H3C AD-NET&U-Center License Matrixes-5W105
HomeSupportInstall & UpgradeLicensing GuidesH3C AD-NET&U-Center License Matrixes-5W105
Download Book
  • Released At: 20-03-2025
  • Page Views:
  • Downloads:
Table of Contents
Related Documents
For license-based software features, you must install licenses to use the features. This document provides information about license-based features and licenses available for them. For information about registering, installing, or managing a license, see H3C Software Products Remote Licensing Guide.
IMPORTANT
IMPORTANT:
License-based features and attributes of licenses might change with software version over time. This document contains information about only licenses for software versions shipped with the products and some of the information might change over time. To obtain the most up-to-date information about licenses or information about licenses for software versions not listed in this document, contact your H3C sales representative or contact H3C Support.
License matrixes
SeerEngine-DC
IMPORTANT
IMPORTANT:
·     H3C SeerEngine-DC supports only remote licensing.
·     After version upgrade, the original licenses can still be used correctly.
·     By default, alerts will be generated for a trial or preinstalled license when the validity period left is 10 days, and an alert is generated every day.
·     H3C SeerEngine-DC supports preinstalled licenses, trial licenses, and formal licenses.
Table 1 SeerEngine-DC license types
License type
Validity period
License uninstallation/transfer
Remarks
Formal license
Permanent
Supported
A formal license can be used permanently once purchased.
When the license expires (for example, during the license migration process), the licensed services are not affected, but new services cannot be onboarded.
Trial (temporary) license
30, 60, or 90 days
Not supported
A trial license is time limited. When a trial license expires, the license-based feature becomes unavailable. To continue to use the feature, you must purchase and install a formal license for it.
When trial and formal licenses are mixed in use, the total number of available licenses is the sum of the two types of licenses.
Preinstalled license
·     Controller: 180 days
·     Unified Platform: 90 days
Not supported
A preinstalled license is time limited. The validity period starts on initial startup of the software system. When a preinstalled license expires, the feature becomes unavailable. To continue to use the feature, you must purchase and install a formal license for it.
All the preinstalled licenses for a component become invalid if you install a trial or formal license for the component. For example, if you install a formal quantity license for a component, the preinstalled feature license installed for the component becomes invalid. After you uninstall the formal license, the preinstalled license takes effect if it has not expired.
Identify the number of nodes supported by a preinstalled license:
·     SeerEngine-DC preinstalled license: Unlimited.
·     Network management preinstalled license: 50 devices.
IMPORTANT
IMPORTANT:
·     For versions earlier than E6203 (including versions E61xx and E3xxx), if a controller cannot connect to the License Server because of license obtaining failure or network error, the controller enters the fail-safe mode. In fail-safe mode, you can use all features on the controller in 30 days. If the controller obtains a license or the connection recovers within 30 days, the controller exits fail-safe mode and goes back to the normal state. If the controller cannot obtain a license or the connection fails to recover within 30 days, the SeerEngine-DC exits fail-safe mode and becomes unavailable.
·     For versions E6203 and later, if a network connection error occurs between a SeerEngine-DC and the License Server, SeerEngine-DC enters the fail-safe mode right after 24 hours. In fail-safe mode, the obtained license validity period is extended for 30 days. If the connection recovers within 30 days, the SeerEngine-DC exits fail-safe mode and goes back to the normal state. If the connection fails to recover within 30 days, the SeerEngine-DC exits fail-safe mode and becomes unavailable. SeerEngine-DC does not enter fail-safe mode if it does not obtain any licenses from the license server.
Table 2 SeerEngine-DC license matrix
License
BOM
Product code
Software versions
Remarks
H3C AD-DC Management and Control Software License, 1 Server Node
3130A4HG
LIS-SeerEngine-DC-BAS1
E3xxx
E6xxx
Required license. Each controller node requires a license. For example, a three-node cluster requires three licenses.
H3C AD-DC Management License for Switches, 1 Device
3132A09S
LIS-SeerEngine-DC-PSW-VAR
E3xxx
Required license. It includes the total number of physical switches with the spine, leaf, border, ED roles.
H3C AD-DC Management License for Virtual Services, 1 Node
3132A09T
LIS-SeerEngine-DC-SC-VAR
E3xxx
E6xxx
Optional license that is previously referred to as the service chain node license. It applies to service nodes including those in south-north and east-west service chains. A virtual service node can be an NFV device (VSR, vFW, vLB) or an M9000 or F5000 virtual device (context).
For example, to create a service chain from context A to context B that passes through the vFW and vLB nodes, configure two virtual service nodes.
H3C S1020V, 1 CPU License
3132A00V
LIS-VSW-1020VX-1
E3xxx
E6xxx
Optional license. The number of licenses is the total number of physical processors of servers deployed with S1020V.
H3C AD-DC Management and Control License for Virtual Switches, 1 vSwitch
3132A09U
LIS-SeerEngine-DC-VSW-VAR
E3xxx
E6xxx
Optional license used for third-party vSwitches. The license applies only to hybrid overlay scenarios.
H3C AD-DC VNF Manager Software License, 1 Cluster
3130A1SM
LIS-VNFM-STD
E3xxx
E6xxx
Optional license used for VNF Manager features.
H3C AD-DC Management License for Fixed-Port Switches, 1 Device
3132A0LT
LIS-SeerEngine-DC-PSWB-VAR
E61xx
E62xx
Required license used for port-fixed switches. The number of license seats reduces one each time a  port-fixed switch is incorporated.
H3C AD-DC Management License for Modular Switches, 1 Device
3132A0LV
LIS-SeerEngine-DC-PSWF-VAR
E61xx
E62xx
Required license used for modular switches. A modular switch requires a license when it is incorporated.
H3C AD-DC Management License for CR Router Series, 1 Device
3132A0LU
LIS-SeerEngine-DC-CR-VAR
E61xx
E62xx
Required license used for CR routers. A CR router requires a license when it is incorporated.
H3C AD-DC Management License for Value-Added Services, 1 Port-Fixed Switch
3132A0LD
LIS-SeerEngine-DC-VA-SWB-VAR
E6xxx
Optional license used for value added services of port-fixed switches, which include simulation and one-click recovery for the entire network. Each license for a port-fixed switch can manage a valid number of devices. The number of license seats reduces one each time a port-fixed switch is incorporated.
If the number of reduced license seats is not larger than the number of purchased licenses, you can use all value-added features.
H3C AD-DC Management License for Value-Added Services, 1 Modular Switch
3132A0LE
LIS-SeerEngine-DC-VA-SWF-VAR
E6xxx
Optional license used for value added services of modular switches, which include simulation and one-click recovery for the entire network. Each license for a port-fixed switch can manage a valid number of devices. The number of license seats reduces one each time a port-fixed switch is incorporated..
H3C AD-DC Management License for SeerFabric, 1 Device
3132A0LC
LIS-SeerEngine-DC-SF-DEV-VAR
E6xxx
Optional license used for physical switches that are activated with the SeerFabric feature.
A switch activated with the SeerFabric feature requires a license when it is incorporated.
The license is only available for the SeerFabric scenario.
H3C AD-DC Management and Control License for Fixed-Port Switches, 1 Device
3132A0V6
LIS-AD-DC-PSWB-MC-VAR
E63xx and later
Required license for licensing a fixed-port physical switch and activating the network management feature. A fixed-port switch requires a license when it is incorporated.
H3C AD-DC Management and Control License for Modular Switches, 1 Device
3132A0V8
LIS-AD-DC-PSWF-MC-VAR
E63xx and later
Required license for licensing a modular physical switch and activating the network management feature. A modular switch requires a license when it is incorporated.
H3C AD-DC Management and Control License for CR Router Series, 1 Device
3132A0V7
LIS-AD-DC-CR-MC-VAR
E63xx and later
Required license for licensing a CR router and activating the network management feature. A CR router requires a license when it is incorporated.
H3C AD-NET Management License for Basic Network Management, 1 Device
3132A0KN
LIS-ADNET-FCAPS-1
E0706 and later
(Unified Platform)
Optional license used for activating the network management feature.
You can manage the license on the license information page of Unified Platform. In the multi-scenario convergence deployment, a device requires a license when it is incorporated.
If the license of the controller already contains the network management license, you do not need to purchase this license again.
H3C AD-DC Management License for Programmable Platform Function, 10 Service Packages
3132A18M
LIS-AD-DC-RUNBOOK-10-VAR
E65xx and later
Optional license for licensing Runbook service process packages of the northbound open service. Each license supports creating 10 Runbook service process packages.
H3C AD-DC Management License for Value-Added Service Security Simulation, 1 Device
3132A18N
LIS-AD-DC-VA-SEC-VAR
E65xx and later
Optional license for licensing simulation security devices.
Each simulation security device requires a valid license seat. The number of license seats reduces one each time a simulation security device is incorporated.
The license seats are not displayed on the license information page of Unified Platform, but are reduced directly on the license server that distributes licenses to simulation devices.
H3C AD-DC Management License for Network Relocation,1 Device
3132A1DM
LIS-AD-DC-NET-RELOCATION-VAR
E66xx and later
Optional license for licensing devices for network relocation.
In a network relocation service, each device in the fabric of the either the old or new network requires a license.
H3C AD-DC Management License for SeerFabric Endpoint-Side Management and Analytics Function1 Server
3132A1FF
LIS-AD-DC-SF-SERVER-VAR
E65xx and later
Optional license for licensing devices that require the endpoint-side management function.
In an endpoint-side management service, each device occupies a license.
SeerEngine-Campus
IMPORTANT
IMPORTANT:
·     H3C SeerEngine-Campus supports only remote licensing.
·     H3C SeerEngine-Campus supports preinstalled licenses, trial licenses, and formal licenses.
Table 3 SeerEngine-Campus license types
License type
Validity period
License uninstallation and transfer
Remarks
Formal license
Permanent
Supported
A formal license is not time limited.
30, 60, or 90 days
Not supported
90 days
Not supported
All the preinstalled licenses for a component become invalid if you install a trial or formal license for the component. For example, if you install a formal quantity license for a component, the preinstalled feature license installed for the component becomes invalid. After you uninstall the formal license, the preinstalled license takes effect if it is not expired.
H3C SeerEngine-Campus Software Additional 1 Server Node License does not support a preinstalled license. The validity period for other types of controller licenses and Unified Platform preinstalled license is 90 days.
·     SeerEngine-Campus preinstalled license: Allows 1 controller node to manage 50 physical NEs.
·     Network management preinstalled license: Manages 50 devices.
IMPORTANT
IMPORTANT:
·     For versions E31xx, E32xx, and versions earlier than E3308, if a SeerEngine-Campus cannot connect to the License Server because of license obtaining failure or network error, the SeerEngine-Campus enters the fail-safe mode. In fail-safe mode, you can use all features on the SeerEngine-Campus in 30 days. If the SeerEngine-Campus obtains a license or the connection recovers within 30 days, the SeerEngine-Campus goes back to the normal state. If the SeerEngine-Campus cannot obtain a license or the connection fails to recover within 30 days, the SeerEngine-Campus exits fail-safe mode and becomes unavailable.
·     For E3308 and later and E61xx and later versions, if a network connection error occurs between a SeerEngine-Campus and the License Server, the SeerEngine-Campus enters the fail-safe mode right after 24 hours. In the fail-safe mode, the obtained license validity period is extended for 30 days. If the connection recovers within 30 days, the SeerEngine-Campus exits fail-safe mode and goes back to the normal state. If the connection fails to recover within 30 days, the SeerEngine-Campus exits fail-safe mode and becomes unavailable. SeerEngine-Campus does not enter fail-safe mode if it does not obtain any licenses from the license server.
Table 4 SeerEngine-Campus license matrix
Feature
License
BOM
Product code
Software versions
Remarks
Controller
H3C SeerEngine Campus Additional 1 Server Node License
3130A3T7
LIS-SeerEngine-Campus-BAS1
E31xx
E32xx
E33xx
E61xx and later
Physical NE
H3C SeerEngine Campus Additional 1 Physical Switch License
3132A06K
LIS-SeerEngine-Campus-PSW-VAR
E31xx
E32xx
E33xx
E61xx and later
Required license that is previously referred to as the physical NE license. It includes the total number of physical switches with the spine, leaf, and access roles, as well as the third-party switches that require incorporation. In the IRF scenario, the number of licenses is the actual number of switches during the IRF fabric setup process, and the number of licenses is the number of devices incorporated by the controller after IRF fabric setup.
Virtual service node
H3C SeerEngine Campus Additional 1 Service Chain Node License
3132A06M
LIS-SeerEngine-Campus-SC-VAR
E32xx
E33xx
E61xx and later
Optional license that is previously referred to as the service chain node license. It applies to service nodes including those in south-north and east-west service chains. A virtual service node can be an M9000 or F5000 virtual device (context) or a firewall module.
H3C AD-Campus Virtual Services License, 1 Node
3132A0NP
LIS-AD-Campus-SC-1
E61xx and later
PON
H3C SeerEngine Campus Additional 1 PON Device License
3132A06L
LIS-SeerEngine-Campus-PON-VAR
E32xx
E33xx
E61xx and later
Optional license. The number of PON licenses is the total number of ONUs incorporated by the SDN network.
Controller
H3C AD-Campus Management and Control Software License
3130A54T
LIS-AD-Campus-SWP
E61xx and later
Required license. For E61xx controllers, select either the H3C AD-Campus Controller Software License or H3C SeerEngine Campus Additional 1 Server Node License (BOM: 3130A3T7). As a best practice, use this license for the E61xx controllers as a preferred selection because a cluster requires only one H3C AD-Campus Controller Software License.
Physical NE
H3C AD-Campus Service Automation License, 1 Device
3132A0NB
LIS-AD-Campus-VNA-1
E61xx and later
Optional license. If an incorporated spine, leaf, core, or distribution device uses H3C AD-Campus Controller Management License for xxxx Series, 1-Device, the device also requires one H3C AD-Campus Controller Service Automation License, 1-Device. If the incorporated device uses H3C SeerEngine Campus Additional 1 Physical Switch License or H3C DR2000 ADCampus Director, xxx Licenses, the device does not require such a license.
Physical NE
H3C AD-Campus Free Mobility License, 1 Device
3132A0MW
LIS-AD-Campus-USR-STG-1
E61xx and later
Optional license. If an incorporated spine, leaf, core, or distribution device uses H3C AD-Campus Controller Management License for xxxx Series, 1-Device and uniform policy enforcement is enabled, the device also requires one H3C AD-Campus Free Mobility License,1-Device. If the incorporated device uses H3C SeerEngine Campus Additional 1 Physical Switch License or H3C DR2000 ADCampus Director, xxx Licenses, the device does not require such a license.
Physical NE
H3C AD-Campus Controller Management License for S3100 Series, 1-Device
3132A0NX
LIS-AD-Campus-S3100-1
E61xx and later
Optional license. The number of S3100 series licenses is the total number of S3100 series physical NEs incorporated by the controller.
Physical NE
H3C AD-Campus Controller Management License for S5100 Series, 1-Device
3132A0NF
LIS-AD-Campus-S5100-1
E61xx and later
Optional license. The number of S5100 series licenses is the total number of S5100 series physical NEs incorporated by the controller.
Physical NE
H3C AD-Campus Controller Management License for S5500 Series, 1-Device
3132A0N0
LIS-AD-Campus-S5500-1
E61xx and later
Optional license. The number of S5500 series licenses is the total number of S5500 series physical NEs incorporated by the controller.
Physical NE
H3C AD-Campus Controller Management License for S6500 Series, 1-Device
3132A0P9
LIS-AD-Campus-S6500-1
E61xx and later
Optional license. The number of S6500 series licenses is the total number of S6500 series physical NEs incorporated by the controller.
Physical NE
H3C AD-Campus Controller Management License for S7500 Series, 1-Device
3132A0PA
LIS-AD-Campus-S7500-1
E61xx and later
Optional license. The number of S7500 series licenses is the total number of S7500 series physical NEs incorporated by the controller.
Physical NE
H3C AD-Campus Controller Management License for S7600 Series, 1-Device
3132A0NK
LIS-AD-Campus-S7600-1
E61xx and later
Optional license. The number of S7600 series licenses is the total number of S7600 series physical NEs incorporated by the controller.
Physical NE
H3C AD-Campus Controller Management License for S10500 Series, 1-Device
3132A0NH
LIS-AD-Campus-S10500-1
E61xx and later
Optional license. The number of S10500 series licenses is the total number of S10500 series physical NEs incorporated by the controller.
Physical NE
H3C AD-Campus Controller Management License for S12500 Series, 1-Device
3132A0NW
LIS-AD-Campus-S12500-1
E61xx and later
Optional license. The number of S12500 series licenses is the total number of S12500 series physical NEs incorporated by the controller.
Physical NE
H3C AD-Campus Controller Management License for Third-Party Switches, 1-Device
3132A0N6
LIS-AD-Campus-DEV-3RD-1
E61xx and later
Optional. The number of third-party device licenses is the total number of third-party devices incorporated by the controller.
Physical NE
H3C AD-Campus Controller Management License for E100 Series, 1-Device
3132A0N3
LIS-AD-Campus-E100-1
E61xx and later
Optional. The number of licenses for the E100 series is the number of E100 series physical NEs to be incorporated in the controller.
Physical NE
H3C AD-Campus Controller Management License for E500 Series, 1-Device
3132A0PB
LIS-AD-Campus-E500-1
E61xx and later
Optional. The number of licenses for the E500 series is the number of E500 series physical NEs to be incorporated in the controller.
Physical NE
H3C AD-Campus Controller Management License for ES4100 Series, 1-Device
3132A0NL
LIS-AD-Campus-ES4100-1
E61xx and later
Optional. The number of licenses for the ES4100 series is the number of ES4100 series physical NEs to be incorporated in the controller.
Physical NE
H3C AD-Campus Controller Management License for ES5500 Series, 1-Device
3132A0N5
LIS-AD-Campus-ES5500-1
E61xx and later
Optional. The number of licenses for the ES5500 series is the number of ES5500 series physical NEs to be incorporated in the controller.
Physical NE
H3C AD-Campus Controller Management License for IE Series, 1-Device
3132A0NJ
LIS-AD-Campus-IE4300-1
E61xx and later
Optional. The number of licenses for the IE series is the number of IE series physical NEs to be incorporated in the controller.
Physical NE
H3C AD-Campus Management and Control License for UNIS S10600 Series, 1-Device
3132A0P2
LIS-AD-Campus-S10600-U-1
E61xx and later
Optional. The number of licenses for the UNIS S10600 series is the number of UNIS S10600 series physical NEs to be incorporated in the controller.
Physical NE
H3C AD-Campus Management and Control License for UNIS S12600 Series, 1-Device
3132A0NQ
LIS-AD-Campus-S12600-U-1
E61xx and later
Optional. The number of licenses for the UNIS S12600 series is the number of UNIS S12600 series physical NEs to be incorporated in the controller.
Physical NE
H3C AD-Campus Management and Control License for UNIS S5200 Series, 1-Device
3132A0MU
LIS-AD-Campus-S5200-U-1
E61xx and later
Optional. The number of licenses for the UNIS S5200 series is the number of UNIS S5200 series physical NEs to be incorporated in the controller.
Physical NE
H3C AD-Campus Management and Control License for UNIS S5600 Series, 1-Device
3132A0P1
LIS-AD-Campus-S5600-U-1
E61xx and later
Optional. The number of licenses for the UNIS S5600 series is the number of UNIS S5600 series physical NEs to be incorporated in the controller.
Physical NE
H3C AD-Campus Management and Control License for UNIS S5800 Series, 1-Device
3132A0MV
LIS-AD-Campus-S5800-U-1
E61xx and later
Optional. The number of licenses for the UNIS S5800 series is the number of UNIS S5800 series physical NEs to be incorporated in the controller.
Physical NE
H3C AD-Campus Management and Control License for UNIS S6600 Series, 1-Device
3132A0N8
LIS-AD-Campus-S6600-U-1
E61xx and later
Optional. The number of licenses for the UNIS S6600 series is the number of UNIS S6600 series physical NEs to be incorporated in the controller.
Physical NE
H3C AD-Campus Management and Control License for UNIS S8600 Series, 1-Device
3132A0P3
LIS-AD-Campus-S8600-U-1
E61xx and later
Optional. The number of licenses for the UNIS S8600 series is the number of UNIS S8600 series physical NEs to be incorporated in the controller.
Physical NE
H3C AD-Campus Management and Control License for UNIS S7800 Series, 1-Device
3132A100
LIS-AD-Campus-S7800-U-1
E62xx and later
Optional. The number of licenses for the UNIS S7800 series is the number of UNIS S7800 series physical NEs to be incorporated in the controller.
Physical NE
H3C AD-Campus Management and Control License for UNIS S9600 Series, 1-Device
3132A10H
LIS-AD-Campus-S9600-U-1
E62xx and later
Optional. The number of licenses for the UNIS S9600 series is the number of UNIS S9600 series physical NEs to be incorporated in the controller.
Physical NE
H3C AD-Campus Controller Management License for S6800 Series, 1-Device
3132A10R
LIS-AD-Campus-S6800-1
E62xx and later
Optional. The number of licenses for the S6800 series is the number of S6800 series physical NEs to be incorporated in the controller.
Physical NE
H3C AD-Campus Controller - Management License for S9800 Series, 1-Device
3132A10B
LIS-AD-Campus-S9800-1
E62xx and later
Optional. The number of licenses for the S9800 series is the number of S9800 series physical NEs to be incorporated in the controller.
Physical NE
H3C AD-Campus Management and Control License for SR Router Series, 1 Device
3132A0NC
LIS-AD-Campus-SR-1
E62xx and later
Optional. The number of licenses for the SR router series is the number of SR router series physical NEs incorporated by the controller.
Physical NE
H3C AD-Campus Management and Control License for CR Router Series, 1 Device
3132A0P4
LIS-AD-Campus-CR-1
E62xx and later
Optional. The number of licenses for the CR router series is the number of CR router series physical NEs incorporated by the controller.
Physical NE
H3C AD-Campus Controller Management License for MSR Series, 1-Device
3132A0YF
LIS-AD-Campus-MSR-1
E65xx and later
Optional. The number of licenses for the MSR series is the number of MSR series physical NEs to be incorporated in the controller.
Physical NE
H3C DR2000 ADCampus Director, 25 Licenses
3130A2FH
LIS-DR2000-ADCAMA-25
E33xx (E3311P09 and later)
Optional. 25 licenses for physical NEs, including the total number of spine, leaf, and access physical switches deployed and the third-party access switches to be incorporated. In the IRF scenario, the number of licenses is the actual number of switches during the IRF fabric setup process, and the number of licenses is the number of devices incorporated by the controller after IRF fabric setup.
Physical NE
H3C DR2000 ADCampus Director, 50 Licenses
3130A2FJ
LIS-DR2000-ADCAMB-50
Optional. 50 licenses for physical NEs, including the total number of spine, leaf, and access physical switches deployed and the third-party access switches to be incorporated. In the IRF scenario, the number of licenses is the actual number of switches during the IRF fabric setup process, and the number of licenses is the number of devices incorporated by the controller after IRF fabric setup.
Physical NE
H3C DR2000 ADCampus Director, 100 Licenses
3130A2FK
LIS-DR2000-ADCAMC-100
Optional. 100 licenses for physical NEs, including the total number of spine, leaf, and access physical switches deployed and the third-party access switches to be incorporated. In the IRF scenario, the number of licenses is the actual number of switches during the IRF fabric setup process, and the number of licenses is the number of devices incorporated by the controller after IRF fabric setup.
Physical NE
H3C DR2000 ADCampus Director, 200 Licenses
3130A2FL
LIS-DR2000-ADCAMD-200
Optional. 200 licenses for physical NEs, including the total number of spine, leaf, and access physical switches deployed and the third-party access switches to be incorporated. In the IRF scenario, the number of licenses is the actual number of switches during the IRF fabric setup process, and the number of licenses is the number of devices incorporated by the controller after IRF fabric setup.
Physical NE
H3C DR2000 ADCampus Director, 500 Licenses
3130A2FM
LIS-DR2000-ADCAME-500
Optional. 500 licenses for physical NEs, including the total number of spine, leaf, and access physical switches deployed and the third-party access switches to be incorporated. In the IRF scenario, the number of licenses is the actual number of switches during the IRF fabric setup process, and the number of licenses is the number of devices incorporated by the controller after IRF fabric setup.
Physical NE
H3C DR2000 ADCampus Director, 1000 Licenses
3130A2FN
LIS-DR2000-ADCAMF-1K
Optional. 1000 licenses for physical NEs, including the total number of spine, leaf, and access physical switches deployed and the third-party access switches to be incorporated. In the IRF scenario, the number of licenses is the actual number of switches during the IRF fabric setup process, and the number of licenses is the number of devices incorporated by the controller after IRF fabric setup.
Controller
H3C DR2000 ADCampus Director, High Availability Enhance License
3130A2RL
LIS-DR2000-ADCAMH-HA
Optional. One license is needed for each cluster environment.
Controller
H3C DR2000 ADCampus Director, Service Orchestration Feature License
3130A2RK
LIS-DR2000-ADCAMG-SOF
Optional. One license is needed for each standalone environment. Select one of this license and the H3C SeerEngine Campus Additional 1 Server Node License (BOM: 3130A3T7).
Controller
3130A6FT
LIS-AD-Campus-SE-SWP
·     E6701 and later
·     E65xx (E6505H17 and later)
Required. One license is needed for each cluster environment.
PON
H3C AD-Campus Management and Control License for APs/ONUs, 1 Device
3132A190
LIS-AD-Campus-APONU-1
·     E6701 and later
Optional. The number of PON licenses is the total number of ONUs incorporated by the SDN network.
PON
H3C AD-Campus Management and Control License for APs/ONUs, 100 Devices
3132A191
LIS-AD-Campus-APONU-100
·     E6701 and later
Optional. The number of PON licenses is the total number of ONUs incorporated by the SDN network..
PON
H3C AD-Campus Management and Control License for ONUs, 100 Devices
3132A10Q
LIS-AD-Campus-ONU-100
E62xx and later
PON
H3C AD-Campus Management and Control License for ONUs, 1 Device
3132A0P0
LIS-AD-Campus-ONU-1
E62xx and later
Physical NE
H3C AD-Campus Standard Edition Management License, 1 Device
3132A194
LIS-AD-Campus-STD-DEV-1
·     E6701 and later
·     E65xx (E6505H11 and later)
Optional. The license is the common physical NE license. It includes the total number of physical switches with the spine, leaf, and access roles, as well as the third-party switches that require incorporation. In the IRF scenario, the number of licenses is the actual number of switches during the IRF fabric setup process, and the number of licenses is the number of devices incorporated by the controller after IRF fabric setup.
Physical NE
H3C AD-Campus Standard Edition Management License, 25 Devices
3132A197
LIS-AD-Campus-STD-DEV-25
·     E6701 and later
Network device management licensing
3132A0KN
LIS-ADNET-FCAPS-1
E0706 and later (Unified Platform)
You can manage the license on the license information page. In the multi-scenario convergence deployment, a device requires a license when it is incorporated.
SeerEngine-WAN
IMPORTANT
IMPORTANT:
·     H3C SeerEngine-WAN supports only remote licensing.
·     H3C SeerEngine-WAN supports preinstalled licenses, trial licenses, and formal licenses.
Table 5 SeerEngine-WAN license types
License type
Validity period
Remarks
Formal license
Permanent
Supported
Be careful that a formal license might have a validity period. To ensure the continuity of services, you must purchase and install a new formal license before the license expires.
30, 60, or 90 days
Not supported
90 days
Not supported
·     SeerEngine-WAN preinstalled license: Supports 3 controller nodes to manage 50 physical NEs.
IMPORTANT
IMPORTANT:
·     For E62xx versions, if a SeerEngine-WAN cannot connect to the License Server because of license obtaining failure or a network error, the SeerEngine-WAN enters the fail-safe mode. In fail-safe mode, you can use all features on the SeerEngine-WAN in 30 days. If the SeerEngine-WAN obtains a license or the connection recovers within 30 days, the SeerEngine-WAN exits fail-safe mode and goes back to the normal state. If the SeerEngine-WAN cannot obtain a license or the connection fails to recover within 30 days, the SeerEngine-WAN exists fail-safe mode and becomes unavailable.
·     For versions E63xx and later, if a network connection error occurs between a SeerEngine-WAN and the License Server, the SeerEngine-WAN enters the fail-safe mode right after 24 hours. In fail-safe mode, the obtained license validity period is extended for 30 days. If the connection recovers within 30 days, the SeerEngine-WAN exits fail-safe mode and goes back to the normal state. If the connection fails to recover within 30 days, the SeerEngine-WAN exits fail-safe mode and becomes unavailable. SeerEngine-WAN does not enter fail-safe mode if it does not obtain any licenses from the license server.
Table 6 SeerEngine-WAN license matrix
Feature
License
BOM
Product code
Software versions
Remarks
Controller
H3C AD-WAN Control Software License, 1 Server
3130A487
LIS-SeerEngine-WAN-BAS1
E61xx
E62xx
E63xx
Required license. Each controller node requires a license. For Example, a three-node cluster requires three licenses.
Carrier network NE
H3C AD-WAN Management License for Backbone NEs, 1 Device
3132A07N
LIS-SeerEngine-WAN-CN-VAR
E61xx
E62xx
E63xx
Required license used in an AD-WAN carrier network solution.
When the devices are deployed in standalone mode, each device requires a license. When the devices operate as an IRF 2 fabric, each fabric requires a license.
Network slicing
H3C AD-WAN Management and Control License for Network Slicing, 50 Devices
3132A0UX
LIS-AD-WAN-CN-Slice-50
E6304 and later
E65xx
E67xx
Optional license used for AD-WAN carrier network slicing.
The license is applied according to the device number, and every 50 devices require one license.
Management and control device
H3C AD-WAN Management and Control Software License, 1 Server
3130A5HL
LIS-AD-WAN-MC-BAS1
E6304 and later
E65xx
E67xx
Carrier network NE for management and control
H3C AD-WAN Management and Control License for Backbone NEs, 1 Device
3132A0V1
LIS-AD-WAN-CN-MC-VAR
E6304 and later
E65xx
E67xx
Each device requires one license and has the functions of a carrier controller and basic network management.
3132A0KN
LIS-ADNET-FCAPS-1
Optional license used for activating the network management feature. A device requires a license when it is incorporated.
SeerEngine-SDWAN
IMPORTANT
IMPORTANT:
·     H3C SeerEngine-SDWAN supports only remote licensing.
·     H3C SeerEngine-SDWAN supports preinstalled licenses, trial licenses, and formal licenses.
Table 7 SeerEngine-SDWAN license types
License type
Validity period
Remarks
Formal license
Permanent
Supported
30, 60, or 90 days
Not supported
90 days
Not supported
·     SeerEngine-SDWAN preinstalled license: Supports 3 controller nodes to manage 50 physical NEs.
IMPORTANT
IMPORTANT:
·     For E61xx versions, if a SeerEngine-SDWAN cannot connect to the License Server because of license obtaining failure or network error, the SeerEngine-SDWAN enters the fail-safe mode. In fail-safe mode, you can use all features on the SeerEngine-SDWAN in 30 days. If the SeerEngine-SDWAN obtains a license or the connection recovers within 30 days, the SeerEngine-SDWAN exits fail-safe mode and goes back to the normal state. If the SeerEngine-SDWAN cannot obtain a license or the connection fails to recover within 30 days, the SeerEngine-SDWAN exits fail-safe mode and becomes unavailable.
·     For versions E62xx and later, if a network connection error occurs between a SeerEngine-SDWAN and the License Server, the SeerEngine-SDWAN enters the fail-safe mode right after 24 hours. In fail-safe mode, the obtained license validity period is extended for 30 days. If the connection recovers within 30 days, the SeerEngine-SDWAN exits fail-safe mode goes back to the normal state. If the connection fails to recover within in 30 days, the SeerEngine-SDWAN exits fail-safe mode becomes unavailable. SeerEngine-SDWAN does not enter fail-safe mode if it does not obtain any licenses from the license server.
Table 8 SeerEngine-SDWAN license matrix
Feature
License
BOM
Product code
Software versions
Remarks
Controller
3130A487
E62xx
E63xx
Required. Each controller node requires a license. For example, a three-node cluster requires three licenses.
Branch access NE
H3C AD-WAN Management License for Branch NEs, 1 Device
3132A07P
LIS-SeerEngine-WAN-BR-VAR
E62xx
E63xx
Required in an AD-WAN branch solution.
When the devices in a site are deployed in standalone mode, each device requires a license. When the devices in a site operate as an IRF 2 fabric, each fabric requires a license.
Management controller
3130A5HL
LIS-AD-WAN-MC-BAS1
E64xx
E66xx
E68xx
Required license. Each controller requires a license.
Branch NE for management and control
H3C AD-WAN Management and Control License for Branch NEs, 1 Device
3132A0V0
LIS-AD-WAN-BR-MC-VAR
E64xx
E66xx
E68xx
Required in an AD-WAN branch solution. Each device requires a license.
3132A0KN
LIS-ADNET-FCAPS-1
SeerEngine-SEC
IMPORTANT
IMPORTANT:
·     H3C SeerEngine-SEC supports only remote licensing.
·     H3C SeerEngine-SEC supports preinstalled licenses, trial licenses, and formal licenses.
Table 9 SeerEngine-SEC license types
License type
Validity period
Remarks
Formal license
Permanent
Supported
180 days
Not supported
90 days
Not supported
·     SeerEngine-SEC preinstalled license: Supports 3 controller nodes to manage 10 virtual service node.
IMPORTANT
IMPORTANT:
If a network connection error occurs between a controller and the License Server, the controller enters the fail-safe mode right after 24 hours. In fail-safe mode, the obtained license validity period is extended for 30 days. If the connection recovers within 30 days, the controller exists fail-safe mode and goes back to the normal state. If the connection fails to recover within 30 days, the controller exits fail-safe mode and becomes unavailable.
Table 10 SeerEngine-SEC license matrix
License
BOM
Product code
Software versions
Remarks
H3C SeerEngine-Sec Controller Base Software License
3130A4S2
LIS-SeerEngine-Sec
E11xx
E12xx
H3C SeerEngine-SEC WAN SeerEngine-Sec Controller Base Software License
3130A67C
LIS-SeerEngine-SEC-WAN
E1105Pxx (E1105P10 and later)
H3C SeerEngine-Sec Controller License for 20 Virtual Nodes
3130A4S3
LIS-SeerEngine-Sec-20
E11xx
E12xx
Optional license. It applies to service nodes including those in south-north and east-west service chains. A virtual service node can be an NFV device (VSR, vFW, vLB) or an M9000 or F5000 virtual device (context).
H3C SeerEngine-Sec Controller License for 50 Virtual Nodes
3130A4S5
LIS-SeerEngine-Sec-50
H3C SeerEngine-Sec Controller License for 100 Virtual Nodes
3130A4S6
LIS-SeerEngine-Sec-100
H3C SeerEngine-SEC WAN, SeerEngine-Sec Controller License for 1 Virtual Node
3130A67D
LIS-SeerEngine-SEC-WAN-1
Optional license. One virtual service node corresponds to one site device. When two site devices form an IRF, they are counted as one virtual service node.
H3C ADNET, Basic Management License for Network Devices, 1 Device
3132A0KN
LIS-ADNET-FCAPS-1
SeerAnalyzer-DC
IMPORTANT
IMPORTANT:
·     H3C SeerAnalyzer-DC supports only remote licensing.
·     H3C SeerAnalyzer-DC supports preinstalled licenses, trial licenses, and formal licenses.
Table 11 SeerAnalyzer license types
License type
Validity period
Remarks
Formal license
Permanent
Supported
30, 60, and 90 days
Not supported
90 days
Not supported
All the preinstalled licenses for a component become invalid if you install a trial or formal license for the component. After you uninstall the formal license, the preinstalled license takes effect if it has not expired.
·     SeerAnalyzer preinstalled license: Supports 100 platform nodes and the incorporated device number is unlimited.
IMPORTANT
IMPORTANT:
If a network connection error occurs between a analyzer and the License Server, the analyzer enters the fail-safe mode right after 24 hours. In fail-safe mode, the obtained license validity period is extended for 30 days. If the connection recovers within 30 days, the analyzer exits fail-safe mode and goes back to the normal state. If the connection fails to recover within 30 days, the analyzer exits fail-safe mode and becomes unavailable.
Table 12 SeerAnalyzer license matrix
License
BOM
Product code
Software versions
Remarks
H3C AD-DC Intelligent Analytics License for Lossless Network Analysis, 1 Switch
3132A0LF
LIS-SeerAnalyzer-DC-AIFabric-VAR
E6xxx and later
When you have a quality-unlimited license, you do not need to install this license. When you do not have a quality-unlimited license and use the RoCE network analysis feature, make sure the number of licenses is the same as the number of switches in the DC scenario.
H3C AD-DC Intelligent Analytics License for Modular Switches, 1 Device
3132A0QR
LIS-SeerAnalyzer-DC-PSW-M-VAR
E62xx and later
When you have a quality-unlimited license, you do not need to install this license. When you do not have a quality-unlimited license, make sure the number of licenses is the same as the number of modular switches in the DC scenario.
H3C AD-DC Intelligent Analytics License for Fixed-Port Switches, 1 Device
3132A0F2
LIS-SeerAnalyzer-DC-PSW-VAR
E63xx and later
When you have a quality-unlimited license, you do not need to install this license. When you do not have a quality-unlimited license, make sure the number of licenses is the same as the number of fixed-port switches in the DC scenario.
H3C AD-DC Intelligent Analytics Software License
3130A3YN
LIS-SeerAnalyzer-DC
E23xx
E6xxx and later
In the DC scenario, you must select at least one such license, enable the network function, and then select the management licenses as needed. Each set of the DC product requires a license.
H3C AD-DC Intelligent Analytics Software License, 1 Server Node
3130A3YS
LIS-SeerAnalyzer-DC-Analyzer
E23xx
E6xxx and later
Optional in the DC scenario. One node requires a license. For example, a three-node cluster requires three licenses.
H3C AD-DC Intelligent Analytics License for Flow Analytics, 1 Switch
3132A0F1
E6xxx and later
When you have a quality-unlimited license, you do not need to install this license. When you do not have a quality-unlimited license and the TCP component package is installed, make sure the number of licenses is the same as the number of switches in the DC scenario.
H3C AD-DC Intelligent Analytics License for Type I Collector
3130A3YP
LIS-SeerAnalyzer-Collector-I
E23xx
E6xxx and later
Optional in the DC scenario for the flow analysis feature. The number of licenses needed is the number of type-I collectors in the environment.
H3C ADNET Application Analytics License, 1 Device
3132A15F
LIS-ADNET-APA-1
E65xx and later
Optional in the DC and campus scenarios. Select licenses according to the number of NetStream-enabled devices.
SeerAnalyzer-WAN
IMPORTANT
IMPORTANT:
·     H3C SeerAnalyzer-WAN supports only remote licensing.
·     H3C SeerAnalyzer-WAN supports preinstalled licenses, trial licenses, and formal licenses.
Table 13 SeerAnalyzer license types
License type
Validity period
Remarks
Formal license
Permanent
Supported
30, 60, and 90 days
Not supported
90 days
Not supported
IMPORTANT
IMPORTANT:
Table 14 SeerAnalyzer license matrix
License
BOM
Product code
Software versions
Remarks
H3C AD-WAN Intelligent Analytics Software License
3130A4E3
LIS-SeerAnalyzer-WAN-APP
E23xx
E6xxx
In the WAN scenario, you must select at least one such license, enable the network function, and then select the management licenses as needed. Each set of the WAN product requires a license.
H3C AD-WAN Intelligent Analytics License, 1 Server
3130A4E5
LIS-SeerAnalyzer-WAN-Analyzer
E23xx
E6xxx
Optional in WAN scenario. One node requires a license. For example, a three-node cluster requires three licenses.
H3C AD-WAN Intelligent Analytics License for Backbone NEs, 1 Device
3132A08N
LIS-SeerAnalyzer-WAN-NTA-VAR
E23xx
E6xxx
Optional in the WAN scenario. Select licenses according to the number of devices incorporated.
H3C AD-WAN Intelligent Analytics License for Branch NEs, 1 Device
3132A0F3
LIS-SeerAnalyzer-WAN-BR-VAR
E6xxx
H3C AD-WAN Intelligent Analytics License for Intelligent Simulation Service, 1 Device
3132A10T
LIS-SeerAnalyzer-WAN-ISS-VAR
E63xx and later
Optional in the WAN scenario. Select licenses according to whether the simulation function is needed and the number of devices incorporated.
3132A15F
LIS-ADNET-APA-1
E65xx and later
H3C AD-WAN Intelligent Analytics License for Backbone NEs, 1 MSR Device
3132A18T
LIS-SeerAnalyzer-WAN-CN-MSR-1
E65xx and later
Optional in the WAN scenario. Select licenses according to the number of MSR devices incorporated.
SeerAnalyzer-Campus
IMPORTANT
IMPORTANT:
·     H3C SeerAnalyzer-Campus supports only remote licensing.
·     H3C SeerAnalyzer-Campus supports preinstalled licenses, trial licenses, and formal licenses.
Table 15 SeerAnalyzer license types
License type
Validity period
Remarks
Formal license
Permanent
Supported
30, 60, and 90 days
Not supported
90 days
Not supported
IMPORTANT
IMPORTANT:
Table 16 SeerAnalyzer license matrix
License
BOM
Product code
Software versions
Remarks
H3C AD-Campus Intelligent Analytics Software License
3130A3YR
LIS-SeerAnalyzer-Campus
E23xx
E6xxx
In the campus scenario, you must select at least one such license, enable the network function, and then select the management licenses as needed. Each set of the campus product requires a license.
H3C AD-Campus Intelligent Analytics License for APs, 1 Device
3132A06Y
LIS-SeerAnalyzer-Campus-AP-VAR
E23xx
E6xxx
Optional in the campus scenario. Select licenses according to the number of devices incorporated.
H3C AD-Campus Intelligent Analytics License for Modular NEs, 1 Device
3132A070
LIS-SeerAnalyzer-Campus-M-VAR
E23xx
E6xxx
H3C AD-Campus Intelligent Analytics License for Fixed-Port NEs, 1 Device
3132A071
LIS-SeerAnalyzer-Campus-F-VAR
E23xx
E6xxx
H3C AD-Campus Intelligent Analytics Software License, 1 Server Node
3130A3YM
LIS-SeerAnalyzer-Campus-Analyzer
E23xx
E6xxx
Optional in the campus scenario. One node requires a license. For example, a three-node cluster requires three licenses.
H3C AD-Campus Intelligent Analytics License for ONUs, 1 Device
3132A0MX
LIS-AD-Campus-AP-A-1
E63xx and later
H3C AD-Campus Intelligent Analytics License for Optimization & Self-Healing, 1 AP
3132A0P6
LIS-AD-Campus-AP-OPT-1
E62xx and later
Optional in the campus scenario for optimization and self-healing. Select licenses according to the number of devices incorporated.
H3C AD-Campus Intelligent Analytics License for Flow Analytics, 1 Physical Switch
3132A0QM
LIS-SeerAnalyzer-Campus-PSWFA
E62xx and later
Optional in the campus scenario for flow analysis. Select licenses according to the number of devices incorporated.
H3C SeerAnalyzer Software Campus Edition License, Unlimited License for 1 Cluster
3130A3YL
LIS-SeerAnalyzer-Campus-UL
E23xx
E6xxx
Optional in the campus scenario. You need to install up to one license in a single set of environment.
When this license is installed, you do not need to install other device licenses in the campus.
H3C AD-Campus Intelligent Operations License for APs/ONUs, 1 Device
3132A192
LIS-AD-Campus-IO-1
E63xx and later
Optional in the campus scenario. Select licenses according to the number of devices incorporated. The ONU intelligent analysis, AP intelligent analysis, AP optimization & self-healing, and AP application analysis functions are combined into a single function.
H3C AD-Campus Intelligent Operations License for APs/ONUs, 100 Devices
3132A193
LIS-AD-Campus-IO-100
E63xx and later
H3C AD-Campus Intelligent Analytics License for APs, 100 Devices
3132A10G
LIS-AD-Campus-IA-AP-100
E23xx
E6xxx
H3C AD-Campus Standard Edition Intelligent Analytics License for APs, 10 Devices
3130A5VF
LIS-AD-Campus-B-IA-AP-10
E23xx
E6xxx
H3C AD-Campus Standard Edition Intelligent Analytics License for APs, 50 Devices
3130A5VQ
LIS-AD-Campus-B-IA-AP-50
E23xx
E6xxx
H3C AD-Campus Intelligent Wireless Operations License for APs, 100 Devices
3132A196
LIS-AD-Campus-WIO-AP-100
E63xx and later
Optional in the campus scenario. Select licenses according to the number of devices incorporated. The AP intelligent analysis, AP optimization & self-healing, and AP application analysis functions are combined into a single function.
H3C AD-Campus Intelligent Wireless Operations License for APs, 1 Device
3132A195
E63xx and later
H3C AD-Campus Intelligent Analytics License for Fixed-Port NEs, 25 Devices
3132A10E
LIS-AD-Campus-IA-F-25
E23xx
E6xxx
H3C AD-Campus Intelligent Analytics License for Modular NEs, 25 Devices
3132A0Y6
LIS-AD-Campus-IA-M-25
E23xx
E6xxx
H3C AD-Campus Intelligent Analytics License for Optimization & Self-Healing, 100 APs
3132A0YY
LIS-AD-Campus-IA-O-AP-100
E62xx and later
H3C AD-Campus Standard Edition Intelligent Analytics License for Optimization & Self-Healing, 10 APs
3130A5VG
LIS-AD-Campus-B-IA-O-AP-10
E62xx and later
H3C AD-Campus Standard Edition Intelligent Analytics License for Optimization & Self-Healing, 50 APs
3130A5V1
LIS-AD-Campus-B-IA-O-AP-50
E62xx and later
H3C AD-Campus Intelligent Analytics License for ONUs, 100 Devices
3132A0YX
LIS-AD-Campus-IA-ONU-100
E63xx and later
H3C AD-Campus Standard Edition Intelligent Analytics License for ONUs, 10 Devices
3130A5VY
LIS-AD-Campus-B-IA-ONU-10
E63xx and later
H3C AD-Campus Standard Edition Intelligent Analytics License for ONUs, 50 Devices
3130A5W0
LIS-AD-Campus-B-IA-ONU-50
E63xx and later
H3C AD-Campus Standard Edition Intelligent Analytics License, 10 Devices
3130A5VC
LIS-AD-Campus-B-IA-DEV-10
E63xx and later
H3C AD-Campus Standard Edition Intelligent Analytics License, 50 Devices
3130A5UY
LIS-AD-Campus-B-IA-DEV-50
E63xx and later
H3C AD-Campus Intelligent Analytics License for Application Analysis, 1 AP
3132A0YK
LIS-AD-Campus-IA-APP-AP-1
E63xx and later
H3C AD-Campus Intelligent Analytics License for Application Analysis, 100 APs
3132A10K
LIS-AD-Campus-IA-APP-AP-100
E63xx and later
H3C AD-Campus Intelligent Analytics License for Application Analysis, 1 Fixed-Port NE Device
3132A10J
LIS-AD-Campus-IA-APP-F-1
E63xx and later
H3C AD-Campus Intelligent Analytics License for Application Analysis, 25 Fixed-Port NE Devices
3132A0YM
LIS-AD-Campus-IA-APP-F-25
E63xx and later
H3C AD-Campus Intelligent Analytics License for Application Analysis, 1 Modular NE Device
3132A0Y8
LIS-AD-Campus-IA-APP-M-1
E63xx and later
H3C AD-Campus Intelligent Analytics License for Application Analysis, 25 Modular NE Devices
3132A103
LIS-AD-Campus-IA-APP-M-25
E63xx and later
H3C AD-Campus Standard Edition Intelligent Analytics License for Application Analysis, 10 Devices
3130A5UV
LIS-AD-Campus-B-IA-APP-10
E63xx and later
H3C AD-Campus Standard Edition Intelligent Analytics License for Application Analysis, 50 Devices
3130A5V2
LIS-AD-Campus-B-IA-APP-50
E63xx and later
3132A15F
LIS-ADNET-APA-1
E65xx and later
iWSM\iNSM\iWO
IMPORTANT
IMPORTANT:
·     Only remote licensing is supported.
·     By default, the trial license will trigger an alarm daily when ten days are remaining. After the trial license expires, the page displays normally, but a prompt message appears every 5 seconds to alert the user of an insufficient license.
·     This system supports preinstalled licenses, trial licenses, and formal licenses.
Table 17 License types
License type
Validity period
Remarks
Formal license
Permanent
Supported
When a formal license expires, the license-based feature becomes unavailable. To ensure the continuity of services, you must purchase and install a new formal license before the license expires.
When the license expires, such as during the transfer process, existing licensed services remain unaffected. However, you cannot launch new services.
Trial license
30, 60, or 90 days
Not supported
Both trial and formal licenses are supported. When they are used together, the number of available licenses is the sum of both trial and formal licenses. The expiration of trial licenses will not affect the official licenses.
90 days
Not supported
All the preinstalled licenses for a component become invalid if you install a trial or formal license for the component. For example, if you install a formal license for a component, the preinstalled feature license installed for the component becomes invalid. After you uninstall the formal license, the preinstalled license takes effect if it has not expired.
The validity period is 90 days for preinstalled licenses of Unified Platform and other components.
·     iWSM preinstalled license: 50 APs.
·     iNSM preinstalled license: 5 devices.
·     If a network connection error occurs between iWSM\iNSM\iWO and the License Server, the iWSM\iNSM\iWO component enters the fail-safe mode after 24 hours. In fail-safe mode, the iWSM\iNSM\iWO component can continue to use the license obtained before entering the fail-safe mode for up to 30 days.
If the connection is restored within 30 days, iWSM/iNSM/iWO will exit fail-safe mode and enter normal state.
If the connection is not restored after 30 days, the iWSM/iNSM/iWO component will exit fail-safe mode and enter unavailable state.
·     If a preinstalled license exists after the component enters fail-safe mode, the preinstalled license will be used. If no preinstalled license exists after the component enters fail-safe mode, the menus on the GUI will be displayed normally, but a prompt will appear every 5 seconds to inform that the licenses are insufficient, and the backend services will proceed normally.
Table 18 iWSM license matrix
License
BOM
Product code
Software versions
Remarks
H3C AD-Campus Management and Control License for APs, 1 Device
3132A0P5
LIS-AD-Campus-AP-1
E71xx (E7103 and later)
iWSM wireless device management license, which depends on H3C AD-Campus Management and Control License
H3C AD-Campus Management and Control License for APs, 100 Devices
3132A10M
LIS-AD-Campus-AP-100
H3C AD-Campus Management and Control License for APs, 1000 Devices
3132A1A6
LIS-AD-Campus-AP-1000
H3C AD-Campus Custom Software Development Service License, 1 Person-Day
3132A0NG
LIS-AD-Campus-MAK-1
H3C AD-Campus Wireless Management License for Fat APs, 1-Device
3132A0PD
LIS-AD-Campus-FAP-1
H3C AD-Campus Management and Control License for Fat APs, 100 Devices
3132A0YN
LIS-AD-Campus-FAT-100
H3C AD-Campus Wireless Intrusion Prevention, 1 License
3132A1A8
LIS-AD-Campus-AP-WS-1
H3C AD-Campus Wireless Intrusion Prevention, 100 Licenses
3132A1A9
LIS-AD-Campus-AP-WS-100
AD-Campus Standard Edition Software License
3130A6FS
AD-CAMPUS-STD-SWP
H3C AD-Campus Standard Edition Software License
Table 19 iNSM license matrix
License
BOM
Product code
Software versions
Remarks
3132A194
3132A197
Table 20 iWO license matrix
License
BOM
Product code
Software versions
Remarks
3132A196
3132A195
NPA
IMPORTANT
IMPORTANT:
·     H3C NPA supports only remote licensing.
Table 21 License types
License type
Validity period
Remarks
Formal license
Permanent
Supported
Trial license
30, 60, or 90 days
Not supported
90 days
Not supported
·     NPA preinstalled license: Supports 100 platform nodes and the incorporated device number is unlimited.
IMPORTANT
IMPORTANT:
If a network connection error occurs between NPA and the License Server, the NPA enters the fail-safe mode right after 24 hours. In fail-safe mode, the obtained license validity period is extended for 30 days. If the connection recovers within 30 days, NPA exits fail-safe mode and goes back to the normal state. If the connection fails to recover within 30 days, NPA exits fail-safe mode and becomes unavailable.
Table 22 NPA license matrix
License
BOM
Product code
Software versions
Remarks
H3C Intelligent Analytics Software License for NPA, Standard Edition
3130A4YE
LIS-SeerAnalyzer-NPA-STD
E6xxx
In versions E61xx and E62xx, this license is required in an NPA scenario, and each set of NPA product requires a license.
In versions E63xx and E65xx, you select at least one of this license and the LIS-SeerAnalyzer-NPA-Basic license for an NPA scenario.
H3C Intelligent Analytics Software License for NPA, Enhanced Edition
3130A4YG
LIS-SeerAnalyzer-NPA-ENH
E6xxx
H3C Intelligent Analytics Software License, NPA Basic Edition
3130A5LJ
E63xx and later
Compatible with LIS-SeerAnalyzer-NPA-STD
H3C Intelligent Analytics Server License, 1 Server Node
3130A4YF
LIS-SeerAnalyzer-NLT-1N
E6xxx
Required in NPA scenarios. Each platform node requires a license. For example, a single server product requires a license and a three-node cluster requires three licenses.
H3C Intelligent Analytics Software License for Cloud Network Traffic Analytics
3130A5LH
LIS-SeerAnalyzer-DC-CPA
E63xx and later
Optional in an NPA scenario.
H3C Intelligent Analytics Software License for Cloud-Network Traffic Analytics, 10 VM Probes
3132A0XB
LIS-SeerAnalyzer-DC-CPA-VM
E63xx and later
Optional in an NPA scenario. Select the number of licenses according to the number of VM probes managed. Each license can manage 10 probes.
3132A15F
LIS-ADNET-APA-1
E65xx and later
U-Center
IMPORTANT
IMPORTANT:
·     U-Center supports only remote licensing.
·     U-Center supports preinstalled licenses, trial licenses, and formal licenses.
Table 23 U-Center license types
License type
Validity period
Remarks
Formal license
Permanent
Supported
30, 60, and 90 days
Not supported
90 days
Not supported
IMPORTANT
IMPORTANT:
If a network connection error occurs between U-Center and the License Server, U-Center  enters the fail-safe mode after 24 hours. In fail-safe mode, the obtained license validity period is extended for 30 days. If the connection recovers within 30 days, U-Center exits fail-safe mode and goes back to the normal state. If the connection fails to recover within 30 days, U-Center exits fail-safe mode and becomes unavailable.
Table 24 U-Center license matrix
License
BOM
Product code
Software versions
Remarks
H3C U-Center2.0, Intelligent Operations Platform Software
3130A3RN
LIS-UCENTER2-IOP
E0512 and later
U-Center 2.0 basic license.
Required license. Each set of U-Center 2.0 product requires a license.
H3C U-Center5.0, Intelligent Operations Platform Software
3130A6YL
LIS-UCENTER5-IOP
E7101 and later
U-Center 5.0 basic license.
Required license. Each set of U-Center 5.0 product requires a license.
H3C U-Center2.0, CMDB License
3130A45B
LIS-UCENTER2-CMDB
E0512 and later
E7101 and later
CMDB basic license, which must be used together with a U-Center basic license
H3C U-Center2.0, CMDB, 25 Licenses
3130A465
LIS-UCENTER2-CMDB-25
E0512 and later
E7101 and later
Optional license, which allows a maximum of 25 resources to be added for polling or management in IOM.
H3C U-Center2.0, CMDB, 50 Licenses
3130A45K
LIS-UCENTER2-CMDB-50
E0512 and later
E7101 and later
Optional license, which allows a maximum of 50 resources to be added for polling or management in IOM.
H3C U-Center2.0, CMDB, 100 Licenses
3130A466
LIS-UCENTER2-CMDB-100
E0512 and later
E7101 and later
Optional license, which allows a maximum of 100 resources to be added for polling or management in IOM.
H3C U-Center2.0, CMDB, 200 Licenses
3130A45V
LIS-UCENTER2-CMDB-200
E0512 and later
E7101 and later
Optional license, which allows a maximum of 200 resources to be added for polling or management in IOM.
H3C U-Center2.0, CMDB, 500 Licenses
3130A45C
LIS-UCENTER2-CMDB-500
E0512 and later
E7101 and later
Optional license, which allows a maximum of 500 resources to be added for polling or management in IOM.
H3C U-Center2.0, CMDB, 1000 Licenses
3130A45U
LIS-UCENTER2-CMDB-1K
E0512 and later
E7101 and later
Optional license, which allows a maximum of 1000 resources to be added for polling or management in IOM.
H3C U-Center2.0, CMDB, 1 License
3132A12C
LIS-UCENTER2-CMDB-1
E0709 and later
E7101 and later
Optional license, which allows only one resource to be added for polling or management in IOM.
3132A16M
LIS-UCENTER2-CMDB-100-A
E0713 and later
E7101 and later
H3C U-Center2.0, IOM, Intelligent Analysis Report License
3130A45S
LIS-UCENTER2-IOM-IAR
E0512 and later
E7101 and later
Optional license. It is required only when you use advanced features such as orchestration and customization. It is not required for predefined report management.
H3C U-Center2.0, IOM License
3130A3RE
LIS-UCENTER2-IOM
E0512 and later
E7101 and later
IOM basic license, which must be used together with a U-Center basic license
H3C U-Center2.0, IOM, 25 Licenses
3130A3RH
LIS-UCENTER2-IOM-25
E0512 and later
E7101 and later
Optional license, which allows a maximum of 25 monitored resources in IOM.
H3C U-Center2.0, IOM, 50 Licenses
3130A3RP
LIS-UCENTER2-IOM-50
E0512 and later
E7101 and later
Optional license, which allows a maximum of 50 monitored resources in IOM.
H3C U-Center2.0, IOM, 100 Licenses
3130A3RK
LIS-UCENTER2-IOM-100
E0512 and later
E7101 and later
Optional license, which allows a maximum of 100 monitored resources in IOM.
H3C U-Center2.0, IOM, 200 Licenses
3130A3RF
LIS-UCENTER2-IOM-200
E0512 and later
E7101 and later
Optional license, which allows a maximum of 200 monitored resources in IOM.
H3C U-Center2.0, IOM, 500 Licenses
3130A3RL
LIS-UCENTER2-IOM-500
E0512 and later
E7101 and later
Optional license, which allows a maximum of 500 monitored resources in IOM.
H3C U-Center2.0, IOM, 1000 Licenses
3130A3RG
LIS-UCENTER2-IOM-1K
E0512 and later
E7101 and later
Optional license, which allows a maximum of 1000 monitored resources in IOM.
H3C U-Center2.0, IOM, 1 License
3132A12V
LIS-UCENTER2-IOM-1
E0711 and later
E7101 and later
Optional license, which allows only one monitored resource in IOM.
3132A16L
LIS-UCENTER2-IOM-100-A
E0711 and later
E7101 and later
H3C U-Center2.0, BSM License
3130A45L
LIS-UCENTER2-BSM
E0512 and later
E7101 and later
BSM basic license, which must be used together with a U-Center basic license
H3C U-Center2.0, BSM, 1 License
3132A12P
LIS-UCENTER2-BSM-1
E0709 and later
E7101 and later
Optional license, which allows only one added service in BSM
H3C U-Center2.0, BSM, 5 Licenses
3130A45D
LIS-UCENTER2-BSM-5
E0512 and later
E7101 and later
Optional license, which allows a maximum of 5 added services in BSM
H3C U-Center2.0, BSM, 10 Licenses
3130A45W
LIS-UCENTER2-BSM-10
E0512 and later
E7101 and later
Optional license, which allows a maximum of 10 added services in BSM
H3C U-Center2.0, BSM, UEM, 1 License
3132A12L
LIS-UCENTER2-BSM-UEM-1-B
E0709 and later
E7101 and later
UEM quantity license, which must be used together with a U-Center basic license
3130A45X
E0512 and later
E7101 and later
Optional license, which allows only one user experience entry
H3C U-Center2.0, BSM, UEM, 2 Licenses
3130A45N
LIS-UCENTER2-BSM-UEM-2
E0512 and later
E7101 and later
Optional license, which allows a maximum of two user experience entries
H3C U-Center2.0, BSM, UEM, 5 Licenses
3130A45M
LIS-UCENTER2-BSM-UEM-5
E0512 and later
E7101 and later
Optional license, which allows a maximum of five user experience entries
H3C U-Center2.0, IOM, Network Traffic Analyzer, 1 License
3132A12U
LIS-UCENTER2-IOM-NTA-1-B
E0512 and later
E7101 and later
NTA basic license, which allows only one managed device in NTA.
3130A463
E0512 and later
E7101 and later
Optional license, which allows only one managed device in NTA
H3C U-Center2.0, IOM, Network Traffic Analyzer, 2 Licenses
3130A45H
LIS-UCENTER2-IOM-NTA-2
E0512 and later
E7101 and later
Optional license, which allows a maximum of two devices in NTA
H3C U-Center2.0, IOM, Network Traffic Analyzer, 5 Licenses
3130A464
LIS-UCENTER2-IOM-NTA-5
E0512 and later
E7101 and later
Optional license, which allows a maximum of five devices in NTA
H3C U-Center2.0, ITSM License
3130A45P
LIS-UCENTER2-ITSM
E0512 and later
E7101 and later
ITSM basic license, which must be used together with a U-Center basic license and controls the total number of count-type users and designated-type users
H3C U-Center2.0, ITSM, 1 License
3132A12D
LIS-UCENTER2-ITSM-1
E0710 and later
E7101 and later
Optional license, which allows only one count-type user or designated-type user.
H3C U-Center2.0, ITSM, 5 Licenses
3130A45E
LIS-UCENTER2-ITSM-5
E0512 and later
E7101 and later
Optional license, which allows a maximum of five count-type users and designated-type users
H3C U-Center2.0, ITSM, 10 Licenses
3130A467
LIS-UCENTER2-ITSM-10
E0512 and later
E7101 and later
Optional license, which allows a maximum of 10 count-type users and designated-type users
H3C U-Center2.0, ITSM, 20 Licenses
3130A461
LIS-UCENTER2-ITSM-20
E0512 and later
E7101 and later
Optional license, which allows a maximum of 20 count-type users and designated-type users
H3C U-Center2.0, ITSM, 50 Licenses
3130A45Q
LIS-UCENTER2-ITSM-50
E0512 and later
E7101 and later
Optional license, which allows a maximum of 50 count-type users and designated-type users
H3C U-Center2.0, ITSM, 100 Licenses
3130A45F
LIS-UCENTER2-ITSM-100
E0512 and later
E7101 and later
Optional license, which allows a maximum of 100 count-type users and designated-type users
H3C U-Center2.0, ITSM, Change and Release Management License
3130A45G
LIS-UCENTER2-ITSM-CRM
E0512 and later
E7101 and later
ITSM change and release management license, which depends on the ITSM basic license
H3C U-Center2.0, ITSM, Service Level Management License
3130A460
LIS-UCENTER2-ITSM-SLM
E0512 and later
E7101 and later
ITSM service level management license, which depends on the ITSM basic license
H3C U-Center2.0, ITSM, Knowledge Base License
3130A45Y
LIS-UCENTER2-ITSM-KB
E0512 and later
E7101 and later
ITSM knowledge base license, which depends on the ITSM basic license
H3C U-Center2.0, ITSM, Self-Service Desk License
3130A468
LIS-UCENTER2-ITSM-SSD
E0513 and later
E7101 and later
ITSM self-service desk license, which depends on the ITSM basic license
H3C U-Center2.0, Network Service Management License
3130A426
LIS-IMC9-NSM
E0512 and later
E7101 and later
Network basic license
H3C U-Center2.0, Network Service Management, 25 Licenses
3130A423
LIS-IMC9-NSMA-25
E0512 and later
E7101 and later
Network quantity license, which depends on the network basic license and allows a maximum of 25 managed resources in NSM
H3C U-Center2.0, Network Service Management, 50 Licenses
3130A429
LIS-IMC9-NSMB-50
E0512 and later
E7101 and later
Network quantity license, which depends on the network basic license and allows a maximum of 50 managed resources in NSM
H3C U-Center2.0, Network Service Management, 100 Licenses
3130A427
LIS-IMC9-NSMC-100
E0512 and later
E7101 and later
Network quantity license, which depends on the network basic license and allows a maximum of 100 managed resources in NSM
H3C U-Center2.0, Network Service Management, 200 Licenses
3130A425
LIS-IMC9-NSMD-200
E0512 and later
E7101 and later
Network quantity license, which depends on the network basic license and allows a maximum of 200 managed resources in NSM
H3C U-Center2.0, Network Service Management, 500 Licenses
3130A424
LIS-IMC9-NSME-500
E0512 and later
E7101 and later
Network quantity license, which depends on the network basic license and allows a maximum of 500 managed resources in NSM
H3C U-Center2.0, Network Service Management, 1000 Licenses
3130A428
LIS-IMC9-NSMF-1K
E0512 and later
E7101 and later
Network quantity license, which depends on the network basic license and allows a maximum of 1000 managed resources in NSM
H3C UCenter, AOM, IP Address Management System, 50 Licenses
3130A1YS
LIS-UCENTER-AOM-IPMS-50
E0608 and later
E7101 and later
IP address management system license, which depends on the network quantity license and allows a maximum of 50 devices managed in IP scan tasks
H3C UCenter, AOM, IP Address Management System, 100 Licenses
3130A1YT
LIS-UCENTER-AOM-IPA-100
E0608 and later
E7101 and later
IP address management system license, which depends on the network quantity license and allows a maximum of 100 devices managed in IP scan tasks
H3C UCenter, AOM, IP Address Management System, 200 Licenses
3130A1YU
LIS-UCENTER-AOM-IPA-200
E0608 and later
E7101 and later
IP address management system license, which depends on the network quantity license and allows a maximum of 200 devices managed in IP scan tasks
H3C UCenter, AOM, IP Address Management System, 500 Licenses
3130A1YV
LIS-UCENTER-AOM-IPA-500
E0608 and later
E7101 and later
IP address management system license, which depends on the network quantity license and allows a maximum of 500 devices managed in IP scan tasks
H3C UCenter, AOM, IP Address Management System, 1000 Licenses
3130A1YW
LIS-UCENTER-AOM-IPA-1000
E0608 and later
E7101 and later
IP address management system license, which depends on the network quantity license and allows a maximum of 1000 devices managed in IP scan tasks
H3C U-Center2.0, AOM, IP Address Management System, 1 License
3132A12E
LIS-UCENTER2-AOM-IPA-1
E0709 and later
E7101 and later
IP address management system license, which depends on the network quantity license and allows  only one device managed in IP scan tasks
H3C U-Center2.0, AOM, IP Address Management System, 100 Licenses
3132A16N
LIS-UCENTER2-AOM-IPA-100-A
E0709 and later
E7101 and later
H3C UCenter, AOM, Configuration And Compliance Intelligent Management, 50 Licenses
3130A2KJ
LIS-UCENTER-AOM-CCI-50-2
E0608 and later
E7101 and later
Configuration and compliance intelligent management license, which depends on the network quantity license and allows a maximum of 50 devices managed in compliance tasks
H3C U-Center, AOM, Configuration And Compliance Intelligent Management, 100 Licenses
3130A2KK
LIS-UCENTER-AOM-CCI-100-2
E0608 and later
E7101 and later
Configuration and compliance intelligent management license, which depends on the network quantity license and allows a maximum of 100 devices managed in compliance tasks
H3C U-Center, AOM, Configuration And Compliance Intelligent Management, 200 Licenses
3130A2KL
LIS-UCENTER-AOM-CCI-200-2
E0608 and later
E7101 and later
Configuration and compliance intelligent management license, which depends on the network quantity license and allows a maximum of 200 devices managed in compliance tasks
H3C U-Center, AOM, Configuration And Compliance Intelligent Management, 500 Licenses
3130A2KM
LIS-UCENTER-AOM-CCI-500-2
E0608 and later
E7101 and later
Configuration and compliance intelligent management license, which depends on the network quantity license and allows a maximum of 500 devices managed in compliance tasks
H3C U-Center, AOM, Configuration And Compliance Intelligent Management, 1000 Licenses
3130A2NJ
LIS-UCENTER-AOM-CCI-1000-2
E0608 and later
E7101 and later
Configuration and compliance intelligent management license, which depends on the network quantity license and allows a maximum of 1000 devices managed in compliance tasks
H3C U-Center2.0, AOM, Configuration And Compliance Intelligent Management, 1 License
3132A12W
LIS-UCENTER2-AOM-CCI-1
E0709 and later
E7101 and later
Configuration and compliance intelligent management license, which depends on the network quantity license and allows only one device managed in compliance tasks
H3C U-Center2.0, AOM, Configuration And Compliance Intelligent Management, 100 Licenses
3132A16K
LIS-UCENTER2-AOM-CCI-100-A
E0709 and later
E7101 and later
H3C UCenter, AOM, Intelligent Inspection Expert Provider Edition, 50 Licenses
3130A1HF
LIS-UCENTER-AOM-IIE-50
E0608 and later
E7101 and later
Intelligent inspection license, which depends on the network quantity license and allows a maximum of 50 devices managed in the inspection manager
H3C UCenter, AOM, Intelligent Inspection Expert Provider Edition, 100 Licenses
3130A1GP
LIS-UCENTER-AOM-IIE-100
E0608 and later
E7101 and later
Intelligent inspection license, which depends on the network quantity license and allows a maximum of 100 devices managed in the inspection manager
H3C UCenter, AOM, Intelligent Inspection Expert Provider Edition, 200 Licenses
3130A1GQ
LIS-UCENTER-AOM-IIE-200
E0608 and later
E7101 and later
Intelligent inspection license, which depends on the network quantity license and allows a maximum of 200 devices managed in the inspection manager
H3C UCenter, AOM, Intelligent Inspection Expert Provider Edition, 500 Licenses
3130A1GR
LIS-UCENTER-AOM-IIE-500
E0608 and later
E7101 and later
Intelligent inspection license, which depends on the network quantity license and allows a maximum of 500 devices managed in the inspection manager
H3C UCenter, AOM, Intelligent Inspection Expert Provider Edition, 1000 Licenses
3130A1GS
LIS-UCENTER-AOM-IIE-1000
E0608 and later
E7101 and later
Intelligent inspection license, which depends on the network quantity license and allows a maximum of 1000 devices managed in the inspection manager
H3C U-Center2.0, AOM, Intelligent Inspection Expert Provider Edition, 1 License
3132A12R
LIS-UCENTER2-AOM-IIE-1
E0709 and later
E7101 and later
Intelligent inspection license, which depends on the network quantity license and allows only one device managed in the inspection manager
H3C U-Center2.0, AOM, Intelligent Inspection Expert Provider Edition, 100 Licenses
3132A16P
LIS-UCENTER2-AOM-IIE-100-A
E0709 and later
E7101 and later
H3C U-Center2.0, IOM, STM License
3130A5M4
LIS-UCENTER2-IOM-STM
E0709 and later
E7101 and later
STM basic license, which controls the number of NQA devices managed and the number of sites used in service dialing tests
H3C U-Center2.0, IOM, STM, 1 License
3132A0XR
LIS-UCENTER2-IOM-STM-1
E0709 and later
STM quantity license, which depends on the STM basic license and allows one NQA devices managed or one site used in service dialing test. Sites used in a lower-level region, a proxy, or a dialing test agent are counted. Local sites are not counted.
H3C IOC License
3130A6HG
LIS-IOC
E0721 and later
IOC basic license
H3C IOC, Portal Integration, 1 License
3132A1AX
LIS-IOC-PORTAL-1
E0721 and later
IOC portal integration quantity license, which must be used together with the IOC basic license and allows only one cloud platform to be managed
H3C U-Center2.0, CM License
3130A6HH
LIS-UCENTER2-CM
E0721 and later
E7101 and later
Capacity management basic license
H3C U-Center2.0, AOM Job Platform License
3130A6KG
LIS-UCENTER2-AOM-JOB
E0721 and later
E7101 and later
Automated job platform basic license
H3C U-Center2.0, AOM Job Platform 1-Node License
3132A1B7
LIS-UCENTER2-AOM-JOB-1
E0721 and later
E7101 and later
Automated job platform quantity license, which is dependent on the automated job platform basic license and allows only one resource to be managed in jobs
H3C U-Center2.0, AOM Job Platform 25-Node License
3130A6KE
LIS-UCENTER2-AOM-JOB-25
E0721 and later
E7101 and later
Automated job platform quantity license, which is dependent on the automated job platform basic license and allows a maximum of 25 resources managed in jobs
H3C U-Center2.0, AOM Job Platform 50-Node License
3130A6KF
LIS-UCENTER2-AOM-JOB-50
E0721 and later
E7101 and later
Automated job platform quantity license, which is dependent on the automated job platform basic license and allows a maximum of 50 resources managed in jobs
H3C U-Center2.0, AOM Job Platform 100-Node License
3130A6KH
LIS-UCENTER2-AOM-JOB-100
E0721 and later
E7101 and later
Automated job platform quantity license, which is dependent on the automated job platform basic license and allows a maximum of 100 resources managed in jobs
H3C U-Center2.0, AOM Job Platform 200-Node License
3130A6KC
LIS-UCENTER2-AOM-JOB-200
E0721 and later
E7101 and later
Automated job platform quantity license, which is dependent on the automated job platform basic license and allows a maximum of 200 resources managed in jobs
H3C U-Center2.0, AOM Job Platform 500-Node License
3130A6KB
LIS-UCENTER2-AOM-JOB-500
E0721 and later
E7101 and later
Automated job platform quantity license, which is dependent on the automated job platform basic license and allows a maximum of 500 resources managed in jobs
H3C U-Center2.0, AOM Job Platform 1000-Node License
3130A6KD
LIS-UCENTER2-AOM-JOB-1K
E0721 and later
E7101 and later
Automated job platform quantity license, which is dependent on the automated job platform basic license and allows a maximum of 1000 resources managed in jobs
H3C U-Center2.0, ODA, Operational Data Analytics License
3130A6QK
LIS-UCENTER2-ODA
E0721 and later
E7101 and later
Operational data analytics basic license
IMC V9
IMPORTANT
IMPORTANT:
·     IMC V9 components support only remote licensing.
·     By default, alerts will be generated for a trial or preinstalled license when the validity period left is 10 days, and an alert is generated every day.
·     IMC V9 components support preinstalled licenses, trial licenses, and formal licenses.
Table 25 IMC V9 component license types
License type
Validity period
License uninstallation/transfer
Remarks
Formal license
Permanent
Supported
When the license expires (for example, during the license migration process), the licensed services are not affected, but new services cannot be onboarded.
Trial (temporary) license
30, 60, and 90 days
Not supported
A trial license is time limited. When a trial license expires, the license-based feature becomes unavailable. To continue to use the feature, you must purchase and install a formal license for it.
When trial and formal licenses are mixed in use, the total number of available licenses is the sum of the two types of licenses.
Preinstalled license
90 days
Not supported
A preinstalled license is time limited. The validity period starts on initial startup of the software system. When a preinstalled license expires, the feature becomes unavailable. To continue to use the feature, you must purchase and install a formal license for it.
All the preinstalled licenses for a component become invalid if you install a trial or formal license for the component. For example, if you install a formal quantity license for a component, the preinstalled feature license installed for the component becomes invalid. After you uninstall the formal license, the preinstalled license takes effect if it has not expired.
IVM, BIMS, and ENM do not support preinstalled licenses.
Identify the number of nodes supported by a preinstalled license:
·     QoSM preinstalled license: Unlimited.
·     MBM preinstalled license: 50 devices.
·     VPNM preinstalled license: 5 devices.
·     MBM preinstalled license: Unlimited.
·     MCN preinstalled license: 50 NEs.
·     EIA/EAD: Up to 500 concurrent online users are supported. The EIP preinstalled license allows for up to 100 concurrent online users.
·     EPS preinstalled license: 500 endpoints.
·     WSM preinstalled license: 50 APs.
·     Network management preinstalled license: 50 devices.
IMPORTANT
IMPORTANT:
·     If a network connection error occurs between an IMC V9 component and the License Server, the IMC V9 component enters the fail-safe mode right after 24 hours. In fail-safe mode, the obtained license validity period is extended for 30 days. If the connection recovers within 30 days, the IMC V9 component exits fail-safe mode and goes back to the normal state. If the connection fails to recover within 30 days, the IMC V9 component exits fail-safe mode and becomes unavailable.
·     When you purchase an EAD license, an EIA license is included. After software installation, you only need to register the EAD license. Upon successful registration, the system will automatically generate the EIA license, and you do not need to purchase it separately.
Table 26 IMC V9 component license matrix
Software service
Feature/functionality
BOM
Product code
License
Dependent license
Software versions
QoSM
QoSM license
3130A4MS
LIS-IMC9-WVAS
H3C iMC9.0, WAN Value-Added Management Service License
SeerEngine-SDWAN or SeerEngine-WAN
E0201 and later
BIMS
BIMS basic license
3130A4MV
LIS-IMC9-BIMS
H3C iMC9.0, Branch Intelligent Management System Component with 50 Licenses
N/A
E0101 and later
BIMS quantity license
3130A4MJ
LIS-IMC9-BIMSA-100
H3C iMC9.0, Branch Intelligent Management System Component, 100 Licenses
BIMS basic license
E0101 and later
3130A4MW
LIS-IMC9-BIMSB-200
H3C iMC9.0, Branch Intelligent Management System Component, 200 Licenses
E0101 and later
3130A4MR
LIS-IMC9-BIMSC-500
H3C iMC9.0, Branch Intelligent Management System Component, 500 Licenses
E0101 and later
3130A4ML
LIS-IMC9-BIMSD-1k
H3C iMC9.0, Branch Intelligent Management System Component, 1000 Licenses
E0101 and later
IVM
IVM basic license
3130A4PD
LIS-IMC9-IVM
H3C iMC9.0, IPsec VPN Manager Component with 50 Licenses
E0101 and later
IVM quantity license
3130A4P7
LIS-IMC9-IVMA-50
H3C iMC9.0, IPsec VPN Manager Component, 50 Licenses
IVM basic license
E0101 and later
3130A4PE
LIS-IMC9-IVMB-100
H3C iMC9.0, IPsec VPN Manager Component, 100 Licenses
E0101 and later
3130A4P8
LIS-IMC9-IVMC-200
H3C iMC9.0, IPsec VPN Manager Component, 200 Licenses
E0101 and later
3130A4P5
LIS-IMC9-IVMD-500
H3C iMC9.0, IPsec VPN Manager Component, 500 Licenses
E0101 and later
3130A4PC
LIS-IMC9-IVME-1K
H3C iMC9.0, IPsec VPN Manager Component, 1000 Licenses
E0101 and later
ENM
ENM license
3130A4PB
LIS-IMC9-ENM
H3C iMC9.0, Electricity Network Manager Component License
E0101 and later
MCN
MCN basic license
3130A4P9
LIS-IMC9-MCN
H3C iMC9.0, Mobile Communications Network Manager Component License
E0101 and later
MCN quantity license
3130A4P6
LIS-IMC9-MCNA-50
H3C iMC9.0, Mobile Communications Network Manager Component, 50 Licenses
MCN basic license
E0101 and later
EAD
EAD basic license
3130A4J7
LIS-IMC9-EAD
H3C iMC9, Endpoint Admission Defense License
N/A
E0201 and later
EAD quantity license
3130A4J8
LIS-IMC9-EADF-50
H3C iMC9, Endpoint Admission Defense License, 50 Licenses
E0201 and later
3130A4HU
LIS-IMC9-EADA-200
H3C iMC9, Endpoint Admission Defense License, 200 Licenses
E0201 and later
3130A4JF
LIS-IMC9-EADB-500
H3C iMC9, Endpoint Admission Defense License, 500 Licenses
E0201 and later
3130A4HV
LIS-IMC9-EADD-2K
H3C iMC9, Endpoint Admission Defense License, 2000 Licenses
E0201 and later
3130A4HW
LIS-IMC9-EADE-5K
H3C iMC9, Endpoint Admission Defense License, 5000 Licenses
E0201 and later
3132A0N4
LIS-AD-Campus-EAD-25
H3C AD-Campus, End-user Admission Defense, 25 Licenses
H3C AD-Campus Management and Control Software License
E0215 and later
3132A10P
LIS-AD-Campus-EAD-100
H3C AD-Campus, End-user Admission Defense, 100 Licenses
E0215 and later
3132A1A1
LIS-AD-Campus-EAD-1000
H3C AD-Campus, End-user Admission Defense, 1000 Licenses
E0215 and later
3132A0VR
LIS-AD-Campus-EAD-A-25
H3C AD-Campus, Advanced Endpoint Admission Defense, 25 Licenses
E0215 and later
3132A1A0
LIS-AD-Campus-EAD-A-1000
HH3C AD-Campus, Advanced Endpoint Admission Defense, 1000 Licenses
E0215 and later
3132A0PC
LIS-AD-Campus-EAD-TEA-25
H3C iMC-EAD, Zero Trust Function for EAD, 50 License
E0215 and later
EIA
EIA basic license
3130A4J3
LIS-IMC9-EIA
H3C iMC9, Endpoint Intelligent Access License
N/A
E0208 and later
EIA quantity license
3130A4J4
LIS-IMC9-EIAA-50
H3C iMC9, Endpoint Intelligent Access License, 50 Licenses
EIA basic license
E0208 and later
3130A4J9
LIS-IMC9-EIAB-200
H3C iMC9, Endpoint Intelligent Access License, 200 Licenses
E0208 and later
3130A4JA
LIS-IMC9-EIAC-500
H3C iMC9, Endpoint Intelligent Access License, 500 Licenses
E0208 and later
3130A4JB
LIS-IMC9-EIAD-2K
H3C iMC9, Endpoint Intelligent Access License, 2000 Licenses
E0208 and later
3130A4HX
LIS-IMC9-EIAE-5K
H3C iMC9, Endpoint Intelligent Access License, 5000 Licenses
E0208 and later
3132A0N1
LIS-AD-Campus-EIA-25
H3C AD-Campus, Endpoint Intelligent Access, 25 Licenses
E0215 and later
3132A107
LIS-AD-Campus-EIA-100
H3C AD-Campus, Endpoint Intelligent Access, 100 Licenses
E0215 and later
3132A1A4
LIS-AD-Campus-EIA-1000
H3C AD-Campus, Endpoint Intelligent Access, 1000 Licenses
E0215 and later
EIA endpoint intelligent profiling feature license
3130A4J5
LIS-IMC9-EIAA-50-EIP
H3C iMC9, End-user Intelligent Access License, Endpoint Intelligent Profiling, 50 Licenses
EIA basic license
E0208 and later
3130A4HY
LIS-IMC9-EIAB-200-EIP
H3C iMC9, Endpoint Intelligent Access License, Endpoint Intelligent Profiling, 200 Licenses
E0208 and later
3130A4J0
LIS-IMC9-EIAC-500-EIP
H3C iMC9, Endpoint Intelligent Access License, Endpoint Intelligent Profiling, 500 Licenses
E0208 and later
3130A4JC
LIS-IMC9-EIAD-2K-EIP
H3C iMC9, Endpoint Intelligent Access License, Endpoint Intelligent Profiling, 2000 Licenses
E0208 and later
3130A4HR
LIS-IMC9-EIAE-5K-EIP
H3C iMC9, Endpoint Intelligent Access License, Endpoint Intelligent Profiling, 5000 Licenses
E0208 and later
3132A0N2
LIS-AD-Campus-EIP-25
H3C AD-Campus, Endpoint Intelligent Profiling for EIA, 25 Licenses
E0215 and later
EBM
EBM quantity license
3132A0NN
LIS-AD-Campus-EBM-25
H3C AD-Campus, Endpoint Behavior Management, 25 Licenses
E6203 and later
3132A10A
LIS-AD-Campus-EBM-100
H3C AD-Campus, Endpoint Behavior Management, 100 Licenses
E6203 and later
3132A1AA
LIS-AD-Campus-EBM-1000
H3C AD-Campus, Endpoint Behavior Management, 1000 Licenses
E6203 and later
EDM
Quantity license for EDM
3132A0MT
LIS-AD-Campus-EDM-25
H3C AD-Campus, Endpoint Data Management, 25 Licenses
E6203 and later
3132A0YR
LIS-AD-Campus-EDM-100
H3C AD-Campus, Endpoint Data Management, 100 Licenses
E6203 and later
3132A1AB
LIS-AD-Campus-EDM-1000
H3C AD-Campus, Endpoint Data Management, 1000 Licenses
E6203 and later
EPS
EPS basic license
3130A43J
LIS-IMC9-EPS
H3C iMC9.0, Endpoint Profiling System License
N/A
E0203 and later
EPS quantity license
3130A42G
LIS-IMC9-EPSA-50
H3C iMC9.0, Endpoint Profiling Component, 50 Licenses
EPS basic license
E0203 and later
3130A42L
LIS-IMC9-EPSB-200
H3C iMC9.0, Endpoint Profiling Component, 200 Licenses
E0203 and later
3130A42K
LIS-IMC9-EPSC-500
H3C iMC9.0, Endpoint Profiling Component, 500 Licenses
E0203 and later
3130A435
LIS-IMC9-EPSD-1K
H3C iMC9.0, Endpoint Profiling Component, 1000 Licenses
E0203 and later
3130A42M
LIS-IMC9-EPSE-2K
H3C iMC9.0, Endpoint Profiling Component, 2000 Licenses
E0203 and later
3130A42Y
LIS-IMC9-EPSF-5K
H3C iMC9.0, Endpoint Profiling Component, 5000 Licenses
E0203 and later
3130A436
LIS-IMC9-EPSG-10K
H3C iMC9.0, Endpoint Profiling Component, 10000 Licenses
E0203 and later
3132A0NA
LIS-AD-Campus-EPS-25
H3C AD-Campus, Endpoint Profiling, 25 Licenses
E0210 and later
3132A0YE
LIS-AD-Campus-EPS-100
H3C AD-Campus, Endpoint Profiling, 100 Licenses
E0210 and later
3132A1AC
LIS-AD-Campus-EPS-1000
H3C AD-Campus, Endpoint Profiling, 1000 Licenses
E0210 and later
EPS-A
Advanced EPS quantity license
3132A0N9
LIS-AD-Campus-EPS-A-25
H3C AD-Campus, Advanced Endpoint Profiling, 25 Licenses
E0210 and later
3132A10S
LIS-AD-Campus-EPS-A-100
H3C AD-Campus, Advanced Endpoint Profiling, 100 Licenses
E0210 and later
3132A1AD
LIS-AD-Campus-EPS-A-1000
H3C AD-Campus, Advanced Endpoint Profiling, 1000 Licenses
E0210 and later
WSM
WSM basic license
3130A42Q
LIS-IMC9-WSM
H3C IMC9.0, Wireless Service Manager License
N/A
E0101 and later
WSM AP manager quantity license
3130A43H
LIS-IMC9-WSMA-50
H3C iMC9.0, Wireless Service Manager Component, 50 Licenses
WSM basic license
E0101 and later
3130A43K
LIS-IMC9-WSMB-100
H3C iMC9.0, Wireless Service Manager Component, 100 Licenses
E0101 and later
3130A42R
LIS-IMC9-WSMC-200
H3C iMC9.0, Wireless Service Manager Component, 200 Licenses
E0101 and later
3130A42S
LIS-IMC9-WSMD-500
H3C iMC9.0, Wireless Service Manager Component, 500 Licenses
E0101 and later
3130A43A
LIS-IMC9-WSME-1K
H3C iMC9.0, Wireless Service Manager Component, 1000 Licenses
E0101 and later
3130A43B
LIS-IMC9-WSMF-2K
H3C iMC9.0, Wireless Service Manager Component, 2000 Licenses
E0101 and later
3130A42E
LIS-IMC9-WSMG-5K
H3C iMC9.0, Wireless Service Manager Component, 5000 Licenses
E0101 and later
3132A0P5
LIS-AD-Campus-AP-1
WSM basic license or H3C AD-Campus Management and Control Software License
E0213 and later
3132A10M
E0213 and later
3132A1A6
E0213 and later
3132A0NG
LIS-AD-Campus-MAK-1
E0213 and later
3132A0P7
LIS-AD-Campus-MSG360-1
H3C AD-Campus Controller Management License for MSG360 Series, 1-Device
E0213 and later
3132A0ND
LIS-AD-Campus-WAC380-1
H3C AD-Campus Wireless Management License for WAC380 Series, 1-Device
E0213 and later
3132A0NR
LIS-AD-Campus-WX1800-1
H3C AD-Campus Controller Management License for WX1800 Series, 1-Device
E0213 and later
3132A0P8
LIS-AD-Campus-WX2500-1
H3C AD-Campus Wireless Management License for WX2500 Series, 1-Device
E0213 and later
3132A0NE
LIS-AD-Campus-WX3000-1
H3C AD-Campus Wireless Management License for WX3000 Series, 1-Device
E0213 and later
3132A0MR
LIS-AD-Campus-WX3500-1
H3C AD-Campus Management and Control License for WX3500/WX3800 Series, 1-Device
E0213 and later
3132A0NU
LIS-AD-Campus-WX5500-1
H3C AD-Campus Management and Control License for WX5500/WX5800 Series, 1-Device
E0213 and later
3132A0MY
LIS-AD-Campus-WX6100-1
H3C AD-Campus Wireless Management License for WX6100 Series, 1-Device
E0213 and later
3132A0NV
LIS-AD-Campus-ACM-1
H3C AD-Campus Wireless Management License for Access Controller Modules, 1-Device
E0213 and later
3132A0PD
LIS-AD-Campus-FAP-1
E0213 and later
WSM AP location license
3132A0NT
LIS-AD-Campus-AP-L-1
H3C AD-Campus Wireless Location License for APs, 1 Device
E0213 and later
3132A108
LIS-AD-Campus-AP-L-1000
H3C AD-Campus Wireless Location License for APs, 1000 Devices
E0213 and later
3132A1A3
H3C AD-Campus Wireless Location License for APs, 100 Devices
E0213 and later
WSM WLAN security license
3132A1A8
E6219 and later
3132A1A9
E6219 and later
WSM intelligent analytics feature license
3132A06Y
H3C AD-Campus Intelligent Analytics License for APs, 1-Device
E0213 and later
WSM optimization and self-healing feature license
3132A0P6
H3C AD-Campus Optimization & Self-Healing License for APs, 1-Device
E0213 and later
3130A6FS
LIS-AD-Campus-STD-SWP
N/A
E0218 and later
3132A194
N/A
E0218 and later
3132A197
N/A
E0218 and later
MBM
Basic license for MBM
3130A69P
LIS-IMC9-MBM
H3C iMC9.0, Mobile Branch Management License
E0301 and later
MBM license, 1 device
3132A166
LIS-IMC9-MBM-VAR
H3C iMC9.0, Mobile Branch Management License, 1 Device
E0301 and later
VPNM
Basic license for VPNM
3130A69N
LIS-IMC9-VPNM
H3C iMC9.0, Multi-VPN Management License
VPNM license, 1 device
E0301 and later
3132A167
LIS-IMC9-VPNM-VAR
H3C iMC9.0, Multi-VPN Management License, 1 Device
E0301 and later
VBM
Basic license for VBM
3130A66S
LIS-IMC9-VBRASM
H3C iMC9.0, vBRAS Management License
N/A
E0101 and later
Super Controller
IMPORTANT
IMPORTANT:
·     Super controller supports only remote licensing.
·     Super controller supports preinstalled licenses, trial licenses, and formal licenses.
Table 27 Super controller license types
License type
Validity period
Remarks
Formal license
Permanent
Supported
30, 60, or 90 days
Not supported
·     Super controller: 180 days
·     Unified Platform: 90 days
Not supported
·     Super Controller preinstalled license: Unlimited.
IMPORTANT
IMPORTANT:
If a network connection error occurs between a super controller and the License Server, the controller enters the fail-safe mode right after 24 hours. In fail-safe mode, the obtained license validity period is extended for 30 days. If the connection recovers within 30 days, the controller exits fail-safe mode and goes back to the normal state. If the connection fails to recover within 30 days, the controller exits fail-safe mode and becomes unavailable.
Table 28 Super controller license matrix
License
BOM
Product code
Software versions
Remarks
H3C AD-DC Super-Level Management and Control Software License, 1 Server Node
3132A060
LIS-SUC-BASE
E31xx
E63xx
E64xx
E65xx
Required license used for super controller nodes. Each node requires a license. For example, a three-node cluster requires three licenses.
H3C AD-DC Super-Level Management and Control License, 1 Lower-Level Control Cluster
3132A061
LIS-SUC-SITE
E31xx
E63xx
E64xx
E65xx
Optional license used in quantity licensing for a super controller managed DC controller or third-party DC controller cluster.
3132A0KN
LIS-ADNET-FCAPS-1
E0706 and later (Unified Platform)
You can manage the license on the license information page of Unified Platform.
H3C AD-DC Super-Level Management and Control License, 1 Public Cloud VM
3132A0XA
LIS-AD-DC-SUC-VM-VAR
E64xx
E65xx
Optional license for licensing the number of VMs in the specified region to which the public cloud VPC managed by Super Controller belongs.
H3C AD-DC Management License for Network Digital Map, 1 Device
3132A1EH
LIS-AD-DC-DIGMAP-VAR
E71xx
Optional license for licensing managed devices in network digital map.
You can add switches, routers, firewalls, and load balancers. Each added device requires a license.
Super Analyzer-DC
IMPORTANT
IMPORTANT:
·     H3C Super Analyzer-DC supports only remote licensing.
·     H3C Super Analyzer-DC supports preinstalled licenses, trial licenses, and formal licenses.
Table 29 SeerAnalyzer license types
License type
Validity period
Remarks
Formal license
Permanent
Supported
Be careful that a formal license might have a validity period. To ensure the continuity of services, you must purchase and install a new formal license before the license expires.
30, 60, and 90 days
Not supported
90 days
Not supported
·     Super Analyzer-DC preinstalled license: Supports 100 platform nodes and the incorporated device number is unlimited.
·     Network management preinstalled license: Manages 50 devices.
IMPORTANT
IMPORTANT:
If a network connection error occurs between a super analyzer-DC and the License Server, the super analyzer-DC enters the fail-safe mode right after 24 hours. In fail-safe mode, the obtained license validity period is extended for 30 days. If the connection recovers within 30 days, the super analyzer-DC exits fail-safe mode and goes back to the normal state. If the connection fails to recover within 30 days, the super analyzer-DC exits fail-safe mode and becomes unavailable.
Table 30 Super Analyzer-DC license matrix
License
BOM
Product code
Software versions
Remarks
H3C AD-DC Super-Level Intelligent Analytics Software License
3130A5LK
LIS-SeerAnalyzer-DC-SUA
E63xx and later
H3C AD-DC super-level intelligent analytics software license
3130A3YS
E63xx and later
Required in any scenario. One platform node requires one license. For example, purchase one license for a standalone node and three licenses for a three-node cluster.
NFA
IMPORTANT
IMPORTANT:
·     NFA 6.0, network traffic collection and analysis system, only supports remote licensing.
·     This system supports preinstalled licenses, trial licenses, and formal licenses. For more information, see the following table.
Table 31 License types
License type
Validity period
Remarks
Formal license
Permanent
Supported
A formal license can be used permanently once purchased.
Trial license
30, 60, or 90 days
Not supported
90 or 180 days
Not supported
IMPORTANT
IMPORTANT:
If a network connection error occurs between NFA and the License Server, the controller enters the fail-safe mode right after 24 hours. In fail-safe mode, the obtained license validity period is extended for 30 days. If the connection recovers within 30 days, NFA exits fail-safe mode and goes back to the normal state. If the connection fails to recover within 30 days, the controller exits fail-safe mode and becomes unavailable.
Table 32 NFA 6.0 license matrix
License
BOM
Product code
Software versions
Remarks
H3C Intelligent Analytics Software License for Full Flow Collection, 500M
3130A5LF
LIS-SeerAnalyzer-Collector-HG
E64xx and later
Optional license, which supports collecting traffic at 500 Mbps.
H3C Intelligent Analytics Software License for Full Flow Collection, 2G
3130A5LL
LIS-SeerAnalyzer-Collector-2G
E64xx and later
Optional license, which supports collecting traffic at 2 Gbps.
H3C Intelligent Analytics Software License for Full Flow Collection, 10G
3130A5LG
LIS-SeerAnalyzer-Collector-10G
E64xx and later
Optional license, which supports collecting traffic at 10 Gbps.
H3C Intelligent Analytics Software License for Full Flow Collection, 20G
3130A5LN
LIS-SeerAnalyzer-Collector-20G
E64xx and later
Optional license, which supports collecting traffic at 20 Gbps.
H3C Intelligent Analytics Software License for Full Flow Collection, 40G
3130A5LM
LIS-SeerAnalyzer-Collector-40G
E64xx and later
Optional license, which supports collecting traffic at 40 Gbps.
H3C Intelligent Analytics Software License for Full Flow Collection, Signature Update Service Basic Edition
3130A2MX
LIS-SeerAnalyzer-NFA-CHAR-M
E6405P03 and later
Optional license.
H3C Intelligent Analytics Software License for Full Flow Collection, Signature Update Service Advanced Edition
3130A2MY
LIS-SeerAnalyzer-NFA-CHAR-X
E6405P03 and later
Optional license.
License configuration examples in common scenarios
This chapter introduces the license configuration examples in common scenarios of the ADNET solution.
License and configuration examples in the AD-DC scenario
The content in this chapter applies to AD-DC 6.3 and later.
License configuration in the network overlay scenario
Configuration requirements: A data center has 24 switches, including four modular devices and 20 fixed-port devices. No security services or third-party interoperation services are required. The license configuration is as shown in the following table.
Table 33 License configuration in the network overlay scenario
BOM
Product code
Product description
Quantity
SeerEngine-DC configuration
3130A4HG
LIS-SeerEngine-DC-BAS1
H3C AD-DC Management and Control Software License, 1 Server Node
3
3132A0V8
LIS-AD-DC-PSWF-MC-VAR
H3C AD-DC Management and Control License for Modular Switches, 1 Device
4
3132A0V6
LIS-AD-DC-PSWB-MC-VAR
H3C AD-DC Management and Control License for Fixed-Port Switches, 1 Device
20
License configuration in the network overlay + network relocation + Runbook scenario
This scenario applies to only AD-DC 6.5 and later.
Configuration requirements: A data center has 24 switches, including four modular devices and 20 fixed-port devices. Two third-party devices and one traditional device requires 10 Runbook workflows. No security services or third-party interoperation services are required. The network relocation feature is used. The license configuration is as shown in the following table.
Table 34 License configuration in the network overlay + network relocation + Runbook scenario
BOM
Product code
Quantity
3130A4HG
3
3132A0V8
4
3132A0V6
23
(20 fixed-port devices, two third-party devices, and one traditional device)
3132A18M
LIS-AD-DC-Runbook-10-VAR
H3C AD-DC Management License for Programmable Platform Function, 10 Service Packages
1
License configuration in the network overlay + security (NFV) scenario
Configuration requirements: A data center has 24 switches, including four modular devices and 20 fixed-port devices. Configure a total of 16 vFWs for NFV and use the security incorporation and service chain features. Only controller configuration is required, and third-party interoperation is not required. The license configuration is as shown in the following table.
Table 35 License configuration in the network overlay + security (NFV) scenario
BOM
Product code
Quantity
3130A4HG
3
3132A0V8
4
3132A0V6
20
3132A09T
LIS-SeerEngine-DC-SC-VAR
H3C AD-DC Management License for Virtual Services, 1 Node
16
3130A1SM
LIS-VNFM-STD
H3C AD-DC VNF Manager Software License, 1 Cluster
1
License configuration in the network overlay + security (hardware) scenario
Configuration requirements: A data center has 24 switches, including four modular devices and 20 fixed-port devices. Incorporate a total of 16 vFWs, including two M9000 devices and two F5K devices. Use the security incorporation and service chain features. Only controller configuration is required, and third-party interoperation is not required. The license configuration is as shown in the following table.
Table 36 License configuration in the network overlay + security (hardware) scenario
BOM
Product code
Quantity
3130A4HG
3
3132A0V8
4
3132A0V6
20
3132A09T
16
License configuration in the network overlay + security (hardware) + value-added service (network-wide one-key restoration) scenario
Configuration requirements: A data center has 24 switches, including four modular devices and 20 fixed-port devices. Incorporate a total of 16 vFWs, including two M9000 devices and two F5K devices. Use the security incorporation, service chain, and network-wide one-key restoration features. Third-party interoperation is not required. The license configuration is as shown in the following table.
Table 37 License configuration in the network overlay + security (hardware) + value-added service (network-wide one-key restoration) scenario
BOM
Product code
Quantity
3130A4HG
3
3132A0V8
4
3132A0V6
20
3132A0LE
LIS-SeerEngine-DC-VA-SWF-VAR
H3C AD-DC Management License for Value-Added Services, 1 Modular Switch
4
3132A0LD
LIS-SeerEngine-DC-VA-SWB-VAR
H3C AD-DC Management License for Value-Added Services, 1 Port-Fixed Switch
20
3132A09T
16
License configuration in the network overlay + security (hardware) + value-added service (simulation + network-wide one-key restoration) scenario
Configuration requirements: A data center has 24 switches, including four modular devices and 20 fixed-port devices. Incorporate a total of 16 vFWs, including two M9000 devices and two F5K devices. Use the security incorporation, service chain, network simulation, and network-wide one-key restoration features. SeerAnalyzer must be deployed to meet flow analysis requirements. The license configuration is as shown in the following table.
Table 38 License configuration in the network overlay + security (hardware) + value-added service (simulation + network-wide one-key restoration) scenario
BOM
Product code
Quantity
3130A4HG
3
3132A0V8
4
3132A0V6
20
3132A0LE
4
3132A0LD
20
3132A18N
LIS-AD-DC-VA-SEC-VAR
H3C AD-DC Management License for Value-Added Service Security Simulation, 1 Device
4
3132A09T
16
SeerAnalyzer-DC configuration
3130A3YN
LIS-SeerAnalyzer-DC-Basic
H3C AD-DC Intelligent Analytics Software License, Basic Edition
1
3130A3YS
3
3132A0F1
LIS-SeerAnalyzer-DC-PSWFA-VAR
24
3132A0F2
LIS-SeerAnalyzer-DC-PSW-VAR
H3C AD-DC Intelligent Analytics License for Fixed-Port Switches, 1 Device
24
3130A3YP
1
License configuration in the network overlay + intelligence analytics + value-added service (simulation + network-wide one-key restoration) scenario
Configuration requirements: A data center has 24 switches, including four modular devices and 20 fixed-port devices. Incorporate a total of 16 vFWs, including two M9000 devices and two F5K devices. Use the security incorporation, service chain, network simulation, and network-wide snapshot and configuration rollback features. SeerAnalyzer must be deployed to meet flow analysis requirements. The license configuration is as shown in the following table.
Table 39 License configuration in the network overlay + intelligence analytics + value-added service (simulation + network-wide one-key restoration) scenario
BOM
Product code
Quantity
3130A4HG
3
3132A0V8
4
3132A0V6
20
3132A0LE
4
3132A0LD
20
3132A18N
4
3132A09T
16
3130A3YN
1
3130A3YS
LIS-SeerAnalyzer-DC-Analyzer
H3C AD-DC Intelligent Analytics Software License, 1 Server Node
3
3132A0F1
H3C AD-DC Intelligent Analytics License for Flow Analytics, 1 Switch
24
3132A0F2
20
3132A0QR
LIS-SeerAnalyzer-DC-PSW-M-VAR
H3C AD-DC Intelligent Analytics License for Modular Switches, 1 Device
4
3130A3YP
LIS-SeerAnalyzer-Collector-I
H3C AD-DC Intelligent Analytics License for Type I Collector
1
License configuration in the SeerFabric scenario
Configuration requirements: A data center has 24 switches, including four modular devices and 20 fixed-port devices. You need to deploy SeerFabric and use AI ECN. Controller and analyzer configuration and flow analytics are required. The license configuration is as shown in the following table.
Table 40 License configuration in the SeerFabric scenario
BOM
Product code
Quantity
3130A4HG
3
3132A0V8
4
3132A0V6
20
3132A0LC
LIS-SeerEngine-DC-SF-DEV-VAR
H3C AD-DC Management License for SeerFabric, 1 Device
24
3130A3YN
1
3130A3YS
3
3132A0F1
24
3132A0F2
20
3132A0QR
4
3132A0LF
LIS-SeerAnalyzer-SeerFabric-VAR
H3C AD-DC Intelligent Analytics License for AI ECN, 1 Physical Switch
24
3130A3YP
1
License configuration in the hybrid overlay scenario
Configuration requirements: A data center has 24 switches, including four modular devices and 20 fixed-port devices. 10 fixed-port switches are used for host overlay. 20 two-line servers and 40 four-line servers use host overlay. Incorporate 16 vFWs, including two M9000 devices. Only controller configuration is required. The license configuration is as shown in the following table.
Table 41 License configuration in the hybrid overlay scenario
BOM
Product code
Quantity
3130A4HG
3
3132A0V8
4
3132A0V6
20
3132A09T
16
3132A09U
LIS-SeerEngine-DC-VSW-VAR
H3C AD-DC Management and Control License for Virtual Switches, 1 vSwitch
60
3132A00V
LIS-VSW-1020VX-1
H3C S1020V, 1 CPU License
200
License configuration in the super control scenario
Configuration requirements: A project has two sets of controllers and one set of super controllers, and requires managing Alibaba Cloud or AWS cloud and 100 VMs on cloud. The license configuration is as shown in the following table.
BOM
Product code
Quantity
Super controller configuration
3132A060
LIS-SUC-BASE
3
3132A061
LIS-SUC-SITE
2
3132A0XA
100
License configuration in the super analytics scenario
Configuration requirements: A project has two sets of analyzers and one set of super analyzers. The license configuration is as shown in the following table.
BOM
Product code
Quantity
SeerAnalyzer-DC and Super Analyzer-DC configuration
3130A5LK
1
3130A3YS
2
Copyright © 2025 New H3C Technologies Co., Ltd. All rights reserved.
