08 Security Configuration Guide
HomeSupportSwitchesH3C S5120 Switch SeriesConfigure & DeployConfiguration GuidesH3C S5120-HI Configuration Guides-Release 52xx-6W10108 Security Configuration Guide
Download Book
Title Size Downloads
08 Security Configuration Guide-book.pdf 3.16 MB
Preface
The H3C S5120-HI documentation set includes 11 configuration guides, which describe the software features for the H3C S5120-HI Switch Series, and guide you through the software configuration procedures. These configuration guides also provide configuration examples to help you apply software features to different network scenarios.
The Security Configuration Guide describes security fundamentals and configuration. It covers the authentication features (including AAA, 802.1X, MAC authentication, portal authentication, and so on) and attack protection features (including IP source guard, ARP attack protection, and so on).
This preface includes:
·     Audience
·     Added and modified features
·     Conventions
·     About the H3C S5120-HI documentation set
·     Obtaining documentation
·     Technical support
·     Documentation feedback
Audience
·     Network planners
·     Field technical support and servicing engineers
·     Network administrators working with the S5120-HI series
This documentation set is for Release 52xx. The following describes the feature changes between releases:
·     Release 5206 has the following feature changes over Release 5203:
Configuration guide
AAA
Added feature: Specifying multiple secondary HWTACACS servers
MAC authentication
Added feature: Enabling MAC authentication multi-VLAN mode
IP source guard
Added feature: 802.1X-based dynamic IPv4 source guard binding entries.
Added feature: ARP Detection logging function.
·     Release 5203 has the following feature changes over Release 5101:
Configuration guide
AAA
Added features:
·     Setting a DSCP value for an ISP domain.
·     Setting the DSCP value for RADIUS protocol packets.
·     Configuring status detection for RADIUS authentication/authorization servers
·     RADIUS/HWTACACS authentication, authorization, and accounting support ciphertext shared key configuration.
·     Setting ciphertext shared keys for secure RADIUS communication.
Modified feature: Configuring a password for the local user.
Removed feature: Setting the password display mode for all local users.
802.1X
Added features:
·     Configuring 802.1X critical VLAN.
·     Specifying supported domain name delimiters.
·     Configuring a port to send EAPOL frames untagged.
·     Setting the maximum number of authentication request attempts.
·     Configuring an 802.1X VLAN group.
EAD fast deployment
N/A
MAC authentication
Added features:
·     Configuring a MAC authentication critical VLAN.
·     Configuring MAC authentication delay.
Portal
N/A
Triple authentication
N/A
Port security
N/A
User profile
N/A
Password control
Modified features: Clearing all users from the password control blacklist.
HABP
N/A
Public Key
N/A
PKI
Added feature: Setting a ciphertext password for certificate revocation.
IPsec
IPsec is a newly added feature.
SSH2.0
Added features:
·     Configuring the service type as SCP for SSH users.
·     Configuring the device as an SCP client.
·     Setting the DSCP value for IPv4 or IPv6 protocol packets sent by the SSH server.
·     Setting the DSCP value for IPv4 or IPv6 protocol packets sent by the Stelnet client.
·     Setting the DSCP value for IPv4 or IPv6 protocol packets sent by the SFTP client.
SSL
N/A
TCP attack protection
N/A
IP source guard
N/A
Added feature: Configuring a user validity check rule.
ND attack defense
N/A
SAVI
Added feature: Setting the deletion delay time for SAVI.
Black list
N/A
FIPS
FIPS is a newly added feature.
Conventions
This section describes the conventions used in this documentation set.
Command conventions
Convention
Boldface
Italic
{ x | y | ... }
[ x | y | ... ]
{ x | y | ... } *
Asterisk marked braces enclose a set of required syntax choices separated by vertical bars, from which you select at least one.
[ x | y | ... ] *
&<1-n>
GUI conventions
Convention
Boldface
Window names, button names, field names, and menu items are in Boldface. For example, the New User window appears; click OK.
Convention
Button names are inside angle brackets. For example, click <OK>.
Window names, menu items, data table and field names are inside square brackets. For example, pop up the [New User] window.
Multi-level menus are separated by forward slashes. For example, [File/Create/Folder].
Symbols
Convention
WARNING WARNING
CAUTION CAUTION
IMPORTANT IMPORTANT
NOTE
TIP TIP
Network topology icons
Port numbering in examples
The port numbers in this document are for illustration only and might be unavailable on your device.
The H3C S5120-HI documentation set includes:
Category
Documents
Purposes
Product description and specifications
Marketing brochure
Describe product specifications and benefits.
Technology white papers
Provide an in-depth description of software features and technologies.
Hardware specifications and installation
Compliance and safety manual
CE DOCs
Provide regulatory information and the safety instructions that must be followed during installation.
Installation quick start
Guides you through initial installation and setup procedures to help you quickly set up your device.
Installation guide
Provides a complete guide to switch installation and specifications.
LSPM1FAN and LSPM1FANB Installation Manual
Describes the appearances, specifications, installation, and removal of the pluggable fan modules available for the products.
PSR150-A [ PSR150-D ] Power Modules User Manual
Describe the specifications, installation, and replacement of hot swappable 150W power modules.
RPS Ordering Information for H3C Low-End Ethernet Switches
Helps you order RPSs for switches that can work with an RPS.
User manuals for RPSs
Describe the specifications, installation, and replacement of RPSs.
User manuals for interface cards
Describe the specifications, installation, and replacement of expansion interface cards.
H3C Low End Series Ethernet Switches Pluggable Modules Manual
Describes the specifications of pluggable transceiver modules.
Pluggable SFP[SFP+][XFP] Transceiver Modules Installation Guide
Describe the installation, and replacement of SFP/SFP+/XFP transceiver modules.
Software configuration
Configuration guides
Describe software features and configuration procedures.
Command references
Provide a quick reference to all available commands.
Operations and maintenance
Release notes
Provide information about the product release, including the version history, hardware and software compatibility matrix, version upgrade information, technical support information, and software upgrading.
You can access the most up-to-date H3C product documentation on the World Wide Web at http://www.h3c.com.
Click the links on the top navigation bar to obtain different categories of product documentation:
[Technical Support & Documents > Technical Documents] – Provides hardware installation, software upgrading, and software feature configuration and maintenance documentation.
[Products & Solutions] Provides information about products and technologies, as well as solutions.
[Technical Support & Documents > Software Download] – Provides the documentation released with the software version.
Technical support
[email protected]
http://www.h3c.com
We appreciate your comments.
