Title | Size | Downloads |
LSQM1MPU06B0 Card Manual-6PW101-book.pdf | 75.64 KB |
1 Card identifier
The card identifier LSQM1MPU06B0 is at the upper right of the front panel..
2 Specifications
Table 1 Card specifications
Item |
Specifications |
Flash |
1 GB |
BootROM |
8 MB |
NVRAM |
1 MB |
SDRAM (DDR3) |
8 GB |
Card size (H × W × D) |
40 × 264 × 318 mm (1.57 × 10.39 × 12.52 in) |
Power consumption |
40 W to 78 W |
Ports |
· 1 console port · 1 USB console port · 4 network management ports: 2 RJ-45 ports and 2 SFP fiber ports · 1 RS485 port · 1 primary USB port |
Port speed |
· Console port: 9600 bps to 115200 bps (default: 9600 bps) · USB console port: ≤ 115200 bps (default: 9600 bps) · network management ports ( RJ-45 ): 10/100/1000 Mbps, half/full duplex · network management ports (SFP ): 1000Mbps · RS485 port: ≤ 115200 bps (default: 9600 bps) |
Transmission medium and max transmission distance |
· Console port: 15 m (49.21 ft) over asynchronous EIA/TIA-232 cables · USB console port: 10 m (32.81 ft) over USB-AB cables · network management ports ( RJ-45 ): 100 m (328.1 ft) over Category 5 or higher twisted pair cables · network management ports (SFP ): see Table 3 · RS485 port: RJ-45 cables |
Applicable hardware platforms |
S7506E-X |
Applicable host software versions |
Version 7168 and later |
NOTE: · The OFFLINE button on the MPU is intended for debugging and locating failures by technical supports. H3C recommends not using it without authorization. · H3C recommends not using a USB extender cable to connect the USB port. |
IMPORTANT: · H3C recommends that you use only H3C-certified USB disks to ensure hardware reliability and compatibility. · Before installing the card, you must remove the protection cover from the card to ensure correct installation. |
The 10/100/1000BASE-T copper port uses an RJ-45 connector.
Figure 1 RJ-45 connector
Table 2 RJ-45 GE connector pinout
Pin |
10BASE-T/100BASE-TX/1000BASE-T |
Signal |
Function |
1 |
MX_0+ |
Transmits and receives data. |
2 |
MX_0- |
3 |
MX_1+ |
4 |
MX_2+ |
5 |
MX_2- |
6 |
MX_1- |
7 |
MX_3+ |
8 |
MX_3- |
Table 3shows the supported GE SFP fiber modules.
Table 3 GE SFP fiber module specifications
Module |
Central wavelength |
Connector type |
Cable specifications |
Maximum transmission distance |
SFP-GE-SX-MM850-A |
850 nm |
LC |
50/125 μm multi-mode optical fiber |
550 m (0.34 miles) |
850 nm |
LC |
62.5/125 μm multi-mode optical fiber |
275 m (0.17 miles) |
SFP-GE-SX-MM850-D |
850 nm |
LC |
850 nm |
LC |
SFP-GE-LX-SM1310-A |
1310 nm |
LC |
9/125 μm single-mode optical fiber |
10 km (6.21 miles) |
1310 nm |
LC |
550 m (1804.46 ft) |
1310 nm |
LC |
SFP-GE-LX-SM1310-D |
1310 nm |
LC |
1310 nm |
LC |
1310 nm |
LC |
SFP-GE-LH40-SM1310 |
1310 nm |
LC |
40 km (24.86 miles) |
SFP-GE-LH40-SM1310-D |
1310nm |
LC |
SFP-GE-LH40-SM1550 |
1550 nm |
LC |
SFP-GE-LH80-SM1550 |
1550 nm |
LC |
70 km (43.50 miles) |
SFP-GE-LH80-SM1550-D |
1550nm |
LC |
SFP-GE-LH100-SM1550 |
1550 nm |
LC |
100 km (62.14 miles) |
SFP-GE-LX-SM1310-BIDI |
RX: 1490 nm TX: 1310 nm |
LC |
SFP-GE-LX-SM1490-BIDI |
RX: 1310 nm TX: 1490 nm |
LC |
NOTE: · BIDI modules use different central wavelengths in transmit and receive directions, in order to implement bidirectional transmission of optical signals over the same fiber. · The BIDI modules must be used in pairs. For example, if you install the SFP-GE-LX-SM1310-BIDI in the local port, you must install the SFP-GE-LX-SM1490-BIDI in the peer port. |
3 Obtaining documentation
For module installation, see H3C S7500E-X Switch Series Installation Guide.
To access the most up-to-date H3C product documentation, go to
http://www.h3c.com.hk/Technical_Documents
For software upgrade, see the release notes for the device.
To access the release notes, go to
http://www.h3c.com.hk/Software_Download
Copyright © 2015-2017 New H3C Technologies Co ., Ltd.
