About the H3C firewall devices Command Reference
HomeSupportSecurityH3C SecPath M9000Reference GuidesCommand ReferencesH3C firewall devices Command Reference(V7) (ESS9114 ESS9304 ESS9204)-5W100About the H3C firewall devices Command Reference
Table of Contents
Related Documents
book(CHM)
book(CHM) 4.17 MB
About the H3C firewall devices command references
The H3C firewall devices command references (Comware V7) describe the commands and command syntax options available for the Comware V7-based firewall devices described in Table 1.
Table 1 Applicable devices
Product series
Model
Device type
H3C SecPath F5000 firewalls
F5020/F5040
Centralized IRF devices. These devices support IRF.
H3C SecPath M9000 multiservice security gateways
M9006/M9010/M9014
Distributed devices. These devices support IRF. They can operate in one of the following modes:
·     Standalone mode—The device cannot form an IRF fabric with other devices.
·     IRF mode—The device can form an IRF fabric with other devices.
H3C SecPath virtual multiservice security gateways
VFW1000
Centralized devices. These devices do not support IRF.
Table 2 describes the content of the command references. The supported commands vary by device model.
Table 2 Command reference content
Command reference
Content
Fundamentals Command Reference
Covers the commands for logging in to and setting up a device. This command reference includes:
·     CLI
·     RBAC
·     Login management
·     FTP and TFTP
·     File system management
·     Configuration file management
·     Software upgrade
·     ISSU
·     Device management
·     Security zone
·     Tcl configuration
·     Python
·     License management
Virtual Technologies Command Reference
Covers the commands for configuring virtual technologies. This command reference includes:
·     IRF
·     Context
Interface Command Reference
Covers the commands for configuring various interfaces. This command reference includes:
·     Ethernet interface
·     Loopback, null, and inloopback interfaces
·     Blade interface
·     Bulk interfaces
Layer 2—LAN Switching Command Reference
Covers the commands for configuring Layer 2 technologies and features in a LAN switched network. This command reference includes:
·     MAC address table
·     Ethernet link aggregation
·     Spanning tree
·     VLAN
·     VLAN termination
·     LLDP
·     Layer 2 forwarding
Layer 2—WAN Accessing Command Reference
Covers the commands for configuring WAN access technologies. This command reference includes:
·     PPP
·     L2TP
Layer 3—IP Services Command Reference
Covers the commands related to IP addressing, IP performance optimization, ARP, and interoperation between IPv4 and IPv6. This command reference includes:
·     ARP (including proxy ARP)
·     IP addressing
·     DHCP
·     DNS
·     NAT
·     IP forwarding basics
·     Fast forwarding
·     Flow classification
·     Adjacency table
·     IP performance optimization
·     IPv6 basics
·     DHCPv6
·     IPv6 fast forwarding
·     Tunneling
·     GRE
Layer 3—IP Routing Command Reference
Covers the commands for configuring routes for IPv4 and IPv6 networks of different sizes, route filtering, route control, and policy based routing. This command reference includes:
·     IP routing basics
·     Static routing
·     RIP
·     OSPF
·     IS-IS
·     BGP
·     Policy-based routing
·     IPv6 static routing
·     RIPng
·     OSPFv3
·     IPv6 IS-IS
·     IPv6 policy-based routing
·     Routing policy
IP Multicast Command Reference
Covers the commands for Layer 3 multicast protocols IGMP, MLD, PIM, IPv6 PIM, and MSDP. This command reference includes:
·     Multicast overview
·     Multicast routing and forwarding
·     IGMP
·     PIM
·     MSDP
·     IPv6 multicast routing and forwarding
·     MLD
·     IPv6 PIM
ACL and QoS Command Reference
Covers the commands for configuring ACL and QoS to classify and control traffic. This command reference includes:
·     ACL
·     Time range
·     QoS (including QoS fundamentals, QoS configuration, traffic monitoring, traffic redirecting, and traffic accounting)
Security Command Reference
Covers security feature commands for identity authentication, access security, secure management, and attack protection. This command reference includes:
·     AAA
·     Portal
·     Password control
·     Public keys
·     PKI
·     IPsec
·     SSH
·     SSL
·     ASPF
·     APR
·     Session management
·     Connection limit
·     Object group
·     Object policy
·     Attack detection and prevention
·     ARP attack protection
·     uRPF
·     Crypto engine
·     FIPS
High Availability Command Reference
Covers high availability commands for managing failure detection and failover. Failure detection technologies focus on fault detection and isolation. Failover technologies focus on network recovery. This command reference includes:
·     VRRP
·     Failover group
·     Reth interface and redundancy group
·     BFD
·     Track
·     Process placement
Network Management and Monitoring Command Reference
Covers the commands that help you manage and monitor your network, for example, manage system events, collect traffic statistics, sample packets, assess network performance, and test network connectivity. This command reference includes:
·     System maintenance and debugging
·     NQA
·     NTP
·     SNMP
·     RMON
·     NETCONF
·     EAA
·     Process monitoring and maintaining
·     Information center
·     Flow log
·     Mirroring
VPN Instance and MCE Command Reference
Covers the commands related to VPN instance and Multi-VPN-Instance CE (MCE) configuration. This command reference includes:
·     VPN instance
·     MCE
Probe Command Reference
Covers commands used in probe view.
