- Released At: 22-12-2022
- Page Views:
- Downloads:
H3C SR8800-F Router Series |
Gigabit Ethernet Interface Module Datasheet |
Copyright © 2015 to 2022 New H3C Technologies Co., Ltd. All rights reserved.
Overview
The following Gigabit Ethernet interface modules are available for the SR8800-F routers.
Table 1 Gigabit Ethernet interface modules available for the SR8800-F routers
Card model |
CSPC-GE24L-E |
24-port 1000BASE-X Ethernet combo interface line processing unit (E Type) |
CSPC-GT48LA1 |
48-port 10/100/1000BASE-T Ethernet interface module (RJ45) (A Type) |
CSPC-GP24LA1 |
16-port 1000BASE-X Ethernet optical interface (SFP, LC) + 8-port combo interface module (A Type) |
CSPC-GP24XP2LB |
16-port 1000BASE-X optical interface (SFP, LC) + 8-port combo interface + 2-port 10GE optical interface module (XFP, LC) (B Type) |
CSPC-GP24GE8XP2L-E |
24-port 1000BASE-X Ethernet optical interface (SFP, LC) + 8-port 1000BASE-X Ethernet combo interface + 2-port 10GBASE-R/W Ethernet optical interface line processing unit |
CSPC-GE16XP4L-E |
16-port 1000BASE-X Ethernet combo interface + 4-port 10GBASE-R/W Ethernet optical interface line processing unit |
CSPC-GP48LB |
48-port enhanced 1000BASE-X Ethernet optical interface module (SFP, LC) (B Type) |
SPC-GP44XP4LA |
44-port 1000BASE-X Ethernet optical interface module (SFP, LC) + 4-port 10GBASE Ethernet optical interface module (SFP+, LC) (A Type) |
SPC-GP44XP4LC |
44-port 1000BASE-X Ethernet optical interface module (SFP, LC) + 4-port 10GBASE Ethernet optical interface module (SFP+, LC) (C Type) |
Key features
High performance and scalability
With high-speed CPUs, the interface modules greatly improve the service processing capability and provide independent OAM engine for link status monitoring.
You can select interface modules with different number of ports and select optical transceiver modules depending on actual applications and transmission distances.
Environment-friendly design
The interface modules are compliant with the Restriction of Hazardous Substances (RoHS) standard.
Hot swapping
The interface modules are hot swappable. Installing and removing such a module on an operating router does not affect ongoing services on other modules. The management system monitors the module in real time and implements automated configuration for the module to ensure service continuity.
Specifications
The figures in this section are for illustration only.
CSPC-GE24L-E
Figure 1 CSPC-GE24L-E
Front panel
Figure 2 CSPC-GE24L-E front panel
(1) Combo interfaces (24 in total, the 1000BASE-X-SFP fiber ports support GE SFP transceiver modules) |
(2) SFP port status LED |
(3) RJ-45 Ethernet port status LED |
Technical specifications
Item |
Specifications |
Dimensions (H × W × D) |
40 × 399 × 352 mm (1.57 × 15.71 × 13.86 in) |
Power consumption |
108 W to 114 W |
Ports |
24 × combo interfaces |
Connector type |
· LC · RJ-45 |
Port speed |
· 1000BASE-X-SFP fiber port: 100/1000 Mbps · 1000BASE-T copper port: 10/100/1000 Mbps (half/full duplex) |
Net weight |
4.45 kg (9.81 lb) |
Applicable system software versions |
7907 or later |
CSPC-GT48LA1
Figure 3 CSPC-GT48LA1
Front panel
Figure 4 CSPC-GT48LA1 front panel
(1) 10/100/1000BASE-T RJ-45 copper ports (48 in total) |
(2) RJ-45 Ethernet port status LED |
Item |
Specifications |
Power consumption |
67 W to 95 W |
Ports |
48 |
Connector type |
RJ-45 |
Port speed |
Net weight |
3.31 kg (7.30 lb) |
7121 or later |
CSPC-GP24LA1
Figure 5 CSPC-GP24LA1
Front panel
Figure 6 CSPC-GP24LA1 front panel
(1) 1000BASE-X-SFP fiber ports (16 in total) |
(2) Combo interfaces (8 in total) |
(3) SFP port status LED |
(4) RJ-45 Ethernet port status LED |
NOTE: · A combo interface is a logical interface that contains an SFP fiber port and a 1000BASE-T RJ-45 copper port. Only one port can be activated at a time. You can activate the SFP fiber port or the RJ-45 copper port at the CLI. By default, the RJ-45 copper port is activated. · Use a category 5 or above twisted pair cable to connect a 1000BASE-T RJ-45 copper port. The maximum transmission distance is 100 m (328.08 ft). |
Item |
Specifications |
Power consumption |
47 W to 75 W |
Ports |
· 16 × 1000BASE-X-SFP fiber ports · 8 × combo interfaces |
Connector type |
· LC · RJ-45 |
Port speed |
· 1000BASE-X-SFP fiber ports: 100/1000 Mbps · 10/100/1000BASE-T copper ports: 10/100/1000 Mbps (half/full duplex) |
Net weight |
3.01 kg (6.64 lb) |
7121 or later |
CSPC-GP24XP2LB
Figure 7 CSPC-GP24XP2LB
Front panel
Figure 8 CSPC-GP24XP2LB front panel
(3) 10GBASE-R-XFP fiber ports (2 in total) |
(4) SFP port status LED |
(5) RJ-45 Ethernet port status LED |
(6) XFP port status LED |
Item |
Specifications |
Power consumption |
51 W to 100 W |
Ports |
· 16 × 1000BASE-X-SFP fiber ports · 8 × combo interfaces · 2 × 10GBASE-R-XFP fiber ports |
Connector type |
· LC · RJ-45 |
Port speed |
· 1000BASE-X-SFP fiber ports: 1000 Mbps · 10/100/1000BASE-T copper ports: 10/100/1000 Mbps (half/full duplex) · 10GBASE-R-XFP fiber ports: 10 Gbps |
Net weight |
3.08 kg (6.79 lb) |
7121 or later |
CSPC-GP24GE8XP2L-E
Figure 9 CSPC-GP24GE8XP2L-E
Front panel
Figure 10 CSPC-GP24GE8XP2L-E front panel
(1) 10GBASE-R-SFP+ fiber ports (2 in total, support for 10GE SFP+ transceiver modules) |
(2) 1000BASE-X-SFP fiber ports (24 in total, support for GE SFP transceiver modules) |
(3) Combo interfaces (8 in total, the 1000BASE-X-SFP fiber ports support GE SFP transceiver modules) |
(5) SFP port status LED |
(6) SFP+ port status LED |
Item |
Specifications |
Power consumption |
101 W to 126 W |
Ports |
· 24 × 1000BASE-X-SFP fiber ports · 8 × combo interfaces · 2 × 10GBASE-R/W-SFP+ fiber ports |
Connector type |
· LC · RJ-45 |
Port speed |
· 1000BASE-X-SFP fiber port: 1000 Mbps · 1000BASE-T-RJ45 copper port: 10/100/1000 Mbps (half/full duplex) · 10GBASE-R/W-SFP+ fiber port: 10 Gbps |
Net weight |
4.45 kg (9.81 lb) |
7907 or later |
CSPC-GE16XP4L-E
Figure 11 CSPC-GE16XP4L-E
Front panel
Figure 12 CSPC-GE16XP4L-E front panel
(1) 10GBASE-R-SFP+ fiber ports (4 in total, support for 10GE SFP+ transceiver modules) |
(2) Combo interfaces (16 in total, the 1000BASE-X-SFP fiber ports support GE SFP transceiver modules) |
(5) SFP+ port status LED |
Item |
Specifications |
Power consumption |
107 W to 127 W |
Ports |
· 16 × combo interfaces · 4 × 10GBASE-R/W-SFP+ fiber ports |
Connector type |
· RJ-45 · LC |
Port speed |
· 1000BASE-T-RJ45 copper port: 10/100/1000 Mbps (half/full duplex) · 1000BASE-X-SFP fiber port: 1000 Mbps · 10GBASE-R/W-SFP+ fiber port: 10 Gbps |
Net weight |
4.35 kg (9.59 lb) |
7907 or later |
CSPC-GP48LB
Figure 13 CSPC-GP48LB
Front panel
Figure 14 CSPC-GP48LB front panel
(1) 1000BASE-X-SFP fiber ports (48 in total) |
Item |
Specifications |
Power consumption |
43 W to 110 W |
Ports |
48 |
Connector type |
LC |
Port speed |
· 100 Mbp/s · 1000 Mbps · 10/100/1000 Mbps |
Net weight |
3.25 kg (7.16 lb) |
7121 or later |
SPC-GP44XP4LA/SPC-GP44XP4LC
The SPC-GP44XP4LA and SPC-GP44XP4LC cards are the same in appearance except for the marks. The following uses the SPC-GP44XP4LC as an example.
Figure 15 SPC-GP44XP4LC
Front panel
Figure 16 SPC-GP44XP4LC front panel
(1) 1000BASE-R-SFP fiber ports (44 in total) |
(2) 10GBASE-R-SFP+ fiber ports (4 in total) |
(4) SFP+ port status LED |
Item |
Specifications |
Power consumption |
· SPC-GP44XP4LA: 83 W to 118 W · SPC-GP44XP4LC: 90 W to 146 W |
Ports |
· 44 × 1000BASE-X-SFP fiber ports · 4 × 10GBASE-R-SFP+ fiber ports |
Connector type |
LC |
Port speed |
· 1000BASE-X-SFP fiber port: 1000 Mbps · 10GBASE-R-SFP+ fiber port: 10 Gbps |
Net weight |
· SPC-GP44XP4LA: 3.55 kg (7.83 lb) · SPC-GP44XP4LC: 3.6 kg (7.94 lb) |
7140P51 or later |
LEDs
Table 2 RJ-45 Ethernet port status LED description
Status |
Flashing |
The port is receiving or transmitting data. |
Steady on |
A link is present. |
Off |
No link is present. |
Table 3 SFP port status LED description
Status |
Flashing |
Steady on |
Off |
Table 4 SFP+ port status LED description
Status |
Flashing |
Steady on |
Off |
Table 5 XFP port status LED description
LINK LED status |
ACT LED status |
Steady on |
Flashing |
Steady on |
Off |
Off |
Off |
Environment requirements
Make sure the ambient environment meets the following requirements:
· Temperature and humidity requirements
Table 6 Temperature and humidity requirements
Item |
Specifications |
Operating temperature |
0°C to 45°C (32°F to 113°F) |
Storage temperature |
–40°C to +70°C (–40°F to +158°F) |
Operating humidity |
10% RH to 95% RH, non-condensing |
Storage humidity |
5% RH to 95% RH, non-condensing |
· Dust protection requirements
Table 7 Dust concentration limits in the equipment room
Substance |
Particle diameter |
Concentration limit |
Dust particles |
≥ 0.5 µm |
≤ 1.8 × 107 particles/m3 |
· Corrosive gas protection requirements
Table 8 Corrosive gas concentration limits in the equipment room
Gas |
Average concentration (mg/m3) |
Maximum concentration (mg/m3) |
SO2 |
0.3 |
1.0 |
H2S |
0.1 |
0.5 |
Cl2 |
0.1 |
0.3 |
HCI |
0.1 |
0.5 |
HF |
0.01 |
0.03 |
NH3 |
1.0 |
3.0 |
O3 |
0.05 |
0.1 |
NOX |
0.5 |
1.0 |
