H3C S7500 Series Ethernet Switches Installation Manual-(V1.02)
HomeSupportSwitchesS7500 SeriesInstall & UpgradeInstallation GuidesH3C S7500 Series Ethernet Switches Installation Manual-(V1.02)
00-1Cover
00-1Cover 47.44 KB
 Installation Manual
Hangzhou H3C Technologies Co., Ltd.
http://www.h3c.com
Manual Version: T2-08046P-20071205-C-1.02
Product Version: Release 3000/3100
Copyright © 2006-2007, Hangzhou H3C Technologies Co., Ltd.
All Rights Reserved
No part of this manual may be reproduced or transmitted in any form or by any means without prior written consent of Hangzhou H3C Technologies Co., Ltd.
Trademarks
H3C, Adobe Systems, Aolynk, , H3Care, , TOP G, , IRF, NetPilot, Neocean, NeoVTL, SecPro, SecPoint, SecEngine, SecPath, Comware, Secware, Storware, NQA, VVG, V2G, VnG, PSPT, XGbus, N-Bus, TiGem, InnoVision and HUASAN are trademarks of Hangzhou H3C Technologies Co., Ltd.
All other trademarks that may be mentioned in this manual are the property of their respective owners.
Notice
The information in this document is subject to change without notice. Every effort has been made in the preparation of this document to ensure accuracy of the contents, but all statements, information, and recommendations in this document do not constitute the warranty of any kind, express or implied.
To obtain the latest information, please access:
http://www. h3c.com
Technical Support
[email protected]
http://www. h3c.com
About This Manual
Related Documentation
In addition to this manual, each H3C S7500 Series Ethernet Switches documentation set includes the following:
Manual
H3C S7500 Series Ethernet Switches  Operation Manual
Guides the user to configure the features supported by the S7500 series.
H3C S7500 Series Ethernet Switches  Command Manual
Elaborates on the commands for configuring the S7500 series.
Organization
H3C S7500 Series Ethernet Switches  Installation Manual is organized as follows:
Chapter
1 Product Overview
Introduces the characteristics of the H3C S7500 Series Ethernet Switches.
2 Line Processing Units
Introduces LPUs of the H3C S7500 Series Ethernet Switches.
3 Installation Preparations
Introduces the preparations and precautions for the H3C S7500 Series Ethernet Switches installation.
4 Hardware Installation
Introduces the integrated equipment installation and cable connection (including connection of grounding cables, power cables, and interface cables, recommended cabling, and cable binding) of the H3C S7500 Series Ethernet Switches.
5 System Commissioning
Introduces the initial power-on startup process of H3C S7500 Series Ethernet Switches.
6 Hardware Maintenance
Introduces the installation and removal of power module, card, fan tray, power distribution box, delivered cable management bracket, memory module, and air filter of the H3C S7500 Series Ethernet Switches.
7 Software Maintenance
Introduces how to load and upgrade the software of the H3C S7500 Series Ethernet Switches.
8 Troubleshooting
Introduces how to troubleshoot the configuration system, power system, fans, and LPUs of the H3C S7500 Series Ethernet Switches.
Appendix A B68-22 Cabinet Installation
Introduces the installation of a B68-22 cabinet.
Appendix B N68 Cabinet Installation
Introduces the installation of an N68-22 cabinet.
Appendix C Lightning Protection
Introduces lightning protection of the H3C S7500 Series Ethernet Switches.
Appendix D AC Power Cables Used in Different Countries
Introduces the AC power cables used in different countries, including 10A AC power cables and 16A AC power cables.
Conventions
The manual uses the following conventions:
I. GUI conventions
Convention
Button names are inside angle brackets. For example, click <OK>.
Window names, menu items, data table and field names are inside square brackets. For example, pop up the [New User] window.
Multi-level menus are separated by forward slashes. For example, [File/Create/Folder].
II. Symbols
Convention
  Warning
Means reader be extremely careful. Improper operation may cause bodily injury.
  Caution
Means reader be careful. Improper operation may cause data loss or damage to equipment.
&  Note
Means a complementary description.
Environmental Protection
This product has been designed to comply with the requirements on environmental protection. For the proper storage, use and disposal of this product, national laws and regulations must be observed.
