Title | Size | Downloads |
H3C S12500-X Switch Series Installation Guide-6PW111-book.pdf | 19.72 MB |
Preface
The H3C S12500-X Switch Series Installation Guide guides you through the installation of your switch, including preparing for installation, installing the switch, installing FRUs, setting up an IRF fabric, connecting your switch to the network, troubleshooting, and replacement procedures.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the S12500-X switch series.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE |
Network topology icons
Represents an access point. |
Wireless terminator unit. |
Wireless terminator. |
Obtaining documentation
To access the most up-to-date H3C product documentation, go to the H3C website at http://www.h3c.com.hk.
To obtain information about installation, configuration, and maintenance, click
http://www.h3c.com.hk/Technical_Documents
To obtain software version information such as release notes, click
http://www.h3c.com.hk/Software_Download
Technical support
Documentation feedback
You can email your comments about product documentation to [email protected].
We appreciate your comments.
