00-About the S7500E-XS Configuration Guides
HomeSupportSwitchesH3C S7500E-XS Switch SeriesConfigure & DeployConfiguration GuidesH3C S7500E-XS Switch Series Configuration Guides-Release7178-6W10000-About the S7500E-XS Configuration Guides
Table of Contents
Related Documents
book(chm)
book(chm) 18.55 MB
About the H3C S7500E-XS configuration guides
The H3C S7500E-XS configuration guides describe the software features for the H3C S7500E-XS Switch Series, and guide you through the software configuration procedures. These configuration guides also provide configuration examples to help you apply the software features to different network scenarios.
Configuration guide
Content
Fundamentals Configuration Guide
Describes how to use the command line interface of the switch, log in to and set up the switch, and use the basic management functions. This guide includes:
·     CLI
·     RBAC
·     Login management
·     FTP and TFTP
·     File system management
·     Configuration file management
·     Software upgrade
·     ISSU
·     Automatic configuration
·     Device management
·     Tcl
·     Management with Boot ROM
·     Python
·     License
Virtual Technologies Configuration Guide
Describes the H3C proprietary Intelligent Resilient Framework (IRF) technology, which provides data center class availability and scalability. IRF creates a fabric from multiple switches. The switches that form the IRF fabric work in 1:N redundancy and appear as one unit in the network. IRF improves management efficiency and streamlines network topologies. It is suitable for highly reliable enterprise networks and data centers.
Interface Configuration Guide
Covers the configuration of various interfaces. This guide includes:
·     Bulk interface configuration
·     Ethernet interface
·     Loopback, null, and inloopback interface
Layer 2—LAN Switching Configuration Guide
Covers Layer 2 technologies and features used on a LAN switched network, such as VLAN technology, port isolation, and spanning tree. You can use these features to divide broadcast domains, remove Layer 2 loops, isolate users within a VLAN and so on. This guide includes:
·     MAC address table
·     Ethernet link aggregation
·     Port isolation
·     Spanning tree
·     Loop detection
·     VLAN
·     MVRP
·     QinQ
·     VLAN mapping
·     LLDP
·     Service loopback group
Layer 3—IP Services Configuration Guide
Describes how to configure ARP, IP addressing, IP performance optimization, IP forwarding basics, IPv6 basics, DHCP, DNS, UDP helper, DHCPv6, tunneling, and GRE. This guide includes:
·     ARP
·     IP addressing
·     DHCP
·     DNS
·     IP forwarding basics
·     Fast forwarding
·     Adjacency table
·     IRDP
·     IP performance optimization
·     UDP Helper
·     IPv6 basics
·     DHCPv6
·     IPv6 fast forwarding
·     Tunneling
·     GRE
Layer 3—IP Routing Configuration Guide
Covers the routing technologies for IPv4 and IPv6 networks of different sizes, route filtering. This guide includes:
·     Basic IP routing
·     Static routing
·     RIP
·     OSPF
·     IS-IS
·     BGP
·     Policy-based routing
·     IPv6 static routing
·     RIPng
·     OSPFv3
·     IPv6 IS-IS
·     IPv6 policy-based routing
·     Routing policy
IP Multicast Configuration Guide
Covers Layer 3 IPv4 multicast protocols (IGMP, PIM, MSDP, and multicast VPN), Layer 3 IPv6 multicast protocols (MLD and IPv6 PIM), Layer 2 IPv4 multicast protocols (IGMP snooping, PIM snooping, and multicast VLAN), and Layer 2 IPv6 multicast protocols (MLD snooping, IPv6 PIM snooping, and IPv6 multicast VLAN). This guide includes:
·     Multicast overview
·     IGMP snooping
·     PIM snooping
·     Multicast VLAN
·     Multicast routing and forwarding
·     IGMP
·     PIM
·     MSDP
·     Multicast VPN
·     MLD snooping
·     IPv6 PIM snooping
·     IPv6 multicast VLAN
·     IPv6 multicast routing and forwarding
·     MLD
·     IPv6 PIM
MPLS Configuration Guide
Describes fundamentals and configurations of MPLS and extended MPLS functions. This configuration guide includes:
·     Basic MPLS
·     Static LSP
·     LDP
·     MPLS TE
·     Static CRLSP
·     RSVP
·     Tunnel policy
·     MPLS L3VPN
·     MPLS L2VPN
·     VPLS
·     MCE
ACL and QoS Configuration Guide
Describes how to classify traffic with ACLs, and allocate network resources and manage congestions with QoS technologies to improve network performance and network use efficiency. You can use ACLs to help other function modules (such as QoS and IP routing) classify or filter traffic. This configuration guide includes:
·     ACL
·     QoS
·     Time range
·     Data buffer
Security Configuration Guide
Covers security features. The major security features available on the switch include: identity authentication, secure management, and attack protection. This guide includes:
·     AAA
·     802.1X
·     MAC authentication
·     Portal
·     Port security
·     Password control
·     Public key management
·     SSL
·     PKI
·     IPsec
·     SSH
·     IP source guard
·     ARP attack protection
·     uRPF
·     FIPS
·     Attack detection and prevention
·     MACsec
·     MFF
·     ND attack defense
·     Keychain
High Availability Configuration Guide
Describes high availability technologies and features available on the switch for failure detection and failover. Failure detection technologies focus on fault detection and isolation. Failover technologies focus on network recovery. This guide includes:
·     High Availability Overview
·     Ethernet OAM
·     CFD
·     DLDP
·     RRPP
·     Smart Link
·     Monitor Link
·     VRRP
·     BFD
·     Track
·     Process placement
Network Management and Monitoring Configuration Guide
Describes features that help you manage and monitor your network, for example, manage system events, and test network connectivity. This guide includes:
·     System maintenance and debugging
·     NQA
·     NTP
·     SNMP
·     NETCONF
·     RMON
·     EAA
·     Process monitoring and maintenance
·     sFlow
·     Mirroring
·     Information center
·     GOLD
·     Packet capture
FCoE Configuration Guide
Describes the application scenarios, fundamentals, and configuration of FCoE.
TRILL Configuration Guide
Describes TRILL fundamentals and configuration. TRansparent Interconnection of Lots of Links (TRILL) is suitable for large flat Layer 2 networks in data centers.
EVB Configuration Guide
Describes the application scenarios, fundamentals, and configuration of EVB.
EVI Configuration Guide
Describes how to use the H3C MAC-in-IP technology Ethernet Virtual Interconnect (EVI) to provide Layer 2 connectivity between distant Layer 2 network sites across an IP routed network. EVI enables dynamic allocation and management of resources and transparent migration of virtual machines between network sites.
OpenFlow Configuration Guide
Describes the application scenarios, fundamentals, and configuration of OpenFlow.
VXLAN Configuration Guide
Describes VXLAN fundamentals and configuration. Virtual eXtensible LAN (VXLAN) is a MAC-in-UDP technology that provides Layer 2 connectivity between distant network sites across an IP network.
