H3C S3100-52P Ethernet Switch Installation Manual(V1.01)
HomeSupportSwitchesS3100 SeriesInstall & UpgradeInstallation GuidesH3C S3100-52P Ethernet Switch Installation Manual(V1.01)
00-1Cover
00-1Cover 303 KB
Installation Manual
Hangzhou H3C Technologies Co., Ltd.
http://www.h3c.com
Manual Version: T2-08048P-20070410-C-1.01
Copyright © 2006-2007, Hangzhou H3C Technologies Co., Ltd. and its licensors
All Rights Reserved
No part of this manual may be reproduced or transmitted in any form or by any means without prior written consent of Hangzhou H3C Technologies Co., Ltd.
Trademarks
H3C, , Aolynk, , H3Care, , TOP G, , IRF, NetPilot, Neocean, NeoVTL, SecPro, SecPoint, SecEngine, SecPath, Comware, Secware, Storware, NQA, VVG, V2G, VnG, PSPT, XGbus, N-Bus, TiGem, InnoVision and HUASAN are trademarks of Hangzhou H3C Technologies Co., Ltd.
All other trademarks that may be mentioned in this manual are the property of their respective owners.
Notice
The information in this document is subject to change without notice. Every effort has been made in the preparation of this document to ensure accuracy of the contents, but all statements, information, and recommendations in this document do not constitute the warranty of any kind, express or implied.
To obtain the latest information, please access:
http://www. h3c.com
Technical Support
[email protected]
http://www. h3c.com
About This Manual
Related Documentation
In addition to this manual, each H3C S3100-52P Ethernet Switch documentation set includes the following:
Manual
H3C S3100-52P Ethernet Switch Operation Manual
It is used for assisting the users in device configuration and typical applications.
H3C S3100-52P Ethernet Switch Command Manual
It is used for assisting the users in using various commands.
Organization
H3C S3100-52P Ethernet Switch Installation Manual is organized as follows:
Chapter
1 Product Overview
Introduces the characteristics and technical specifications of S3100-52P Ethernet Switches.
2 Preparing for Installation
Introduces the installation preparation and precaution of S3100-52P Ethernet Switches.
3 Installing the Switch
Introduces the procedures to install an S3100-52P Ethernet Switch, including the setup of the mainframe, cards, power supply, and cables.
4 Starting up the Switch at the Initial Boot
Introduces the booting process of an S3100-52P Ethernet Switch, including the power-on booting of the switch and the system initialization.
5 Loading Boot ROM and Host Software
Introduces the ways to load BootROM and host software for an S3100-52P Ethernet Switch.
6 Maintenance and Troubleshooting
Introduces the problems that might occur during the installation and the booting of an S3100-52P Ethernet Switch and the corresponding solutions.
Appendix Lightning Protection of the Switch
Introduces lightning protection of an S3100-52P Ethernet Switch.
Conventions
The manual uses the following conventions:
I. GUI conventions
Convention
Button names are inside angle brackets. For example, click <OK>.
Window names, menu items, data table and field names are inside square brackets. For example, pop up the [New User] window.
Multi-level menus are separated by forward slashes. For example, [File/Create/Folder].
II. Symbols
Convention
  Warning
Means reader be extremely careful. Improper operation may cause bodily injury.
  Caution
Means reader be careful. Improper operation may cause data loss or damage to equipment.
&  Note
Means a complementary description.
Environmental Protection
This product has been designed to comply with the requirements on environmental protection. For the proper storage, use and disposal of this product, national laws and regulations must be observed.
