H3C SR8800-X Routers 100G Ethernet Optical Interface Module Datasheet-5W103
HomeSupportRoutersH3C SR8800-X Router SeriesProduct LiteratureCard DatasheetsH3C SR8800-X Routers 100G Ethernet Optical Interface Module Datasheet-5W103
Download Book
Copyright © 2015 to 2022 New H3C Technologies Co., Ltd. All rights reserved.
Overview
The following 100G Ethernet optical interface modules are available for the SR8800-X routers.
Table 1 100G Ethernet optical interface modules available for the routers
Module model
SPC-CP1LAX
1-port 100GBASE Ethernet optical interface module (CFP, LC) (A Type), not supported on the SR8800-X-S routers
SPC-CP1LC
1-port 100GBASE Ethernet optical interface module (CFP, LC) (C Type), supported only on the SR8800-X-S routers
SPC-CP1LCX
1-port 100GBASE Ethernet optical interface module (CFP, LC) (C Type), not supported on the SR8800-X-S routers
SPC-CP2LA
2-port 100GBASE Ethernet optical interface module (CFP, LC) (A Type)
SPC-CP2LB
2-port 100GBASE Ethernet optical interface module (CFP, LC) (B Type)
For compatibility between 100G Ethernet optical interface modules and switching fabric modules, see Appendix B FRUs and compatibility matrixes in H3C SR8800-X Routers Installation Guide.
Key features
High-speed access rate
The interface modules use 100GE CFP transceiver modules to provide an access rate of 100 Gbps per port, meeting data rate requirements for data centers.
High performance and scalability
With high-speed CPUs, the interface modules greatly improve the service processing capability and provide independent OAM engine for link status monitoring.
Environment-friendly design
The interface modules are compliant with the Restriction of Hazardous Substances (RoHS) standard.
Hot swapping
The interface modules are hot swappable. Installing and removing such a module on an operating router does not affect ongoing services on other modules. The management system monitors the module in real time and implements automated configuration for the module to ensure service continuity.
Specifications
The figures in this section are for illustration only.
SPC-CP1LAX/SPC-CP1LC/SPC-CP1LCX
The SPC-CP1LAX, SPC-CP1LC, and SPC-CP1LCX have the same appearance. This section uses the SPC-CP1LCX as an example.
Figure 1 SPC-CP1LCX
Front panel
Figure 2 SPC-CP1LCX front panel
(1) 100GBASE-R-CFP fiber port
(2) CFP port status LED
Technical specifications
Item
Specifications
Dimensions (H × W × D)
40 × 399 × 352 mm (1.57 ×15.7 × 13.86 in)
Power consumption
·     SPC-CP1LAX: 103 W to 135 W
·     SPC-CP1LC: 85 W to 120 W
·     SPC-CP1LCX: 115 W to 173 W
Ports
1
Connector type
LC
Port speed
100 Gbps
Net weight
·     SPC-CP1LAX/SPC-CP1LCX: 3.5 kg (7.72 lb)
·     SPC-CP1LC: 3.4 kg (7.50 lb)
System software version
·     SPC-CP1LAX/SPC-CP1LCX: 7133 or later
·     SPC-CP1LC: 7140P51 or later
SPC-CP2LA/SPC-CP2LB
The SPC-CP2LA and SPC-CP2LB have the same appearance. This section uses the SPC-CP2LA as an example.
Figure 3 SPC-CP2LA
Front panel
Figure 4 SPC-CP2LA front panel
(1) 100GBASE-R-CFP fiber ports (2 in total)
Item
Specifications
40 × 399 ×352 mm (1.57 ×15.7 × 13.86 in)
Power consumption
·     SPC-CP2LA: 144 W to 197 W
·     SPC-CP2LB: 150 W to 197 W
Ports
2
Connector type
LC
Port speed
100 Gbps
Net weight
4.06 kg (8.95 lb)
7133 or later
·     The SR8803-X-S that is installed with an MPU SR07SRPUC1 and the SR8802-X-S do not support the SPC-CP2LA or SPC-CP2LB.
·     For the SR8810-X-S, you must install the SPC-CP2LA and SPC-CP2LB in slot 0, slot 4, or slot 7.
LEDs
Table 2 CFP port status LED description
Status
Flashing
The port is receiving or transmitting data.
On
A link is present.
Off
No link is present.
Environment requirements
Make sure the ambient environment meets the following requirements:
·     Temperature and humidity requirements
Table 3 Temperature and humidity requirements
Item
Specifications
Operating temperature
0°C to 45°C (32°F to 113°F)
Storage temperature
–40°C to +70°C (–40°F to +158°F)
Operating humidity
10% RH to 95% RH, non-condensing
Storage humidity
5% RH to 95% RH, non-condensing
·     Dust protection requirements
Table 4 Dust concentration limits in the equipment room
Substance
Particle diameter
Concentration limit
Dust particles
≥ 0.5 µm
≤ 1.8 × 107 particles/m3
·     Corrosive gas protection requirements
Table 5 Corrosive gas concentration limits in the equipment room
Gas
Average concentration (mg/m3)
Maximum concentration (mg/m3)
SO2
0.3
1.0
H2S
0.1
0.5
Cl2
0.1
0.3
HCI
0.1
0.5
HF
0.01
0.03
NH3
1.0
3.0
O3
0.05
0.1
NOX
0.5
1.0
