H3C S5800 Series LSWM1WCM20 Card Manual-APW100
HomeSupportWirelessH3C LSWM1WCM20 Access Controller ModuleInstall & UpgradeCard Module ManualsH3C S5800 Series LSWM1WCM20 Card Manual-APW100
Title Size Downloads
book.pdf 239.28 KB
Table of Contents
Related Documents
book
book 239.28 KB
Access Controller Module LSWM1WCM20
1  Overview
The H3C LSWM1WCM20 access controller module is a wireless access controller (AC) product developed by Hangzhou H3C Technologies Co., Ltd. (referred to as H3C hereinafter). The LSWM1WCM20 is applicable to the H3C S5800 series Ethernet switches and can address the deployment requirements of medium-sized WLAN networks. It features moderate capacity, high reliability and rich services and provides powerful WLAN access control capability. Designed for WLAN access of enterprise networks, the LSWM1WCM20 provides the most ideal access control solutions for WLAN access of medium-sized enterprise campus networks, wireless area coverage and hot spot coverage.
2  Hardware Features of the LSWM1WCM20
(1)        Appearance
The silkscreen LSWM1WCM20 is printed at the upper left corner of the front panel, which is used to identify the module. The following figure depicts the appearance of the module.
Figure-1 Appearance of the LSWM1WCM20
(2)        Specifications
The LSWM1WCM20 can provide wireless features for the S5800 series switches. It provides one 10/100Base-TX interface for out-of-band management. The following figure depicts the front panel of the LSWM1WCM20.
Figure-2  Front panel of the LSWM1WCM20
Table1 LSWM1WCM20 specifications
Item
Specification
CPU frequency
1 GHz
CF card
128 MB
Capacity
512MB DDRII
Dimensions (H × W × D)
36.6 × 221.0 × 166.0 mm (1.44 × 8.70 × 6.54 in.)
Power consumption
15.6 W to 17.8 W
Weight
0.75 kg ( 1.65 lb)
One 10/100Base-T management Ethernet port
Interface transmission rate
10/100Mbps autosensing, full-duplex
Operating temperature
0°C to 45°C (32°F to 113°F)
Operating humidity (noncondensing)
10% to 95%
Applicable device model
S5800-60C-PWR/S5800-32F/S5800-56C/S5800-32C/S5800-32C-PWR/S5800-56C-PWR
3  Software Features of the LSWM1WCM20
Table2 Software features of the LSWM1WCM20
Item
Network interconnection
802.3 LAN protocols
ARP (gratuitous ARP)
ARP fast-reply
VLAN (port/MAC-based VLANs)
SSID/AP based VLANs
802.1p, 802.1q, 802.1X, 802.3x
Port loopback
Port broadcast storm suppression
IP application
Ping, Tracert
DHCP server, DHCP client, DHCP relay agent, DHCP snooping
DNS client
NTP
Telnet
TFTP client
FTP client, FTP server
IP routing
Static routing
Multicasting
IGMP snooping
MLD snooping
IPv6
TCPv6, UDPv6, ICMPv6
IPv6 ND
Pingv6, Tracertv6
Telnetv6
DNSv6
IPv6 PMTU
IPv6 FIB
IPv6 ACL
IPv6 static routing
WLAN
802.11
802.11, 802.11 , 802.11b, 802.11g, 802.11n, 802.11h, 802.11d, 802.11i, 802.11e, 802.11s draft
RF management
Transmission rate selection
Transmission rate auto-adjustment
Manual and automatic channel configuration; radar avoidance
Maximum transmission power configuration
Manual and automatic transmission power configuration
Country code configuration
Coverage hole correction
Wireless RF interference detection and mitigation
Roaming
Intra-AC roaming
Inter-AC roaming
Key cache fast roaming
CAPWAP
Layer 2/Layer 3 network topology between AP and AC
Automatic AC discovery by APs
AP software version upgrade through the AC
AP configuration file download from the AC
IPv4/IPv6 networks supported between AP and AC
Traffic and user number based AP load sharing
Centralized and local forwarding modes
Network security
Security authentication
MAC address authentication
802.1X authentication (EAP-TLS, EAP-TTLS, EAP-PEAP, EAP-SIM, EAP-MD5)
Portal authentication (both embedded portal server and external portal server supported)
PPPoE authentication
Wireless EAD
User profile based on QACL, bandwidth control and permitted AP/SSID
AAA
RADIUS
LDAP (portal authentication)
HWTACACS
Local authentication:
l      802.1X authentication (MD5/TLS/PEAP-MSCHAPv2)
l      Portal authentication
l      MAC address authentication
Multi-domain configuration on the authentication server
Backup authentication server
ESS based authentication server selection
SSID-to-user account binding
VLAN/ACL/User profile-to-user account binding
802.11 security and privacy
Multi-SSID support
SSID hiding
802.11i
WPA , WPA2
WEP (WEP64/WEP128)
TKIP
CCMP
WIDS/WIPS
Whitelist
Static/dynamic blacklist
Detection of and countermeasures against rogue wireless devices
Wireless attack prevention
Others
SSH V1.5/2.0
Isolation of users
User management
User-based bandwidth limit
User-based access control
User-based QoS
Reliability
N+1 redundancy
N+N redundancy
QoS
Layer-2 QoS
Layer 2-4 packet filtering and traffic classification
User-based packet filtering and traffic classification
Ethernet interface/SSID based priority
Mapping between wired priority and wireless priority
Mapping between wireless priority and CAPWAP tunnel priority
Traffic policing
CAR/LR
Flow-based bandwidth control
CAPWAP tunnel based bandwidth control
User/SSID based intelligent bandwidth control
User-based bandwidth control (AAA authorization)
Congestion management
FIFO, PQ, CQ
Wireless QoS
WMM (802.11e)
Maintainability
Network management
SNMP V1/V2c/V3
Syslog
RMON
User access management
Console port login
Telnet (VTY) login
SSH login
Web-based management
FTP login
System management
File system management
Application program backup (dual image)
Hotfix
4  Installing and Removing the LSWM1WCM20
Avoid touching any components on the module during the installation or removal process. It is recommended to wear an ESD-preventive wrist strap and ESD-preventive gloves before installation.
The LSWM1WCM20 is hot swappable. You need to install the LSWM1WCM20 in the interface card slot of an appropriate switch.
Installing the LSWM1WCM20
(1)          Face the switch’s panel where the interface card slot is located.
(2)          Choose an empty slot and remove the filler panel.
(3)          Push the access controller module into the slot along the guide rails until the positioning hole of the module is seated onto the positioning pin on the backplane.
(4)          Push the ejector levers inward to lock the access controller module in place.
(5)          Fasten the captive screws on the access controller module with a Philips screwdriver.
Figure-3 Installing the LSWM1WCM20
(2)          Loosen the captive screws on the access controller module with a Philips screwdriver until all spring pressure is released.
(3)          Hold the ejector levers of the access controller module and push them outward.
(4)          Gently pull the access controller module out of the slot along the guide rails.
After removing a module, if no new module is to be installed, install the filer panel on the slot to prevent dust and ensure normal ventilation in the switch.
5  Upgrading the LSWM1WCM20
The LSWM1WCM20 has its own Boot ROM program and application program with a Boot ROM menu different from that of the S5800 series switches. To update the application program of the LSWM1WCM20, use one of the following ways:
(1)          Local update through the Boot ROM menu
l              Use the TFTP protocol through the 10/100Base-TX Ethernet port of the LSWM1WCM20
l              Use the FTP protocol through the 10/100Base-TX Ethernet port of the LSWM1WCM20
(2)          Remote update through CLI
l              Use the FTP protocol through the Ethernet port of the switch
l              Use the TFTP protocol through the Ethernet port of the switch
For how to upgrade the LSWM1WCM20, refer to H3C Access Controller Module  Software Maintenance Manual.
6  Logging in to the LSWM1WCM20
Using the following command on a switch, you can to log in to the software system of the LSWM1WCM20 (OAP card), and the switch’s command line interface (CLI) will switch to the software system operating interface of the LSWM1WCM20. Thus, you can manage the application software of LSWM1WCM20 on the switch.
Press the shortcut key Ctrl + K to return to the CLI of the switch.
Table3 Log in to the software system of the LSWM1WCM20 from a switch
To do…
Use the command…
Remarks
mcms connect slot slot-number system system-name
Required
Available in user view.
Besides the above-mentioned OAP login method, you can log in to the LSWM1WCM20 through telent, web page, or NMS. For details, refer to the Login Volume of the H3C WX Series Access Controllers  User Manual.
7  Guidelines
l              If the host software version does not match the access controller module, contact the sales agent or the integrator for the right version.
l              For how to upgrade the host software version, refer to the related part in H3C S5800 Series Switches  Installation Manual.
l              The types and specifications of the access controller modules may vary with product versions. For the latest documentation, go to Technical Support & Document > Technical Documents on H3C's website at http://www.h3c.com.
8  Related Manuals
Manual
Provides a guide to the operation of H3C series access controller products (including access controllers, access controller modules, and the access controller engine of unified switches). It covers configurations of CLI, VLAN, system maintenance and debugging, WLAN, IPv4, IPv6, port basic configurations, multicast protocols, 802.1x, AAA, SSH, ACL, QoS, description of the acronyms used throughout the manual, and a command index.
H3C WX Series Access Controllers  Web-Based Configuration Manual
Introduces the Web-based management function of the WX series access controllers.
H3C S5800 Series Ethernet Switches  Quick Start
Briefly introduces the appearance, installation, startup, maintenance, troubleshooting and lightning protection of the H3C S5800 series Ethernet switches.
H3C S5800 Series Ethernet Switches  Installation Manual
Elaborates the appearance, installation, startup, software loading, troubleshooting, maintenance and lightning protection of the H3C S5800 series Ethernet switches.
Copyright © 2009 Hangzhou H3C Technologies Co., Ltd.
