- Released At: 22-12-2022
- Page Views:
- Downloads:
H3C SR8800-F Router Series |
100G Ethernet Optical Interface Module Datasheet |
Copyright © 2015 to 2022 New H3C Technologies Co., Ltd. All rights reserved.
Overview
The following 100G Ethernet optical interface modules are available for the SR8800-F routers.
Table 1 100G Ethernet optical interface modules available for the routers
Module model |
CSPC-CP2LB |
2-port 100GBASE Ethernet optical interface module (CFP, LC) (B Type) |
SPC-CP1LC |
1-port 100GBASE Ethernet optical interface module (CFP, LC) (C Type) |
Key features
High-speed access rate
The interface modules use 100GE CFP transceiver modules to provide an access rate of 100 Gbps per port, meeting data rate requirements for data centers.
High performance and scalability
With high-speed CPUs, the interface modules greatly improve the service processing capability and provide an independent OAM engine for link status monitoring.
Environment-friendly design
The interface modules are compliant with the Restriction of Hazardous Substances (RoHS) standard.
Hot swapping
The interface modules are hot swappable. Installing and removing such a module on an operating router does not affect ongoing services on other modules. The management system monitors the module in real time and implements automated configuration for the module to ensure service continuity..
Specifications
The figures in this section are for illustration only.
SPC-CP1LC
Figure 1 SPC-CP1LC
Front panel
Figure 2 SPC-CP1LC front panel
(1) 100GBASE-R-CFP fiber ports (1 in total) |
(2) CFP port status LED |
Technical specifications
Item |
Specifications |
Dimensions (H × W × D) |
40 × 399 ×352 mm (1.57 ×15.7 × 13.86 in) |
Power consumption |
85 W to 120 W |
Ports |
1 |
Connector type |
LC |
Port speed |
100 Gbps |
Net weight |
3.4 kg (7.50 lb) |
Applicable system software versions |
7140P51 or later |
CSPC-CP2LB
Figure 3 CSPC-CP2LB
Front panel
Figure 4 CSPC-CP2LB front panel
(1) 100GBASE-R-CFP fiber ports (2 in total) |
IMPORTANT: · SR8805-F routers installed with CSR07SRPUC1 MPUs and SR8803-F routers do not support CSPC-CP2LB modules. · For an SR8812-F router, a CSPC-CP2LB module must be installed in slot 0, 4, or 7. |
Item |
Specifications |
Power consumption |
150 W to 197 W |
Ports |
2 |
Connector type |
LC |
Port speed |
100 Gbps |
Net weight |
4.06 kg (8.95 lb) |
7133 or later |
LEDs
Table 2 CFP port status LED description
Status |
Flashing |
The port is receiving or transmitting data. |
On |
A link is present. |
Off |
No link is present. |
Environment requirements
Make sure the ambient environment meets the following requirements:
· Temperature and humidity requirements
Table 3 Temperature and humidity requirements
Item |
Specifications |
Operating temperature |
0°C to 45°C (32°F to 113°F) |
Storage temperature |
–40°C to +70°C (–40°F to +158°F) |
Operating humidity |
10% RH to 95% RH, non-condensing |
Storage humidity |
5% RH to 95% RH, non-condensing |
· Dust protection requirements
Table 4 Dust concentration limits in the equipment room
Substance |
Particle diameter |
Concentration limit |
Dust particles |
≥ 0.5 µm |
≤ 1.8 × 107 particles/m3 |
· Corrosive gas protection requirements
Table 5 Corrosive gas concentration limits in the equipment room
Gas |
Average concentration (mg/m3) |
Maximum concentration (mg/m3) |
SO2 |
0.3 |
1.0 |
H2S |
0.1 |
0.5 |
Cl2 |
0.1 |
0.3 |
HCI |
0.1 |
0.5 |
HF |
0.01 |
0.03 |
NH3 |
1.0 |
3.0 |
O3 |
0.05 |
0.1 |
NOX |
0.5 |
1.0 |
