H3C Access Controller Modules Software Upgrade Guide-5PW101
HomeSupportWirelessH3C LSWM1WCM10 Access Controller ModuleInstall & UpgradeUpgrade GuidesH3C Access Controller Modules Software Upgrade Guide-5PW101
Preface
The H3C Access Controller Modules Software Upgrade Guide describes how to upgrade various types of access controller modules through the web interface or at the command line interface (CLI).
The Appendix describes how to upgrade the software of access controller modules at the BootWare menu.
This preface includes:
·           Audience
·           Conventions
·           Obtaining documentation
·           Technical support
·           Documentation feedback
Audience
·           Network planners
·           Field technical support and servicing engineers
·           Network administrators working with the access controller modules
Conventions
This section describes the conventions used in this guide.
Command conventions
Convention
Boldface
Italic
{ x | y | ... }
[ x | y | ... ]
{ x | y | ... } *
Asterisk marked braces enclose a set of required syntax choices separated by vertical bars, from which you select at least one.
[ x | y | ... ] *
&<1-n>
GUI conventions
Convention
Boldface
Window names, button names, field names, and menu items are in Boldface. For example, the New User window appears; click OK.
Convention
Button names are inside angle brackets. For example, click <OK>.
Window names, menu items, data table and field names are inside square brackets. For example, pop up the [New User] window.
Multi-level menus are separated by forward slashes. For example, [File/Create/Folder].
Symbols
Convention
 WARNING
 CAUTION
 IMPORTANT
NOTE
 TIP
You can access the most up-to-date H3C product documentation on the World Wide Web at http://www.h3c.com.
Click the links on the top navigation bar to obtain different categories of product documentation:
[Technical Support & Documents > Technical Documents]—Provides hardware installation, software upgrading, and software feature configuration and maintenance documentation.
[Products & Solutions]—Provides information about products and technologies, as well as solutions.
[Technical Support & Documents > Software Download]—Provides the documentation released with the software version.
Technical support
[email protected]
http://www.h3c.com
We appreciate your comments.
