- H3C Low-End Ethernet Switches Configuration Guide(V1.01)
- H3C Low-End Ethernet Switches Configuration Examples(V1.04)
- H3C S3100 Series Ethernet Switches Installation Manual-(V1.06)
- H3C S3100 Series Ethernet Switches Quick Start(V1.08)
- H3C S3100-52P Ethernet Switch Operation Manual-Release 1500(V1.02)
- H3C S3100-52P Ethernet Switch Installation Manual(V1.01)
Preface
Download the entire book or click on the links to the left for one chapter at a time.
H3C S3100 Series Ethernet Switches Operation Manual-Release 22XX Series describes the software features for the H3C S3100 Series Ethernet Switches and guides you through the software configuration procedures. It also provides configuration examples to help you apply software features to different network scenarios.
This preface includes:
l Audience
l About the H3C S3100 Documentation Set
Audience
l Network planners
l Field technical support and servicing engineers
l Network administrators working with the S3100 series
Organization
H3C S3100 Series Ethernet Switches Operation Manual-Release 22XX Series is organized as follows:
Part | Features |
01-CLI Operation | l Introduction to CLI l CLI configuration |
02-Login Operation | l Logging into a switch through the console port l Logging in through Telnet/SSH l Logging in through the web-based network management system |
03-Configuration File Management Operation | l Saving and deleting the configuration file |
04-VLAN Operation | l VLAN overview l Port-based VLAN l MAC-based VLAN (applicable only to the S3100-EI series) l Protocol-based VLAN (applicable only to the S3100-EI series) |
05-Static Route Operation | l Introduction to static route l Static route configuration |
06-IP Address-IP Performance Operation | l Configuring an IP address for a switch l Configuring the TCP attributes for a switch |
07-Voice VLAN Operation | Voice VLAN (applicable only to the S3100-EI series) |
08-GVRP Operation | GARP VLAN registration protocol (GVRP) |
09-Port Basic Configuration Operation | l Configuring port auto-negotiation speed l Limiting traffic on individual ports l Enabling flow control on a port l Duplicating the configuration of a port to other ports l Configuring loopback detection for Ethernet port(s) l Enabling the system to test connected cable l Configuring the interval to perform statistical analysis on port traffic l Disabling Up/Down log output on a port |
10-Link Aggregation Operation | l Link aggregation control protocol (LACP) l Manual aggregation l Static aggregation |
11-Port Isolation Operation | Port isolation group |
12-Port Security-Port Binding Operation | l Configuring port security l Configuring port binding (applicable only to the S3100-EI series) |
13-DLDP Operation | Device link detection protocol (DLDP) (applicable only to the S3100-EI series) |
14-MAC Address Table Management Operation | l Manually configuring dynamic, static, and black hole MAC addresses l Setting the MAC address aging timer l Setting the maximum number of MAC addresses a port can learn l Disabling MAC address learning for a VLAN (applicable only to the S3100-EI series) l Assigning MAC addresses for Ethernet ports l Configuring MAC address replication (applicable only to the S3100-EI series) |
15-MSTP Operation | l STP/RSTP/MSTP overview and basic configuration l Performing mCheck operation l Guard functions: BPDU Guard, Root Guard, Loop Guard, TC-BPDU Attack Guard, and BPDU Drop (BPDU Drop is applicable only to the S3100-EI series) l Digest snooping l Rapid transition l VLAN-VPN tunnel (applicable only to the S3100-SI series) l MSTP maintenance configuration l Sending trap messages conforming to 802.1d standard |
16-Multicast Operation | l Internet group management protocol (IGMP) snooping v2&v3 l Multicast Listener Discovery (MLD) snooping v1&v3 (applicable only to the S3100-EI series) l IPv6 multicast VLAN configuration (applicable only to the S3100-EI series) l Multicast user control policy configuration (applicable only to the S3100-EI series) |
17-802.1x-System Guard Operation | l Basic 802.1x configuration l Advanced 802.1x configuration l Configuring quick EAD deployment l Configuring HABP server l Configuring HABP client l Configuring system guard |
18-AAA Operation | l AAA overview l AAA configuration l RADIUS configuration l HWTACACS configuration l EAD configuration |
19-MAC Address Authentication Operation | l MAC authentication overview l Configuring basic MAC authentication functions l MAC address authentication enhanced function configuration |
20-Web Authentication Operation (Applicable only to the S3100-EI series) | l Introduction to web authentication l Web authentication configuration l Configuring an Auth-Fail VLAN for web authentication l Configuring a web authentication-free user l Configuring HTTPS access for web authentication l Customizing web authentication pages l Configuring web authentication transition l Configuring a proxy server port for web authentication |
21-Triple Authentication Operation (Applicable only to the S3100-EI series) | l Triple authentication overview l Triple authentication configuration |
22-ARP Operation | l Gratuitous ARP l Manually configuring ARP entries l ARP attack detection (applicable only to the S3100-EI series) l ARP packet rate limit (applicable only to the S3100-EI series) |
23-DHCP Operation | l DHCP server (applicable only to the S3100-EI series) l DHCP snooping l DHCP packet rate limit (applicable only to the S3100-EI series) l DHCP/BOOTP client |
24-ACL Operation | l Basic/advanced ACLs (Only ACLs defined on S3100-EI series switches can be applied to hardware directly.) l Layer 2 ACLs (applicable only to the S3100-EI series) l IPv6 ACLs (applicable only to the S3100-EI series) |
25-QoS-QoS Profile Operation | l Quality of Service (QoS) l QoS profile (applicable only to the S3100-EI series) |
26-Mirroring Operation | l Local port mirroring l Remote port mirroring |
27-Stack-Cluster Operation | l Stack l Huawei Group Management Protocol (HGMP) v2 l Neighbor Discovery Protocol (NDP) l Neighbor Topology Discovery Protocol (NTDP) l Cluster topology management function l Cluster synchronization function |
28-PoE-PoE Profile Operation | l Power over Ethernet (PoE) l PoE profile |
29-SNMP-RMON Operation | l Simple network management protocol (SNMP) l Remote monitoring (RMON) |
30-NTP Operation | l Network time protocol (NTP) |
31-SSH Operation | l Configuring the SSH server l Configuring the SSH client |
32-File System Management Operation | l File system management l File attribute configurable |
33-FTP-SFTP-TFTP Operation | l Operating as an FTP server/FTP client l Operating as an SFTP server/SFTP client l Operating as a TFTP client |
34-Information Center Operation | l System logs l Hierarchical alarms l Debugging information output |
35-System Maintenance and Debugging Operation | l Boot ROM and host software loading |
36-VLAN-VPN Operation | l VLAN-VPN (QinQ) l Configuring TPID value (applicable only to the S3100-EI series) l Configuring BPDU tunnels (applicable only to the S3100-EI series) l Selective QinQ (applicable only to the S3100-EI series) |
37-VLAN Mapping Operation | l One-to-one VLAN mapping (applicable only to the S3100-EI series) l Many-to-One VLAN mapping (applicable only to the S3100-EI series) |
38-HWPing Operation | l HWPing Server/HWPing client configuration l Nine test types, including ICMP test, DHCP test, FTP test, HTTP test, DNS test, SNMP test, jitter test, TCP test, and UDP test |
39-IPv6 Management Operation | l Supporting IPv6 address l Supporting static IPv6 route l Supporting ND snooping (applicable only to the S3100-EI series) l Supporting ND detection (applicable only to the S3100-EI series) l Supporting DHCPv6 snooping (applicable only to the S3100-EI series) l Supporting IPv6 filtering (applicable only to the S3100-EI series) l Supporting IPv6 DNS l IPv6-based ping, traceroute, TFTP, and Telnet |
40-DNS Operation | l Static domain name resolution l Dynamic domain name resolution |
41-Smart Link-Monitor Link Operation | l Smart Link (applicable only to the S3100-EI series) l Monitor Link (applicable only to the S3100-EI series) |
42-ARP and IP Attack Defense Operation | l Supporting ARP packet filtering based on gateway’s address (applicable only to the S3100-EI series) l Supporting configuring the maximum number of dynamic ARP entries a VLAN interface can learn (applicable only to the S3100-EI series) l Supporting ARP/IP attack defense based on 802.1x (applicable only to the S3100-EI series) l Supporting ARP source MAC address consistency check |
43-LLDP Operation | l Basic Link Layer Discovery Protocol (LLDP) configuration l CDP compatibility (applicable only to the S3100-EI series) l LLDP trapping |
44-PKI Operation | l PKI overview l PKI configuration |
45-SSL Operation | l Configuring an SSL server policy l Configuring an SSL client policy |
46-HTTPS Operation | l HTTPS overview l HTTPS configuration |
47-Ethernet OAM Operation (Applicable only to the S3100-EI series) | l Configuring basic ethernet OAM functions l Configuring the Ethernet OAM connection detection timers l Enabling OAM remote loopback |
48-CFD Operation (Applicable only to the S3100-EI series) | l Configuring basic CFD settings l Configuring CC on MEPs |
Software Version
H3C S3100 Series Ethernet Switches Operation Manual-Release 22XX Series and H3C S3100 Series Ethernet Switches Command Manual-Release 22XX Series are for the software version Release 22XX Series of the S3100-SI series and S3100-EI series switches.
Compared with Release 21XX Series, some new features are added in Release 22XX Series. For more information, see Table -1.
Software version | Added features compared with the earlier version Release 2108P04 | Part |
Release 2211P06 | Configuring MAC address replication (applicable only to the S3100-EI series) | 14-MAC Address Table Management Operation |
Setting the offline detect timer for MAC authentication on the Ethernet port view | 19-MAC Address Authentication Operation | |
Configuring a web authentication-free user on the Ethernet port view (applicable only to the S3100-EI series) | 20-Web Authentication Operation | |
Configuring web authentication transition (applicable only to the S3100-EI series) | ||
Configuring a proxy server port for web authentication (applicable only to the S3100-EI series) | ||
Release 2211P02 | Limit broadcast traffic in pps | 09-Port Basic Configuration Operation |
Multicast user control policy configuration (applicable only to the S3100-EI series) | 16-Multicast Operation | |
Disables the EPON ONU from dropping unknown multicast packets (applicable only to the S3100-EI series) | ||
Unicast trigger function of 802.1x (applicable only to the S3100-EI series) | 17-802.1X-System Guard Operation | |
Triple authentication (applicable only to the S3100-EI series) | 21-Triple Authentication Operation | |
Cluster synchronization function | 27-Stack-Cluster Operation | |
Many-to-one VLAN mapping (applicable only to the S3100-EI series) | 37-VLAN Mapping Operation | |
DHCPv6 snooping options 18 and 37 Functions (applicable only to the S3100-EI series) | 39-IPv6 Management Operation | |
Ethernet OAM configuration (applicable only to the S3100-EI series) | 47-Ethernet OAM Operation | |
CFD configuration (applicable only to the S3100-EI series) | 48-CFD Operation | |
Release 2209 | MAC-based VLAN configuration (applicable only to the S3100-EI series) | 04-VLAN Operation |
Configuring QoS priority settings for voice traffic on an interface (applicable only to the S3100-EI series) | 07-Voice VLAN Operation | |
09-Port Basic Configuration Operation | ||
10-Link Aggregation Operation | ||
Guest VLAN for a Port in macAddressOrUserLoginSecure mode function | 12-Port Security-Port Binding Operation | |
Configuring an aging time for learned security MAC address entries | ||
IPv6-supported port binding (applicable only to the S3100-EI series) | ||
16-Multicast Operation | ||
MLD snooping (applicable only to the S3100-EI series) | ||
IPv6 multicast VLAN (applicable only to the S3100-EI series) | ||
Mandatory 802.1X authentication domain | 17-802.1x-System Guard Operation | |
Per user type AAA | 18-AAA Operation | |
Multiple secondary RADIUS servers | ||
IPv6-supported RADIUS authentication | ||
Web authentication | 20-Web Authentication Operation | |
DHCP Server (applicable only to the S3100-EI series) | 23-DHCP Operation | |
Removing DHCP snooping entries | ||
Automatic Configuration | ||
IPv6 ACL (applicable only to the S3100-EI series) | 24-ACL Operation | |
VLAN marking | 25-QoS-QoS Profile Operation | |
IPv6-supported SNMP | 29-SNMP-RMON Operation | |
35-System Maintenance and Debugging Operation | ||
Enabling auto power down on the 1000 Mbps uplink port | ||
Scheduled task configuration | ||
New HWPing commands, including: adv-factor, datafill, description, display hwping statistics, filesize, history keep-time, history-record enable, hwping-agent clear, hwping-agent max-requests, sendpacket passroute, statistics, statistics keep-time, test-time begin, and ttl. | 38-HWPing Operation | |
ND snooping function (applicable only to the S3100-EI series) | 39-IPv6 Management Operation | |
ND detection function (applicable only to the S3100-EI series) | ||
DHCPv6 snooping function (applicable only to the S3100-EI series) | ||
IPv6 filtering function (applicable only to the S3100-EI series) | ||
ARP packet filtering based on gateway’s address (applicable only to the S3100-EI series) | 42-ARP and IP Attack Defense Operation | |
Configuring the maximum number of dynamic ARP entries a VLAN interface can learn (applicable only to the S3100-EI series) | ||
ARP/IP attack defense based on 802.1x (applicable only to the S3100-EI series) | ||
LLDP | 43-LLDP Operation | |
PKI | 44-PKI Operation | |
SSL | 45-SSL Operation | |
HTTPS | 46-HTTPS Operation |
Conventions
This section describes the conventions used in this documentation set.
Command conventions
Convention | Description |
Boldface | Bold text represents commands and keywords that you enter literally as shown. |
italic | Italic text represents arguments that you replace with actual values. |
[ ] | Square brackets enclose syntax choices (keywords or arguments) that are optional. |
{ x | y | ... } | Braces enclose a set of required syntax choices separated by vertical bars, from which you select one. |
[ x | y | ... ] | Square brackets enclose a set of optional syntax choices separated by vertical bars, from which you select one or none. |
{ x | y | ... } * | Asterisk marked braces enclose a set of required syntax choices separated by vertical bars, from which you select at least one. |
[ x | y | ... ] * | Asterisk marked square brackets enclose optional syntax choices separated by vertical bars, from which you may select multiple choices or none. |
&<1-n> | The argument or keyword and argument combination before the ampersand (&) sign can be entered 1 to n times. |
# | A line that starts with a pound (#) sign is comments. |
GUI conventions
Boldface | Window names, button names, field names, and menu items are in Boldface. For example, the New User window appears; click OK. |
> | Multi-level menus are separated by angle brackets. For example, File > Create > Folder. |
Symbols
Means reader be extremely careful. Improper operation may cause bodily injury. | |
Means reader be careful. Improper operation may cause data loss or damage to equipment. | |
Means an action or information that needs special attention to ensure successful configuration or good performance. | |
Means a complementary description. | |
Means techniques helpful for you to make configuration with ease. |
The H3C S3100 documentation set includes:
Category | Documents | Purposes |
l S3100-EI series switches marketing brochure l S3100-SI series switches marketing brochure | Describe product specifications and benefits. | |
H3C Low End Series Ethernet Switches Pluggable Modules Manual | Describes the types, appearance, and specifications of pluggable modules. | |
RPS user manuals | Describe the RPS power supply appearance, functions, and specifications. | |
RPS Ordering Information for H3C Low-End Ethernet Switches | Describe the switch models that can use RPS power supply modules and the RPS power cable specifications. | |
Hardware specifications and installation | Compliance and Safety Manual | Provides regulatory information and the safety instructions that must be followed during installation. |
Installation guide | Provides a complete guide to hardware installation and hardware specifications. | |
H3C Pluggable SFP[SFP+][XFP] Transceiver Modules Installation Guide | Guides you through installing SFP/SFP+/XFP transceiver modules. | |
Software configuration | Operation manuals | Describe software features and configuration procedures. |
Command references | Provide a quick reference to all available commands. | |
H3C Low-End Ethernet Switches Configuration Example H3C Low-End Ethernet Switches Configuration Guide | Describe typical network scenarios and provide configuration examples and instructions. | |
Operations and maintenance | H3C Series Ethernet Switches Login Password Recovery Manual | Describes the method of recovering or changing the login password if the password is lost. |
Release notes | Describe product version information (including hardware and software compatibility matrix, software compatibility, feature updates, and technical information) and software upgrade methods. |
Obtaining Documentation
You can access the most up-to-date H3C product documentation on the World Wide Web at http://www.h3c.com.
Click the links on the top navigation bar to obtain different categories of product documentation:
[Technical Support & Documents > Technical Documents] – Provides hardware installation, software feature configuration and maintenance documentation.
[Products & Solutions] – Provides information about products and technologies.
[Technical Support & Documents > Software Download] – Provides the documentation released with the software version.
Documentation Feedback
We appreciate your comments.
