE 802.1X
l      IEEE 802.1w
l      IEEE 802.1ad
l      IEEE 802.1s
Figure 2-17 LS82GT20A panel
(1) 10/100/1000Base-T Ethernet port
(2) Silkscreen of the LPU name
(3) Captive screw
(4) LPU edge (purple)
(5) Ejector lever
(6) Ethernet port status LED
Figure 2-18 Partially amplified view of the LS82GT20A panel
Table 2-13 LED description of the LS82GT20A
LED
Status
Meaning
LINK/ACT
OFF
No link is present.
ON
A link is present.
Blinking
2.8  LS81GT48
Figure 2-19 LS81GT48 appearance
The LS81GT48 provides forty-eight autosensing 10/100/1000Base-T Ethernet ports.
Table 2-14 LS81GT48 specifications
Item
Specification
CPU
MPC8241, 200 MHz
Boot ROM
512 KB
SDRAM
128 MB
70 W
Connector
RJ-45
Number of ports
48
Port speed
Compliant standard
l      IEEE 802.3
l      IEEE 802.3u
l      IEEE 802.3ab
l      IEEE 802.3x
l      IEEE 802.1p
l      IEEE 802.1D
l      IEEE 802.1Q
l      IEEE 802.1X
l      IEEE 802.1s
l      IEEE 802.1w
Figure 2-20 LS81GT48 panel
(2) Captive screw
(4) Ejector lever
(5) 10/100/1000Base-T Ethernet port status LED
Figure 2-21 Partially amplified view of the LS81GT48 panel
Each 10/100/1000Base-T Ethernet port has a green LED.
Table 2-15 LED description of the LS81GT48
LED
Status
Meaning
LINK/ACT
OFF
No link is present.
ON
A link is present.
Blinking
2.9  LS81GT48A
Figure 2-22 LS81GT48A appearance
The LS81GT48A provides forty-eight autosensing 10/100/1000Base-T Ethernet ports. All the ports support PoE, that is, they supply power to remote PDs through Ethernet twisted pair cables.
Table 2-16 LS81GT48A specifications
Item
Specification
CPU
MPC8241, 200 MHz
Boot ROM
512 KB
SDRAM
128 MB
70 W
Connector
RJ-45
Number of ports
48
Port speed
100 m (328.1 ft)
15.4 W
Compliant standard
l      IEEE 802.3
l      IEEE 802.3u
l      IEEE 802.3ab
l      IEEE 802.3x
l      IEEE 802.1p
l      IEEE 802.1D
l      IEEE 802.1Q
l      IEEE 802.1X
l      IEEE 802.1s
l      IEEE 802.1w
l      IEEE 802.3af
Figure 2-23 LS81GT48A panel
(2) Captive screw
(4) Ejector lever
Figure 2-24 Partially amplified view of the LS81GT48A panel
Table 2-17 LED description of the LS81GT48A
LED
Status
Meaning
LINK/ACT
OFF
No link is present.
ON
A link is present.
Blinking
The 10/100/1000Base-T Ethernet ports use category-5 twisted pairs and RJ-45 connectors, with a maximum transmission distance of 100 m (328.1 ft).
2.10  LS81GT48B
Figure 2-25 LS81GT48B appearance
The LS81GT48B adopts an XG high-speed bus. It can also serve as the SRPU of the S7502.
Table 2-18 LS81GT48B specifications
Item
Specification
CPU
MPC8245, 300 MHz
BOOT ROM
512 KB
Flash memory
32 MB
SDRAM
256 MB
40.1 x 376.7 x 364.5 mm (1.6 × 14.8 × 14 in.)
107 W
Connector
RJ-45
Number of ports
48
Port speed
l      10 Mbps half-duplex/full-duplex
l      100 Mbps half-duplex/full-duplex
l      1000 Mbps half-duplex/full-duplex
Compliant standard
l      IEEE 802.3
l      IEEE 802.3u
l      IEEE 802.3ab
l      IEEE 802.3x
l      IEEE 802.1p
l      IEEE 802.1D
l      IEEE 802.1Q
l      IEEE 802.1X
l      IEEE 802.1s
l      IEEE 802.1w
&  Note:
When using the LS81GT48B as an LPU of the S7503/S7506/S7506R, you can only use it together with a Salience III or Salience III Plus SRPU:
l      If you use the LS81GT48B together with a Salience III Plus SRPU, you can insert it into any LPU slot on the S7503/S7506/S7506R.
l      If you use the LS81GT48B together with a Salience III SRPU, you can only insert it into one of the last two LPU slots on the S7503/S7506/S7506R switch (slot 2 or 3 for the S7503, slot 5 or 6 for the S7506, and slot 6 or 7 for the S7506R).
Figure 2-26 LS81GT48B panel
(2) Captive screw
(4) Ejector lever
Figure 2-27 Partially amplified view of the LS81GT48B panel
Table 2-19 LED description of the LS81GT48B
LED
Status
Meaning
LINK/ACT
OFF
No link is present.
ON
A link is present.
Blinking
The 10/100/1000Base-T Ethernet ports use category-5 twisted pairs and RJ-45 connecters, with a maximum transmission distance of 100 m (328.1 ft).
2.11  LS81T12P
Figure 2-28 LS81T12P appearance
The LS81T12P provides twelve autosensing 10/100/1000Base-T Ethernet ports and four 1000Base-X-SFP ports operating in the full-duplex mode.
Table 2-20 LS81T12P specifications
Item
Specification
CPU
MPC8241, 200 MHz
Boot ROM
512 KB
SDRAM
128 MB
33 W
Connector
RJ-45, LC
Number of ports
16
Port speed
l      1000 Mbps full-duplex (optical/electrical)
l      10/100 Mbps half-duplex/full-duplex (electrical)
SFP modules
Refer to Table 2-22
Compliant standard
l      IEEE 802.3
l      IEEE 802.3u
l      IEEE 802.3z
l      IEEE 802.3ab
l      IEEE 802.1p
l      IEEE 802.1Q
l      IEEE 802.1D
l      IEEE 802.1X
l      IEEE 802.1s
l      IEEE 802.1w
l      IEEE 802.3x
l      IEEE 802.3ad
Figure 2-29 LS81T12P panel
(1) Port number
(3) Captive screw
(5) Ejector lever
(6) 1000Base-X-SPF port
(7) 10/100/1000Base-T Ethernet port status LED
Figure 2-30 Partially amplified view of the LS81T12P panel
The following table describes the LED.
Table 2-21 LED description of the LS81T12P
LED
Status
Meaning
LINK/ACT
OFF
No link is present.
ON
A link is present.
Blinking
I. Cables for the four 1000Base-X-SFP ports
Table 2-22 Cables for 1000Base-X-SFP ports
SFP module
Central wavelength
Connector
Matching cable
SFP-GE-SX-MM850-A
850 nm
LC
550 m (1804 ft)
275 m (902 ft)
SFP-GE-LX-SM1310-A
1,310 nm
LC
10 km (6 mi)
SFP-GE-LH40-SM1310
40 km (25 mi)
SFP-GE-LH40-SM1550
1,550 nm
LC
40 km (about 25 mi)
SFP-GE-LH70-SM1550
70 km (43 mi)
SFP-GE-LH100-SM1550
100 km (62 mi)
SFP-GE-LH70-SM1470-CW
1,470 nm
LC
70 km (43 mi)
SFP-GE-LH70-SM1490-CW
1,490 nm
LC
70 km (43 mi)
SFP-GE-LH70-SM1510-CW
1,510 nm
LC
70 km (43 mi)
SFP-GE-LH70-SM1530-CW
1,530 nm
LC
70 km (43 mi)
SFP-GE-LH70-SM1550-CW
1,550 nm
LC
70 km (43 mi)
SFP-GE-LH70-SM1570-CW
1,570 nm
LC
70 km (43 mi)
SFP-GE-LH70-SM1590-CW
1,590 nm
LC
70 km (43 mi)
SFP-GE-LH70-SM1610-CW
1,610 nm
LC
70 km (43 mi)
II. Cables for the twelve 10/100/1000Base-T Ethernet ports
2.12  LS81T12PE
Figure 2-31 LS81T12PE appearance
The LS81T12PE can serve as the SRPU of the S7502.
Table 2-23 LS81T12PE specifications
Item
Specification
CPU
MPC8245, 300 MHz
Boot ROM
512 KB
Flash memory
32 MB
SDRAM
256 MB
Number of ports
Twelve 10/100/1000Base-T Ethernet ports
Four 1000BASE-X-SFP ports
29 W
Connector
RJ-45, LC
Number of ports
16
Port speed
l      1000 Mbps full-duplex (optical port)
l      10 Mbps half-duplex/full-duplex (electrical port)
l      100 Mbps half-duplex/full-duplex (electrical port)
l      1000M full-duplex (electrical port)
SFP modules
Refer to Table 2-22
Port cable and max transmission distance
Compliant standard
l      IEEE 802.3
l      IEEE 802.3u
l      IEEE 802.3z
l      IEEE 802.3ab
l      IEEE 802.1p
l      IEEE 802.1Q
l      IEEE 802.1D
l      IEEE 802.1X
l      IEEE 802.1s
l      IEEE 802.1w
l      IEEE 802.3x
l      IEEE 802.3ad
LS81T12PE provides twelve 10/100/1000BASE-T ports and four 1000BASE-X-SFP ports, and each port has a status LED.
Figure 2-32 LS81T12PE panel
(1) Port number
(3) Captive screw
(4) LPU edge (green)
(5) Ejector lever
Figure 2-33 Partially amplified view of the LS81T12PE panel
The status LEDs on an LS81T12PE are described in the following table.
Table 2-24 LED description of the LS81T12PE
LED
Status
Meaning
LINK/ACT
OFF
No link is present.
ON
A link is present.
Blinking
Refer to section 2.11  “LS81T12P“ on page 2-21.
2.13  LS81P12T
Figure 2-34 LS81P12T appearance
The LS81P12T provides twelve 1000Base-X-SFP ports operating in the full duplex mode and four autosensing 10/100/1000 Base-T Ethernet ports.
Table 2-25 LS81P12T specifications
Item
Specification
CPU
MPC8241, 200 MHz
Boot ROM
512 KB
SDRAM
128 MB
31 W
Connector
RJ-45, LC
Number of ports
16
Port speed
l      1000 Mbps full-duplex (optical)
l      10/100/1000 Mbps half-duplex/full-duplex (electrical)
SFP modules
Refer to Table 2-22
Compliant standard
l      IEEE 802.3
l      IEEE 802.3u
l      IEEE 802.3z
l      IEEE 802.3ab
l      IEEE 802.1p
l      IEEE 802.1Q
l      IEEE 802.1D
l      IEEE 802.1X
l      IEEE 802.1s
l      IEEE 802.1w
l      IEEE 802.3x
l      IEEE 802.3ad
Figure 2-35 LS81P12T panel
(1) Port number
(3) Captive screw
(5) Ejector lever
(6) 1000Base-X-SFP port status LED
(7) 1000Base-X-SPF port
Figure 2-36 Partially amplified view of the LS81P12T panel
Table 2-26 LED description of the LS81P12T
LED
Status
Meaning
LINK/ACT
OFF
No link is present.
ON
A link is present.
Blinking
Refer to section 2.11.3  “Matching Cable” on page 2-23.
2.14  LS81P12TE
Figure 2-37 LS81P12TE appearance
The LS81P12TE can serve as the SRPU of the S7502.
Table 2-27 LS81P12TE specifications
Item
Specification
CPU
MPC8245, 300 MHz
Boot ROM
512 KB
Flash memory
32 MB
SDRAM
256 MB
Number of ports
l      Four 10/100/1000BASE-T Ethernet ports
l      Twelve 1000BASE-X-SFP ports
40 W
Port speed
l      1000 Mbps full-duplex (electrical port)
SFP modules
Refer to Table 2-22
Category-5 twisted pair cable, with a maximum transmission distance of 100 m (328.1 ft)
Compliant standard
l      IEEE 802.3
l      IEEE 802.3u
l      IEEE 802.3z
l      IEEE 802.3ab
l      IEEE 802.1p
l      IEEE 802.1Q
l      IEEE 802.1D
l      IEEE 802.1X
l      IEEE 802.1s
l      IEEE 802.1w
l      IEEE 802.3x
l      IEEE 802.3ad
The LS81P12TE provides four 10/100/1000BASE-T Ethernet ports and twelve 1000BASE-X-SFP ports and each port has a status LED.
Figure 2-38 LS81P12TE panel
(1) Port number
(3) Captive screw
(5) Ejector lever
(6) Port status LED
(7) SPF port (Gigabit)
(8) Ethernet port (Gigabit)
Figure 2-39 Partially amplified view of the LS81P12TE panel
For the description of the LED of the LS81P12TE, see Table 2-26.
Refer to section 2.11  “LS81T12P” on page 2-21.
2.15  LS81T16P
Figure 2-40 LS81T16P appearance
The LS81T16P adopts an XG high-speed bus. It can also serve as the SRPU of the S7502.
Table 2-28 LS81T16P specifications
Item
Specification
CPU
MPC8245, 300M
BOOT ROM
512 KB
Flash memory
32 MB
SDRAM
256 MB
Dimensions (W x D)
366.7 x 340 mm (14.4 x 13.4 in.)
Number of ports
l      Sixteen autosensing 10/100/1000Base-T Ethernet ports
l      Eight 1000Base-X-SFP ports
55 W
Connector
RJ-45, LC
Number of ports
24
Port speed
SFP module
Refer to Table 2-22.
Compliant standard
l      IEEE 802.3
l      IEEE 802.3u
l      IEEE 802.3z
l      IEEE 802.3ab
l      IEEE 802.1p
l      IEEE 802.1Q
l      IEEE 802.1D
l      IEEE 802.1X
l      IEEE 802.1s
l      IEEE 802.1w
l      IEEE 802.3x
l      IEEE 802.3ad
&  Note:
When using the LS81T16P as an LPU of the S7503/S7506/S7506R, you can only use it together with a Salience III or Salience III Plus SRPU.
l      If you use the LS81T16P together with a Salience III Plus SRPU, you can insert it into any LPU slot on the S7503/S7506/S7506R.
l      If you use the LS81T16P together with a Salience III SRPU, you can only insert it into one of the last two LPU slots on the S7503/S7506/S7506R (slot 2 or 3 for the S7503, slot 5 or 6 for the S7506, and slot 6 or 7 for S7506R).
Figure 2-41 LS81T16P panel
(2) Captive screw
(3) LPU edge (green)
(4) Ejector lever
(5) 1000Base-X-SPF port
Figure 2-42 Partially amplified view of the LS81T16P panel
The following table describes the LED of the LS81T16P:
Table 2-29 LED description of the LS81T16P
LED
Status
Meaning
LINK/ACT
OFF
No link is present.
ON
A link is present.
Blinking
Refer to section 2.11  “LS81T12P” on page 2-21..
2.16  LS81T32P
Figure 2-43 LS81T32P appearance
The LS81T32P adopts an XG high-speed bus. It can also serve as the SRPU of the S7502.
Table 2-30 LS81T32P specifications
Item
Specification
CPU
MPC8245, 300 MHz
BOOT ROM
512 KB
Flash memory
32 MB
SDRAM
256 MB
Number of ports
l      Thirty-two autosensing 10/100/1000Base-T Ethernet ports
l      Sixteen 1000Base-X-SFP ports
93 W
Connector
RJ-45, LC
Port speed
SFP modules
Compliant standard
l      IEEE 802.3
l      IEEE 802.3u
l      IEEE 802.3z
l      IEEE 802.3ab
l      IEEE 802.1p
l      IEEE 802.1Q
l      IEEE 802.1D
l      IEEE 802.1X
l      IEEE 802.1s
l      IEEE 802.1w
l      IEEE 802.3x
l      IEEE 802.3ad
&  Note:
When using the LS81T32P as an LPU of the S7503/S7506/S7506R switch, you can only use it together with a Salience III or Salience III Plus SRPU.
l      If you use the LS81T32P together with a Salience III Plus SRPU, you can insert it into any LPU slot on the S7503/S7506/S7506R.
l      If you use the LS81T32P together with a Salience III SRPU, you can only insert it into one of the last two LPU slots on the S7503/S7506/S7506R (slot 2 or 3 for the S7503, slot 5 or 6 for the S7506, and slot 6 or 7 for the S7506R).
Figure 2-44 LS81T32P panel
(2) Captive screw
(4) Ejector lever
(5) 1000Base-X-SFP port status LED
Figure 2-45 Partially amplified view of the LS81T32P panel
The following table describes the LED of the LS81T32P:
Table 2-31 LED state description of LS81T32P
LED
Status
Meaning
LINK/ACT
OFF
No link is present.
ON
A link is present.
Blinking
2.17  LS81GP8UB
Figure 2-46 LS81GP8UB appearance
The LS81GP8UB provides eight 1000Base-X-SFP ports operating in the full-duplex mode.
Table 2-32 LS81GP8UB specifications
Item
Specification
CPU
MPC850, 50 MHz
Boot ROM
512 KB
SDRAM
64M
9.5 W
Connector
LC, RJ-45
Number of ports
8
Port speed
SFP modules
Refer to Table 2-22
Compliant standard
l      IEEE 802.3
l      IEEE 802.3z
l      IEEE 802.1p
l      IEEE 802.1Q
l      IEEE 802.1D
l      IEEE 802.3x
l      IEEE 802.3ad
l      IEEE 802.1X
l      IEEE 802.1s
l      IEEE 802.1w
&  Note:
l      The LS81GP8UB can only be used together with a Salience III and Salience III Edge SRPU.
l      If a Salience III or Salience III Edge SRPU is used, the LS81GP8UB cannot be inserted in the last LPU slot of the S7506 or the S7506R (slot 6 for the S7506 and slot 7 for the S7506R), but can be inserted in any LPU slot of the S7503.
Figure 2-47 LS81GP8UB panel
(1) Port number
(3) Captive screw
(5) Ejector lever
(7) 1000Base-X-SFP port
Figure 2-48 Partially amplified view of the LS81GP8UB panel
The following table describes the LED of the LS81GP8UB.
Table 2-33 LED description of the LS81GP8UB
LED
Status
Meaning
LINK/ACT
OFF
No link is present.
ON
A link is present.
Blinking
Refer to Table 2-22 in section 2.11.3  "Matching Cable" on page 2-23.
2.18  LS82GP20
Figure 2-49 LS82GP20 appearance
The LS82GP20 provides twenty 1000Base-X-SFP ports operating in the full-duplex mode.
Table 2-34 LS82GP20 specifications
Item
Specification
CPU
MPC8241, 200 MHz
Boot ROM
512 KB
SDRAM
64 MB
35 W
Connector
LC
Number of ports
20
Port speed
SFP modules
Refer to Table 2-22
Compliant standard
l      IEEE 802.3
l      IEEE 802.3z
l      IEEE 802.1p
l      IEEE 802.1Q
l      IEEE 802.1D
l      IEEE 802.3x
l      IEEE 802.1X
l      IEEE 802.1w
l      IEEE 802.3ad
l      IEEE 802.1s
Figure 2-50 LS82GP20 panel
(1) Port number
(3) Captive screw
(5) Ejector lever
(7) 1000Base-X-SFP port status LED
Figure 2-51 Partially amplified view of the LS82GP20 panel
The following table describes the LED of the LS82GP20.
Table 2-35 LED description of the LS82GP20
LED
Status
Meaning
LINK/ACT
OFF
No link is present.
ON
A link is present.
Blinking
2.19  LS82GP20A
Figure 2-52 LS82GP20A appearance
The LS82GP20A provides twenty 1000Base-X-SFP ports operating in the full-duplex mode.
Table 2-36 LS82GP20A specifications
Item
Specification
CPU
MPC8241, 200 MHz
Boot ROM
512 KB
SDRAM
128 MB
35 W
Connector
LC
Number of ports
20
Port speed
SFP modules
Refer to Table 2-22
Compliant standard
l      IEEE 802.3
l      IEEE 802.3z
l      IEEE 802.1p
l      IEEE 802.1Q
l      IEEE 802.1D
l      IEEE 802.3x
l      IEEE 802.1X
l      IEEE 802.1w
l      IEEE 802.3ad
l      IEEE 802.1s
Figure 2-53 LS82GP20A panel
(1) Port number
(3) Captive screw
(5) Ejector lever
Figure 2-54 Partially amplified view of the LS82GP20A panel
The following table describes the LED of the LS82GP20A.
Table 2-37 LED description of the LS82GP20A
LED
Status
Meaning
LINK/ACT
OFF
No link is present.
ON
A link is present.
Blinking
Refer to Table 2-22 in section “Matching Cable” on page 2-23.
2.20  LS81GP48
Figure 2-55 LS81GP48 appearance
The LS81GP48 adopts an XG high-speed bus and provides forty-eight 1000Base-X-SFP ports operating in the full-duplex mode. It can also serve as the SRPU of the S7502.
Table 2-38 LS81GP48 specifications
Item
Specification
CPU
MPC8245, 300 MHz
BOOT ROM
512 KB
Flash memory
32 MB
SDRAM
256 MB
75 W
Connector
LC
Number of ports
48
Port speed
SFP modules
Compliant standard
l      IEEE 802.3
l      IEEE 802.3z
l      IEEE 802.1p
l      IEEE 802.1Q
l      IEEE 802.1D
l      IEEE 802.3x
l      IEEE 802.1X
l      IEEE 802.1w
l      IEEE 802.3ad
l      IEEE 802.1s
&  Note:
When using the LS81GP48 as an LPU of the S7503/S7506/S7506R, you can only use it together with a Salience III or Salience III Plus SRPU.
l      If you use the LS81GP48 together with a Salience III Plus SRPU, you can insert it into any LPU slot on the S7503/S7506/S7506R.
l      If you use the LS81GP48 together with a Salience III SRPU, you can only insert it into one of the last two LPU slots on the S7503/S7506/S7506R (slot 2 or 3 for the S7503, slot 5 or 6 for the S7506, and slot 6 or 7 for the S7506R).
Figure 2-56 LS81GP48 panel
(2) Captive screw
(4) Ejector lever
Figure 2-57 Partially amplified view of the LS81GP48 panel
The following table describes the LED of the LS81GP48:
Table 2-39 LED description of the LS81GP48
LED
Status
Meaning
LINK/ACT
OFF
No link is present.
ON
A link is present.
Blinking
2.21  LS81TGX1C
Figure 2-58 LS81TGX1C appearance
The LS81TGX1C provides one 10GBase-R-XENPAK port operating the full-duplex mode.
Table 2-40 LS81TGX1C specifications
Item
Specification
CPU
MPC8245, 300 MHz
Boot ROM
512 KB
SDRAM
64 MB
35 W
Connector
SC
Number of ports
1
Port speed
10 Gbps full-duplex
XENPAK modules
l      XENPAK-SX-MM850 (multimode optical fiber, 850 nm, 300 m [984 ft])
l      XENPAK-LX-SM1310 (single mode optical fiber, 1310 nm, 10 km [6.2 mi])
l      XENPAK-LH40-SM1550 (single mode optical fiber, 1550 nm, 40 km [24.9 mi])
Compliant standard
l      IEEE 802.3
l      IEEE 802.3ae
l      IEEE 802.1p
l      IEEE 802.1Q
l      IEEE 802.1D
l      IEEE 802.3x
l      IEEE 802.3ad
l      IEEE 802.1X
l      IEEE 802.1s
l      IEEE 802.1w
Figure 2-59 LS81TGX1C panel
(1) 10GBase-R-XENPAK port status LED (LINK)
(2) 10GBase-R-XENPAK port status LED (ACT)
(3) Silkscreen of the LPU
(4) Captive screw
(5) LPU edge (green)
(6) Ejector lever
(7) 10GBase-R-XENPAK port
(8) Captive screw
Figure 2-60 Partially amplified view of the LS81TGX1C panel
The following table describes the LEDs of the LS81TGX1C.
Table 2-41 LED state description of LS81TGX1C
LED
Status
Meaning
LINK
OFF
No link is present.
ON
A link is present.
ACT
OFF
Blinking
Table 2-42 Cables for the LS81TGX1C
XENPAK module
Central wavelength
Connector
Matching cable
XENPAK-SX-MM850
850 nm
SC
Multimode fiber
300 m (984 ft)
XENPAK-LX-SM1310
1310 nm
9µm/125µm single mode fiber
10 km (6 mi)
XENPAK-LH40-SM1550
1550 nm
40 km (25 mi)
2.22  LS81TGX2
Figure 2-61 LS81TGX2 appearance
The LS81TGX2 adopts an XG high-speed bus and provides two 10GBase-XFP ports operating in the full-duplex mode. It can also serve as the SRPU of the S7502.
Table 2-43 LS81TGX2 specifications
Item
Specification
CPU
MPC8245, 300 MHz
BOOT ROM
512 KB
Flash memory
32 MB
SDRAM
256 MB
38 W
Connector
LC
Number of ports
2
Port speed
10 Gbps full-duplex
XFP modules
l      XFP-SX-MM850 (850 nm multi-mode fiber with a maximum transmission distance of 300 m [984.3 ft]).
l      XFP-LX-SM1310 (1,310 nm single-mode fiber with a maximum transmission distance of 10 km [6.2 mi])
l      XFP-LH40-SM1550 (1,550 nm single-mode fiber with a maximum transmission distance of 40 km [24.9 mi])
l      XFP-LH80-SM1550(1,550 nm single-mode fiber with a maximum transmission distance of 80 km [49.7 mi])
Compliant standard
l      IEEE 802.3
l      IEEE 802.3ae
l      IEEE 802.1p
l      IEEE 802.1Q
l      IEEE 802.1D
l      IEEE 802.3x
l      IEEE 802.3ad
l      IEEE 802.1X
l      IEEE 802.1s
l      IEEE 802.1w
&  Note:
When using the LS81TGX2 as an LPU of the S7503/S7506/S7506R, you can only use it together with a Salience III or Salience III Plus SRPU.
l      If you use the LS81TGX2 together with a Salience III Plus SRPU, you can insert it into any LPU slot on the S7503/S7506/S7506R.
l      If you use the LS81TGX2 together with a Salience III SRPU, you can only insert it into one of the last two LPU slots on the S7503/S7506/S7506R (slot 2 or 3 for the S7503, slot 5 or 6 for the S7506, and slot 6 or 7 for the S7506R).
Figure 2-62 LS81TGX2 panel
(1) 10GBase-XFP port number
(2) 10GBase-XFP port status LED (LINK)
(3) 10GBase-XFP port status LED (ACT)
(5) Captive screw
(6) LPU edge (green)
(7) Ejector lever
(8) 10GBase-XFP port
Figure 2-63 Partially amplified view of the LS81TGX2 panel
The following table describes the LEDs of the LS81TGX2:
Table 2-44 LED description of the LS81TGX2
LED
LINK
OFF
No link is present.
ON
A link is present.
ACT
OFF
Blinking
Table 2-45 Cables for the LS81TGX2
XFP module
Central wavelength
Connector
Matching cable
XFP-SX-MM850
850 nm
LC
50 µm/125 µm multi-mode optical fiber
300 m (984.3 ft)
XFP-LX-SM1310
1,310 nm
9 µm/125 µm single-mode optical fiber
10 km (6.2 mi)
XFP-LH40-SM1550
1510 nm
40 km (24.9 mi)
XFP-LH80-SM1550
1510 nm
80 km (49.7 mi)
2.23  LS81TGX4
Figure 2-64 LS81TGX4 appearance
The LS81TGX4 adopts an XG high-speed bus and provides four 10GBase-XFP ports operating in the full-duplex mode. It can also serve as the SRPU of the S7502.
Table 2-46 LS81TGX4 specifications
Item
Specification
CPU
MPC8245, 300 MHz
BOOT ROM
512 KB
Flash memory
32 MB
SDRAM
256 MB
54 W
Connector
LC
Number of ports
4
Port speed
l      10 Gbps full-duplex
XFP modules
l      XFP-LX-SM1310 (1310 nm single-mode fiber with a maximum transmission distance of 10 km [6.2 mi])
l      XFP-LH40-SM1550 (1550 nm single-mode fiber with a maximum transmission distance of 40 km [24.9 mi])
l      XFP-LH80-SM1550 (1550 nm single-mode fiber with a maximum transmission distance of 80 km [49.7 mi])
Compliant standard
l      IEEE 802.3
l      IEEE 802.3ae
l      IEEE 802.1p
l      IEEE 802.1Q
l      IEEE 802.1D
l      IEEE 802.3x
l      IEEE 802.3ad
l      IEEE 802.1X
l      IEEE 802.1s
l      IEEE 802.1w
&  Note:
When using the LS81TGX4 as an LPU of the S7503/S7506/S7506R, you can only use it together with a Salience III or Salience III Plus SRPU.
l      If you use the LS81TGX4 together with a Salience III Plus SRPU, you can insert it into any LPU slot on the S7503/S7506/S7506R.
l      If you use the LS81TGX4 together with a Salience III SRPU, you can only insert it into one of the last two LPU slots on the S7503/S7506/S7506R (slot 2 or 3 for the S7503, slot 5 or 6 for the S7506, and slot 6 or 7 for the S7506R).
Figure 2-65 LS81TGX4 panel
(5) Captive screw
(7) Ejector lever
Figure 2-66 Partially amplified view of the LS81TGX4 panel
Refer to Table 2-44 in section 2.22.2  "Panel and LEDs" on page 2-48 for the LED description of the LS81TGX4.
Refer to Table 2-45 in section 2.22.3  "Matching Cable" on page 2-49.
Figure 2-67 LS81VSNP appearance
The LS81VSNP supports XG high speed bus and possesses a high-performance network processor (NP) and CPU and can cooperate with other LPUs to provide the following features:
l           Policy routing
l           Network address translation (NAT)
l           NetStream
The LS81VSNP provides no port.
Table 2-47 LS81VSNP specifications
Item
Specification
CPU
MPC750, 350 MHz
BOOT ROM
512 KB
SDRAM
256 MB
100 W
Connector
Number of ports
0
&  Note:
When using the LS81VSNP as an LPU of the S7503/S7506/S7506R, you can only use it together with a Salience III or Salience III Plus SRPU:
l      If you use the LS81VSNP together with a Salience III Plus SRPU, you can insert it into any LPU slot on the S7503/S7506/S7506R.
l      If you use the LS81VSNP together with a Salience III SRPU, you can only insert it into one of the last two LPU slots on the S7503/S7506/S7506R (slot 2 or 3 for the S7503, slot 5 or 6 for the S7506, and slot 6 or 7 for the S7506R).
l      When serving as an LPU of the S7502, the LS81VSNP can be inserted only into slot 1.
Figure 2-68 LS81VSNP panel
