Title | Size | Downloads |
01-Fundamentals Command Reference-book.pdf | 729.82 KB |
Preface
This command reference describes commands for fundamental device configuration and management, including:
· Use the command line interface (CLI), emergency shell, and Tcl.
· Log in to your switch.
· Configure RBAC, FTP, and TFTP.
· Manage the file system and configuration files.
· Perform basic device management.
· Upgrade software.
· Audience.
Audience
· Network planners.
· Network administrators working with the S5130-EI switch series.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Wireless terminator unit. |
Wireless terminator. |
Documentation feedback
We appreciate your comments.
