- H3C Low-End Ethernet Switches Configuration Guide(V1.01)
- H3C Low-End Ethernet Switches Configuration Examples(V1.04)
- H3C S3100 Series Ethernet Switches Installation Manual-(V1.06)
- H3C S3100 Series Ethernet Switches Quick Start(V1.08)
- H3C S3100-52P Ethernet Switch Operation Manual-Release 1500(V1.02)
- H3C S3100-52P Ethernet Switch Installation Manual(V1.01)
Preface
Download the entire book or click on the links to the left for one chapter at a time.
H3C S3100 Series Ethernet Switches Command Manual-Release 22XX Series describes the commands available for the H3C S3100 Series Ethernet Switches.
This preface includes:
l Audience
l About the H3C S3100 Documentation Set
Audience
l Network planners
l Field technical support and servicing engineers
l Network administrators working with the S3100 series
Organization
H3C S3100 Series Ethernet Switches Command Reference-Release 22XX Series is organized as follows:
Part | Description |
01-CLI Commands | CLI configuration commands |
Ethernet switch login commands User control commands | |
03-Configuration File Management Commands | Configuration file management commands |
04-VLAN Commands | VLAN configuration commands Port-based VLAN configuration commands MAC Address-Based VLAN Configuration Commands(applicable only to the S3100-EI series) Protocol-based VLAN configuration commands(applicable only to the S3100-EI series) |
Static route configuration commands | |
06-IP Address-IP Performance Commands | IP address configuration commands |
07-Voice VLAN Commands | Voice VLAN commands(applicable only to the S3100-EI series) |
08-GVRP Commands | GARP commands |
09-Port Basic Configuration Commands | |
10-Port Aggregation Commands | Port aggregation configuration commands |
11-Port Isolation Commands | Port isolation configuration commands |
12-Port Security-Port Binding Commands | Port security commands Port binding commands (applicable only to the S3100-EI series) |
13-DLDP Commands | DLDP configuration commands (applicable only to the S3100-EI series) |
14-MAC Address Table Management Commands | |
15-MSTP Commands | MSTP configuration commands |
16-Multicast Commands | IGMP snooping configuration commands MLD snooping configuration commands (applicable only to the S3100-EI series) IPv6 multicast VLAN configuration commands (applicable only to the S3100-EI series) Multicast user control policy configuration commands (applicable only to the S3100-EI series) Common multicast configuration commands |
17-802.1x-System Guard Commands | 802.1x configuration commands Quick EAD deployment configuration commands HABP configuration commands System-guard configuration commands |
18-AAA Commands | AAA configuration commands RADIUS configuration commands HWTACACS configuration commands EAD configuration commands |
19-MAC Address Authentication Commands | MAC address authentication basic function configuration commands MAC address authentication enhanced function configuration commands |
20-Web Authentication Commands | Web authentication configuration commands |
21-ARP Commands | |
22-DHCP Commands | DHCP server configuration commands (applicable only to the S3100-EI series) DHCP snooping configuration commands DHCP packet rate limit configuration commands (applicable only to the S3100-EI series) |
23-ACL Commands | ACL configuration commands |
24-QoS-QoS Profile Commands | QoS configuration commands QoS profile configuration commands |
25-Mirroring Commands | Mirroring commands |
26-Stack-Cluster Commands | Stack function configuration commands NDP configuration commands NTDP configuration commands Cluster configuration commands Enhanced cluster feature configuration commands |
27-PoE-PoE Profile Commands | PoE configuration commands |
28-SNMP-RMON Commands | SNMP configuration commands RMON configuration commands |
29-NTP Commands | NTP configuration commands |
30-SSH Commands | SSH configuration commands |
31-File System Management Commands | File system configuration commands File attribute configuration commands |
32-FTP-SFTP-TFTP Commands | FTP server/client configuration commands SFTP server/client configuration commands TFTP configuration commands |
33-Information Center Commands | Information center configuration commands |
34-System Maintenance and Debugging Commands | Basic system configuration and debugging commands Network connectivity test commands Device management commands |
35-VLAN-VPN Commands | VLAN-VPN (or QinQ) configuration commands Selective QinQ configuration commands (applicable only to the S3100-EI series) BPDU tunnel configuration commands (applicable only to the S3100-EI series) |
36-VLAN Mapping Commands | One-to-one VLAN mapping configuration commands (applicable only to the S3100-EI series) Many-to-one VLAN mapping configuration commands (applicable only to the S3100-EI series) |
37-HWPing Commands | HWPing client commands HWPing server commands |
38-IPv6 Management Commands | Basic IPv6 configuration commands |
39-DNS Commands | Domain name resolution commands |
40-Smart Link-Monitor Link Commands | Smart link configuration commands (applicable only to the S3100-EI series) Monitor link configuration commands (applicable only to the S3100-EI series) |
41-ARP and IP Attack Defense Commands | |
42-LLDP Commands | LLDP configuration commands |
43-PKI Commands | PKI configuration commands |
44-SSL Commands | SSL configuration commands |
45-HTTPS Commands | HTTPS configuration commands |
46-Ethernet OAM Commands | Ethernet OAM configuration commands (applicable only to the S3100-EI series) |
47-CFD Commands | CFD configuration commands (applicable only to the S3100-EI series) |
Software Version
H3C S3100 Series Ethernet Switches Operation Manual-Release 22XX Series and H3C S3100 Series Ethernet Switches Command Manual-Release 22XX Series are for the software version Release 22XX Series of the S3100-SI series and S3100-EI series switches.
Compared with Release 21XX Series, some new commands are added in Release 22XX Series. For more information, see Table -1.
Table -1 Added commands
Software version | Added commands compared with the earlier version Release 2108P04 | Part |
Release 2211P06 | mac-address-mapping(applicable only to the S3100-EI series) | |
mac-authentication timer offline-detect offline-detect-value(In the Ethernet port view) | 19-MAC Address Authentication Commands | |
web-authentication free-user ip ip-address mac mac-address (applicable only to the S3100-EI series) | 20-Web Authentication Commands | |
web-authentication move-mode { auto | secure } (applicable only to the S3100-EI series) | ||
web-authentication web-proxy port port-number (applicable only to the S3100-EI series) | ||
Release 2211P02 | Multicast user control policy commands (applicable only to the S3100-EI series) | 16-Multicast Commands |
dot1x unicast-trigger (applicable only to the S3100-EI series) | 17-802.1x-System Guard Commands | |
dot1x auth-fail vlan authfail-vlan-id (applicable only to the S3100-EI series) | ||
mac-authentication auth-fail vlan authfail-vlan-id (applicable only to the S3100-EI series) | 19-MAC Address Authentication Commands | |
web-authentication auth-fail vlan authfail-vlan-id (applicable only to the S3100-EI series) | 20-Web Authentication Commands | |
web-authentication select method extended (applicable only to the S3100-EI series) | ||
cluster-local-user | 26-Stack-Cluster Commands | |
cluster-snmp-agent community | ||
cluster-snmp-agent group v3 | ||
cluster-snmp-agent mib-view included | ||
cluster-snmp-agent usm-user v3 | ||
vlan-mapping n-to-1 | 36-VLAN Mapping Commands | |
dhcp-snooping information ignore-vlanmapping | ||
dhcp-snooping ipv6 information enable | 38-IPv6 Management Commands | |
dhcp-snooping ipv6 information option { 18 | 37 } | ||
dhcp-snooping ipv6 information remote-id { ipv4-address ipv4-address | ipv6-address ipv6-address | string string | sysname } | ||
Ethernet OAM commands (applicable only to the S3100-EI series) | 46-Ethernet OAM Commands | |
CFD commands (applicable only to the S3100-EI series) | 47-CFD Commands | |
Release 2209 | 04-VLAN Commands | |
voice vlan qos | 07-Voice VLAN Commands | |
speed auto | 09-Port Basic Configuration Commands | |
storm-constrain | ||
port-security guest-vlan vlan-id | 12-Port Security-Port Binding Commands | |
port-security timer guest-vlan-reauth interval | ||
port-security timer autolearn age | ||
igmp-snooping nonflooding-enable | 16-Multicast Commands | |
MLD commands (applicable only to the S3100-EI series) | ||
IPv6 multicast VLAN commands (applicable only to the S3100-EI series) | ||
dot1x mandatory-domain | 17-802.1x-System Guard Commands | |
accounting start-mode { with-ip | without-ip } | 18-AAA Commands | |
User type-based server commands, including accounting lan-access, accounting login, authentication lan-access, authentication login, authorization login, scheme lan-access, scheme login, and state secondary | ||
Add commands (applicable only to the S3100-EI series) : web-authentication customize, web-authentication cut connection, web-authentication enable, web-authentication free-ip, web-authentication free-user, web-authentication max-connection, web-authentication protocol, web-authentication select method, web-authentication timer idle-cut, web-authentication timer max-online, web-authentication web-server, display web-authentication configuration, display web-authentication connection | 20-Web Authentication Commands | |
DHCP Server commands | 22-DHCP Commands | |
reset dhcp-snooping [ ip-address ] | ||
rule (for IPv6 ACLs) (applicable only to the S3100-EI series) | 23-ACL Commands | |
24-QoS-QoS Profile Commands | ||
command-alias enable | 34-System Maintenance and Debugging Commands | |
command-alias mapping | ||
display command-alias | ||
display job | ||
job | ||
port auto-power-down | ||
time at | ||
time delay | ||
view | ||
Add commands: datafill, description, display hwping statistics, sendpacket passroute, ttl, filesize, history-record enable, history keep-time, statistics, statistics keep-time, test-time begin, hwping-agent max-requests, hwping-agent clear, and adv-factor | 37-HWPing Commands | |
ND snooping commands (applicable only to the S3100-EI series) | 38-IPv6 Management Commands | |
ND detection commands (applicable only to the S3100-EI series) | ||
DHCPv6 snooping commands (applicable only to the S3100-EI series) | ||
IPv6 filtering commands (applicable only to the S3100-EI series) | ||
ARP packet filtering based on gateway’s address commands (applicable only to the S3100-EI series) | 41-ARP and IP Attack Defense Commands | |
Configuring the maximum number of dynamic ARP entries a VLAN interface can learn commands (applicable only to the S3100-EI series) | ||
ARP/IP attack defense based on 802.1x commands (applicable only to the S3100-EI series) | ||
LLDP commands | 42-LLDP Commands | |
PKI commands | 43-PKI Commands | |
SSL commands | 44-SSL Commands | |
HTTPS commands | 45-HTTPS Commands |
Compared with Release 21XX Series, some commands are extended in Release 22XX Series. For more information, see Table -2.
Software version | Extended commands | Part |
Release 2211P06 | mac-authentication timer offline-detect offline-detect-value | 19-MAC Address Authentication Commands |
Release 2211P02 | broadcast-suppression { ratio | bps max-bps | pps max-pps } | 09-Port Basic Configuration Commands |
unknown-multicast drop enable [ pon-ignore ] | 16-Multicast Commands | |
Release 2209 | am user-bind mac-addr mac-address { ip-addr ip-address | ipv6 ipv6-address } [ interface interface-type interface-number ] (applicable only to the S3100-EI series) | 12-Port Security-Port Binding Commands |
am user-bind [ mac-addr mac-address ] [ ip-addr ip-address | ipv6 ipv6-address ] (applicable only to the S3100-EI series) | ||
display am user-bind ipv6 [ interface interface-type interface-number | ipv6-address | mac-address mac-address | unit unit-id ] (applicable only to the S3100-EI series) | ||
cut connection { all | access-type { dot1x | mac-authentication } | domain isp-name | interface interface-type interface-number | ip ip-address | ipv6 ipv6-address | mac mac-address | radius-scheme radius-scheme-name | vlan vlan-id | ucibindex ucib-index | user-name user-name } | 18-AAA Commands | |
display connection [ access-type { dot1x | mac-authentication } | domain isp-name | interface interface-type interface-number | ip ip-address | ipv6 ipv6-address | mac mac-address | radius-scheme radius-scheme-name | hwtacacs-scheme hwtacacs-scheme-name | vlan vlan-id | ucibindex ucib-index | user-name user-name ] | ||
nas-ip ipv6 ipv6-address | ||
primary accounting { ip-address | ipv6 ipv6-address } [ port-number ] [ key string ] | ||
primary authentication { ip-address | ipv6 ipv6-address } [ port-number ] [ key string ] | ||
radius nas-ip ipv6 ipv6-address | ||
secondary accounting { ip-address | ipv6 ipv6-address } [ port-number ] [ key string ] | ||
secondary authentication { ip-address | ipv6 ipv6-address } [ port-number ] [ key string ] | ||
state secondary { accounting | authentication } { ip-address | ipv6 ipv6-address } { active | block } | ||
snmp-agent target-host trap address udp-domain { ip-address | ipv6 ipv6-address } [ udp-port port-number ] params securityname security-string [ v1 | v2c | v3 [authentication | privacy ] ] | 28-SNMP-RMON Commands |
Conventions
This section describes the conventions used in this documentation set.
Command conventions
Convention | Description |
Boldface | Bold text represents commands and keywords that you enter literally as shown. |
italic | Italic text represents arguments that you replace with actual values. |
[ ] | Square brackets enclose syntax choices (keywords or arguments) that are optional. |
{ x | y | ... } | Braces enclose a set of required syntax choices separated by vertical bars, from which you select one. |
[ x | y | ... ] | Square brackets enclose a set of optional syntax choices separated by vertical bars, from which you select one or none. |
{ x | y | ... } * | Asterisk marked braces enclose a set of required syntax choices separated by vertical bars, from which you select at least one. |
[ x | y | ... ] * | Asterisk marked square brackets enclose optional syntax choices separated by vertical bars, from which you may select multiple choices or none. |
&<1-n> | The argument or keyword and argument combination before the ampersand (&) sign can be entered 1 to n times. |
# | A line that starts with a pound (#) sign is comments. |
GUI conventions
Boldface | Window names, button names, field names, and menu items are in Boldface. For example, the New User window appears; click OK. |
> | Multi-level menus are separated by angle brackets. For example, File > Create > Folder. |
Symbols
Means reader be extremely careful. Improper operation may cause bodily injury. | |
Means reader be careful. Improper operation may cause data loss or damage to equipment. | |
Means an action or information that needs special attention to ensure successful configuration or good performance. | |
Means a complementary description. | |
Means techniques helpful for you to make configuration with ease. |
The H3C S3100 documentation set includes:
Documents | Purposes | |
l S3100-EI series switches marketing brochure l S3100-SI series switches marketing brochure | Describe product specifications and benefits. | |
H3C Low End Series Ethernet Switches Pluggable Modules Manual | Describes the types, appearance, and specifications of pluggable modules. | |
RPS user manuals | Describe the RPS power supply appearance, functions, and specifications. | |
RPS Ordering Information for H3C Low-End Ethernet Switches | Describe the switch models that can use RPS power supply modules and the RPS power cable specifications. | |
Hardware specifications and installation | Compliance and Safety Manual | Provides regulatory information and the safety instructions that must be followed during installation. |
Installation guide | Provides a complete guide to hardware installation and hardware specifications. | |
H3C Pluggable SFP[SFP+][XFP] Transceiver Modules Installation Guide | Guides you through installing SFP/SFP+/XFP transceiver modules. | |
Software configuration | Operation manuals | Describe software features and configuration procedures. |
Command references | Provide a quick reference to all available commands. | |
H3C Low-End Ethernet Switches Configuration Example | Describe typical network scenarios and provide configuration examples and instructions. | |
Operations and maintenance | H3C Series Ethernet Switches Login Password Recovery Manual | Describes the method of recovering or changing the login password if the password is lost. |
Release notes | Describe product version information (including hardware and software compatibility matrix, software compatibility, feature updates, and technical information) and software upgrade methods. |
Obtaining Documentation
You can access the most up-to-date H3C product documentation on the World Wide Web at http://www.h3c.com.
Click the links on the top navigation bar to obtain different categories of product documentation:
[Technical Support & Documents > Technical Documents] – Provides hardware installation, software feature configuration and maintenance documentation.
[Products & Solutions] – Provides information about products and technologies.
[Technical Support & Documents > Software Download] – Provides the documentation released with the software version.
Documentation Feedback
We appreciate your comments.
