01-Fundamentals Command Reference
HomeSupportRouters5G IPRAN Access RoutersReference GuidesCommand ReferencesH3C RA5100-G Routers Command Reference-R7752-6W10001-Fundamentals Command Reference
05-Login management commands
05-Login management commands 304.67 KB
Some login management commands are available in both user line view and user line class view. For these commands, the device uses the following rules to determine the settings to be activated:
·     A setting in user line view applies only to the user line. A setting in user line class view applies to all user lines of the class.
·     A non-default setting in either view takes precedence over the default setting in the other view. A non-default setting in user line view takes precedence over the non-default setting in user line class view.
·     A setting in user line class view takes effect on login sessions that are established after the setting is configured.
acl
Use acl to bind an ACL to control user access to or from the device by filtering users in a user line.
Use undo acl to cancel the binding with an ACL.
acl [ ipv6 ] { acl-number | name acl-name }
undo acl [ ipv6 ]
The system does not control user access to or from the device by filtering users in a user line.
User line view
ipv6: Specifies the IPv6 ACL type. If you do not specify this keyword, this command specifies the IPv4 ACL type.
acl-number: Specifies an ACL by its ID, in the range of 2000 to 2999.
name acl-name: Specifies an ACL by its name, a case-insensitive string of 1 to 63 characters. The name must start with a letter, in the range of a to z or A to Z. To avoid ambiguity, an ACL name cannot be all.
Operating mechanism
After you execute this command to bind an ACL to a user line, only users whose IP addresses match the permit rules in the ACL can be allocated to the user line and access other devices after login.
If you specify an ACL that does not exist or the specified ACL has no rules, the system does not filter users.
Only VTY lines support this command.
# Configure only users with IP address 1.1.1.1 to be allocated to user lines VTY 0 through VTY 4 when the users log in to the device.
[Sysname] acl basic 2000
[Sysname-acl-ipv4-basic-2000] rule permit source 1.1.1.1 0
[Sysname] line vty 0 4
[Sysname-line-vty0-4] acl 2000
acl (ACL and QoS Command Reference)
activation-key
Use activation-key to set the terminal session activation key. Pressing this shortcut key starts a terminal session.
Use undo activation-key to restore the default.
activation-key key-string
undo activation-key
The terminal session activation key is Enter.
User line view
User line class view
key-string: Specifies a shortcut key. It can be a character (case sensitive), or an ASCII code value in the range of 0 to 127. For example, if you execute activation-key 1, the shortcut key is Ctrl+A. If you execute activation-key a, the shortcut key is a. For information about ASCII code values of individual characters, see the standard ASCII code chart. For information about ASCII code values of combined keys that use the Ctrl key, see Table 1.
This command is not supported in VTY line view or VTY line class view.
This command takes effect immediately.
This command is available in both user line view and user line class view. A non-default setting in either view takes precedence over the default setting in the other view. A non-default setting in user line view takes precedence over the non-default setting in user line class view.
You can use only the specified terminal session activation key to start a terminal session. To display the current terminal session activation key, use the display current-configuration | include activation-key command.
Table 1 ASCII code values for combined keys that use the Ctrl key
Combined key
ASCII code value
Ctrl+A
1
Ctrl+B
2
Ctrl+C
3
Ctrl+D
4
Ctrl+E
5
Ctrl+F
6
Ctrl+G
7
Ctrl+H
8
Ctrl+I
9
Ctrl+J
10
Ctrl+K
11
Ctrl+L
12
Ctrl+M
13
Ctrl+N
14
Ctrl+O
15
Ctrl+P
16
Ctrl+Q
17
Ctrl+R
18
Ctrl+S
19
Ctrl+T
20
Ctrl+U
21
Ctrl+V
22
Ctrl+W
23
Ctrl+X
24
Ctrl+Y
25
Ctrl+Z
26
# Configure character s as the terminal session activation key for console line 0.
[Sysname] line console 0
[Sysname-line-console0] activation-key s
To verify the configuration:
1.     Exit the console session.
[Sysname-line-console0] return
<Sysname> quit
2.     Log in again through the console line.
The following message appears:
Press ENTER to get started.
3.     Press Enter.
Pressing Enter does not start a session.
4.     Press s.
A terminal session is started.
<Sysname>
authentication-mode
Use authentication-mode to set the authentication mode for a user line.
Use undo authentication-mode to restore the default.
authentication-mode { none | password | scheme }
The authentication mode is none for console login.
The authentication mode is password for the VTY line.
User line view
none: Disables authentication.
password: Performs local password authentication.
scheme: Performs AAA authentication. For more information about AAA, see Security Configuration Guide.
CAUTION
CAUTION:
·     When authentication is disabled, users can login without authentication. For security purpose, disable authentication with caution.
·     When you enable password authentication, you must also configure an authentication password for the line or line class. If no authentication password is configured, you cannot log in to the device through the line or line class at the next time.
·     When you enable scheme authentication, make sure an authentication user account is available. If no authentication user account is available, you cannot log in to the device through the line or line class at the next time.
Only users assigned the network-admin or level-15 user role can execute this command. Other users cannot execute this command, even if they are granted the right to execute this command.
In VTY line view, this command is associated with the protocol inbound command. If one command has a non-default setting in VTY line view, the other command uses its setting in VTY line view, regardless of its setting in VTY line class view.
An authentication mode change does not take effect on the current session. It takes effect on subsequent login sessions.
# Enable the none authentication mode for VTY line 0.
[Sysname-line-vty0] authentication-mode none
# Enable password authentication for VTY line 0 and set the password to hello12345.
[Sysname-line-vty0] authentication-mode password
[Sysname-line-vty0] set authentication password simple hello12345
# Enable scheme authentication for VTY line 0. Configure local user test and set the password to hello12345. Assign the Telnet service and the user role network-admin to the user.
[Sysname-line-vty0] authentication-mode scheme
[Sysname-line-vty0] quit
[Sysname] local-user test
[Sysname-luser-manage-test] password simple hello12345
[Sysname-luser-manage-test] authorization-attribute user-role network-admin
auto-execute command
Use auto-execute command to specify the command to be automatically executed for a login user.
Use undo auto-execute command to restore the default.
auto-execute command command
No command is specified to be automatically executed for a login user.
User line view
command: Specifies the command to be automatically executed.
CAUTION
CAUTION:
After executing this command for a user line, you might be unable to access the CLI through the user line. Make sure you can access the CLI through a different user line before you execute this command and save the configuration.
The device will automatically execute the specified command when a user logs in through the user line, and close the user connection after the command is executed.
This command is not supported in console line view or console line class view.
A configuration change made by this command does not take effect on the current session. It takes effect on subsequent login sessions.
# Configure the device to automatically execute the telnet 192.168.1.41 command when a user logs in through VTY line 0.
[Sysname-line-vty0] auto-execute command telnet 192.168.1.41
This action will lead to configuration failure through line-vty0. Are you sure?
[Y/N]:y
[Sysname-line-vty0]
# To verify the configuration, Telnet to the device (192.168.1.40).
The device automatically Telnets to 192.168.1.41. The following output is displayed on the configuration terminal:
C:\> telnet 192.168.1.40
* Copyright (c) 2004-2019 New H3C Technologies Co., Ltd. All rights reserved.*
Trying 192.168.1.41 ...
Press CTRL+K to abort
Connected to 192.168.1.41 ...
<Sysname.41>
This operation is the same as directly logging in to the device at 192.168.1.41 through Telnet. When you close the Telnet connection to 192.168.1.41, the Telnet connection to 192.168.1.40 is closed at the same time.
command accounting
Use command accounting to enable command accounting.
Use undo command accounting to disable command accounting.
command accounting
Command accounting is disabled. The accounting server does not record executed commands.
User line view
When command accounting is enabled but command authorization is not, every executed command is recorded on the HWTACACS server. When both command accounting and command authorization are enabled, only authorized commands that are executed are recorded on the HWTACACS server.
Invalid commands are not recorded.
After you execute the command accounting command in user line class view, you cannot execute the undo command accounting command in any user line views in the class.
# Enable command accounting for VTY line 0.
[Sysname-line-vty0] command accounting
accounting command (Security Command Reference)
Use command authorization to enable command authorization.
Use undo command authorization to disable command authorization.
Command authorization is disabled. Logged-in users can execute commands without authorization.
User line view
When command authorization is enabled, commands available for a user vary by the user's login authentication mode.
·     If authentication is disabled or password authentication is enabled, command authorization does not take effect, and the user cannot use any commands.
·     If scheme authentication is enabled, commands available for a user vary by the user's access authentication method.
¡     If local authentication is used, the device uses the user roles assigned to the user to perform command authorization.
¡     If remote authentication is used, the remote authorization server performs command authorization to determine whether a command entered by a login user is permitted. If remote authorization fails, the device uses the user roles of a local user with the same name as the login user to determine whether the command can be used. If the authorization also fails, the login user cannot use the command.
Command authorization configuration changes in user line class view do not take effect on the current session. The changes take effect only on subsequent login sessions. Command authorization configuration changes in user line view take effect immediately on all users that access the user line.
If you use the command authorization command in user line class view, command authorization is enabled for all user lines in the class. You cannot use the undo command authorization command in the view of a user line in the class.
# Enable command authorization for VTY line 0.
[Sysname-line-vty0] command authorization
authorization command (Security Command Reference)
command accounting
display line
Use display line to display user line information.
display line [ number1 | { console | vty } number2 ] [ summary ]
number1: Specifies the absolute number of a user line.
console: Specifies the console line.
vty: Specifies the VTY line.
number2: Specifies the relative number of a user line.
summary: Displays summary information about user lines. If you do not specify this keyword, the command displays detailed information.
# Display information about line 0.
<Sysname> display line 0
  Idx  Type     Tx/Rx      Modem Auth  Int        Location
F 0    CON 0    9600       -     N     -           0/0
  +    : Line is active.
  F    : Line is active and in async mode.
  Idx  : Absolute index of line.
  Type : Type and relative index of line.
  Auth : Login authentication mode.
  Int  : Physical port of the line.
  A    : Authentication use AAA.
  N    : No authentication is required.
  P    : Password authentication.
Modem
Whether the modem allows calling in or out. By default, this attribute is not configured and this field displays a hyphen (-).
Int
Physical port for the line. If there is no physical port for the line or the port is a console port, this field displays a hyphen (-).
Location
Physical position of the line.
# Display summary information about all user lines.
<Sysname> display line summary
  Line type : [CON]
           0:UXXX XXXX XX
  Line type : [VTY]
          10:UUUX XXXX XXXX XXXX
          26:XXXX XXXX XXXX XXXX
          42:XXXX XXXX XXXX XXXX
          58:XXXX XXXX XXXX XXXX
   4 lines used.      (U)
  70 lines not used.  (X)
Fields
Line type
Type of the user line:
·     CON—Console line.
·     VTY—VTY line.
number:status
number: Absolute number of the first user line in the user line class.
status: User line status. X is for unused and U is for used.
display telnet client
Use display telnet client to display the packet source setting for the Telnet client.
This command displays the source IPv4 address or source interface specified for the Telnet client to use in outgoing Telnet packets, depending on the telnet client source command.
# Display the packet source setting for the Telnet client.
<Sysname> display telnet client
 The source IP address is 1.1.1.1.
display user-interface
Use display user-interface to display user line information.
display user-interface [ number1 | { console |  vty } number2 ] [ summary ]
summary: Displays summary information about user lines. If you do not specify this keyword, the detailed information is displayed.
This command is an older version reserved for backward compatibility purposes. It has the same functionality and output as the display line command. As a best practice, use the display line command.
<Sysname> display user-interface 0
  +    : Line is active.
Modem
Int
Location
<Sysname> display user-interface summary
  Line type : [CON]
           0:UXXX XXXX XX
  Line type : [VTY]
   4 lines used.      (U)
Table 5 Command output
Fields
Line type
·     CONConsole line.
·     VTYVTY line.
number:status
display users
Use display users to display online CLI users.
display users [ all ]
all: Displays all user lines supported by the device.
# Display online user information.
<Sysname> display users
  Idx  Line     Idle       Time              Pid     Type
  10   VTY 0    00:10:49   Jun 11 11:27:32   320     TEL
+ 11   VTY 1    00:00:00   Jun 11 11:39:40   334     TEL
Following are more details.
VTY 0   :
        User role list: network-admin network-operator
VTY 1   :
        User role list: level-0 network-admin network-operator
 +    : Current operation user.
 F    : Current operation user works in async mode.
Table 6 Command output
Idx
Absolute number of the user line.
Line
Type and relative number of the user line.
Idle
Time elapsed after the user's most recent input, in the hh:mm:ss format.
Time
Login time of the user.
Pid
Process ID of the user session.
User type:
·     TEL—Telnet user.
·     SSH—SSH user.
For a user who logged in through the console port, this field does not display anything.
User line you are using.
User name
Username used by the user.
This field is displayed only if the user provided a username and password for authentication at login.
User role list
User roles assigned to the user.
Location
IP address of the user.
escape-key
Use escape-key to set the escape key.
Use undo escape-key to disable the escape key.
escape-key { key-string | default }
undo escape-key
The escape key is Ctrl+C.
User line view
key-string: Specifies a shortcut key. It can be a case-sensitive character except for d and D, or an ASCII code value in the range of 0 to 127. For example, if you execute escape-key 1, the shortcut key is Ctrl+A. If you execute escape-key a, the shortcut key is a. If you specify character d or D for this argument, the actual shortcut key is Ctrl+C. To use d or D as the shortcut key, you must specify the ASCII code value of the character for this argument. For information about ASCII code values of individual characters, see the standard ASCII code chart. For information about ASCII code values of combined keys that use the Ctrl key, see Table 1.
default: Restores the default escape key Ctrl+C.
You can press the escape key to abort a command that is being executed, for example, a ping or tracert command. Whether a command can be aborted by Ctrl+C by default depends on the software implementation of the command. For more information, see the usage guidelines for the command.
As a best practice, use a key sequence as the escape key. If you define a single character as the escape key, pressing the key while a command is being executed stops the command. If no command is being executed, pressing the key enters the character as a common character. If you Telnet from the device to a remote device, pressing the key enters the character as a common character on the remote device. The key acts as the escape key on the remote device only when the following conditions are met:
·     You define the same character as the escape key on the remote device.
·     You press the key while a command is being executed on the remote device.
The undo escape-key command disables the current escape key. After you execute this undo command, no escape key is available.
The setting in user line view takes effect immediately on the current session. The setting in user line class view takes effect on login sessions that are established after the setting is configured.
To display the current escape key, use the display current-configuration | include escape-key command.
# Configure character a as the escape key for VTY line 0.
[Sysname-line-vty0] escape-key a
5.     Ping IP address 192.168.1.49, specifying the -c keyword to set the number of ICMP echo request packets to 20.
<Sysname> ping -c 20 192.168.1.49
Ping 192.168.1.49 (192.168.1.49): 56 data bytes, press 'a' to break
56 bytes from 192.168.1.49: icmp_seq=0 ttl=255 time=1.000 ms
56 bytes from 192.168.1.49: icmp_seq=1 ttl=255 time=0.000 ms
6.     Press a.
The system aborts the command and returns to user view.
--- Ping statistics for 192.168.1.49 ---
20 packet(s) transmitted, 20 packet(s) received, 0.0% packet loss
round-trip min/avg/max/std-dev = 0.000/0.200/1.000/0.400 ms
<Sysname>
free line
Use free line to release a user line.
free line { number1 | { console | vty } number2 }
This command does not release the line you are using.
# Release VTY line 1.
<Sysname> free line vty 1
Are you sure to free line vty1? [Y/N]:y
 [OK]
free user-interface
Use free user-interface to release a user line.
free user-interface { number1 | { console | vty } number2 }
This command is an older version reserved for backward compatibility purposes. It has the same functionality and output as the free line command. As a best practice, use the free line command.
<Sysname> free user-interface vty 1
 [OK]
history-command max-size
Use history-command max-size to set the size of the command history buffer for a user line.
Use undo history-command max-size to restore the default.
history-command max-size size-value
The command history buffer for a user line stores up to 10 history commands.
User line view
size-value: Specifies the maximum number of history commands the buffer can store, in the range of 0 to 256.
Each user line uses a separate command history buffer to store commands successfully executed by its user. The buffer size determines how many history commands the buffer can store.
To display history commands in the buffer for your session, press the up or down arrow key, or execute the display history-command command. For more information about the command history buffer, see Fundamentals Configuration Guide.
Terminating a CLI session clears the commands in the command history buffer.
# Set the command history buffer size to 20 for VTY line 0.
[Sysname-line-vty0] history-command max-size 20
idle-timeout
Use idle-timeout to set the CLI connection idle-timeout timer.
Use undo idle-timeout to restore the default.
undo idle-timeout
The CLI connection idle-timeout timer is 10 minutes.
User line view
minutes: Specifies the number of minutes, in the range of 0 to 35791.
seconds: Specifies the number of seconds, in the range of 0 to 59. The default is 0 seconds.
The system automatically terminates a user connection if no information interaction occurs on the connection within the idle-timeout interval.
To disable the idle-timeout feature, execute the idle-timeout 0 command.
# Set the CLI connection idle-timeout timer to 1 minute and 30 seconds for VTY line 0.
[Sysname-line-vty0] idle-timeout 1 30
line
Use line to enter one or multiple user line views.
line { first-number1 [ last-number1 ] | { console | vty } first-number2 [ last-number2 ] }
first-number1: Specifies the absolute number of the first user line.
last-number1: Specifies the absolute number of the last user line. This number must be greater than first-number1.
first-number2: Specifies the relative number of the first user line.
last-number2: Specifies the relative number of the last user line. This number must be greater than first-number2.
# Enter the view of VTY line 0.
[Sysname-line-vty0]
# Enter the views of VTY lines 0 to 63.
[Sysname] line vty 0 63
[Sysname-line-vty0-63]
line class
line class
Use line class to enter user line class view.
line class { console | vty }
console: Specifies the console line class view.
vty: Specifies the VTY line class view.
To configure the same settings for all user lines of a line class, use this command to enter the user line class view.
In user line class view, you can execute the following commands:
·     activation-key
·     auto-execute command
·     authentication-mode
·     command accounting
·     command authorization
·     escape-key
·     history-command max-size
·     idle-timeout
·     protocol inbound
·     screen-length
·     set authentication password
·     shell
·     terminal type
·     user-role
For commands that are available in both user line view and user line class view, the device uses the following rules to determine the settings to use:
·     A setting in user line class view takes effect only on users who log in after the setting is made. It does not affect users who have been online before the setting is made.
# Set the CLI connection idle-timeout timer to 15 minutes in VTY line class view.
[Sysname] line class vty
[Sysname-line-class-vty] idle-timeout 15
line
lock
Use lock to lock the current user line and set the password for unlocking the line.
lock
The system does not lock any user lines.
This command locks the current user line to prevent unauthorized users from using the line. You must set the password for unlocking the line as prompted. The user line is locked after you enter the password and confirm the password.
To unlock the user line, press Enter and enter the password you set.
# Lock the current user line and set the password for unlocking the line.
<Sysname> lock
Please input password<1 to 16> to lock current line:
Password:
Again:
                   locked !
// The user line is locked. To unlock it, press Enter and enter the password:
Password:
<Sysname>
lock reauthentication
Use lock reauthentication to lock the current user line and enable unlocking authentication.
The system does not lock any user lines or initiate reauthentication.
This command locks the current user line. To unlock the user line, you must press Enter and provide the login password to pass reauthentication. If you have changed the login password after login, you must provide the new password. If no login password is set, the system unlocks the user line after you press Enter.
# Lock the current user line and enable unlocking authentication.
<Sysname> lock reauthentication
Please press Enter to unlock the screen.
// The user line is locked. To unlock it, press Enter and enter the login password:
Password:
<Sysname>
lock-key
lock-key
Use lock-key to set the user line locking key. Pressing this shortcut key locks the current user line and enables unlocking authentication.
Use undo lock-key to restore the default.
lock-key key-string
undo lock-key
No user line locking key is set.
User line view
key-string: Specifies a shortcut key. It can be a character (case sensitive), or an ASCII code value in the range of 0 to 127. For example, if you execute lock-key 1, the shortcut key is Ctrl+A. If you execute lock-key a, the shortcut key is a. For information about ASCII code values of individual characters, see the standard ASCII code chart. For information about ASCII code values of combined keys that use the Ctrl key, see Table 1.
As a best practice, specify a combined key as the user line locking key. If you specify a single character as the key, the character acts only as the user line locking key. You cannot type the character for any commands, keywords, or arguments.
Pressing the user line locking key is equivalent to executing the lock reauthentication command.
To display the current user line locking key, use the display current-configuration | include lock-key command.
# Set the user line locking key to Ctrl+A for VTY line 0.
[Sysname-line-vty0] lock-key 1
7.     Press Ctrl+A.
[Sysname]
8.     Press Enter and enter the login password.
Password:
[Sysname]
protocol inbound
Use protocol inbound to specify the supported protocols.
Use undo protocol inbound to restore the default.
All protocols are supported.
VTY line view
VTY line class view
all: Supports all protocols, including SSH, PAD, and Telnet.
ssh: Supports SSH only.
telnet: Supports Telnet only.
A configuration change in user line view does not take effect on the current session. It takes effect on subsequent login sessions.
Before configuring a user line to support SSH, set the authentication mode to scheme for the user line.
In VTY line view, this command is associated with the authentication-mode command. If one command has a non-default setting in VTY line view, the other command uses its setting in VTY line view, regardless of its setting in VTY line class view.
# Enable user lines VTY 0 through VTY 4 to support only SSH.
[Sysname-line-vty0-4] authentication-mode scheme
[Sysname-line-vty0-4] protocol inbound ssh
# Enable SSH support and set the authentication mode to scheme in VTY line class view. Enable user lines VTY 0 through VTY 4 to support all protocols and disable authentication for the user lines.
[Sysname-line-class-vty] authentication-mode scheme
[Sysname-line-class-vty] protocol inbound ssh
[Sysname-line-class-vty] line vty 0 4
[Sysname-line-vty0-4] authentication-mode none
9.     Telnet to the device.
<Client> telnet 192.168.1.241
Trying 192.168.1.241 ...
Connected to 192.168.1.241 ...
<Server>
You are logged in without authentication.
10.     Display online CLI user information. The output shows that you are using VTY 0. The configuration in user line view is effective.
<Server> display users
+ 50   VTY 0    00:00:00   Jan 17 15:29:27   189     TEL
VTY 0   :
authentication-mode
restful http enable
Use restful http enable to enable RESTful access over HTTP.
Use undo restful http enable to disable RESTful access over HTTP.
restful http enable
RESTful access over HTTP is disabled.
For users to access the device through the HTTP-based RESTful API, you must enable RESTful access over HTTP.
# Enable RESTful access over HTTP.
[Sysname] restful http enable
restful https enable
Use restful https enable to enable RESTful access over HTTPS.
Use undo restful https enable to disable RESTful access over HTTPS.
RESTful access over HTTPS is disabled.
For users to access the device through the HTTPS-based RESTful API, you must enable RESTful access over HTTPS.
# Enable RESTful access over HTTPS.
[Sysname] restful https enable
restful https ssl-server-policy
Use restful https ssl-server-policy to apply an SSL server policy to the RESTful access over HTTPS service.
Use undo restful https ssl-server-policy to restore the default.
restful https ssl-server-policy policy-name
No SSL server policy is applied to the RESTful access over HTTPS service.
policy-name: Specifies an SSL server policy name, a string of 1 to 31 characters.
The RESTful access over HTTPS service will use the SSL server policy to enhance service security. For more information about SSL server policies, see SSL configuration in Security Configuration Guide.
You can execute this command only when RESTful access over HTTPS is disabled.
This command takes effect after you enable RESTful access over HTTPS.
After the RESTful access over HTTPS service is enabled, changes to the applied SSL server policy do not take effect. For the changes to take effect, you must disable the service and then enable the service again.
# Apply SSL server policy myssl to the RESTful access over HTTPS service.
[Sysname] restful https ssl-server-policy myssl
ssl server-policy (Security Command Reference)
screen-length
Use screen-length to set the maximum number of lines of command output to send to the terminal at a time when the screen pausing feature is enabled.
Use undo screen-length to restore the default.
screen-length screen-length
undo screen-length
A maximum of 24 lines are sent.
User line view
screen-length: Specifies the maximum number of lines to send, in the range of 0 to 512. To send command output without pausing, set the number to 0 or execute the screen-length disable command.
The number of lines that can be displayed on the terminal screen is restricted by both this setting and the display specification of the terminal. For example, if this setting is 40, the device sends 40 lines to the terminal at a time. If the terminal display specification is 24 lines, only the last 24 lines are displayed on the terminal screen. To view the previous 16 lines, you must press PgUp.
To continue to display command output after a pause, press the space bar.
By default, pausing between screens of output is enabled.
# Set the maximum number of lines to send at a time to 30 for VTY line 0.
[Sysname-line-vty0] screen-length 30
send
Use send to send messages to online login users.
send { all | number1 | { console | vty } number2 }
all: Specifies all user lines.
You can use this command to send notifications to online users before performing an operation that might affect other online users, for example, before rebooting the device.
To end a message, press Enter. To abort the send operation, press Ctrl+C.
# Send a notification to the user on VTY 1.
<Sysname> send vty 1
Input message, end with Enter; abort with CTRL+C:
Your attention, please. I will reboot the system in 3 minutes.
Send message? [Y/N]:y
The message should appear on the user's terminal screen as follows:
[Sysname]
***Message from vty0 to vty1
Use set authentication password to set the password for local password authentication.
Use undo set authentication password to restore the default.
set authentication password { hash | simple } string
No password is set for local password authentication.
User line view
hash: Specifies a password in hashed form.
simple: Sets a password in plaintext form. For security purposes, the password specified in plaintext form will be stored in hashed form.
string: Specifies the password. Its plaintext form is a case-sensitive string of 4 to 16 characters and must contain a minimum of two character types. Its hashed form is a case-sensitive string of 1 to 110 characters.
A password change does not take effect on the current session. It takes effect on subsequent login sessions.
The device supports login password complexity check.
·     If a user logs in to the device with the default password, the system forcibly requests the user to change its password to a password that meets the system requirements.
·     If a user logs in to the device with a less complicated password (not the default password), the system prompts the user to change its password. As a best practice to ensure device security, change the password to a password that meets the system requirements.
# Set the password to hello12345 for local password authentication on VTY line 0.
authentication-mode
shell
Use shell to enable the terminal service for user lines.
Use undo shell to disable the terminal service for user lines.
shell
undo shell
The terminal service is enabled on all user lines.
User line view
You cannot disable the terminal service on the user line you are using.
When the device acts as a Telnet or SSH server, you cannot execute the undo shell command.
If the undo shell command is executed in user line class view, you cannot execute the shell command in the view of a user line in the class.
When terminal service is enabled, a user line can be used for device login. If the device is acting as the redirect server, the user line can also be used for the redirect service. However, the user line can be used for only one purpose at a time.
# Disable the terminal service for VTY lines VTY 0 through 4 so no user can log in to the device through the user lines.
[Sysname-line-vty0-4] undo shell
Disable ui-vty0-4 , are you sure? [Y/N]:y
speed
Use speed to set the transmission rate (also called the baud rate) on a user line.
Use undo speed to restore the default.
speed speed-value
undo speed
The transmission rate is 9600 bps on a user line.
User line view
speed-value: Specifies the transmission rate in bps.
This command is not supported in VTY line view.
The configuration terminal and the device must be configured with the same transmission rate to communicate.
# Set the transmission rate to 19200 bps for console line 0.
[Sysname-line-console0] speed 19200
telnet
Use telnet to Telnet to a host in an IPv4 network.
telnet remote-host [ service-port ] [ vpn-instance vpn-instance-name ] [ source { interface  interface-type interface-number | ip ip-address } | dscp dscp-value ] *
remote-host: Specifies the IPv4 address or host name of a remote host. A host name can be a case-insensitive string of 1 to 253 characters. Valid characters include letters, digits, hyphens (-), underscores (_), and dots (.).
service-port: Specifies the TCP port number for the Telnet service on the remote host. The value range is 0 to 65535 and the default is 23.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN instance to which the remote host belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the remote host belongs to the public network, do not specify this option.
source: Specifies a source IPv4 address or source interface for outgoing Telnet packets. If you do not specify this option, the device uses the primary IPv4 address of the output interface for the route to the server as the source address.
interface interface-type interface-number: Specifies the source interface. The primary IPv4 address of the interface will be used as the source IPv4 address for outgoing Telnet packets.
ip ip-address: Specifies the source IPv4 address for outgoing Telnet packets.
dscp dscp-value: Specifies a DSCP value for outgoing Telnet packets. The value range is 0 to 63. The default is 48. The DSCP value is carried in the TOS field of an IPv4 packet to indicate the packet transmission priority.
To terminate the current Telnet connection, press Ctrl+K or execute the quit command.
The source address or interface specified by this command is applied only to the Telnet connection that is being established.
# Telnet to host 1.1.1.2, using 1.1.1.1 as the source IP address for outgoing Telnet packets.
<Sysname> telnet 1.1.1.2 source ip 1.1.1.1
Use telnet client source to specify a source IPv4 address or source interface for the Telnet client to use for outgoing Telnet packets.
Use undo telnet client source to restore the default.
No source IPv4 address or source interface is specified. The Telnet client uses the primary IPv4 address of the output interface for the route to the server as the source IPv4 address.
interface interface-type interface-number: Specifies a source interface. The primary IPv4 address of the interface will be used as the source IPv4 address for outgoing Telnet packets.
ip ip-address: Specifies a source IPv4 address.
The setting configured by this command applies to all Telnet connections but has a lower precedence than the source setting specified for the telnet command.
# Set the source IPv4 address to 1.1.1.1 for outgoing Telnet packets.
[Sysname] telnet client source ip 1.1.1.1
display telnet client configuration
telnet ipv6
Use telnet ipv6 to Telnet to a host in an IPv6 network.
telnet ipv6 remote-host [ -i interface-type interface-number ] [ port-number ] [ vpn-instance vpn-instance-name ] [ source { interface interface-type interface-number | ipv6 ipv6-address } | dscp dscp-value ] *
remote-host: Specifies the IPv6 address or host name of a remote host. A host name can be a case-insensitive string of 1 to 253 characters. Valid characters include letters, digits, hyphens (-), underscores (_), and dots (.).
-i interface-type interface-number: Specifies the interface for sending Telnet packets. This option is required when the remote host address is a link-local address. When the server address is a global unicast address, you cannot specify this option.
port-number: Specifies the TCP port number for the Telnet service on the remote host. The value range is 0 to 65535 and the default is 23.
source: Specifies a source IPv6 address or source interface for outgoing Telnet packets. If you do not specify this option, the device uses the primary IPv6 address of the output interface for the route to the server as the source address.
interface interface-type interface-number: Specifies the source interface. The primary IPv6 address of the interface will be used as the source IPv6 address for outgoing Telnet packets.
ipv6 ipv6-address: Specifies the source IPv6 address for outgoing Telnet packets.
dscp dscp-value: Specifies a DSCP value for outgoing Telnet packets. The value range is 0 to 63. The default is 48. The DSCP value is carried in the Traffic class field of an IPv6 packet to indicate the packet transmission priority.
# Telnet to the host at 5000::1.
<Sysname> telnet ipv6 5000::1
# Telnet to the host at 2000::1. Use 1000::1 as the source address for outgoing Telnet packets.
<Sysname> telnet ipv6 2000::1 source ipv6 1000::1
telnet server acl
Use telnet server acl to apply an ACL to filter Telnet logins.
Use undo telnet server acl to restore the default.
telnet server acl [ mac ] { ipv4-acl-number | name ipv4-acl-name }
No ACL is used to filter Telnet logins.
mac: Specifies a Layer 2 ACL. To specify an ACL of a different type, do not specify this keyword.
ipv4-acl-number: Specifies an IPv4 ACL by its number. If you specify the mac keyword, the value range of this argument is 4000 to 4999. If you do not specify the mac keyword, the value range of this argument is 2000 to 3999.
name ipv4-acl-name: Specifies a basic/advanced/Layer 2 IPv4 ACL by its name, a case-insensitive string of 1 to 63 characters. The name must start with a letter, in the range of a to z or A to Z. To avoid ambiguity, an ACL name cannot be all.
When no ACL is applied to the Telnet service, all users can Telnet to the device. To control Telnet logins, specify an ACL that exists and has rules so that only users permitted by the ACL can Telnet to the device. If you specify an ACL that does not exist or does not have rules, no users can Telnet to the device.
If a VPN instance is specified in an ACL rule, the ACL rule applies only to the packets of the VPN instance. If no VPN instance is specified in an ACL rule, the ACL rule applies only to the packets on the public network.
For more information about ACL, see ACL and QoS Configuration Guide.
This command does not take effect on existing Telnet connections.
# Permit only the user at 1.1.1.1 to Telnet to the device.
[Sysname] acl basic 2001
[Sysname] telnet server acl 2001
telnet server acl-deny-log enable
Use telnet server acl-deny-log enable to enable logging for Telnet login attempts that are denied by the Telnet login control ACL.
Use undo telnet server acl-deny-log enable to disable logging for Telnet login attempts that are denied by the Telnet login control ACL.
Logging is disabled for Telnet login attempts that are denied by the Telnet login control ACL.
Only clients permitted by the Telnet login control ACL can Telnet to the device. This logging feature generates log messages for Telnet login attempts that are denied by the Telnet login control ACL.
For information about log message output, see the information center in Network Management and Monitoring Configuration Guide. For information about configuring a Telnet login control ACL, see the telnet server acl or telnet server ipv6 acl command.
# Enable logging for Telnet login attempts that are denied by the Telnet login control ACL.
[Sysname] telnet server acl-deny-log enable
telnet server acl
telnet server dscp
Use telnet server dscp to specify the DSCP value for IPv4 to use for Telnet packets sent to a Telnet client.
Use undo telnet server dscp to restore the default.
telnet server dscp dscp-value
IPv4 uses the DSCP value 48 for Telnet packets sent to a Telnet client.
dscp-value: Specifies a DSCP value in the range of 0 to 63.
The DSCP value is carried in the ToS field of an IPv4 packet to indicate the packet transmission priority.
# Set the DSCP value for IPv4 to use for outgoing Telnet packets to 30 on a Telnet server.
[Sysname] telnet server dscp 30
telnet server enable
Use telnet server enable to enable the Telnet server.
Use undo telnet server enable to disable the Telnet server.
The Telnet server is disabled.
Users can Telnet to the device only when the Telnet server is enabled.
# Enable the Telnet server.
Use telnet server ipv6 acl to apply an IPv6 ACL to filter IPv6 Telnet logins.
Use undo telnet server ipv6 acl to restore the default.
telnet server ipv6 acl { ipv6 | mac } { ipv6-acl-number | name ipv6-acl-name }
No IPv6 ACL is used to filter IPv6 Telnet logins.
ipv6: Specifies an IPv6 ACL.
mac: Specifies a Layer 2 IPv6 ACL. To specify an ACL of a different type, do not specify this keyword.
ipv6-acl-number: Specifies an ACL by its number. If you specify the ipv6 keyword, the value range of this argument is 2000 to 3999. If you specify the mac keyword, the value range of this argument is 4000 to 4999.
name ipv6-acl-name: Specifies a basic/advanced/Layer 2 IPv6 ACL by its name, a case-insensitive string of 1 to 63 characters. The name must start with a letter, in the range of a to z or A to Z. To avoid ambiguity, an ACL name cannot be all.
For more information about ACLs, see ACL and QoS Configuration Guide.
# Permit only the user at 2000::1 to Telnet to the device.
[Sysname] acl ipv6 basic 2001
[Sysname-acl6-ipv6-basic-2001] rule permit source 2000::1 128
[Sysname-acl6-ipv6-basic-2001] quit
[Sysname] telnet server ipv6 acl ipv6 2001
telnet server ipv6 dscp
Use telnet server ipv6 dscp to specify the DSCP value for IPv6 to use for Telnet packets sent to a Telnet client.
Use undo telnet server ipv6 dscp to restore the default.
IPv6 uses the DSCP value 48 for Telnet packets sent to a Telnet client.
# Set the DSCP value for IPv6 to use for outgoing Telnet packets to 30 on a Telnet server.
[Sysname] telnet server ipv6 dscp 30
telnet server ipv6 port
Use telnet server ipv6 port to specify the IPv6 Telnet service port number.
Use undo telnet server ipv6 port to restore the default.
The IPv6 Telnet service port number is 23.
port-number: Specifies a port number. The value can be 23 or in the range of 1025 to 65535.
This command terminates all Telnet connections to the IPv6 Telnet server. To use the Telnet service, you must reestablish Telnet connections.
# Set the IPv6 Telnet service port number to 1026.
[Sysname] telnet server ipv6 port 1026
telnet server login-failed threshold-alarm
Use telnet server login-failed threshold-alarm to configure the alarm threshold and alarm clearance threshold for Telnet login failures in a statistics period.
Use undo telnet server login-failed threshold-alarm to restore the default.
telnet server login-failed threshold-alarm upper-limit report-times lower-limit resume-times period period-time
The statistics period is 5 minutes, and the alarm threshold and alarm clearance threshold for Telnet login failures in the statistics period are 30 and 20, respectively.
upper-limit report-times: Specifies the alarm threshold for Telnet login failures. The device generates an alarm message if the number of Telnet login failures in the statistics period specified by the period period-time option reaches or exceeds the alarm threshold. The report-times argument specifies the number of Telnet login failures, in the range of 0 to 100. If you set the report-times argument to 0, the device does not generate any alarm message upon Telnet login failures.
lower-limit resume-times: Specifies the alarm clearance threshold for Telnet login failures. The device generates an alarm clearance message if the number of Telnet login failures in the statistics period specified by the period period-time option drops below the alarm clearance threshold. The resume-times argument specifies the number of Telnet login failures. If the value for the report-times argument is equal to or smaller than 45, the value range for the resume-times argument is 0 to the report-times argument. If the value for the report-times argument is greater than 45, the value range for the resume-times argument is 0 to 45. Both values 0 and 1 indicate that an alarm clearance threshold is generated only when no Telnet login failure occurs in the specified statistics period.
period period-time: Specifies the statistics period for Telnet login failures, in the range of 1 to 120, in minutes. The default is 5.
Application scenarios
By default, an alarm message or alarm clearance message is generated when the number of Telnet login failures is equal to or greater than 30 or smaller than 20, respectively, in 5 minutes. You can configure the settings as follows:
·     If you do not care about the number of Telnet login failures and do not want to obtain alarm information upon these failures, set the report-times argument to 0. In this case, the device does not generate any alarm information about Telnet login failures.
·     If you care about the number of Telnet login failures and want to obtain alarm information about these failures, use this command as needed.
The value for the report-times argument must be equal to or greater than that for the resume-times argument.
# Specify the statistics period for Telnet login failures as 3 minutes, and set the alarm threshold and alarm clearance threshold to 20 and 10, respectively.
[Sysname] telnet server login-failed threshold-alarm upper-limit 20 lower-limit 10 period 3
telnet server port
Use telnet server port to specify the IPv4 Telnet service port number.
Use undo telnet server port to restore the default.
The IPv4 Telnet service port number is 23.
This command terminates all Telnet connections to the IPv4 Telnet server. To use the Telnet service, you must reestablish Telnet connections.
# Set the IPv4 Telnet service port number to 1025.
[Sysname] telnet server port 1025
terminal type
Use terminal type to specify the terminal display type.
Use undo terminal type to restore the default.
undo terminal type
The terminal display type is ANSI.
User line view
ansi: Specifies the ANSI type.
vt100: Specifies the VT100 type.
The device supports two terminal display types: ANSI and VT100. As a best practice, specify the VT100 type on both the device and the configuration terminal. If either side uses the ANSI type, a display problem might occur when a command line has more than 80 characters. For example, a cursor positioning error might occur.
A terminal display type change does not take effect on the current session. It takes effect on subsequent login sessions.
# Set the terminal display type to VT100.
[Sysname-line-vty0] terminal type vt100
user-interface
Use user-interface to enter one or multiple user line views.
user-interface { first-number1 [ last-number1 ] | { console | vty } first-number2 [ last-number2 ] }
This command is an older version reserved for backward compatibility purposes. It has the same functionality and output as the line command. As a best practice, use the line command.
To configure settings for a single user line, use this command to enter the user line view.
To configure the same settings for multiple user lines, use this command to enter multiple user line views.
# Enter the views of VTY lines 0 to 4.
[Sysname] user-interface vty 0 4
user-interface class
Use user-interface class to enter user line class view.
user-interface class { console | vty }
This command is an older version reserved for backward compatibility purposes. It has the same functionality and output as the line class command. As a best practice, use the line class command.
To configure the same settings for all user lines of a line class, you can use this command to enter the user line class view.
The following commands are available in user line class view:
·     activation-key
·     escape-key
·     idle-timeout
·     protocol inbound
·     screen-length
·     shell
·     terminal type
·     user-role
[Sysname] user-interface class vty
user-interface
user-role
Use user-role to assign a user role to a user line. The device assigns the user role to a user of the line when the user logs in.
Use undo user-role to remove a user role or restore the default.
user-role role-name
undo user-role [ role-name ]
A console user is assigned the network-admin user role. Other users are assigned the network-operator user role.
User line view
role-name: Specifies a user role name, a case-sensitive string of 1 to 63 characters. The user role can be user-defined or predefined. Available predefined user roles include network-admin, network-operator, and level-0 to level-15. If you do not specify this argument, the undo user-role command restores the default user role.
A user role change does not take effect on the current session. It takes effect on subsequent login sessions.
You can assign up to 64 user roles to a user line.
For more information about user roles, see RBAC configuration in Fundamentals Configuration Guide.
# Assign user role network-admin to console line 0.
[Sysname-line-console0] user-role network-admin
