03-Interface Configuration Guide
HomeSupportSwitchesH3C S7500X Switch SeriesConfigure & DeployConfiguration GuidesH3C S7500X Switch Series Configuration Guides-Release7536P05-6W10003-Interface Configuration Guide
Download Book
Title Size Downloads
03-Interface Configuration Guide-book.pdf 240.86 KB
Preface
This configuration guide covers the configuration of various interfaces.
·     Audience.
·     Conventions
·     Obtaining documentation
·     Technical support
·     Documentation feedback
Audience
·     Network planners.
·     Network administrators working with the routers.
Conventions
Command conventions
Convention
Boldface
Italic
{ x | y | ... }
[ x | y | ... ]
{ x | y | ... } *
[ x | y | ... ] *
&<1-n>
GUI conventions
Convention
Boldface
Multi-level menus are separated by angle brackets. For example, File>Create>Folder.
Symbols
Convention
WARNINGWARNING!
Analertthatcallsattentiontoimportantinformationthatifnotunderstoodorfollowedcanresultinpersonalinjury.
CAUTIONCAUTION:
IMPORTANTIMPORTANT:
Analertthatcallsattentiontoessentialinformation.
Analertthatcontainsadditionalorsupplementaryinformation.
TIP TIP:
Network topology icons
Convention
Represents an access point.
Wireless terminator unit.
Wireless terminator.
Represents a security product, such as a firewall, UTM, multiservice security gateway, or loadbalancing device.
Represents a security module, such as a firewall, loadbalancing, NetStream, SSL VPN, IPS, or ACG module.
To access the most up-to-date H3Cproduct documentation, go to the H3C website at
http://www.h3c.com.hk
To obtain information about installation, configuration, and maintenance, click
http://www.h3c.com.hk/Technical_Documents
To obtain software version information such as release notes, click
http://www.h3c.com.hk/Software_Download
Technical support
[email protected]
You can e-mail your comments about product documentation [email protected].
We appreciate your comments.
