15-Unsupported Commands
HomeSupportSwitchesH3C S9500E Switch SeriesReference GuidesCommand ReferencesH3C S9500E Command References-Release1828P04-6W18215-Unsupported Commands
Download Book
Title Size Downloads
15-Unsupported Commands-book.pdf 107.59 KB
The commands listed in this chapter are available but not valid. Do not use these commands.
aaa nas-id profile
undo aaa nas-id profile profile-name
View
acsei client close
acsei client close client-id
View
ACSEI Server view
authorization-attribute user-profile
authorization-attribute user-profile profile-name
undo authorization-attribute user-profile
View
ISP domain view
cfd dm one-way
cfd dm one-way service-instance instance-id mep mep-id { target-mac mac-address | target-mep target-mep-id } [ number number ]
View
cfd dm two-way
cfd dm two-way service-instance instance-id mep mep-id { target-mac mac-address | target-mep target-mep-id } [ number number ]
View
cfd slm
cfd slm service-instance instance-id mep mep-id { target-mac mac-address | target-mep target-mep-id } [ number number ]
View
display cfd dm one-way history
display cfd dm one-way history [ service-instance instance-id [ mep mep-id ] ] [ | { begin | exclude | include } regular-expression ]
View
display issu negotiated
display issu negotiated [ | { begin | exclude | include } regular-expression ]
View
display mpls ldp cr-lsp
display mpls ldp cr-lsp [ lspid lsr-id lsp-id ] [ | { begin | exclude | include } regular-expression ] [ | { begin | exclude | include } regular-expression ]
View
display rpr statistics
display rpr statistics { dmac | smac } [ mac-address ] [ { rpr | rpr-bridge } interface-number ] [ | { begin | exclude | include } regular-expression ]
View
dns spoofing
dns spoofing ip-address
undo dns spoofing
View
dot1p-priority (IGMP-snooping view)
dot1p-priority priority-number
undo dot1p-priority
View
IGMP-snooping view
dot1p-priority (MLD-snooping view)
undo dot1p-priority
View
MLD-snooping view
dot1x multicast-trigger
undo dot1x multicast-trigger
View
Ethernet interface view
flag j1
flag j1 ignore
undo flag j1 ignore
View
POS interface view, RPRPOS interface view
idle-cut enable
idle-cut enable minute
undo idle-cut enable
View
ISP domain view
igmp-snooping dot1p-priority
igmp-snooping dot1p-priority priority-number
undo igmp-snooping dot1p-priority
View
VLAN view
ip policy-based-route
ip policy-based-route policy-name
undo ip policy-based-route
View
Tunnel interface view
ipv6 policy-based-route
ipv6 policy-based-route policy-name
undo ipv6 policy-based-route
View
link-delay enable trap updown
undo link-delay enable trap updown
View
POS interface view
View
mac-learn-style
mac-learn-style { qualify | unqualify }
View
VSI view
mac-move enable
mac-move enable
undo mac-move enable
View
VSI view
mld-snooping dot1p-priority
mld-snooping dot1p-priority priority-number
undo mld-snooping dot1p-priority
View
VLAN view
mpls te auto-bandwidth
mpls te auto-bandwidth { adjustment | collect-bw } [ frequency seconds ] [ max-bw max-bandwidth | min-bw min-bandwidth ] *
undo mpls te auto-bandwidth
View
mpls te timer auto-bandwidth
mpls te timer auto-bandwidth [ seconds ]
undo mpls te timer auto-bandwidth
View
MPLS view
multicast-domain holddown-time
multicast-domain holddown-time interval
undo multicast-domain holddown-time
View
VPN instance view
nas-id bind vlan
nas-id nas-identifier bind vlan vlan-id
undo nas-id nas-identifier bind vlan vlan-id
View
NAS ID profile view
oam errored-symbol period
oam errored-symbol period period-value
undo oam errored-symbol period
View
oam errored-symbol threshold
oam errored-symbol threshold threshold-value
undo oam errored-symbol threshold
View
peer ignore-originatorid (BGP/BGP-VPN instance view)
peer { group-name | ip-address } ignore-originatorid
undo peer { group-name | ip-address } ignore-originatorid
View
IPv6 BGP-VPN instance view
peer ttl-security hops (BGP/BGP-VPN instance view)
peer { group-name | ip-address } ttl-security hops hop-count
undo peer { group-name | ip-address } ttl-security hops
View
BGP view, BGP-VPN instance view
peer ttl-security hops (IPv6 address family view)
peer { group-name | ipv6-address } ttl-security hops hop-count
undo peer { group-name | ipv6-address } ttl-security hops
View
portal nas-id profile
portal nas-id-profile profile-name
undo portal nas-id-profile
View
Interface view
portal redirect-url
portal redirect-url url-string wait-time period
View
primap color-map-dp
primap color-map-dp
undo primap color-map-dp
View
Traffic behavior view
primap pre-defined dscp-dscp
undo primap pre-defined dscp-dscp
View
qos car
qos car { inbound | outbound } name car-name
undo qos car { inbound | outbound }
View
L2VPN peer view
reset cfd dm one-way history
reset cfd dm one-way history [ service-instance instance-id [ mep mep-id ] ]
View
reset mpls te auto-bandwidth adjustment timers
View
service
Standalone mode:
service slot slot-number
undo service slot
IRF mode:
service chassis chassis-number slot slot-number
undo service chassis
View
Tunnel view
service modem-callback
undo service modem-callback
View
snmp-agent trap enable bfd
undo snmp-agent trap enable bfd
View
tcp path-mtu-discovery
tcp path-mtu-discovery [ aging minutes | no-aging ]
undo tcp path-mtu-discovery
View
te-set-subtlv
te-set-subtlv { bw-constraint value | lo-multiplier value | unreserved-bw-sub-pool value } *
undo te-set-subtlv { bw-constraint | lo-multiplier | unreserved-bw-sub-pool } *
View
IS-IS view
tunnel discard ipv4-compatible-packet
undo tunnel discard ipv4-compatible-packet
View
tunnel vpn-instance
tunnel vpn-instance vpn-instance-name
undo tunnel vpn-instance
View
vrrp dot1q
vrrp dot1q vid vlan-id [ secondary-dot1q secondary-vlan-id ]
undo vrrp dot1q
View
Interface view
xml
xml
View
