- Released At: 05-06-2025
H3C G3&G5 Servers HDM Redfish |
Technology White Paper |
Copyright © 2025 New H3C Technologies Co., Ltd. All rights reserved.
Overview
Redfish is the combination of a REST API and Software-defined servers (data models), and is defined by DMTF at www.dmtf.org.
Technical background
As a widely supported industry standard, IPMI defines a set of APIs to provide out-of-band management and monitoring functions. These functions are independent from the host system's CPU, firmware (legacy BIOS or UEFI), and operating system.
However, IPMI no longer meets the function scalability of modern data center customers as a legacy API with a history of over 20 years. IPMI is limited to a set of lowest common denominator commands (for example, power on/off, restart, temperature reading, and fan speed). Customers can use only a reduced set of functions. In addition, IPMI-capable extensions specific to vendors are not common across the platforms. Therefore, customers have to develop their own tools to implement tool integration, which relies on inband management software.
Trapped by unstandardized IPMI functions and fragments caused by OEM extensions, vendor-specific solutions are demanding function scalability. To resolve this issue, Redfish is introduced. Based on HTTPS and SSL, Redfish aims to provide a simpler, more secure, and more auditable API than IPMI.
Benefits
As a general management protocol designed for converged infrastructure, Redfish can be easily integrated into commonly used tools to manage converged single-node and multiple-node server infrastructure.
Protocol
In Redfish, each URL represents a resource, service, or a resource collection. In RESTful terms, Redfish uses URIs to indicate resources in order to implement resource interaction with clients.
The format of resources is defined by the Redfish schema, which can be used by clients to define correct semantics. Redfish semantics are designed to be greatly intuitive.
All resources are linked to the service entry point (the root), which is located at /redfish/v1. Main resource types are structured as collections to support standalone, multi-node, or converged rack server systems. Other resources are contained as members of these collections.
HDM Redfish implementation
Developed based on Redfish canonical version 1.5.0, HDM Redfish API can be used to implement HDM and BIOS configuration items such as user management, server information obtaining, and module management.
HDM Redfish API includes HDM API and BIOS API.
HDM API
Table 1 Redfish features
Features |
Chassis management |
Displays collection resource information for chassis. |
Server power management |
Supports power control. Obtains server power information. |
Server resource operations |
Obtains information about fans, processors, memory, PCIe modules, expansion modules, UIDs, and network ports. Configures fans, processors, memory, PCIe modules, expansion modules, UIDs, and network ports. |
HDM system resource operations |
Supports HDM restart and primary/backup switchover. |
Storage management |
Obtains RAID controller information. Creates, deletes, and obtains logical volumes. |
Firmware management |
Obtains firmware information. Updates firmware. |
Network service |
Obtains and configures NTP, SNMP, SMTP, and Syslog. |
Session and service management |
Creates sessions. Obtains service information. |
HDM user management |
Supports user account and user group operations. |
BIOS configuration management |
Obtains next-boot device and BIOS configuration items. Edits BIOS password. Restores the BIOS to the default settings. |
Event log report |
Configures event subscription resources. |
Table 2 BIOS configuration items
Menu |
Advanced |
ACPI settings. Hibernation. Terminal settings. Serial port console redirection. Legacy USB devices. XHCI hand-off. USB mass storage driver. Option ROM policy. PXE. Media detect count. |
Platform Configuration |
SATA controller. USB settings. Selection of a monitor to display videos. Debug mode. SOL. Software error injection. |
Socket Configuration |
CPU core settings. Hyper-threading. MONITOR and MWAIT instructions. Intel TXT. VMX. SMX. Hardware prefetcher. EIST (P-States) settings. TDP. Intel® Speed Select. EIST PSD Function. Turbo mode. Processor core ratio. Hardware P-states. Hardware PM interrupt. EPP. CPU C state control. CPU T-state control. Thermal monitor. Power performance tuning. |
Server Management |
FRB-2 timer. FRB-2 timer policy. OS watchdog timer. OS watchdog timer policy. |
Security |
Secure boot mode. Restore factory keys. |
Boot |
Numeric lock status. Boot mode (UEFI and legacy). UEFI shell status. Boot options. |
