03-Device Management
HomeSupportRoutersCR16000-M SeriesReference GuidesMIB CompanionH3C CR16000-M Routers MIB Reference-R8530Pxx-6W10003-Device Management
09-HH3C-TRANSCEIVER-INFO-MIB
09-HH3C-TRANSCEIVER-INFO-MIB 144.95 KB
About this MIB
Use this MIB to obtain information about transceiver modules, including vendor information and physical transmission characteristics.
MIB file name
hh3c-transceiver-info.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cTransceiver(70)
Scalar objects
hh3cTransceiverExtrAlarmEnable (1.3.6.1.4.1.25506.2.70.2.1)
Object (OID)
Access
Value range
Implementation
read-write
TruthValue
true(1),
false(2)
Whether to send an alarm when a third-party transceiver module is detected.
As per the MIB.
hh3cTransceiverCurrentTotalPower (1.3.6.1.4.1.25506.2.70.2.2)
Object (OID)
Access
Value range
Implementation
read-only
Integer32
Standard MIB values.
Real-time total power of all transceiver modules, in milliwatts.
As per the MIB.
hh3cTransceiverMaxTotalPower (1.3.6.1.4.1.25506.2.70.2.3)
Object (OID)
Access
Value range
Implementation
read-only
Integer32
Maximum total power of all transceiver modules, in milliwatts.
As per the MIB.
Tabular objects
hh3cTransceiverInfoTable
About this table
Use this table to obtain or edit information about transceiver modules.
Support for operations
CreateNot supported
Edit/ModifySupported
DeleteNot supported
ReadSupported
Columns
The table index is ifIndex.
Object (OID)
Access
Value range
Implementation
hh3cTransceiverHardwareType (1.3.6.1.4.1.25506.2.70.1.1.1.1)
read-only
OCTET STRING
Hardware type of the transceiver module, such as single mode (SM).
As per the MIB.
hh3cTransceiverType (1.3.6.1.4.1.25506.2.70.1.1.1.2)
read-only
OCTET STRING
Type of the transceiver module, such as SFP.
As per the MIB.
hh3cTransceiverWaveLength (1.3.6.1.4.1.25506.2.70.1.1.1.3)
read-only
Integer32
Wavelength of the transceiver module, in nm.
As per the MIB.
hh3cTransceiverVendorName (1.3.6.1.4.1.25506.2.70.1.1.1.4)
read-only
OCTET STRING
Vendor name of the transceiver module.
As per the MIB.
hh3cTransceiverSerialNumber (1.3.6.1.4.1.25506.2.70.1.1.1.5)
read-only
OCTET STRING
Serial number of the transceiver module.
As per the MIB.
hh3cTransceiverFiberDiameterType (1.3.6.1.4.1.25506.2.70.1.1.1.6)
read-only
INTEGER
fiber9(1),
fiber50(2),
fiber625(3),
copper(4),
unknown(65535)
Fiber diameter for the transceiver module, in microns (μm).
As per the MIB.
hh3cTransceiverTransferDistance (1.3.6.1.4.1.25506.2.70.1.1.1.7)
read-only
Integer32
Maximum transmission distance of the transceiver module, in meters.
As per the MIB.
hh3cTransceiverDiagnostic (1.3.6.1.4.1.25506.2.70.1.1.1.8)
read-only
TruthValue
true(1),
false(2)
Whether the transceiver module supports digital diagnosis.
As per the MIB.
hh3cTransceiverCurTXPower (1.3.6.1.4.1.25506.2.70.1.1.1.9)
read-only
Integer32
Current transmit power of the transceiver module, in dBm, accurate to 0.01 dBm.
The object returns 2147483647 when read if the device does not support this parameter.
hh3cTransceiverMaxTXPower (1.3.6.1.4.1.25506.2.70.1.1.1.10)
read-only
Integer32
Maximum transmit power of the transceiver module, in dBm, accurate to 0.01 dBm.
hh3cTransceiverMinTXPower (1.3.6.1.4.1.25506.2.70.1.1.1.11)
read-only
Integer32
Minimum transmit power of the transceiver module, in dBm, accurate to 0.01 dBm.
hh3cTransceiverCurRXPower (1.3.6.1.4.1.25506.2.70.1.1.1.12)
read-only
Integer32
Current receive power in dBm of the transceiver module, accurate to 0.01 dBm.
hh3cTransceiverMaxRXPower (1.3.6.1.4.1.25506.2.70.1.1.1.13)
read-only
Integer32
Maximum receive power of the transceiver module, in dBm, accurate to 0.01 dBm.
hh3cTransceiverMinRXPower (1.3.6.1.4.1.25506.2.70.1.1.1.14)
read-only
Integer32
Minimum receive power of the transceiver module, in dBm, accurate to 0.01 dBm.
hh3cTransceiverTemperature (1.3.6.1.4.1.25506.2.70.1.1.1.15)
read-only
Integer32
Current temperature of the transceiver module, in °C.
As per the MIB.
hh3cTransceiverVoltage (1.3.6.1.4.1.25506.2.70.1.1.1.16)
read-only
Integer32
Current voltage of the transceiver module, in V, accurate to 0.01 V.
As per the MIB.
hh3cTransceiverBiasCurrent (1.3.6.1.4.1.25506.2.70.1.1.1.17)
read-only
Integer32
Current bias current of the transceiver module, in mA, accurate to 0.01 mA.
As per the MIB.
hh3cTransceiverTempHiAlarm (1.3.6.1.4.1.25506.2.70.1.1.1.18)
read-only
Integer32
High temperature alarm threshold in °C, accurate to 0.001 °C , for example, 49120 representing 49.120 °C
As per the MIB.
hh3cTransceiverTempLoAlarm (1.3.6.1.4.1.25506.2.70.1.1.1.19)
read-only
Integer32
Low temperature alarm threshold in °C, accurate to 0.001 °C
As per the MIB.
hh3cTransceiverTempHiWarn (1.3.6.1.4.1.25506.2.70.1.1.1.20)
read-only
Integer32
High temperature warning threshold in °C, accurate to 0.001 °C
As per the MIB.
hh3cTransceiverTempLoWarn (1.3.6.1.4.1.25506.2.70.1.1.1.21)
read-only
Integer32
Low temperature warning threshold in °C, accurate to 0.001 °C
As per the MIB.
hh3cTransceiverVccHiAlarm (1.3.6.1.4.1.25506.2.70.1.1.1.22)
read-only
Integer32
High voltage alarm threshold in µV, accurate to 0.01 µV.
As per the MIB.
This object returns 0 when read if the transceiver module does not support this parameter.
hh3cTransceiverVccLoAlarm (1.3.6.1.4.1.25506.2.70.1.1.1.23)
read-only
Integer32
Low voltage alarm threshold in µV, accurate to 0.01 µV.
As per the MIB.
hh3cTransceiverVccHiWarn (1.3.6.1.4.1.25506.2.70.1.1.1.24)
read-only
Integer32
High voltage warning threshold in µV, accurate to 0.01 µV.
As per the MIB.
hh3cTransceiverVccLoWarn (1.3.6.1.4.1.25506.2.70.1.1.1.25)
read-only
Integer32
Low voltage warning threshold in mV, accurate to 0.01 µV.
As per the MIB.
hh3cTransceiverBiasHiAlarm (1.3.6.1.4.1.25506.2.70.1.1.1.26)
read-only
Integer32
High bias current alarm threshold in µA.
As per the MIB.
hh3cTransceiverBiasLoAlarm (1.3.6.1.4.1.25506.2.70.1.1.1.27)
read-only
Integer32
Low bias current alarm threshold in µA.
As per the MIB.
hh3cTransceiverBiasHiWarn (1.3.6.1.4.1.25506.2.70.1.1.1.28)
read-only
Integer32
High bias current warning threshold in µA.
As per the MIB.
hh3cTransceiverBiasLoWarn (1.3.6.1.4.1.25506.2.70.1.1.1.29)
read-only
Integer32
Low bias current warning threshold in µA.
As per the MIB.
hh3cTransceiverPwrOutHiAlarm (1.3.6.1.4.1.25506.2.70.1.1.1.30)
read-only
Integer32
High transmit power alarm threshold in µW, accurate to 0.1 µW.
As per the MIB.
hh3cTransceiverPwrOutLoAlarm (1.3.6.1.4.1.25506.2.70.1.1.1.31)
read-only
Integer32
Low transmit power alarm threshold in µW, accurate to 0.1 µW.
As per the MIB.
hh3cTransceiverPwrOutHiWarn (1.3.6.1.4.1.25506.2.70.1.1.1.32)
read-only
Integer32
High transmit power warning threshold in µW, accurate to 0.1 µW.
As per the MIB.
hh3cTransceiverPwrOutLoWarn (1.3.6.1.4.1.25506.2.70.1.1.1.33)
read-only
Integer32
Low transmit power warning threshold in µW, accurate to 0.1 µW.
As per the MIB.
hh3cTransceiverRcvPwrHiAlarm (1.3.6.1.4.1.25506.2.70.1.1.1.34)
read-only
Integer32
High receive power alarm threshold in µW, accurate to 0.1 µW.
As per the MIB.
hh3cTransceiverRcvPwrLoAlarm (1.3.6.1.4.1.25506.2.70.1.1.1.35)
read-only
Integer32
Low receive power alarm threshold in µW, accurate to 0.1 µW.
As per the MIB.
hh3cTransceiverRcvPwrHiWarn (1.3.6.1.4.1.25506.2.70.1.1.1.36)
read-only
Integer32
High receive power warning threshold in µW, accurate to 0.1 µW.
As per the MIB.
hh3cTransceiverRcvPwrLoWarn (1.3.6.1.4.1.25506.2.70.1.1.1.37)
read-only
Integer32
Low receive power warning threshold in µW, accurate to 0.1 µW.
As per the MIB.
hh3cTransceiverErrors (1.3.6.1.4.1.25506.2.70.1.1.1.38)
read-only
BITS
BITS {
xcvrIOError(0),
xcvrChecksum(1),
xcvrTypeAndPortConfigMismatch(2),
xcvrTypeNotSupported(3),
wisLocalFault(4),
rcvOpticalPowerFault(5),
pmapmdReceiverLocalFault(6),
pcsReceiveLocalFault(7),
phyXSReceiveLocalFault(8),
laserBiasCurrentFault(9),
laserTemperatureFault(10),
laserOutputPowerFault(11),
txFault(12),
pmapmdTransmitterLocalFault(13),
pcsTransmitLocalFault(14),
phyXSTransmitLocalFault(15),
rxLossOfSignal(16),
tecError(17),
wavelengthUnlocked(18),
txIsNotReadyDueToTuning(19) ,
Unused(20-31)
Error information about the transceiver module.
As per the MIB.
hh3cTransceiverVendorOUI (1.3.6.1.4.1.25506.2.70.1.1.1.39)
read-only
SnmpAdminString
OCTET STRING (0..255)
Vendor OUI of the transceiver module.
As per the MIB.
hh3cTransceiverRevisionNumber (1.3.6.1.4.1.25506.2.70.1.1.1.40)
read-only
SnmpAdminString
Revision number of the transceiver module.
As per the MIB.
hh3cTransceiverFrequency (1.3.6.1.4.1.25506.2.70.1.1.1.41)
read-only
Integer32
Frequency of the transceiver module, in THz, accurate to 0.01 THz.
As per the MIB.
hh3cTransceiverActiveITUChannel (1.3.6.1.4.1.25506.2.70.1.1.1.42)
read-write
Unsigned32
Unsigned32 (1.. 2147483647)
Index of the current ITU channel.
As per the MIB.
hh3cTransceiverPartNumber (1.3.6.1.4.1.25506.2.70.1.1.1.49)
read-only
OCTET STRING
Part number of the transceiver module.
As per the MIB.
hh3cTransceiverProductCode (1.3.6.1.4.1.25506.2.70.1.1.1.50)
read-only
OCTET STRING
Product code of the transceiver module.
As per the MIB.
hh3cTransceiverOriginalSN (1.3.6.1.4.1.25506.2.70.1.1.1.51)
read-only
OCTET STRING
Original serial number of the transceiver module.
As per the MIB.
hh3cTransceiverPwrOutHiAlarmDbm (1.3.6.1.4.1.25506.2.70.1.1.1.52)
read-only
Integer32
High transmit power alarm threshold of the transceiver module.
As per the MIB.
hh3cTransceiverPwrOutLoAlarmDbm (1.3.6.1.4.1.25506.2.70.1.1.1.53)
read-only
Integer32
Low transmit power alarm threshold of the transceiver module.
As per the MIB.
hh3cTransceiverPwrOutHiWarnDbm (1.3.6.1.4.1.25506.2.70.1.1.1.54)
read-only
Integer32
High transmit power warning threshold of the transceiver module.
As per the MIB.
hh3cTransceiverPwrOutLoWarnDbm (1.3.6.1.4.1.25506.2.70.1.1.1.55)
read-only
Integer32
Low transmit power warning threshold of the transceiver module.
As per the MIB.
hh3cTransceiverRcvPwrHiAlarmDbm (1.3.6.1.4.1.25506.2.70.1.1.1.56)
read-only
Integer32
High receive power alarm threshold of the transceiver module.
As per the MIB.
hh3cTransceiverRcvPwrLoAlarmDbm (1.3.6.1.4.1.25506.2.70.1.1.1.57)
read-only
Integer32
Low receive power alarm threshold of the transceiver module.
As per the MIB.
hh3cTransceiverRcvPwrHiWarnDbm (1.3.6.1.4.1.25506.2.70.1.1.1.58)
read-only
Integer32
High receive power warning threshold of the transceiver module.
As per the MIB.
hh3cTransceiverRcvPwrLoWarnDbm (1.3.6.1.4.1.25506.2.70.1.1.1.59)
read-only
Integer32
Low receive power warning threshold of the transceiver module.
As per the MIB.
hh3cTransceiverRelySlotMfgName (1.3.6.1.4.1.25506.2.70.1.1.1.60)
read-only
OCTET STRING
Vendor name of the card on which the transceiver is installed.
As per the MIB.
hh3cTransceiverRelySlotMfgDate (1.3.6.1.4.1.25506.2.70.1.1.1.61)
read-only
DateAndTime
Manufacturing date of the card on which the transceiver is installed.
As per the MIB.
hh3cTransceiverCurrentPower (1.3.6.1.4.1.25506.2.70.1.1.1.62)
read-only
Integer32
Real-time power of the transceiver module, in milliwatts.
As per the MIB.
hh3cTransceiverMaxPower (1.3.6.1.4.1.25506.2.70.1.1.1.63)
read-only
Integer32
Maximum power of the transceiver module, in milliwatts.
As per the MIB.
hh3cTransceiverTotalTXPower(1.3.6.1.4.1.25506.2.70.1.1.1.64)
read-only
Integer32
Total transmit power of the transceiver module, in one-hundredth of a dBm.
As per the MIB.
hh3cTransceiverTotaRXPower(1.3.6.1.4.1.25506.2.70.1.1.1.65)
read-only
Integer32
Total receive power of the transceiver module, in one-hundredth of a dBm.
As per the MIB.
hh3cTransceiverChannelTable
About this table
This table contains information about the ITU channels for Ethernet fiber ports.
CreateNot supported
Edit/ModifyNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are ifIndex and hh3cTransceiverChannelIndex.
Object (OID)
Access
Value range
Implementation
hh3cTransceiverChannelIndex (1.3.6.1.4.1.25506.2.70.1.2.1.1)
not-accessible
Integer32
Integer32 (1..2147483647)
Transceiver module channel index.
As per the MIB.
hh3cTransceiverChannelCurTXPower (1.3.6.1.4.1.25506.2.70.1.2.1.2)
read-only
Integer32
Current transmit power in dBm, accurate to 0.01 dBm.
This object returns 2147483647 when read if this parameter is not supported.
hh3cTransceiverChannelCurRXPower (1.3.6.1.4.1.25506.2.70.1.2.1.3)
read-only
Integer32
Current receiver power in dBm, accurate to 0.01 dBm.
hh3cTransceiverChannelTemperature (1.3.6.1.4.1.25506.2.70.1.2.1.4)
read-only
Integer32
Current temperature in °C.
hh3cTransceiverChannelBiasCurrent (1.3.6.1.4.1.25506.2.70.1.2.1.5)
read-only
Integer32
Current bias current in mA, accurate to 0.01 mA.
hh3cTransceiverChanTXPwrHiAmDbm (1.3.6.1.4.1.25506.2.70.1.2.1.10)
read-only
Integer32
High transmit power alarm threshold.
As per the MIB.
hh3cTransceiverChanTXPwrLoAmDbm
(1.3.6.1.4.1.25506.2.70.1.2.1.11)
read-only
Integer32
Low transmit power alarm threshold.
As per the MIB.
hh3cTransceiverITUChanTable
About this table
This table contains information about all ITU channels.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are ifIndex and hh3cTransceiverITUChanIdx.
Object (OID)
Access
Value range
Implementation
hh3cTransceiverITUChanIdx (1.3.6.1.4.1.25506.2.70.1.3.1.1)
not-accessible
Unsigned32
Index of an ITU channel on the transceiver module.
As per the MIB.
hh3cTransceiverITUChanFreq (1.3.6.1.4.1.25506.2.70.1.3.1.2)
read-only
Integer32
Frequency of the ITU channel, in THz, accurate to 0.01 THz.
As per the MIB.
hh3cTransceiverITUChanWaveLth (1.3.6.1.4.1.25506.2.70.1.3.1.3)
read-only
Integer32
Wavelength of the ITU channel, in pm.
As per the MIB.
