H3C S7500 LS82GP20A Card Manual(V1.01)
HomeSupportSwitchesH3C S7500 Switch SeriesInstall & UpgradeCard Module ManualsH3C S7500 LS82GP20A Card Manual(V1.01)
Download Book
20端口10/100/1000Base-T千兆以太网业务板-LS82GT20A
BOM: 3123A06A
单板标识
前面板右上角标有丝印:LS82GT20A,用来标识该单板。
单板简介
表-1 LS82GT20A属性
属性
LS82GT20A
接口连接器类型
RJ-45
接口数量
20
接口传输速率
10/100 Mbps/全双工;1000 Mbps全双工
可选用线缆及最大传输距离
5类双绞线,传输距离100m
单板适用的机型
S7502/S7503/S7506/S7506R以太网交换机
单板适用的主机软件版本
Release 3000系列/Release 3100系列
注意事项
l           如主机软件版本不匹配,可以联系该设备的销售商或集成商获取相应的主机软件版本。
l           单板安装说明及版本的加载方法请参见《H3C S7500系列以太网交换机  安装手册》和《H3C S7502以太网交换机  安装手册》相关章节。
l           单板种类或规格可能随产品版本的变更而改变,请从公司网站http://www.h3c.com.cn主页上的“文档中心”获取最新资料。
杭州华三通信技术有限公司
20-Port 10/100/1000Base-T GE Card-LS82GT20A
Card Identifier
The silkscreen LS82GT20A is printed at the upper right corner of the front panel, and is used to identify the card.
Specifications
Table1 LS82GT20A specifications
Item
LS82GT20A
Connector
RJ-45
Port quantity
20
Transmission rate
10/100 Mbps half/full duplex, 1000 Mbps full duplex
Cable
Category-5 twisted pair
Maximum transmission distance
100 meters (328 ft)
Applied to
S7502/S7503/S7506/S7506R Ethernet  Switch
Host software version
Release 3000 Series/Release 3100 Series
Note
l           If the host software version does not match the one applicable to the card, contact the vendor or the integrator for the right version.
l           For the introduction of card installation and host software upgrade, see the related part in H3C S7500 Series Ethernet Switches Installation Manual and H3C S7502 Ethernet Switch Installation Manual
l           As board types or specifications might change with product versions, you may need to obtain the latest documents from  Technical Support & Document link on H3C website http://www.h3c.com.
Hangzhou H3C Technologies Co., Ltd
