Title | Size | Downloads |
21-Acronyms-book.pdf | 122.26 KB |
book | 122.26 KB |
H3C Network Technology Acronyms
# A B C D E F G H I K L M N O P Q R S T U V W X Z
10GE |
Ten-GigabitEthernet |
1DM |
One-way Delay Measurement |
3DES |
Triple Data Encryption Standard |
6PE |
IPv6 Provider Edge |
AAA |
Authentication, Authorization and Accounting |
AAL |
ATM Adaptation Layer |
AAL5 |
ATM Adaptation Layer 5 |
ABR |
Area Border Router |
AC |
Access Controller |
AC |
Access Circuit |
AC |
Attachment Circuit |
AC |
Access Category |
AC Name |
Access Concentrator Name |
ACA |
Acquire Change Authorization |
ACCM |
Async-Control-Character-Map |
ACFC |
Address-and-Control-Field-Compression |
ACFP |
Application Control Forwarding Protocol |
Ack |
Acknowledgment |
ACL |
Access Control List |
ACR |
Adaptive Clock Recovery |
ACS |
Auto-Configuration Server |
ACS |
AS Control Server |
ACSEI |
ACFP Client and Server Exchange Information |
Active-Stateful PCC |
Active-Stateful Path Computation Client |
Active-Stateful PCE |
Active-Stateful Path Computation Element |
AD |
Active Directory |
ADM |
ATM Direct Mapping |
ADP |
Add Diagnostic Parameter |
ADPCM |
Adaptive Differential Pulse Code Modulation |
ADR |
Adaptive Date Rate |
ADSL |
Asymmetric Digital Subscriber Line |
ADVPN |
Auto Discovery Virtual Private Network |
AER |
AS Edge Router |
AES |
Advanced Encryption Standard |
AF |
Assured Forwarding |
AFI |
Address Family Identifier |
AFI |
Authority and Format Identifier |
AFT |
Address Family Translation |
AFTR |
Address Family Transition Router |
AH |
Authentication Header |
AIFSN |
Arbitration Inter Frame Spacing Number |
AIGP |
Accumulated Interior Gateway Protocol Metric |
AIS |
Alarm Indication Signal |
AIW |
APPN Implementers Workshop |
AKM |
Authentication and Key Management |
ALG |
Application Level Gateway |
AM |
Analog Modem |
AMB |
Active Main Board |
AMI |
Alternate Mark Inversion |
A-MPDU |
Aggregate MAC Protocol Data Unit |
A-MSDU |
Aggregate MAC Service Data Unit |
ANCP |
Access Node Control Protocol |
ANI |
Adaptive Noise Immunity |
ANSI |
American National Standards Institute |
AP |
Access Point |
AP |
Agreement Protocol |
APD |
Avalanche Photo Diode |
APDB |
Access Point Information Database |
APoT |
AP of things |
APP |
Application Protocol |
APPN |
Advanced Peer-to-Peer Networking |
APR |
Application Recognition |
ARP |
Address Resolution Protocol |
ARQ |
Automatic Repeat Request |
AS |
Autonomous System |
ASBR |
Autonomous System Boundary Router |
ASM |
Any-Source Multicast |
ASPF |
Application Specific Packet Filter |
ASPF |
Advanced Stateful Packet Filter |
AT |
AppleTalk |
ATD |
Attribute Discovery |
ATM |
Asynchronous Transfer Mode |
AU |
Administration Unit |
AUG |
Administration Unit Group |
AU-PTR |
Administration Unit Pointer |
AVF |
Active Virtual Forwarder |
AVF |
Appointed VLAN-x Forwarder |
AVP |
Attribute Value Pair |
B4 |
Basic Bridging BroadBand |
B8ZS |
Bipolar 8-zero substitution |
BA |
Block Acknowledgment |
BAS |
Broadband Access Server |
BB_Credit |
Buffer-to-Buffer Credit |
BC |
Boundary Clock |
BC |
Bandwidth Constraint |
BCB |
Backbone Core Bridge |
BCMP |
Broadband-access-network Cluster Management Protocol |
BDF |
Backup DF |
BDI |
Backward Defect Indication |
BDR |
Backup Designated Router |
BE |
Best Effort |
BEB |
Backbone Edge Bridge |
BECN |
Backward Explicit Congestion Notification |
BF |
Build Fabric |
BFD |
Bidirectional Forwarding Detection |
BGP |
Border Gateway Protocol |
BGP-EPE |
BGP Egress Peer Engineering |
BIDIR-PIM |
Bidirectional Protocol Independent Multicast |
BIMS |
Branch Intelligent Management System |
BIP |
Bit-Interleaved Parity |
BIP |
Broadcast Integrity Protocol |
BITS |
Building Integrated Timing Supply System |
BLE |
Bluetooth Low Energy |
B-MAC |
Backbone MAC |
BMC |
Best Master Clock |
BMP |
BGP Monitoring Protocol |
BOOTP |
Bootstrap Protocol |
BPDU |
Bridge Protocol Data Unit |
BQ |
Bandwidth Queuing |
BRAS |
Broadband Remote Access Server |
BRI |
Basic Rate Interface |
BRPC |
Backward-Recursive PCE-Based Computation |
BSB |
Blockade State Block |
BSM |
Bootstrap Message |
BSMF |
Bootstrap Message Fragment |
BSR |
Bootstrap Router |
BSS |
Basic Service Set |
BSV |
BRI S/T Voice |
BT |
BitTorrent |
B-VLAN |
Backbone VLAN |
CA |
Certificate Authority |
CA |
Connectivity Association |
CAC |
Connect Admission Control |
CAMS |
Comprehensive Access Management Server |
CAPWAP |
Controlling and Provisioning of Wireless Access Point |
CAR |
Committed Access Rate |
CARP |
Cache Array Routing Protocol |
CB |
Controlling Bridge |
CB |
Customer Bridge |
CBQ |
Class Based Queuing |
CBR |
Constant Bit Rate |
CBS |
Committed Burst Size |
C-BSR |
Candidate-BSR |
CBT |
Core-Based Tree |
CBTS |
Class-of-service Based Tunnel Selection |
CBWFQ |
Class Based Weighted Fair Queuing |
CC |
Continuity Check |
CC |
Call Control |
CC |
Control Channel |
CC |
Challenge Collapsar |
CC |
Common Criteria |
CCA |
Clear Channel Assessment |
CCC |
Circuit Cross Connect |
CCF |
Congestion Controlled Flow |
CCM |
Continuity Check Message |
CD |
Computed Distance |
C-DCC |
Circular DCC |
CDCP |
S-Channel Discovery and Configuration Protocol |
CDP |
Cisco Discovery Protocol |
CDR |
Call Detail Record |
CDV |
Cell Delay Variation |
CE |
Customer Edge |
CED |
Called Station Identifier |
CEDCNG |
CEE |
Converged Enhanced Ethernet |
CEM |
Circuit Emulation |
CEM Class |
Circuit Emulation Class |
CESoPSN |
Circuit Emulation Services over PSN |
CFD |
Connectivity Fault Detection |
CFI |
Canonical Format Indicator |
CFM |
Connectivity Fault Management |
CGN |
Carrier Grade NAT |
CHAP |
Challenge Handshake Authentication Protocol |
CID |
Calling Identity Delivery |
CIDR |
Classless Inter-Domain Routing |
CIR |
Committed Information Rate |
CIR ALLOW |
Committed Information Rate ALLOW |
CIST |
Common and Internal Spanning Tree |
CLC |
Channel Link Control |
CLI |
Command Line Interface |
CLI |
Calling Line Identification |
CLNP |
Connection-Less Network Protocol |
CLP |
Cell Loss Priority |
CMC |
Call Management Center |
CNAME |
Canonical Name |
CND |
Congestion Notification Domain |
CNG |
Comfortable Noise Generation |
CNG |
Calling Tone |
CNGCED |
Calling Tone |
CNM |
Congestion Notification Message |
CNPV |
Congestion Notification Priority Value |
CO |
Central Office |
COPS |
Common Open Policy Service |
CoS |
Class of Service |
CP |
Congestion Point |
CP |
Control Plane |
CPE |
Customer Premises Equipment |
CPOS |
Channelized POS |
CPS |
Certification Practice Statement |
CPTone |
Call Progress Tone |
CQ |
Custom Queuing |
CR |
Constraint-based Routing |
CR |
Core Router |
CRC |
Cyclic Redundancy Check |
CRC |
Cyclic Redundancy Code |
CRC4 |
Cyclic Redundancy Check 4 |
CRL |
Certificate Revocation List |
CRLDP |
Constraint-based Routed Label Distribution Protocol |
CRLSP |
Constraint-based Routed Label Switched Paths |
C-RP |
Candidate-RP |
CS |
Class Selector |
CSMA/CD |
Carrier Sense Multiple Access/Collision Detect |
CSNP |
Complete Sequence Number PDU |
CSP |
Port Extender Control and Status Protocol |
CSPF |
Constraint-based Shortest Path First |
CST |
Common Spanning Tree |
CSV |
Comma Separated Value |
CT |
Class Type |
CTR |
Counter mode |
CTS |
Clear to Send |
CUG |
Closed User Group |
CV |
Connectivity Verification |
CWMP |
CPE WAN Management Protocol |
DAC |
Data Analysis Center |
DAC |
Digital to Analog Converter |
DAD |
Duplicate Address Detection |
DAE |
Dynamic Authorization Extensions |
DAR |
Deeper Application Recognition |
Data-MDT |
Data-Multicast Distribution Tree |
DBA |
Dynamic Bandwidth Allocation |
DCBX |
Data Center Bridging Exchange Protocol |
DCC |
Dial Control Center |
DCD |
Data Carrier Detection |
DCE |
Data Center Ethernet |
DCE |
Data Circuit-terminating Equipment |
DCF |
Distributed Coordination Function |
DCN |
Data Communication Network |
DCR |
Differential Clock Recovery |
DD |
Database Description |
DDN |
Digital Data Network |
DDNS |
Dynamic Domain Name System |
DDoS |
Distributed Denial of Service |
DDR |
Dial-on-Demand Routing |
DDT |
Delegated Database Tree |
DE |
Discard Eligibility |
DED |
Designated Edge Device |
Default-MDT |
Default-Multicast Distribution Tree |
DER |
Distinguished Encoding Rules |
DF |
Designated Forwarder |
DGAF |
Downstream Group-Addressed Forwarding |
DH |
Diffie-Hellman |
DHCP |
Dynamic Host Configuration Protocol |
DHCPv6 |
Dynamic Host Configuration Protocol for IPv6 |
DID |
Direct Inward Dialing |
DID |
Device ID |
DiffServ |
Differentiated Service |
DIS |
Designated IS |
DLCI |
Data Link Connection Identifier |
DLDP |
Device Link Detection Protocol |
DLSw |
Data Link Switching |
DM |
Diagnostic and Monitoring |
DM |
Delay Measurement |
DMC |
Device Management Controller |
DMM |
Delay Measurement Message |
DMR |
Delay Measurement Reply |
DMZ |
Demilitarized Zone |
DN |
Distinguished Name |
DN |
Directory Number |
DNAT |
Destination Network Address Translation |
DND |
Do-not Disturb |
DNS |
DNSSL |
DNS Search List |
DNU |
Do Not Use for synchronization |
DoD |
Downstream On Demand |
DoS |
Denial of Service |
DP |
Drop Profile |
DP |
Data Plane |
DPD |
Dead Peer Detection |
DPI |
Deep Packet Inspection |
DR |
Designated Router |
DR device |
Distributed Relay device |
DRB |
Designated Routing Bridge |
DRCP |
Distributed Relay Control Protocol |
DRCPDU |
Distributed Relay Control Protocol Data Unit |
DRE |
Data Redundancy Elimination |
DRNI |
Distributed Resilient Network Interconnect |
DRS |
DPI Report Statistics |
DS |
Differentiated Services |
DSA |
Digital Signature Algorithm |
DSCP |
Differentiated Services Code Point |
DSL |
DS-Lite |
Dual Stack Lite |
DSU |
Data Service Unit |
DTD |
Document Type Definition |
DTE |
Data Terminal Equipment |
DTIM |
Delivery Traffic Indication Message |
DTLS |
Datagram Transport Layer Security |
DTMF |
Dual Tone Multi-Frequency |
DU |
Downstream Unsolicited |
DUAL |
Diffusing Update Algorithm |
DUID |
DHCP Unique Identifier |
DUID-LL |
DUID Based on Link-layer Address |
D-V |
Distance Vector |
DVMRP |
Distance Vector Multicast Routing Protocol |
DVPN |
Dynamic Virtual Private Network |
DWDM |
Dense Wavelength Division Multiplexing |
E2ETC |
End-to-End Transparent Clock |
EAA |
Embedded Automation Architecture |
EACL |
Enhanced ACL |
EAD |
Endpoint Admission Defense |
EAIS |
Ethernet Alarm Indication Signal |
EAN |
Ethernet Access Node |
EAP |
Extensible Authentication Protocol |
EAPOL |
Extensible Authentication Protocol over LAN |
EAPOL KCK |
EAPOL-Key Confirmation Key |
EAPOL KEK |
EAPOL-Key Encryption Key |
EAP-TLS |
Extensible Authentication Protocol -Transport Layer Security |
EBS |
Excess Burst Size |
ECDSA |
Elliptic Curve Digital Signature Algorithm |
ECID |
E-channel Identifier |
ECM |
Encapsulated Control Message |
ECM |
Error Correction Mode |
ECN |
ECP |
Edge Control Protocol |
ECT |
Equal Cost Tree |
ECWmax |
Exponent form of CWmax |
ECWmin |
Exponent form of CWmin |
ED |
Edge Device |
EDCA |
Enhanced Distributed Channel Access |
EDSG |
Enhanced Dynamic Service Gateway |
EEE |
Energy Efficient Ethernet |
EF |
Expedited Forwarding |
EFM |
Ethernet First Mile |
EGP |
Exterior Gateway Protocol |
EID |
Endpoint Identifier |
EIGRP |
Enhanced Interior Gateway Routing Protocol |
EIRP |
Effective Isotropic Radiated Power |
EM |
Event Monitor |
EMO |
Endpoint Mobile Office |
EMR |
Ensure Minimum Rate |
ENDC |
EVI Neighbor Discovery Client |
ENDC |
Enhanced Neighbor Discovery Client |
End-Of-RIB |
End of Routing-Information-Base |
ENDP |
Enhanced Neighbor Discovery Protocol |
ENDP |
EVI Neighbor Discovery Protocol |
ENDS |
Enhanced Neighbor Discovery Server |
ENDS |
EVI Neighbor Discovery Server |
eNodeB |
evolved Node B |
ENUM |
Telephone Number Mapping |
EOAM |
Ethernet Operation, Administration and Maintenance |
EoPW |
Ethernet over Pseudo Wire |
EPC |
External Path Computation |
EPC |
Evolved Packet Core |
EPON |
Ethernet Passive Optical Network |
EPS |
Endpoints Profiling System |
ER |
Edge Relay |
ERPS |
Ethernet Ring Protection Switching |
ERSPAN |
Encapsulated Remote Switch Port Analyzer |
ERT |
Export Route-target |
ES |
End System |
ES |
Ethernet Segment |
ESF |
Extended Super Frame |
ESI |
Ethernet Segment Identifier |
ESMC |
Ethernet Synchronous Message Channel |
ESN |
Extended Sequence Number |
ESP |
Encapsulating Security Payload |
ESS |
Extended Service Set |
ESS |
Exchange Switch Support |
ETR |
Egress Tunnel Router |
ETS |
Enhanced Transmission Selection |
ETSI |
European Telecommunications Standards Institute |
EUI |
Extended Unique Identifier |
EUI-64 |
64-bit Extended Unique Identifier |
EVB |
Edge Virtual Bridging |
Event MIB |
Event Management Information Base |
EVFP |
Exchange Virtual Fabrics Parameter |
EVI |
Ethernet Virtual Interconnect |
EVPN |
Ethernet Virtual Private Network |
Extended-MAM |
Extended Maximum Allocation Model |
FA |
Foreign Agent |
FA |
Foreign-AC |
FAC |
Feature Access Code |
FAS |
Frame Alignment Signal |
FC |
Forwarding Class |
FC |
Fibre Channel |
FC |
Feasibility Condition |
FCF |
FCoE Forwarder |
FCM |
Fast Connect Modem |
FCoE |
Fibre Channel over Ethernet |
FCPS |
FC Port Security |
FCS |
Fabric Configuration Server |
FCS |
Frame Check Sequence |
FD |
Feasible Distance |
FDB |
Forwarding Database |
FDMI |
Fabric Device Management Interface |
FE |
Fast Ethernet |
FEAC |
Far End Alarm and Control signal |
FEC |
Forward Error Correction |
FEC |
Forwarding Equivalence Class |
FECN |
Forward Explicit Congestion Notification |
FEP |
Front End Processor |
FF |
Fixed-Filter |
FFD |
Fast Failure Detection |
FFT |
Fast Fourier Transform |
FG |
Forwarding Group |
FHR |
First Hop Router |
FIB |
Forwarding Information Base |
FIFO |
First In First Out |
FIFO |
First In First Out Queuing |
FIP |
FCoE Initialization Protocol |
FIP Snooping |
FCoE Initialization Protocol Snooping |
FIPS |
Federal Information Processing Standards |
Flowspec |
Flow Specification |
FNG |
Fault Notification Generator |
FP |
Forwarding Profile |
FPGA |
Field Programmable Gate Array |
FPMA |
Fabric Provided MAC Address |
FQ |
Fair Queuing |
FQDN |
Fully Qualified Domain Name |
FR |
Frame Relay |
FRR |
Fast Reroute |
FRTP |
Frame Relay Traffic Policing |
FRTS |
Frame Relay Traffic Shaping |
FRU |
Field Replaceable Unit |
FS |
Forced Switch |
FS |
Feasible Successor |
FSK |
Frequency Shift Keying |
FSPF |
Fabric Shortest Path First |
FT |
Fault Tolerance |
FT |
Fast BSS Transition |
FTN |
FEC to NHLFE map |
FTP |
File Transfer Protocol |
FXO |
Foreign Exchange Office |
FXS |
Foreign Exchange Station |
GAL |
G-ACh Label |
GARP |
Generic Attribute Registration Protocol |
GAS |
Generic Advertisement Service |
GDOI |
Group Domain of Interpretation |
GE |
Gigabit Ethernet |
GI |
Guard Interval |
GK |
GateKeeper |
GLB |
Global Load Balance |
GM |
Group Member |
GM |
Grandmaster Clock |
GMK |
Group Master Key |
GNE |
Gateway Network Element |
GNS |
Get Nearest Server |
GOLD |
Generic OnLine Diagnostics |
GPS |
Global Positioning System |
GR |
Graceful Restart |
GRE |
Generic Routing Encapsulation |
Group Domain VPN |
Group Domain Virtual Private Network |
gRPC |
Google Remote Procedure Call |
GSMPv3 |
General Switch Management Protocol Version 3 |
GTC |
Generic Token Card |
GTK |
Group Temporal Key |
GTP |
GPRS Tunneling Protocol |
GTP-U |
GPRS Tunneling Protocol User |
GTS |
Generic Traffic Shaping |
GTSM |
Generalized TTL Security Mechanism |
GVRP |
GARP VLAN Registration Protocol |
GW |
Gateway |
GWMP |
Gateway Message Protocol |
HA |
Home-AC |
HA |
High Availability |
HA |
Home Agent |
HABP |
HW Bypass Protocol |
HBA |
Host Bus Adapter |
HDB3 |
High-density bipolar 3 |
HDLC |
High-level Data Link Control |
HDSL |
High-speed Digital Subscriber Line |
HESSID |
Homogenous Extended Service Set IDentifier |
HGMP |
HW Group Management Protocol |
HGMPv2 |
HW Group Management Protocol version 2 |
HMAC |
Hash-based Message Authentication Code |
HoPE |
Hierarchy of PE |
HoVPN |
Hierarchy of VPN |
HQoS |
Hierarchical Quality of Service |
HS |
High-performance Switch |
HTTP |
Hypertext Transfer Protocol |
HTTPS |
Hypertext Transfer Protocol Secure |
H-VPLS |
Hierarchical VPLS |
HWTACACS |
HW Terminal Access Controller Access Control System |
IA |
Identity Association |
IACTP |
Inter Access Controller Tunneling Protocol |
IAD |
Integrated Access Device |
IANA |
Internet Assigned Numbers Authority |
IBGP |
Internal Border Gateway Protocol |
ICANN |
Internet Corporation for Assigned Names and Numbers |
ICMP |
Internet Control Message Protocol |
ICMPv6 |
Internet Control Message Protocol for IPv6 |
ICP |
IMA Control Protocol |
ICPIF |
Calculated Planning Impairment Factor |
ICRQ |
Incoming Call Request |
IDN |
Integrated Digital Network |
IDS |
Intrusion Detection System |
IE |
Information Element |
IE |
Interconnect Element |
IEEE |
Institute of Electrical and Electronics Engineers |
IETF |
Internet Engineering Task Force |
IGMP |
Internet Group Management Protocol |
IGMP Snooping |
Internet Group Management Protocol Snooping |
IGP |
Interior Gateway Protocol |
IGTK |
Integrity Group Temporal Key |
IIH |
Intermediate System-to-Intermediate System Hello |
IKE |
Internet Key Exchange |
IKEv2 |
Internet Key Exchange Version 2 |
ILM |
Incoming Label Map |
ILS |
Internet Locator Service |
IM |
Instant Messaging |
IMA |
Inverse Multiplexing for ATM |
IMAP |
Internet Mail Access Protocol |
iMC |
Intelligent Management Center |
IMSI |
International Mobile Subscriber Identification Number |
InARP |
Inverse Address Resolution Protocol |
IND |
Inverse Neighbor Discovery |
INT |
In-band Network Telemetry |
IntServ |
Integrated Service |
IPC |
Inter-process Communication |
IPE |
Image Package Envelope |
IPHC |
IP Header Compression |
IPL |
Intra-Portal Link |
IPN |
IGTK Packet Number |
IPng |
IP Next Generation |
IPoA |
IP over ATM |
IPoEoA |
IP over Ethernet over ATM |
IPP |
Intra-Portal Port |
IPS |
Intrusion Prevention System |
IPsec |
IP Security |
IPTA |
IP Terminal Access |
IPv6 |
Internet Protocol version 6 |
IPv6 MBGP |
IPv6 Multicast BGP |
IPv6 ND |
IPv6 Neighbor Discovery |
IPv6 PIM |
IPv6 Protocol Independent Multicast |
IPv6 PIM Snooping |
IPv6 Protocol Independent Multicast Snooping |
IPX |
Internetwork Packet Exchange |
IRB |
Integrated Bridging and Routing |
IRB |
Integrated Routing and Bridging |
IRB |
Integrated Routing Bridging and Bridging Routing |
IRDP |
ICMP Router Discovery Protocol |
IRF |
Intelligent Resilient Framework |
IS |
Intermediate System |
ISAKMP |
Internet Security Association and Key Management Protocol |
ISATAP |
Intra-Site Automatic Tunnel Addressing Protocol |
ISDN |
Integrated Services Digital Network |
I-SID |
Backbone Service Instance Identifier |
IS-IS |
Intermediate System-to-Intermediate System |
ISO |
International Organization for Standardization |
ISP |
Internet Service Provider |
ISPF |
Incremental Shortest Path First |
ISSU |
In-Service Software Upgrade |
IST |
ITA |
Intelligent Target Accounting |
ITR |
Ingress Tunnel Router |
ITSP |
Internet Telephone Service Provider |
ITU |
International Telecommunication Union |
ITU-T |
International Telecommunication Union Telecommunication |
IV |
Initialization Vector |
IVR |
Interactive Voice Response |
KAT |
Known-Answer Test |
KCK |
KEK |
Key Encrytion Key |
KEK |
KS |
Key Server |
L2F |
Layer 2 Forwarding |
L2PT |
Layer 2 Protocol Tunneling |
L2TP |
Layer 2 Tunneling Protocol |
L2VPN |
Layer 2 Virtual Private Network |
L3VNI |
Layer 3 VNI |
L3VPN |
Layer 3 Virtual Private Network |
LAC |
L2TP Access Concentrator |
LACP |
Link Aggregation Control Protocol |
LACPDU |
Link Aggregation Control Protocol Data Unit |
LAN |
Local Area Network |
LB |
Loopback |
LB |
Label Base |
LB |
Load Balance |
LBM |
Loopback Message |
LBR |
Loopback Reply |
LC |
Logic Channel |
LCFO |
Loop Current Feed Open |
LCI |
Logic Channel Identifier |
LCP |
Link Control Protocol |
LDAP |
Lightweight Directory Access Protocol |
LDN |
Local Dialing Number |
LDP |
LDP ID |
LDP Identifier |
LDPC |
Low-Density Parity Check |
LER |
Label Edge Router |
LFI |
Link Fragmentation and Interleaving |
LFIB |
Label Forwarding Information Base |
LGS |
Loop-start & Ground-start Signaling |
LHR |
Last-Hop Router |
LI |
Leap Indicator |
LLC |
Logical Link Control |
LLDP |
Link Layer Discovery Protocol |
LLDPDU |
Link Layer Discovery Protocol Data Unit |
LLDP-MED |
Link Layer Discovery Protocol Media Endpoint Discovery |
LLID |
Logical Link ID |
LLQ |
Low Latency Queuing |
LM |
Loss Measurement |
LMI |
Local Management Interface |
LMM |
Loss Measurement Message |
LMR |
Loss Measurement Reply |
LNS |
L2TP Network Server |
LO |
Label-block Offset |
LOCV |
Loss of Connectivity Verification defect |
LOID |
Logical ONU Identifier |
LoRaWAN |
Long Range Wide Area Network |
LOS |
Loss of Signal |
LPU |
Line Processing Unit |
LPU Port |
Line Processing Unit Port |
LQR |
Link Quality Reports |
LR |
Line Rate |
LR |
Label Range |
LS |
Link State |
LSA |
Link State Acknowledgment |
LSA |
Link State Advertisement |
LSAck |
LSDB |
Link State Database |
LSDB |
Link State DataBase |
LSN |
Large-scale NAT |
LSP |
Label Switched Path |
LSP |
Link State PDU |
LSPDU |
Link State Protocol Data Unit |
LSR |
Link State Request |
LSR |
Link State Record |
LSR |
Label Switching Router |
LSU |
Link State Update |
LT |
Linktrace |
LTM |
Linktrace Message |
LTR |
Linktrace Reply |
LTS |
L2TP Tunnel Switch |
LVF |
Listening Virtual Forwarder |
LZ |
Lempel-Ziv compression |
M flag |
Managed Address Configuration Flag |
MA |
Mobility Agent |
MA |
Maintenance Association |
MAC |
MAC |
Media Access Control |
MACsec |
Media Access Control Security |
MAD |
Multi-Active Detection |
MAM |
MAN |
Metropolitan Area Network |
MAP |
Mesh Access Point |
MBGP |
Multicast BGP |
MBS |
Maximum Burst Size |
MC |
Mobility Controller |
MCC |
Mobile Country Code |
MCE |
Multi-VPN-Instance Customer Edge |
MCS |
Modulation and Coding Scheme |
MCU |
Multipoint Control Unit |
MD |
Maintenance Domain |
MD |
Multicast Domain |
MDC |
Multitenant Device Context |
MDI |
Medium Dependent Interface |
MDL |
Maintenance Data Link |
mDNS |
Multicast DNS |
MDT |
ME |
Maintenance Entity |
MEC |
Multi-access Edge Computing |
MED |
Multi-Exit Discriminator |
MEG |
Maintenance Entity Group |
MEP |
Maintenance association End Point |
MEP |
MEG End Point |
MFAS |
Multiframe FAS |
MFC |
Multi-Frequency Compelled |
MFF |
MAC-Forced Forwarding |
MFR |
Multilink Frame Relay |
MGCP |
Media Gateway Control Protocol |
mGRE |
Multipoint Generic Routing Encapsulation |
MIB |
MIC |
Message Integrity Check |
MIMO |
Multiple Input, Multiple Output |
MIP |
Maintenance association Intermediate Point |
MIP |
Mobile IP |
MKA |
MACsec Key Agreement |
MKD |
Mesh Key Distributor |
MKI |
Master Key Identifier |
MLD |
Multicast Listener Discovery Protocol |
MLD Snooping |
Multicast Listener Discovery Snooping |
MLSP |
Mobile Link Switch Protocol |
MME |
Management MIC IE |
MNC |
Mobile Network Code |
MoH |
Music on Hold |
MOS |
Mean Opinion Scores |
MOTD |
Message of The Day |
MP |
Maintenance Point |
MP |
Mesh Point |
MP |
Merge Point |
MP_REACH_NLRI |
Multiprotocol Reachable NLRI |
MP_UNREACH_NLRI |
Multiprotocol Unreachable NLRI |
MP-BGP |
Multiprotocol Border Gateway Protocol |
MPCP |
Multipoint Control Protocol |
MPDU |
MPE |
Middle-Level PE |
MPLS |
Multiprotocol Label Switching |
MPLS SR |
Segment Routing with MPLS |
MPLS TE |
Multiprotocol Label Switching Traffic Engineering |
MPLS VPN |
MPLS Virtual Private Network |
MPLS-TP |
MPLS Transport Profile |
MPP |
Mesh Portal Point |
MQC |
Model QoS Command |
MR |
Map Resolver |
MR |
Merge Request |
MRIB |
Multicast Routing Information Base |
MRP |
Multiple Registration Protocol |
MRPDU |
MRP Protocol Data Unit |
MRRA |
Merge Request Resource Allocation |
MRU |
Maximum-Receive-Unit |
MS |
Manual Switch |
MS |
Map Server |
MSCHAP |
Microsoft Challenge Handshake Authentication Protocol |
MSDP |
Multicast Source Discovery Protocol |
MSDU |
MSK |
Multicast Session Key |
MSOH |
Multiplex Section Overhead |
MSS |
Maximum Segment Size |
MSTI |
Multiple Spanning Tree Instance |
MSTP |
Multiple Spanning Tree Protocol |
MT |
Multicast Tunnel |
MTI |
Multicast Tunnel Interface |
MTP |
Maintain Probe |
MTR |
Multi-Topology Routing |
MTU |
Maximum Transmission Unit |
MTU-s |
Multi-Tenant Unit switch |
MU |
Mobile Unit |
MVPN |
Multicast Virtual Private Network |
MVRP |
Multiple VLAN Registration Protocol |
MVXLAN |
Multicast VXLAN |
MWI |
Message Waiting Indication |
MX |
Mail Exchanger |
NA |
Neighbor Advertisement |
NAI |
Network Access Identifier |
NAPT |
Network Address Port Translation |
NAPT-PT |
Network Address Port Translation-Protocol Translation |
NAS |
Network Access Service |
NAS |
Network Access Server |
NAS-ID |
Network Access Server Identifier |
NAS-Port-ID |
Network Access Server Port Identifier |
NAS-VLAN-ID |
Network Access Server VLAN Identifier |
NAT |
NAT-PT |
Network Address Translation-Protocol Translation |
NBAR |
Network Based Application Recognition |
NBMA |
Non-Broadcast Multi-Access |
NCP |
Network Control Protocol |
ND |
NDA |
NetStream Data Analyzer |
NDE |
NetStream Data Exporter |
NDP |
NDPP |
Network Device Protection Profile |
NE |
Network Element |
NEMO |
Network Mobility |
NET |
Network Entity Title |
NetBIOS |
Network Basic Input/Output System |
NETCONF |
Network Configuration Protocol |
NFAS |
non–FAS |
NFV |
Network Function Virtualisation |
NHLFE |
Next Hop Label Forwarding Entry |
NHRP |
Next Hop Resolution Protocol |
NI |
National ISDN |
NIB |
Nexthop Information Base |
NII |
Network International Identifier |
NIST |
National Institute of Standards and Technology |
NIT |
Not Initial Terminal |
NLB |
Network Load Balancing |
NLBS |
Network Load Balancing Service |
NLPID |
Network Layer Protocol Identifier |
NLRI |
Network Layer Reachability Information |
NM |
Network Management |
NMFAS |
Non-Multiframe FAS |
NMS |
Network Management Station |
NMS |
Network Management System |
NMS |
Network Management Server |
NNI |
Network-to-Network Interface |
NO-PAT |
Not Port Address Translation |
NPDU |
Network Protocol Data Unit |
NPE |
Network Provider Edge |
NPTv6 |
IPv6-to-IPv6 Network Prefix Translation |
NPV |
N_Port Virtualization |
NQA |
Network Quality Analyzer |
NR |
No Request |
nrt-VBR |
non-real-time Variable Bit Rate |
NS |
Neighbor Solicitation |
NS |
Name Server |
NSAP |
Network Service Access Point |
NSC |
NetStream Collector |
NSF |
Non-Standard Facilities |
NSR |
Nonstop Routing |
NSS |
Number of Spatial Streams |
NTDP |
Neighbor Topology Discover Protocol |
NTE |
Named Telephone Event |
NTP |
Network Time Protocol |
NTT |
Nippon Telegraph and Telephone Corpration |
NVC |
Network Virtualization Controller |
NVE |
Network Virtualization Edge |
NVGRE |
Network Virtualization using Generic Routing Encapsulation |
O Flag |
Other Stateful Configuration Flag |
OAA |
Open Application Architecture |
OAMPDU |
OAM Protocol Data Unit |
OAP |
Open Application Platform |
OC |
Optical Carrier |
OC |
Ordinary Clock |
ODAP |
On-Demand Address Pool |
ODF |
Optical Distribution Frame |
ODN |
Optical Distribution Network |
ODU |
Optical Data Unit |
OEM |
Original Equipment Manufacturer |
OFDM |
Orthogonal Frequency Division Multiplexing |
OI |
Organization Identifier |
OID |
Object Identifier |
OLT |
Optical Line Terminal |
ONU |
Optical Network Unit |
OOB |
Out-of-Band |
OPU |
Optical Payload Unit |
ORF |
Outbound Route Filtering |
OSI |
Open System Interconnection |
OSPF |
Open Shortest Path First |
OSU |
Online Sign Up |
OTN |
Optical Transport Network |
OTU |
Optical Transmit Unit |
OUI |
Organizationally Unique Identifier |
OVSDB |
Open vSwitch Database |
P2MP |
Point-to-MultiPoint |
P2P |
PW to PW |
P2P |
Peer-to-Peer |
P2P |
Point-to-Point |
P2PTC |
Peer-to-Peer Transparent Clock |
PA |
Provider Allocated |
PADT |
PPPoE Active Discovery Terminate |
PAGP |
Port Aggregation Protocol |
PAM |
Port to Application Map |
PAM |
Pulse Amplitude Modulation |
PAN ID |
Personal Area Network Identifier |
PAP |
Password Authentication Protocol |
Passive-Stateful PCC |
Passive-Stateful Path Computation Client |
Passive-Stateful PCE |
Passive-Stateful Path Computation Element |
PAT |
PBAR |
Port Based Application Recognition |
PBB |
Provider Backbone Bridge |
PBBN |
Provider Backbone Bridge Network |
PBN |
Provider Bridge Network |
PBR |
Policy-based Routing |
PBX |
Private Branch Exchange |
PCB |
Protocol Control Block |
PCC |
PCE |
PCEP |
Path Computation Element Communication Protocol |
PCM |
PCR |
Peak Cell Rate |
PD |
Powered Device |
PD |
Prefix Delegation |
PDH |
Plesiochronous Digital Hierarchy |
PDP |
Policy Decision Point |
PDU |
PE |
Provider Edge |
PE-agg |
PE Aggregation |
PEAP |
Protected Extensible Authentication Protocol |
PEAP-GTC |
Protected Extensible Authentication Protocol-Microsoft Generic Token Card |
PEAP-MSCHAPv2 |
Protected Extensible Authentication Protocol-Microsoft Challenge Handshake Authentication Protocol v2 |
PEM |
Privacy Enhanced Mail |
PEM |
Power Entry Module |
PEP |
Policy Enforcement Point |
PFC |
Power Free Connector |
PFC |
Priority-based Flow Control |
PFC |
Protocol-Field-Compression |
PFS |
Perfect Forward Secrecy |
PHB |
Per-hop Behavior |
PHP |
Penultimate Hop Popping |
PI |
Power Interface |
PI |
Provider Independent |
PI |
Progress Indicator |
PIC |
Prefix Independent Convergence |
PIM |
PIM Snooping |
PIM-DM |
Protocol Independent Multicast-Dense Mode |
PIM-SM |
Protocol Independent Multicast-Sparse Mode |
PIM-SSM |
Protocol Independent Multicast Source-Specific Multicast |
PIN |
Personal Identification Number |
PIR |
Peak Information Rate |
PKCS |
Public Key Cryptography Standards |
PKI |
Public Key Infrastructure |
PLCP |
Physical Layer Convergence Procedure |
PLMN |
Public Land Mobile Network |
PLR |
Point of Local Repair |
PMK |
Pairwise Master Key |
PMTU |
Path MTU |
PoE |
Power over Ethernet |
POH |
Path Overhead |
POP3 |
Post Office Protocol - Version 3 |
POS |
Passive Optical Splitter |
POS |
Point of Sale |
PPP |
Point-to-Point Protocol |
PPPoA |
PPP over ATM |
PPPoE |
Point-to-Point Protocol over Ethernet |
PPPoEoA |
PPPoE over ATM |
PPTP |
Point-to-Point Tunneling Protocol |
PQ |
Priority Queuing |
PRBS |
Pseudo Random Bit Sequence |
PRC |
Primary Reference Clock |
PRI |
Primary Rate Interface |
PRL |
Preferred Roaming List |
PS |
PSB |
Path State Block |
PSC |
Protection State Coordination |
PSD |
Power Spectral Density |
PSE |
Power Sourcing Equipment |
PSK |
Pre-Shared Key |
PSN |
Packet Switched Network |
PSNP |
Partial Sequence Number PDU |
PSST |
Principal Switch Selection Timer |
PSTN |
Public Switched Telephone Network |
PTK |
Pairwise Transient Key |
PTP |
Precision Time Protocol |
PTR |
Pointer Record |
PTY |
Pseudo-Terminals |
PUK |
PIN Unlocking Key |
PVC |
Permanent Virtual Circuit |
PVC PQ |
PVC Priority Queuing |
PVID |
Port VLAN ID |
PVP |
Permanent Virtual Path |
PVST |
Per-VLAN Spanning Tree |
PW |
Pseudowire |
PW-ACH |
PW Associated Channel Header |
PWCT |
Pairwise Conditional Test |
PWE3 |
Pseudo Wire Emulation Edge-to-Edge |
PXE |
Preboot eXecution Environment |
QCN |
Quantized Congestion Notification |
QL |
Quality Level |
QoS |
QPPB |
QoS Policy Propagation Through the Border Gateway Protocol |
RA |
Router Alert |
RA |
Router Advertisement |
RA |
Registration Authority |
RADIUS |
Remote Authentication Dial-In User Service |
RAI |
Remote Alarm Indication |
RALM |
RADIUS Authenticated Login Using MAC-address |
R-APS |
Ring Automatic Protection Switching |
RAS |
Registration, Admission, and Status |
RB |
Routing Bridge |
RBAC |
Role Based Access Control |
RBM |
Remote Backup Management |
RCA |
Release Change Authorization |
RCF |
Reconfigure Fabric |
RCPI |
Received Channel Power Indicator |
RD |
Routing Domain |
RD |
Reported Distance |
RD |
Route Distinguisher |
RDI |
Remote Defect Indication |
RDM |
Russian Dolls Model |
RDP |
Read Diagnostic Parameters |
RED |
Random Early Detection |
RedisDBM |
Redis Database Manager |
REG |
Registration Center |
RFID |
Radio Frequency Identification |
RIB |
RIP |
Routing Information Protocol |
RIP-2 |
Routing Information Protocol version 2 |
RIPng |
RIP next generation |
RIR |
Resilient Intelligent Route |
RLOC |
Routing Locator |
RLSN |
Remote Link Status Notification |
RMON |
Remote Network Monitoring |
ROA |
Recognized operating Agency |
Roam OI |
Roam Organization Identifier |
RP |
Rendezvous Point |
RP |
Reflective Relay |
RP |
Reaction Point |
RPA |
Register Port Attributes |
RPA |
Rendezvous Point Address |
RPC |
RPF |
Reverse Path Forwarding |
RPI |
Receive Power Indication |
RPKI |
Resource Public Key Infrastructure |
RPL |
Rendezvous Point Link |
RPL |
Ring Protection Link |
RPR |
Resilient Packet Ring |
RPRT |
Register Port |
RPS |
Redundant Power System |
RP-Set |
Rendezvous Point Set |
RPT |
Rendezvous Point Tree |
RR |
Route Reflector |
RR |
Reflective Relay |
RR |
Router Renumber |
RRI |
Reverse Route Injection |
RRM |
Radio Resource Management |
RRPP |
Rapid Ring Protection Protocol |
RS |
Router Solicitation |
RSB |
Reservation State Block |
RSCN |
Registered State Change Notification |
RS-DCC |
Resource-Shared DCC |
RSH |
Remote Shell |
RSN |
Robust Security Network |
RSNA |
Robust Security Network Association |
RSNI |
Received Signal to Noise Indicator |
RSOH |
Regenerator Section Overhead |
RSSI |
Received Signal Strength Indicator |
RSSI |
Received Signal Strength Indication |
RSTP |
Rapid Spanning Tree Protocol |
RSVP |
Resource Reservation Protocol |
RT |
Route Target |
RTC |
Remote Terminal Connection |
RTCP |
Real-Time Transport Control Protocol |
RTM |
Real-Time Event Manager |
RTP |
Reliable Transport Protocol |
RTP |
Real-Time Transport Protocol |
RTPQ |
Real-Time Transport Protocol Priority Queuing |
RTS |
Request to Send |
RTSP |
Real Time Streaming Protocol |
RTT |
Round-Trip Time |
rt-VBR |
Real-time Variable Bit Rate |
RU |
Rack Unit |
S/MIME |
Secure/Multipurpose Internet Mail Extensions |
SA |
Security Association |
SA |
Source Active |
SA Query |
Security Association Query |
SABM |
Set Asynchronous Balanced Mode |
SACK |
Selective Acknowledgment |
SAE |
Simultaneous authentication of equals |
SAFI |
Subsequent Address Family Identifier |
SAII |
Source Attachment Individual Identifier |
SAM |
Security Accounting Management |
SAN |
Storage Area Networks |
SAP |
Service Advertising Protocol |
SAToP |
Structure-Agnostic TDM over Packet |
SAVI |
Source Address Validation Improvement |
SB |
Service Bridge |
SBFD |
Seamless BFD |
SBM |
Subnetwork Bandwidth Management |
SCCP |
Skinny Client Control Protocol |
SCEP |
Simple Certificate Enrollment Protocol |
SCFF |
Single Choke Fairness Frame |
SCR |
Sustainable Cell Rate |
SCR |
State Change Registration |
SD |
Signal Degrade |
SDH |
Synchronous Digital Hierarchy |
SDLC |
Synchronous Data Link Control |
SDN |
Software Defined Network |
SDP |
Session Description Protocol |
SDSL |
Symmetric Digital Subscriber Line |
SDU |
Service Data Unit |
SE |
Shared-Explicit |
SEC |
SDH Equipment Clock |
SF |
Super Frame |
SF |
Signal Fail |
SFC |
Stage Fabric Configuration Update |
sFlow |
Sampled Flow |
SFM |
Source-Filtered Multicast |
SFP |
Small Form-factor Pluggable |
SFTP |
Secure FTP |
Short GI |
Short Guard Interval |
SIA |
Stuck In Active |
SID |
SIP |
Session Initiation Protocol |
SIPS |
SIP Secure |
SLA |
Service Level Agreement |
SLAAC |
Stateless Address Autoconfiguration |
SLB |
Server Load Balance |
SLC |
Service Logic Control |
SLIP |
Serial Line Internet Protocol |
SLM |
Single-ended Loss Measurement |
SMA |
State Machine based Anti-spoofing |
SmartMC |
Smart Management Center |
SMET |
Selective Multicast Ethernet Tag Route |
S-MLAG |
Simple Multichassis Link Aggregation |
SMTP |
Simple Mail Transfer Protocol |
SN |
Serial Number |
SNA |
System Network Architecture |
SNAP |
Subnet Access Protocol |
SNAT |
Source Network Address Translation |
SNMP |
Simple Network Management Protocol |
SNMP-DCA |
SNMP Data Collection Agent |
SNP |
SNPA |
Subnetwork Point of Attachment |
SNR |
Signal-to-Noise Ratio |
SNTP |
Simple NTP |
SOA |
Start of Authority |
SOAP |
Simple Object Access Protocol |
SOH |
Section Overhead |
SONET |
Synchronous Optical Network |
SoO |
Site of Origin |
SP |
Strict Priority |
SP |
Service Provider |
SP |
Scheduler Policy |
SPB |
Shortest Path Bridging |
SPBM |
Shortest Path Bridging MAC Mode |
SPBM |
Shortest Path Bridging MAC |
SPBN |
Shortest Path Bridging Network |
SPCS |
Stored Program Control Switching System |
SPE |
Superstratum PE or Service Provider-end PE |
SPF |
SPI |
Security Parameter Index |
SPID |
Service Profile Identification |
SPM |
Smart PoE Manager |
SPSource ID |
Shortest Path Source Identifier |
SPT |
Shortest Path Tree |
SQL |
Structured Query Language |
SR |
Segment Routing |
Srefresh |
Summary Refresh |
SRGB |
Segment Routing Global Block |
SRLB |
Segment Routing Local Block |
SRLSP |
Segment Routing Label Switched Path |
SRMC |
Segment Routing Mapping Client |
SRMS |
Segment Routing Mapping Server |
SRST |
Survivable Remote Site Telephony |
sr-TCM |
single rate TCM |
SRTP |
Secure Real-Time Transport Protocol |
SRV |
Service |
SSA |
SIP Stack Adapt |
SSH |
Secure Shell |
SSID |
Service Set Identifier |
SSL |
Secure Sockets Layer |
SSM |
Synchronization Status Message |
SSM |
SSP |
Switch-to-Switch Protocol |
SSU-A |
primary level SSU |
SSU-B |
second level SSU |
ST |
Shared Tree |
Stateful PCE |
Stateless PCC |
Stateless Path Computation Client |
Stateless PCE |
Stateless Path Computation Element |
STBC |
Space-Time Block Coding |
STP |
STR |
Switch Trace Route |
SVC |
Static Virtual Circuit |
SVC |
Switched Virtual Circuit |
SVP |
SpectraLink Voice Priority |
TA |
Terminal Adapter |
TACACS |
TACL |
Temporary Access Control List |
TAI |
International Atomic Time |
TAII |
Target Attachment Individual Identifier |
T-BC |
Telecom Boundary Clock |
TC |
Topology Checksum |
TC |
Topology Change |
TC |
Topology client |
TC |
Traffic Class |
TC |
Transparent Clock |
TCA |
Topology Change Acknowledge |
TCAM |
Ternary Content Addressable Memory |
TCI |
Tag Control Information |
Tcl |
Tool Command Language |
TCN BPDU |
Topology Change Notification BPDU |
TCP |
Transmission Control Protocol |
TCT-BC |
Transparent Telecom Boundary Clock |
TDM |
Time Division Multiplexing |
TDMA |
Time Division Multiple Access |
TE |
TEDB |
TE DataBase |
TEI |
Terminal Endpoint Identifier |
TEID |
Tunnel Endpoint Identifier |
TEK |
Tranfic Encrytion Key |
TFO |
Transport Flow Optimization |
TFTP |
Trivial File Transfer Protocol |
TI-LFA FRR |
Topology-Independent Loop-free Alternate Fast Reroute |
TIM |
Traffic Indication Map |
TK |
Temporal Key |
TKIP |
Temporal Key Integrity Protocol |
TLS |
TLS |
Transparent LAN Service |
TLV |
Type/Length/Value |
TM |
Topology Master |
ToS |
Type of Service |
TP |
Traffic Policing |
TP |
Topology Protection |
TPA |
Third-part Application |
TPC |
Transmit Power Control |
TPDU |
Transport Protocol Data Unit |
TPID |
Tag Protocol Identifier |
TPMR |
Two-Port MAC Relay |
TQ |
Time Quantum |
TRILL |
TRansparent Interconnection of Lots of Links |
TRIP |
Triggered RIP |
tr-TCM |
two-rate TCM |
TS |
Traffic Shaping |
TSA |
Tunnel Switching Aggregator |
TST |
Test |
T-TC |
Telecom Transparent Clock |
TTI |
Trail Trace Identifier |
TTL |
Time to Live |
TTLS |
Tunneled Transport Layer Security |
TTLS-GTC |
Tunneled Transport Layer Security-Microsoft Generic Token Card |
TTLS-MSCHAPv2 |
Tunneled Transport Layer Security-Microsoft Challenge Handshake Authentication Protocol v2 |
T-TSC |
Telecom Time Slave Clock |
TTY |
True Type Terminal |
TU |
Tributary Unit |
TUG |
Tributary Unit Group |
TWAMP |
Two-Way Active Measurement Protocol |
TxBF |
Tx Beamforming |
TXOP Limit |
Transmission Opportunity Limit |
TXT |
Text |
UA |
Unnumbered Acknowledge |
UA |
User Agent |
UAC |
User Agent Client |
U-APSD |
Unscheduled Automatic Power-Save Delivery |
UAS |
User Agent Server |
UBR |
Unspecified Bit Rate |
UCM |
User Connection Management |
UDLD |
Uni-directional Link Direction |
UDP |
User Data Protocol |
UE |
User Equipment |
UFC |
Update Fabric Configuration |
UIM |
User Identity Module |
UNI |
User-to-Network Interface |
UNI |
User Network Interface |
UPE |
User facing-Provider Edge |
UPE |
Underlayer PE or User-end PE |
URI |
Uniform Resource Identifier |
URL |
Uniform Resource Locator |
uRPF |
Unicast Reverse Path Forwarding |
USK |
Unicast Session Key |
USM |
User-Based Security Model |
UTC |
Coordinated Universal Time |
UTM |
Unified Threat Management |
V2V |
Video to Video |
VA |
Virtual Access |
VACM |
View-based Access Control Model |
VAD |
Voice Activity Detection |
VAM |
VPN Address Management |
VBR-NRT |
Variable Bit Rate-Non Real Time |
VBR-RT |
Variable Bit Rate-Real Time |
VC |
Virtual Circuit |
VC |
Virtual Container |
VCC |
Virtual Circuit Connection |
VCCV |
Virtual Circuit Connectivity Verification |
VCF |
Vertical Converged Framework |
VCFC |
VCF Controller |
VCI |
Virtual Channel Identifier |
VCN |
Virtual Circuit Number |
VCPM |
Voice Co-processing Module |
VD |
Virtual Device |
VDP |
VSI Discovery and Configuration Protocol |
VDSL |
Very high-speed Digital Subscriber Line |
VE |
Virtual Ethernet |
VE-Bridge |
Virtual Ethernet Bridge |
VEth |
Virtual Ethernet |
VF Owner |
Virtual Forwarder Owner |
VFW |
Virtual Firewall |
VLAN |
Virtual Local Area Network |
VM |
Virtual Machine |
VMM |
Virtual Machine Management |
VN |
Version Number |
VNC |
Virtual Network Computing |
VNI |
VXLAN Network Identifier |
VoD |
Video on Demand |
VoIP |
Voice over IP |
VP |
Virtual Path |
VPC |
Virtual Path Connection |
VPC |
Virtual Private Cloud |
VPDN |
Virtual Private Dial-up Network |
VPI |
Virtual Path Identifier |
VPLS |
Virtual Private LAN Service |
VPM |
Voice Processing Module |
VPN |
VPWS |
Virtual Private Wire Service |
VR |
Virtual Router |
VRF |
Virtual Routing and Forwarding |
VRRP |
Virtual Router Redundancy Protocol |
VSAN |
Virtual Storage Area Network |
VSD |
Virtual Security Domain |
VSI |
Virtual Switch Instance |
VSI |
Virtual Station Interface |
VSID |
Virtual Subnet Identifier |
VSIP |
Virtual Service IP |
VSRP |
Virtual Service Redundancy Protocol |
vSwitch |
Virtual Switch |
VT |
Virtual Template |
VTEP |
VXLAN Tunnel End Point |
VTP |
VLAN Trunking Protocol |
VTY |
Virtual Type Terminal |
VXLAN |
Virtual eXtensible LAN |
VXLAN-DCI |
VXLAN Data Center Interconnection |
WAAS |
Wide Area Application Services |
WAF |
Web Application Firewall |
WAI |
WLAN Authentication Infrastructure |
WAN |
Wide Area Network |
WAP |
Wireless Application Protocol |
WAPI |
WLAN Authentication and Privacy Infrastructure |
WASS |
WDS |
Wireless Distribution System |
WEP |
Wired Equivalent Privacy |
WFQ |
WHA |
WLAN High Availability |
WIDS |
Wireless Intrusion Detection System |
WiNet |
Wisdom Network |
WINS |
Windows Internet Naming Service |
WIPS |
Wireless Intrusion Prevention System |
WLAN |
Wireless Local Area Network |
WLAN RRM |
WMM |
Wi-Fi Multimedia |
WPA |
Wi-Fi Protected Access |
WPAD |
Web Proxy Auto-Discovery |
WPI |
WLAN Privacy Infrastructure |
WRED |
Weighted Random Early Detection |
WRR |
Weighted Round Robin |
WSA |
Wireless Spectrum Analysis |
WT |
Wireless Terminator |
WTU |
Wireless Terminator Unit |
WWN |
World Wide Name |
XFP |
10-Gigabit Small Form-factor Pluggable |
XML |
Extensible Markup Language |
XSD |
XML Schema Document |
XSD |
XML Schema Definition |
ZBR |
Zone Border Router |
