Title | Size | Downloads |
04 Layer 3 - IP Services Configuration Guide-book.pdf | 3.2 MB |
Preface
This configuration guide describes the IP services fundamentals and configuration procedures for the H3C S6800 switch series.
· Audience.
· Conventions.
· About the H3C S6800 documentation set.
Audience
· Network planners.
· Network administrators working with the S6800 switch series.
Conventions
This section describes the conventions used in the documentation.
Port numbering in examples
The port numbers in the documentation are for illustration only and might be unavailable on your device.
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
Asterisk marked braces enclose a set of required syntax choices separated by vertical bars, from which you select at least one. |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Window names, button names, field names, and menu items are in Boldface. For example, the New User window appears; click OK. |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Wireless terminator unit. |
Wireless terminator. |
Represents a security card, such as a firewall, load balancing, NetStream, SSL VPN, IPS, or ACG card. |
The H3C S6800 documentation set includes the following categories of documents:
Category |
Documents |
Purposes |
Hardware specifications and installation |
Compliance and safety manual CE DOC |
Provides regulatory information and the safety instructions that must be followed during installation. |
Installation quick start |
Provides basic installation instructions. |
Installation guide |
Provides a complete guide to hardware installation and hardware specifications. |
Fan assemblies installation manual |
Describes the appearance, specifications, and installation and removal of hot-swappable fan assemblies. |
Power modules user manual |
Describes the appearance, specifications, and installation and removal of hot-swappable power modules. |
Pluggable transceiver modules installation guide |
Guides you through installing SFP/SFP+/QSFP+ transceiver modules. |
Pluggable modules manual |
Describes the hot-swappable modules available for the H3C switches, their external views, and specifications. |
Software configuration |
Configuration guides |
Describe software features and configuration procedures. |
Command references |
Provide a quick reference to all available commands. |
Operations and maintenance |
MIB Companion |
Describes the MIBs for the software release. |
Release notes |
Provide information about the product release, including the version history, hardware and software compatibility matrix, version upgrade information, technical support information, and software upgrading. |
Obtaining documentation
Access the most up-to-date H3C product documentation on the World Wide Web at http://www.h3c.com.
Click the following links to obtain different categories of product documentation:
[Technical Documents]—Provides hardware installation, software upgrading, and software feature configuration and maintenance documentation.
[Products & Solutions]—Provides information about products and technologies, as well as solutions.
[Software Download]—Provides the documentation released with the software version.
Technical support
Documentation feedback
We appreciate your comments.
