02-Interface Command Reference
HomeSupportRouters5G IPRAN Access RoutersReference GuidesCommand ReferencesH3C RA5300[5300-X][5300-AC] Routers Command Reference-R7752-6W10002-Interface Command Reference
03-WAN interface commands
03-WAN interface commands 118.63 KB
Only the HRIC-ET16-G interface module supports this feature. For more information about the interfaces provided by the device, see the installation guide and interface module manual of the device.
Common WAN interface commands
default
Use default to restore the default settings for an interface.
default
CE1 interface view
CAUTION
CAUTION:
The default command might interrupt ongoing network services. Make sure you are fully aware of the impact of this command when you use it on a live network.
This command might fail to restore the default settings for some commands for reasons such as command dependencies and system restrictions. You can use the display this command in interface view to check for these commands, and use their undo forms or follow the command reference to restore their respective default settings. If your restoration attempt still fails, follow the error message instructions to resolve the problem.
# Restore the default settings of E1 2/0/1..
[Sysname] controller e1 2/0/1
[Sysname-E1 2/0/1] default
description
The interface description uses the interface name Interface format, for example, E1 2/0/1 Interface.
CE1 interface view
text: Specifies the description, a case-sensitive string of 1 to 255 characters.
# Configure the description of E1 2/0/1 as router-interface.
[Sysname-E1 2/0/1] description router-interface
shutdown
Use shutdown to shut down an interface.
Use undo shutdown to restore the default.
shutdown
A WAN interface is up.
CE1 interface view
# Shut down E1 2/0/1.
[Sysname-E1 2/0/1] shutdown
Basic CE1 interface commands
cem-set (CE1 interface)
Use cem-set to bundle timeslots into a CEM set on a CE1 interface.
Use undo cem-set to remove a CEM set.
cem-set set-number timeslot-list list
undo cem-set [ set-number ]
No CEM sets exist on a CE1 interface.
CE1 interface view
set-number: Specifies the number of the CEM set for the timeslot bundle. The value range is 0 to 30.
timeslot-list list: Specifies a comma-separated list of timeslot items. An item can be an individual timeslot or a timeslot range. Use a hyphen (-) to separate the start and end timeslot numbers of a range. The value range for the timeslot number is 1 to 31.
A CE1 interface in CE1 mode is physically divided into 32 timeslots numbered 0 through 31. All timeslots except timeslot 0 can be bundled into CEM sets. For each CEM set, the system automatically creates a CEM interface.
The CEM interface name uses the circuit-emulation interface-number:set-number format. The interface-number argument specifies the CE1 interface number. The set-number argument specifies the CEM set number.
# On E1 2/0/1, bundle timeslots 1, 2, 5, 10 through 15, and 18 into CEM set 0 and specify the CAS signaling method for the set.
[Sysname-E1 2/0/1] cem-set 0 timeslot-list 1,2,5,10-15,18
clock (CE1 interface)
Use clock to set the clock mode of a CE1 interface.
Use undo clock to restore the default.
clock { master | slave }
undo clock
The clock mode of a CE1 interface is slave.
CE1 interface view
master: Sets the clock mode to master.
slave: Sets the clock mode to slave.
When the clock mode of an interface is master, it uses the internal clock source. When the clock mode of an interface is slave, it uses the line clock source.
Set the clock mode for a CE1 interface according to its operating mode:
·     When the interface is operating in DCE mode, set its clock mode to master.
·     When the interface is operating in DTE mode, set its clock mode to slave.
# Set the clock mode to master for CE1 interface E1 2/0/1.
[Sysname-E1 2/0/1] clock master
clock-change auto
Use clock-change auto to enable automatic clock mode switchover on an interface.
Use undo clock-change auto to disable automatic clock mode switchover.
clock-change auto
Automatic clock mode switchover is disabled on an interface.
CE1 interface view
When automatic clock mode switchover is enabled, the interface automatically switches to the master clock mode when both of the following conditions exist:
·     The interface uses the slave clock mode.
·     The interface receives an alarm indication signal (AIS), loss of signal (LOS), or loss of frame (LOF) alarm.
After the alarm is cleared, the interface automatically switches back to the slave mode.
When automatic clock mode switchover is disabled, the interface uses the user-configured clock mode.
# Enable automatic clock mode switchover for E1 2/0/1.
[Sysname-E1 2/0/1] clock-change auto
clock
code (CE1 interface)
Use code to set the line code format for a CE1 interface.
Use undo code to restore the default.
code { ami | hdb3 }
undo code
The line code format is HDB3 for the CE1 interface.
CE1 interface view
ami: Specifies the alternate mark inversion (AMI) line code format.
hdb3: Specifies the high-density bipolar 3 (HDB3) line code format.
A CE1 interface must use the same line code format as its remote end.
For the interface to operate correctly, configure the data-coding inverted command on the interface if the AMI format is used.
# Set the line code format to AMI for E1 2/0/1.
[Sysname-E1 2/0/1] code ami
data-coding
controller e1
Use controller e1 to enter CE1 interface view.
controller e1 interface-number
interface-number: Specifies a CE1 interface by its number.
# Enter E1 2/0/1 interface view.
[Sysname-E1 2/0/1]
data-coding (CE1 interface)
Use data-coding to enable user data inversion on a CE1 interface.
Use undo data-coding to restore the default.
data-coding { inverted | normal }
undo data-coding
Data inversion is disabled on a CE1 interface.
CE1 interface view
inverted: Enables user data inversion.
normal: Disables user data inversion.
To prevent 7e in valid data from being mistaken for padding characters, HDLC inserts a zero after every five consecutive ones in the data stream. In data inversion, each bit one is inverted to bit zero, and each bit zero is inverted to bit one. After the inversion, at least a bit one is present in every eight consecutive bits.
When AMI encoding is used on an E1 interface, data inversion eliminates the presence of multiple consecutive zeros.
The data inversion setting must be the same on the CE1 interfaces at two ends of an E1 line.
# Enable user data inversion on E1 2/0/1.
[Sysname-E1 2/0/1] data-coding inverted
display controller e1
Use display controller e1 to display information about CE1 interfaces.
display controller [ e1 [ interface-number ] ]
e1 [ interface-number ]: Specifies a CE1 interface by its number. If you do not specify the e1 keyword, the command displays information about all CE1 interfaces. If you specify the e1 keyword without specifying an interface, the command displays information about all CE1 interfaces.
# Display information about E1 2/0/1.
<Sysname> display controller e1 2/0/1
E1 2/0/1
Interface index: 721
Current state: UP
Description: E1 2/0/1 Interface
Basic Configuration:
  Work mode: E1 framed, Cable type: 75 Ohm unbalanced
  Line code: hdb3, Source clock: slave
  Idle code: 7e, Itf type: 7e, Itf number: 4, Loop back: not set
Alarm State:
  Receiver alarm state is None
Historical Statistics:
Last link flapping: 6 hours 39 minutes 25 seconds
Data in current interval (150 seconds elapsed):
  Loss Frame Alignment: 0 seconds, Framing Error: 0 seconds
  CRC Error: 0 seconds, Alarm Indication: 0 seconds
  Loss-of-signals: 0 seconds, Code Violations: 0 seconds
  Slip: 0 seconds, E-Bit error: 0 seconds
Current state
Physical link state of the interface:
·     Administratively DOWN—The interface has been shut down by using the shutdown command.
·     DOWN—The interface is administratively up, but its physical state is down (possibly because no physical link exists or the link has failed).
·     UP—The interface is both administratively and physically up.
Description of the interface.
Work mode
Operating mode of the interface.
Cable type
Cable type of the interface.
Source clock
Clock source used by the interface: master or slave.
Line code
Line code: AMI or HDB3.
Idle code
Idle code: 7e or ff.
Itf type
Interframe filling tag: 7e or ff.
Itf number
Number of interframe filling tags between two successive frames.
Loopback
Loopback state.
Statistics for the interface.
Last link flapping
The amount of time that has elapsed since the most recent physical state change of the interface. This field displays Never if the interface has been physically down since device startup.
The most recent time that the reset counters controller e1 command was executed. This field displays Never if this command has not been executed since the device startup.
Error statistics for the current interval.
display this controller
Use display this controller to display the operating status and information of a controller interface.
Interface view
In controller interface view, to quickly view the operating status or packet statistics of the interface, execute this command.
For a controller interface, the output from the display this interface command in controller interface view is the same as the output from the display controller interface-type interface-number command in any view.
display controller
frame-format (CE1 interface)
Use frame-format to set the framing format for a CE1 interface.
Use undo frame-format to restore the default.
frame-format { crc4 | no-crc4 }
undo frame-format
The framing format on a CE1 interface is no-CRC4.
CE1 interface view
crc4: Sets the framing format to CRC4.
no-crc4: Sets the framing format to no-CRC4.
A CE1 interface in CE1 mode supports both CRC4 and no-CRC4 framing formats. Only CRC4 supports four-bit CRC on physical frames.
# Set the framing format to CRC4 on E1 2/0/1.
[Sysname-E1 2/0/1] frame-format crc4
idle-code (CE1 interface)
Use idle-code to set the line idle code on a CE1 interface.
Use undo idle-code to restore the default.
Idle-code { 7e | ff }
undo idle-code
The line idle code on a CE1 interface is 7e.
CE1 interface view
7e: Sets the line idle code to 7e (hexadecimal).
ff: Sets the line idle code to ff (hexadecimal).
The line idle code is sent in timeslots that are not bundled into logical channels.
# Set the line idle code to 7e on E1 2/0/1.
[Sysname-E1 2/0/1] idle-code 7e
loopback (CE1 interface)
Use loopback to enable loopback and set the loopback mode on a CE1 interface.
Use undo loopback to disable loopback on a CE1 interface.
loopback { local | payload | remote }
undo loopback
Loopback is disabled on a CE1 interface.
CE1 interface view
local: Sets the interface to operate in local loopback mode.
payload: Sets the interface to operate in external payload loopback mode.
remote: Sets the interface to operate in external loopback mode.
Loopback is intended for testing only. Disable the feature when the interface is operating correctly.
You can bundle timeslots on the CE1 interface to form a serial interface and encapsulate it with PPP. After you enable loopback on this serial interface, it is normal that the state of the link layer protocol is reported as down.
# Set E1 2/0/1 to operate in internal loopback mode.
[Sysname-E1 2/0/1] loopback local
Use reset counters controller e1 to clear CE1 interface statistics.
reset counters controller e1 [ interface-number ]
interface-number: Specifies a CE1 interface by its number. If you do not specify this argument, the command clears statistics for all CE1 interfaces.
The reset counters interface command clears statistics for all interfaces.
To display CE1 interface statistics, use the display controller e1 command.
# Clear statistics for CE1 interface E1 2/0/1.
<Sysname> reset counters controller e1 2/0/1
using (CE1 interface)
Use using to set the operating mode of a CE1 interface.
Use undo using to restore the default.
using { ce1 | cem }
undo using
A CE1 interface operates in channelized mode.
CE1 interface view
ce1: Sets the interface to operate in channelized mode.
cem: Sets the interface to operate in CEM mode.
A CE1 interface can operate in channelized or unchannelized mode. Unchannelized mode is also called CEM mode. The channelized mode is also called the CE1 mode.
·     In channelized mode, the CE1 interface is physically divided into 32 timeslots numbered 0 through 31. Timeslot 0 is used for frame synchronization control (FSC).
·     When a CE1 interface operates in unchannelized mode:
¡     For an interface in CEM mode, the system automatically creates a 2.048 Mbps circuit emulation (CEM) interface. The interface name uses the circuit-emulation interface-number:0 format. The interface-number argument specifies the CE1 interface number.
# Set E1 2/0/1 to operate in CEM mode.
[Sysname-E1 2/0/1] using cem
