H3C S3100 Series Ethernet Switches Command Manual-Release 22XX Series(V1.00)
HomeSupportSwitchesH3C S3100 Switch SeriesReference GuidesCommand ReferencesH3C S3100 Series Ethernet Switches Command Manual-Release 22XX Series(V1.00)
book
book 1.43 MB
Preface
Download the entire book or click on the links to the left for one chapter at a time.
H3C S3100 Series Ethernet Switches Command Manual-Release 22XX Series describes the commands available for the H3C S3100 Series Ethernet Switches.
This preface includes:
l          Audience
l          Organization
l          Software Version
l          Conventions
l          About the H3C S3100 Documentation Set
l          Obtaining Documentation
l          Documentation Feedback
Audience
l          Network planners
l          Field technical support and servicing engineers
l          Network administrators working with the S3100 series
Organization
H3C S3100 Series Ethernet Switches Command Reference-Release 22XX Series is organized as follows:
Part
01-CLI Commands
CLI configuration commands
02-Login Commands
Ethernet switch login commands
User control commands
03-Configuration File Management Commands
Configuration file management commands
04-VLAN Commands
VLAN configuration commands
Port-based VLAN configuration commands
MAC Address-Based VLAN Configuration Commands(applicable only to the S3100-EI series)
Protocol-based VLAN configuration commands(applicable only to the S3100-EI series)
05-Static Route Commands
Static route configuration commands
06-IP Address-IP Performance Commands
IP address configuration commands
IP performance configuration commands
07-Voice VLAN Commands
Voice VLAN commands(applicable only to the S3100-EI series)
08-GVRP Commands
GARP commands
GVRP commands
09-Port Basic Configuration Commands
Port basic configuration commands
10-Port Aggregation Commands
Port aggregation configuration commands
11-Port Isolation Commands
Port isolation configuration commands
12-Port Security-Port Binding Commands
Port security commands
Port binding commands (applicable only to the S3100-EI series)
13-DLDP Commands
DLDP configuration commands (applicable only to the S3100-EI series)
14-MAC Address Table Management Commands
MAC address table configuration commands
15-MSTP Commands
MSTP configuration commands
16-Multicast Commands
IGMP snooping configuration commands
MLD snooping configuration commands (applicable only to the S3100-EI series)
IPv6 multicast VLAN configuration commands (applicable only to the S3100-EI series)
Multicast user control policy configuration commands (applicable only to the S3100-EI series)
Common multicast configuration commands
17-802.1x-System Guard Commands
802.1x configuration commands
Quick EAD deployment configuration commands
HABP configuration commands
System-guard configuration commands
18-AAA Commands
AAA configuration commands
RADIUS configuration commands
HWTACACS configuration commands
EAD configuration commands
19-MAC Address Authentication Commands
MAC address authentication basic function configuration commands
MAC address authentication enhanced function configuration commands
20-Web Authentication Commands
Web authentication configuration commands
21-ARP Commands
ARP configuration commands
22-DHCP Commands
DHCP server configuration commands (applicable only to the S3100-EI series)
DHCP snooping configuration commands
DHCP packet rate limit configuration commands (applicable only to the S3100-EI series)
DHCP/BOOTP client configuration commands
23-ACL Commands
ACL configuration commands
24-QoS-QoS Profile Commands
QoS configuration commands
QoS profile configuration commands
25-Mirroring Commands
Mirroring commands
26-Stack-Cluster Commands
Stack function configuration commands
NDP configuration commands
NTDP configuration commands
Cluster configuration commands
Enhanced cluster feature configuration commands
27-PoE-PoE Profile Commands
PoE configuration commands
PoE profile configuration commands
28-SNMP-RMON Commands
SNMP configuration commands
RMON configuration commands
29-NTP Commands
NTP configuration commands
30-SSH Commands
SSH configuration commands
31-File System Management Commands
File system configuration commands
File attribute configuration commands
Configuration file backup and recovery commands
32-FTP-SFTP-TFTP Commands
FTP server/client configuration commands
SFTP server/client configuration commands
TFTP configuration commands
33-Information Center Commands
Information center configuration commands
34-System Maintenance and Debugging Commands
Basic system configuration and debugging commands
Network connectivity test commands
Device management commands
Scheduled task configuration commands
35-VLAN-VPN Commands
VLAN-VPN (or QinQ) configuration commands
Selective QinQ configuration commands (applicable only to the S3100-EI series)
BPDU tunnel configuration commands (applicable only to the S3100-EI series)
36-VLAN Mapping Commands
One-to-one VLAN mapping configuration commands (applicable only to the S3100-EI series)
Many-to-one VLAN mapping configuration commands (applicable only to the S3100-EI series)
37-HWPing Commands
HWPing client commands
HWPing server commands
38-IPv6 Management Commands
Basic IPv6 configuration commands
IPv6 application configuration commands
39-DNS Commands
Domain name resolution commands
40-Smart Link-Monitor Link Commands
Smart link configuration commands (applicable only to the S3100-EI series)
Monitor link configuration commands (applicable only to the S3100-EI series)
41-ARP and IP Attack Defense Commands
ARP and IP attack defense configuration commands
42-LLDP Commands
LLDP configuration commands
43-PKI Commands
PKI configuration commands
44-SSL Commands
SSL configuration commands
45-HTTPS Commands
HTTPS configuration commands
46-Ethernet OAM Commands
Ethernet OAM configuration commands (applicable only to the S3100-EI series)
47-CFD Commands
CFD configuration commands (applicable only to the S3100-EI series)
Software Version
H3C S3100 Series Ethernet Switches Operation Manual-Release 22XX Series and H3C S3100 Series Ethernet Switches Command Manual-Release 22XX Series are for the software version Release 22XX Series of the S3100-SI series and S3100-EI series switches.
Compared with Release 21XX Series, some new commands are added in Release 22XX Series. For more information, see Table -1.
Table -1 Added commands
Software version
Added commands compared with the earlier version Release 2108P04
Part
Release 2211P06
mac-address-mapping(applicable only to the S3100-EI series)
mac-authentication timer offline-detect offline-detect-valueIn the Ethernet port view
web-authentication free-user ip ip-address mac mac-address (applicable only to the S3100-EI series)
web-authentication move-mode { auto | secure (applicable only to the S3100-EI series)
web-authentication web-proxy port port-number (applicable only to the S3100-EI series)
Release 2211P02
Multicast user control policy commands (applicable only to the S3100-EI series)
dot1x unicast-trigger (applicable only to the S3100-EI series)
dot1x auth-fail vlan authfail-vlan-id (applicable only to the S3100-EI series)
mac-authentication auth-fail vlan authfail-vlan-id (applicable only to the S3100-EI series)
web-authentication auth-fail vlan authfail-vlan-id (applicable only to the S3100-EI series)
web-authentication select method extended (applicable only to the S3100-EI series)
cluster-local-user
cluster-snmp-agent community
cluster-snmp-agent group v3
cluster-snmp-agent mib-view included
cluster-snmp-agent usm-user v3
vlan-mapping n-to-1
dhcp-snooping information ignore-vlanmapping
dhcp-snooping ipv6 information enable
dhcp-snooping ipv6 information option { 18 | 37 }
dhcp-snooping ipv6 information remote-id { ipv4-address ipv4-address | ipv6-address ipv6-address | string string | sysname }
Ethernet OAM commands (applicable only to the S3100-EI series)
CFD commands (applicable only to the S3100-EI series)
47-CFD Commands
Release 2209
display mac-vlan
04-VLAN Commands
display mac-vlan interface
mac-vlan enable
mac-vlan mac-address
voice vlan qos
speed auto
storm-constrain
storm-constrain control
storm-constrain enable
storm-constrain interval
port-security guest-vlan vlan-id
port-security timer guest-vlan-reauth interval
port-security timer autolearn age
igmp-snooping nonflooding-enable
MLD commands (applicable only to the S3100-EI series)
IPv6 multicast VLAN commands (applicable only to the S3100-EI series)
dot1x mandatory-domain
accounting start-mode { with-ip | without-ip }
18-AAA Commands
User type-based server commands, including accounting lan-access, accounting login, authentication lan-access, authentication login, authorization login, scheme lan-access, scheme login, and state secondary
Add commands  (applicable only to the S3100-EI series) : web-authentication customize, web-authentication cut connection, web-authentication enable, web-authentication free-ip, web-authentication free-user, web-authentication max-connection, web-authentication protocol, web-authentication select method, web-authentication timer idle-cut, web-authentication timer max-online, web-authentication web-server, display web-authentication configuration, display web-authentication connection
DHCP Server commands
22-DHCP Commands
reset dhcp-snooping [ ip-address ]
rule (for IPv6 ACLs) (applicable only to the S3100-EI series)
23-ACL Commands
traffic-remark-vlanid
command-alias enable
command-alias mapping
display command-alias
display job
job
port auto-power-down
time at
time delay
view
Add commands: datafill, description, display hwping statistics, sendpacket passroute, ttl, filesize, history-record enable, history keep-time, statistics, statistics keep-time, test-time begin, hwping-agent max-requests, hwping-agent clear, and adv-factor
37-HWPing Commands
ND snooping commands (applicable only to the S3100-EI series)
ND detection commands (applicable only to the S3100-EI series)
DHCPv6 snooping commands (applicable only to the S3100-EI series)
IPv6 filtering commands (applicable only to the S3100-EI series)
ARP packet filtering based on gateway’s address commands (applicable only to the S3100-EI series)
Configuring the maximum number of dynamic ARP entries a VLAN interface can learn commands (applicable only to the S3100-EI series)
ARP/IP attack defense based on 802.1x commands (applicable only to the S3100-EI series)
LLDP commands
42-LLDP Commands
PKI commands
43-PKI Commands
SSL commands
44-SSL Commands
HTTPS commands
45-HTTPS Commands
Compared with Release 21XX Series, some commands are extended in Release 22XX Series. For more information, see Table -2.
Table -2 Extended commands
Software version
Extended commands
Part
Release 2211P06
Release 2211P02
broadcast-suppression { ratio | bps max-bps | pps max-pps }
unknown-multicast drop enable [ pon-ignore ]
Release 2209
am user-bind mac-addr mac-address { ip-addr ip-address | ipv6 ipv6-address } [ interface interface-type interface-number ] (applicable only to the S3100-EI series)
am user-bind [ mac-addr mac-address ] [ ip-addr ip-address | ipv6 ipv6-address ] (applicable only to the S3100-EI series)
display am user-bind ipv6 [ interface interface-type interface-number | ipv6-address | mac-address mac-address | unit unit-id ] (applicable only to the S3100-EI series)
cut connection { all | access-type { dot1x | mac-authentication } | domain isp-name | interface interface-type interface-number | ip ip-address | ipv6 ipv6-address | mac mac-address | radius-scheme radius-scheme-name | vlan vlan-id | ucibindex ucib-index | user-name user-name }
18-AAA Commands
display connection [ access-type { dot1x | mac-authentication } | domain isp-name | interface interface-type interface-number | ip ip-address | ipv6 ipv6-address | mac mac-address | radius-scheme radius-scheme-name | hwtacacs-scheme hwtacacs-scheme-name | vlan vlan-id | ucibindex ucib-index | user-name user-name ]
nas-ip ipv6 ipv6-address
primary accounting { ip-address | ipv6 ipv6-address } [ port-number ] [ key string ]
primary authentication { ip-address | ipv6 ipv6-address } [ port-number ] [ key string ]
radius nas-ip ipv6 ipv6-address
secondary accounting { ip-address | ipv6 ipv6-address } [ port-number ] [ key string ]
secondary authentication { ip-address | ipv6 ipv6-address } [ port-number ] [ key string ]
state secondary { accounting | authentication } { ip-address | ipv6 ipv6-address } { active | block }
snmp-agent target-host trap address udp-domain { ip-address | ipv6 ipv6-address } [ udp-port port-number ] params securityname security-string [ v1 | v2c | v3 [authentication | privacy ] ]
Conventions
This section describes the conventions used in this documentation set.
Command conventions
Convention
Boldface
italic
{ x | y | ... }
[ x | y | ... ]
{ x | y | ... } *
Asterisk marked braces enclose a set of required syntax choices separated by vertical bars, from which you select at least one.
[ x | y | ... ] *
Asterisk marked square brackets enclose optional syntax choices separated by vertical bars, from which you may select multiple choices or none.
&<1-n>
GUI conventions
Convention
Boldface
Window names, button names, field names, and menu items are in Boldface. For example, the New User window appears; click OK.
Symbols
Convention
Means reader be extremely careful. Improper operation may cause bodily injury.
Means reader be careful. Improper operation may cause data loss or damage to equipment.
Means an action or information that needs special attention to ensure successful configuration or good performance.
Means a complementary description.
Means techniques helpful for you to make configuration with ease.
The H3C S3100 documentation set includes:
Category
Documents
Purposes
Product description and specifications
l      S3100-EI series switches marketing brochure
l      S3100-SI series switches marketing brochure
Describe product specifications and benefits.
H3C Low End Series Ethernet Switches Pluggable Modules Manual
Describes the types, appearance, and specifications of pluggable modules.
RPS user manuals
Describe the RPS power supply appearance, functions, and specifications.
RPS Ordering Information for H3C Low-End Ethernet Switches
Describe the switch models that can use RPS power supply modules and the RPS power cable specifications.
Hardware specifications and installation
Compliance and Safety Manual
Provides regulatory information and the safety instructions that must be followed during installation.
Installation guide
Provides a complete guide to hardware installation and hardware specifications.
H3C Pluggable SFP[SFP+][XFP] Transceiver Modules Installation Guide
Guides you through installing SFP/SFP+/XFP transceiver modules.
Software configuration
Operation manuals
Describe software features and configuration procedures.
Command references
Provide a quick reference to all available commands.
H3C Low-End Ethernet Switches Configuration Example
H3C Low-End Ethernet Switches Configuration Guide
Describe typical network scenarios and provide configuration examples and instructions.
Operations and maintenance
H3C Series Ethernet Switches Login Password Recovery Manual
Describes the method of recovering or changing the login password if the password is lost.
Release notes
Describe product version information (including hardware and software compatibility matrix, software compatibility, feature updates, and technical information) and software upgrade methods.
You can access the most up-to-date H3C product documentation on the World Wide Web at http://www.h3c.com.
Click the links on the top navigation bar to obtain different categories of product documentation:
[Technical Support & Documents > Technical Documents] – Provides hardware installation, software feature configuration and maintenance documentation.
[Products & Solutions] – Provides information about products and technologies.
[Technical Support & Documents > Software Download] – Provides the documentation released with the software version.
We appreciate your comments.
