Title | Size | Downloads |
H3C S9825 & S9855 Switch Series Transceiver Module Compatibility Matrix-6W100-book.pdf | 200.18 KB |
book | 200.18 KB |
H3C S9825[S9855] Switch Series |
Transceiver Module Compatibility Matrix |
Document version: 6W100-20250227
Copyright © 2025 New H3C Technologies Co., Ltd. All rights reserved. No part of this manual may be reproduced or transmitted in any form or by any means without prior written consent of New H3C Technologies Co., Ltd. Except for the trademarks of New H3C Technologies Co., Ltd., any trademarks that may be mentioned in this document are the property of their respective owners. The information in this document is subject to change without notice. |
Switches and transceiver modules compatibility matrix
The S9825 switch series and S9855 switch series support a wide range of transceiver modules and cables. See Table 1 for the transceiver modules and cables supported by different ports on the switches and cards. For more information about transceiver modules and cables, see H3C Transceiver Modules User Guide.
You cannot use the speed command to change the speed of a split interface on a module.
You can only use QSFP+ to SFP+ cables for 10GE interfaces split from a 100GE interface.
Table 1 Switches and transceiver modules compatibility matrix
Hardware |
Port |
Available transceiver modules |
Device software version and remarks |
S9825-128B |
1 to 128 |
QSFP56-200G-2QSFP56-100G-AOC-10m |
R9131 and later |
QSFP56-200G-2QSFP56-100G-AOC-20m |
R9131 and later |
QSFP56-200G-2QSFP56-100G-AOC-30m |
R9131 and later |
QSFP56-200G-2QSFP56-100G-AOC-50m |
R9131 and later |
QSFP56-200G-2QSFP56-100G-AOC-5m |
R9131 and later |
QSFP56-200G-2QSFP56-100G-AOC-7m |
R9131 and later |
QSFP56-200G-D-AOC-10m |
R9131 and later |
QSFP56-200G-D-AOC-20m |
R9131 and later |
QSFP56-200G-D-AOC-5m |
R9131 and later |
QSFP56-200G-D-AOC-7m |
R9131 and later |
QSFP56-200G-D-DAC-1m |
R9131 and later |
QSFP56-200G-D-DAC-2m |
R9131 and later |
QSFP56-200G-D-DAC-3m |
R9131 and later |
QSFP56-200G-FR4-WDM1300 |
R9131 and later |
QSFP56-200G-SR4-MM850 |
R9131 and later |
S9825-64D |
1 to 64 |
CAB-400G-QSFP-DD-2m |
R9126P03 |
OSFP112-RHS-QDD-400G-AOC-20m |
R9130 and later |
OSFP112-RHS-QDD-400G-AOC-50m |
R9130 and later |
QSFP-100G-CWDM4-SM1300-A |
R9126P03 and later |
QSFP-100G-D-AOC-10M |
QSFP-100G-D-AOC-20M |
QSFP-100G-D-AOC-20M-H |
QSFP-100G-D-AOC-7M |
QSFP-100G-D-AOC-7M-H |
QSFP-100G-D-CAB-1M |
QSFP-100G-D-CAB-1M-Z |
QSFP-100G-D-CAB-3M |
QSFP-100G-D-CAB-3M-Z |
QSFP-100G-D-CAB-5M |
QSFP-100G-D-CAB-5M-Z |
QSFP-100G-DR1-SM1310 |
R9130 and later |
QSFP-100G-ER4L-WDM1300 |
QSFP-100G-eSR4-MM850 |
QSFP-100G-FR1-SM1310 |
R9130 and later |
QSFP-100G-LR1-SM1310-DC |
R9130 and later |
QSFP-100G-LR4L-WDM1300 |
QSFP-100G-LR4-WDM1300 |
QSFP-100G-LR4-WDM1300-A |
QSFP-100G-PSM4-SM1310 |
QSFP-100G-SR4-MM850 |
QSFP-100G-SR4-MM850-A |
QSFP-100G-SR4-MM850-H |
QSFP-100G-SWDM4-MM850 |
R9126P03 |
R9126P03 |
R9126P03 |
R9126P03 |
R9126P03 |
QSFPDD-400G-2QSFP56-200G-AOC-10m |
R9126P03 |
QSFPDD-400G-2QSFP56-200G-AOC-20m |
R9126P03 |
QSFPDD-400G-2QSFP56-200G-AOC-30m |
R9126P03 |
QSFPDD-400G-2QSFP56-200G-AOC-50m |
R9126P03 |
QSFPDD-400G-2QSFP56-200G-AOC-5m |
R9126P03 |
QSFPDD-400G-2QSFP56-200G-AOC-7m |
R9126P03 |
QSFPDD-400G-D-AOC-10m |
QSFPDD-400G-D-AOC-20m |
QSFPDD-400G-D-AOC-30m |
QSFPDD-400G-D-AOC-50m |
QSFPDD-400G-D-AOC-5m |
QSFPDD-400G-D-AOC-7m |
QSFPDD-400G-D-CAB-2M-Z |
R9126P03 |
QSFPDD-400G-DR4-SM1310 |
R9216H03 |
QSFPDD-400G-FR4-WDM1300 |
R9126P03 |
QSFPDD-400G-FR4-WDM1300-Z |
QSFPDD-400G-LR4-WDM1300-DC |
R9126P03 |
QSFPDD-400G-LR8-WDM1300 |
R9126P03 |
QSFPDD-400G-SR4-MM850 |
QSFPDD-400G-SR8-MM850 |
R9126P03 |
QSFPDD-400G-SR8-MM850-Z |
R9126P03 |
QSFPDD-400G-ZR-A |
The 16 ports in the top row (ports 1, 5, 9, 13, 17, 21, 25, 29, 33, 37, 41, 45, 49, 53, 57, and 61) can be used simultaneously. |
QSFPDD-400G-ZR-B |
S9855-24B8D |
1 to 24 |
40GBASE-SR4-QSFP+ |
E9128 and later |
LSWM1QSTK0 |
E9128 and later |
LSWM1QSTK1 |
E9128 and later |
LSWM1QSTK2 |
E9128 and later |
LSWM1QSTK3 |
E9128 and later |
LSWM1QSTK4 |
E9128 and later |
LSWM1QSTK5 |
E9128 and later |
QSFP-100G-4SFP-25G-CAB-1M |
E9128 and later |
QSFP-100G-4SFP-25G-CAB-1M-Z |
E9128 and later |
QSFP-100G-4SFP-25G-CAB-3M |
E9128 and later |
QSFP-100G-4SFP-25G-CAB-3M-Z |
E9128 and later |
QSFP-100G-4SFP-25G-CAB-5M |
E9128 and later |
QSFP-100G-4SFP-25G-CAB-5M-Z |
E9128 and later |
E9128 and later |
E9128 and later |
E9128 and later |
E9128 and later |
E9128 and later |
E9128 and later |
E9128 and later |
E9128 and later |
E9128 and later |
E9128 and later |
R9130 and later |
E9128 and later |
E9128 and later |
R9130 and later |
R9130 and later |
E9128 and later |
E9128 and later |
E9128 and later |
E9128 and later |
E9128 and later |
E9128 and later |
QSFP-40G-4SFP-10G-CAB-1M-Z |
E9128 and later |
QSFP-40G-4SFP-10G-CAB-3M-Z |
E9128 and later |
QSFP-40G-4SFP-10G-CAB-5M-Z |
E9128 and later |
QSFP-40G-BIDI-SR-MM850 |
E9128 and later |
QSFP-40G-CSR4-MM850 |
E9128 and later |
QSFP-40G-D-AOC-10M |
E9128 and later |
QSFP-40G-D-AOC-20M |
E9128 and later |
QSFP-40G-D-AOC-7M |
E9128 and later |
QSFP-40G-D-CAB-1M-Z |
E9128 and later |
QSFP-40G-D-CAB-3M-Z |
E9128 and later |
QSFP-40G-D-CAB-5M-Z |
E9128 and later |
QSFP-40G-ER4-WDM1300 |
E9128 and later |
QSFP-40G-LR4L-WDM1300 |
E9128 and later |
QSFP-40G-LR4-WDM1300 |
E9128 and later |
QSFP-40G-SR4-MM850 |
E9128 and later |
QSFP56-200G-2QSFP56-100G-DAC-1m |
R9129P01 |
QSFP56-200G-2QSFP56-100G-DAC-2m |
R9129P01 |
QSFP56-200G-2QSFP56-100G-DAC-3m |
R9129P01 |
F9126P02 |
F9126P02 |
F9126P02 |
F9126P02 |
E9128 |
25 to 32 |
40GBASE-SR4-QSFP+ |
E9128 and later |
LSWM1QSTK0 |
E9128 and later |
LSWM1QSTK1 |
E9128 and later |
LSWM1QSTK2 |
E9128 and later |
R9130 and later |
R9130 and later |
E9128 and later |
E9128 and later |
E9128 and later |
E9128 and later |
E9128 and later |
E9128 and later |
E9128 and later |
E9128 and later |
E9128 and later |
E9128 and later |
E9128 and later |
E9128 and later |
E9128 and later |
E9128 and later |
E9128 and later |
E9128 and later |
R9130 and later |
E9128 and later |
E9128 and later |
R9130 and later |
R9130 and later |
E9128 and later |
E9128 and later |
E9128 and later |
E9128 and later |
E9128 and later |
E9128 and later |
E9128 and later |
E9128 and later |
E9128 and later |
E9128 and later |
QSFP-40G-D-AOC-7M |
E9128 and later |
E9128 and later |
E9128 and later |
E9128 and later |
E9128 and later |
E9128 and later |
E9128 and later |
E9128 and later |
F9126P02 |
F9126P02 |
F9126P02 |
F9126P02 |
E9128 |
F9126P02 |
F9126P02 |
F9126P02 |
F9126P02 |
F9126P02 |
F9126P02 |
F9126P02 |
E912901 |
F9126P02 |
F9126P02 |
F9126P02 |
F9126P02 |
F9126P02 |
QSFPDD-400G-ZR-A |
F9126P02 |
QSFPDD-400G-ZR-B |
F9126P02 |
S9855-32D |
1 to 32 |
LSWM1QSTK0 |
R9127 and later |
LSWM1QSTK1 |
R9127 and later |
LSWM1QSTK2 |
R9127 and later |
R9127 and later |
R9127 and later |
R9127 and later |
E912901 |
E912901 |
E912901 |
R9127 |
E9129P01 |
E9129P01 |
E9129P01 |
E9129P01 |
E9129P01 |
E9129P01 |
E9129P01 and later |
33 and 34 |
BD-SFP-XG-SX-MM850-A1-F |
LSTM1STK |
R9127 and later |
LSWM1STK |
R9127 and later |
LSWM2STK |
LSWM2STK |
R9127 and later |
LSWM3STK |
R9127 and later |
S5500-10GSTK |
R9127 and later |
SFP-10G-D-CAB-1M-Z |
R9127 and later |
SFP-10G-D-CAB-3M-Z |
R9127 and later |
SFP-10G-D-CAB-5M-S |
R9127 and later |
SFP-10G-D-CAB-5M-Z |
R9127 and later |
SFP-GE-LH100-SM1550 |
R9127 and later |
SFP-GE-LH40-SM1310 |
SFP-GE-LH40-SM1310-D |
SFP-GE-LH40-SM1310-S |
SFP-GE-LH40-SM1550 |
SFP-GE-LH80-SM1550 |
SFP-GE-LH80-SM1550-D |
SFP-GE-LX-SM1310-A |
SFP-GE-LX-SM1310-D |
SFP-GE-LX-SM1310-S |
SFP-GE-SX-MM850-A |
SFP-GE-SX-MM850-A-H-Z |
SFP-GE-SX-MM850-A-Z |
SFP-GE-SX-MM850-D |
SFP-GE-SX-MM850-S |
SFP-GE-T |
SFP-GE-T-D |
SFP-GE-T-S |
SFP-XG-D-AOC-10M |
SFP-XG-D-AOC-10M-H |
SFP-XG-D-AOC-20M |
SFP-XG-D-AOC-20M-H |
SFP-XG-D-AOC-7M |
SFP-XG-D-AOC-7M-H |
SFP-XG-LH40-SM1270-BIDI |
SFP-XG-LH40-SM1330-BIDI |
SFP-XG-LH80-SM1550 |
SFP-XG-LH80-SM1550-D |
SFP-XG-LX-SM1270-BIDI |
SFP-XG-LX-SM1270-BIDI-S |
SFP-XG-LX-SM1310 |
SFP-XG-LX-SM1310-D |
SFP-XG-LX-SM1310-E |
SFP-XG-LX-SM1310-H |
SFP-XG-LX-SM1310-S |
SFP-XG-LX-SM1330-BIDI |
SFP-XG-LX-SM1330-BIDI-S |
SFP-XG-SX-MM850-A |
SFP-XG-SX-MM850-D |
SFP-XG-SX-MM850-E |
SFP-XG-SX-MM850-H |
SFP-XG-SX-MM850-S |
UIS-SFP-XG-SX-MM850 |
UN-SFP-XG-SX-MM850-A1 |
UN-SFP-XG-SX-MM850-A1-X |
S9855-40B |
1 to 40 |
100GBASE-LR4-QSFP28 |
E9305 and later |
100GBASE-SR4-QSFP28 |
E9305 and later |
40GBASE-SR4-QSFP+ |
E9305 and later |
LSWM1QSTK0 |
E9305 and later |
LSWM1QSTK1 |
E9305 and later |
LSWM1QSTK2 |
E9305 and later |
QSFP-100G-BIDI-MM850 |
E9305 and later |
QSFP-100G-BIDI-MM850-Z |
E9305 and later |
E9305 and later |
E9305 and later |
QSFP-100G-D-AOC-10M-H |
E9305 and later |
QSFP-100G-D-AOC-10M-Z |
E9305 and later |
E9305 and later |
E9305 and later |
E9305 and later |
E9305 and later |
E9305 and later |
E9305 and later |
E9305 and later |
E9305 and later |
E9305 and later |
E9305 and later |
E9305 and later |
E9305 and later |
QSFP-100G-ER4L-WDM1300-Z |
E9305 and later |
QSFP-100G-ER4-WDM1300 |
E9305 and later |
E9305 and later |
E9305 and later |
E9305 and later |
E9305 and later |
QSFP-100G-LR4L-WDM1300-Z |
E9305 and later |
E9305 and later |
E9305 and later |
QSFP-100G-LR4-WDM1300-Z |
E9305 and later |
E9305 and later |
E9305 and later |
QSFP-100G-SR4-MM850-Z |
E9305 and later |
E9305 and later |
QSFP-100G-SWDM4-MM850-Z |
E9305 and later |
QSFP-100G-ZR4-WDM1300 |
E9305 and later |
E9305 and later |
QSFP-40G-BIDI-SR-MM850-Z |
E9305 and later |
QSFP-40G-BIDI-WDM1310 |
E9305 and later |
QSFP-40G-BIDI-WDM850 |
E9305 and later |
E9305 and later |
QSFP-40G-CSR4-MM850-H |
E9305 and later |
QSFP-40G-CSR4-MM850-NDDM |
E9305 and later |
QSFP-40G-CSR4-MM850-Z |
E9305 and later |
E9305 and later |
QSFP-40G-D-AOC-10M-H |
E9305 and later |
QSFP-40G-D-AOC-3M |
E9305 and later |
QSFP-40G-D-AOC-7M |
E9305 and later |
QSFP-40G-D-AOC-7M-H |
E9305 and later |
E9305 and later |
E9305 and later |
E9305 and later |
E9305 and later |
QSFP-40G-ER4-WDM1300-Z |
E9305 and later |
E9305 and later |
QSFP-40G-LR4L-WDM1300-Z |
E9305 and later |
E9305 and later |
QSFP-40G-LR4-WDM1300-Z |
E9305 and later |
QSFP-40G-LX4-WDM1300 |
E9305 and later |
QSFP-40G-LX4-WDM1300-Z |
E9305 and later |
E9305 and later |
QSFP-40G-SR4-MM850-E |
E9305 and later |
QSFP-40G-SR4-MM850-H |
E9305 and later |
QSFP-40G-SR4-MM850-NDDM |
E9305 and later |
QSFP-40G-SR4-MM850-Z |
E9305 and later |
E9305 and later |
E9305 and later |
E9305 and later |
E9305 and later |
E9305 and later |
E9305 and later |
E9305 and later |
E9305 and later |
S9855-48CD8D |
1 to 48 |
E9125 and later |
LSTM1STK |
E9125 and later |
LSWM1STK |
E9125 and later |
LSWM2STK |
E9125 and later |
LSWM3STK |
E9125 and later |
S5500-10GSTK |
E9125 and later |
E9125 and later |
E9125 and later |
E9125 and later |
E9125 and later |
SFP-25G-D-AOC-10M |
E9125 and later |
SFP-25G-D-AOC-20M |
E9125 and later |
SFP-25G-D-AOC-3M |
E9125 and later |
SFP-25G-D-AOC-5M |
E9125 and later |
SFP-25G-D-AOC-7M |
E9125 and later |
SFP-25G-D-CAB-1M |
E9125 and later |
SFP-25G-D-CAB-3M |
E9125 and later |
SFP-25G-D-CAB-5M |
E9125 and later |
SFP-25G-D-CAB-5M-Z |
E9125 and later |
SFP-25G-LR-SM1310 |
E9125 and later |
SFP-25G-SR-MM850 |
E9125 and later |
E9125 and later |
E9125 and later |
SFP-XG-LH40-SM1550 |
E9125 and later |
SFP-XG-LH40-SM1550-D |
E9125 and later |
SFP-XG-LH40-SM1550-S |
E9125 and later |
SFP-XG-LH80-SM1490-BIDI |
E9125 and later |
E9125 and later |
SFP-XG-LH80-SM1550-BIDI |
E9125 and later |
E9125 and later |
E9125 and later |
E9125 and later |
SFP-XG-LX-SM1310 |
E9125 and later |
E9125 and later |
E9125 and later |
SFP-XG-LX-SM1310-E-H-Z |
E9125 and later |
SFP-XG-LX-SM1310-E-Z |
E9125 and later |
E9125 and later |
E9125 and later |
E9125 and later |
SFP-XG-SX-MM850-A |
E9125 and later |
SFP-XG-SX-MM850-D |
E9125 and later |
SFP-XG-SX-MM850-D-H-Z |
E9125 and later |
SFP-XG-SX-MM850-D-Z |
E9125 and later |
SFP-XG-SX-MM850-E |
E9125 and later |
SFP-XG-SX-MM850-S |
E9125 and later |
E9125 and later |
E9125 and later |
E9125 and later |
49 to 56 |
R9216 |
E9125 and later |
E9125 and later |
E9125 and later |
E9125 and later |
E9125 and later |
E9125 and later |
E9125 and later |
E9125 and later |
E9125 and later |
E9125 and later |
R9130 and later |
E9125 and later |
R9130 and later |
R9130 and later |
E9125 and later |
E9125 and later |
E9125 and later |
E9125 and later |
E9125 and later |
E9125 and later |
F9126P02 |
F9126P02 |
F9126P02 |
F9126P02 |
E9128 |
F9126P02 |
F9126P02 |
F9126P02 |
F9126P02 |
F9126P02 |
F9126P02 |
A9127 and later |
A9127 and later |
A9127 and later |
A9127 and later |
A9127 and later |
A9127 and later |
R9216 |
A9127 |
F9126P02 |
F9126P02 |
F9126P02 |
E9124 |
E9124 |
