01-iMC Plat Configuration Examples
HomeSupportNetwork Operations & ManagementIntelligent Management Center 7Configure & DeployConfiguration ExamplesiMC Platform Configuration Examples-5W10801-iMC Plat Configuration Examples
Table of Contents
Related Documents
Intelligent Management Center (iMC) is a next generation intelligent service management platform. It provides a full functionality of network management, control and monitor with a unified management interface. With its open and modular architecture, this platform enables distributed, hierarchical and interactive management of the services running on it. It is a reliable, scalable, high-performance service platform for next generation service software products.
The Plat configuration examples are intended to help customers deploy various Plat features in typical network scenarios. These documents provide not only step-by-step configuration procedures but also configuration analysis and guidelines to help customers understand the configuration.
The following are available configuration examples:
·           iMC Plat DBA User Database to IMC User Database Restoration Configuration Examples
·           iMC Plat IMC Deployment Migration to New Master Server and New Slave Server Configuration Examples
·           iMC Plat IMC Deployment Migration to New Subordinate Server Configuration Examples
·           iMC Plat IMC Server IP Modification Configuration Examples
·           iMC Plat LDAP-based IMC Login Authentication Configuration Examples
·           iMC Plat Switch Access Binding Configuration Examples
·           iMC Plat Device Append Information Import Configuration Examples
·           iMC Plat Terminal Access Binding Configuration Examples
·           iMC Plat VRM VM Migration Configuration Examples
·           iMC Plat IMC Local Database Migration Configuration Examples
·           iMC Plat IMC Command References
·           iMC Plat Querying and Changing IMC Database User Passwords Configuration Examples
·           iMC Plat Automatic Database Backup and Restoration in IMC Stateless Failover Configuration Examples
·           iMC Plat IMC Remote Database Backup (Linux) Configuration Examples
·           iMC Plat Adding Devices to IMC Configuration Examples
·           iMC Plat IMC Remote Database Backup Configuration Examples
·           iMC Plat 3D Room Configuration Examples
·           iMC Plat Custom Topology Configuration Examples
·           iMC Plat Dashboard Configuration Examples
·           iMC Plat Desktop Edition Configuration Examples
·           iMC Plat Home Page Widget Customization Configuration Examples
·           iMC Plat IP Address Management and Endpoint Access Policy Control Configuration Examples
·           iMC Plat Performance Monitoring Configuration Examples
·           iMC Plat iMC Local License Registration and Upgrade Configuration Examples
·           iMC Plat Operator Privilege Management Configuration Examples
