H3C Wi-Fi7 Indoor Access Points Installation Guide-5W108
HomeSupportInstall & UpgradeInstallation GuidesH3C Wi-Fi7 Indoor Access Points Installation Guide-5W108
03-Appendix A AP views and technical specifications
3 Appendix A  AP views and technical specifications
WA7220-HI
AP views
Figure3-1 WA7220-HI
Ports
The AP provides the following ports:
·     One 2.5GE2/PSE port.
·     One 2.5GE1/PoE+ port.
·     One CONSOLE port.
·     One power port.
·     One USB port.
The AP also has a reset button and a security slot. The security slot is 7 × 3 mm (0.28 × 0.12 in) in size.
Figure3-2 Ports on the WA7220-HI AP (1)
(1) Power port
(2) 2.5GE1/PoE+ port
(3) 2.5GE2/PSE port
(4) Console port
(5) USB port
(6) Security slot
Figure3-3 Ports on theWA7220-HI AP (2)
(1) Reset button
Technical specifications
Table3-1 Technical specifications
Item
Dimensions (H × W × D) (without the mounting bracket)
40 × 220 × 220 mm (1.57 × 8.66 × 8.66 in)
Weight
0.67 kg (1.48 lb)
Power consumption
Support for local DC power supply and PoE power supply:
·     Local power supply:
¡     ≤ 33.9 W (including PoE_OUT/USB)
¡     ≤ 16.4 W (excluding PoE_OUT/USB)
·     PoE power reception compliant with 802.3at:
¡     ≤ 26.1 W (PoE_OUT port supplying power, radios in 1×1 MIMO mode, and excluding USB)
¡     ≤ 18.9 W (PoE_OUT port not supplying power and including USB)
·     PoE power reception compliant with 802.3af: 13.6 W (PoE_OUT port not supplying power, radios in 1×1 MIMO mode, and including USB)
Antenna
Built-in antenna
Standard compliance
·     IEEE802.11a/b/g/n/ac/ax/be
·     802.3af/at
Powering option
IEEE802.3af/at powering standard-compliant:
·     Power adapter
·     PoE802.3at
·     PoE802.3af
Operating temperature
-10°C to 50°C (14°F to 122°F)
Storage temperature
–40°C to +70°C (–40°F to +158°F)
Operating humidity
5%RH to 95%RH, non-condensing
Storage humidity
Operating altitude
–60 m to +5000 m (–196.85 ft to +16404.20 ft)
Console port
Control port, used for debugging by the maintenance personnel
2.5GE/PoE+ port
100M/1000M/2.5GEthernet copper port that can act as the device uplink port to connect to the Internet or MAN and as the standard PoE port at the same time.
When the AP operates in fit AP mode, the port is represented by interface number SGE1/0/1 in the MAP file and smartrate-ethernet 1 for configuration on the AC
2.5GE2/PSE port
100/1000/2500M Ethernet copper port,that can act as the device downlink port to supply power for a standard PD.
When the AP operates in fit AP mode, the port is represented by interface number Smartrate-Ethernet1/0/2 in the MAP file and gigabitethernet 2 for configuration on the AC
USB port
USB-compliant USB2.0 port.
By default, the USB port is disabled. To enable the USB port, execute the usb enable command in AP view.
Power port (54VDC)
Used for receiving power from a local power source.
Reset button
For more information, see "Appendix B  LEDs and buttons."
WA7320
AP views
Figure3-4 WA7320
Ports
·     One 5GE/P+SFP port
·     One Power port
·     One 2.5GE/PoE+ port.
·     One GE port.
·     One CONSOLE port.
·     One USB port.
Figure3-5 Ports on the WA7320 AP (1)
(1) 5GE/P+SFPport
(2) Power port
(3) 2.5GE/PoE+ port
(4) GE port
(5) Console port
Figure3-6 Ports on the WA7320 AP (2)
(1) Security slot
(2) USB port
(3) Reset button
Table3-2 Technical specifications
Item
35 × 205 × 205 mm (1.38 × 8.07 × 8.07 in)
Weight
0.8 kg (1.76 lb)
Power consumption
18.5 W
Antenna
Built-in antenna
Standard compliance
·     IEEE802.3at
Powering option
IEEE802.3at powering standard-compliant:
·     Power adapter
·     PoE
·     PoE optical transceiver module
Storage temperature
Operating humidity
Storage humidity
Operating altitude
Console port
5GE2/P+SFP port
1000M/2.5G/5G/10G photoelectric hybrid port
When the AP operates in fit AP mode, the port is represented by interface number SGE1/0/2 in the MAP file and smartrate-ethernet 2 for configuration on the AC
2.5GE/PoE+ port
100M/1000M/2.5G/5G/10G Ethernet copper port that can act as the device uplink port to connect to the Internet or MAN and as the standard PoE port at the same time.
When the AP operates in fit AP mode, the port is represented by interface number SGE1/0/1 in the MAP file and smartrate-ethernet 1 for configuration on the AC.
GE port
100M/1000M Ethernet copper port, used for connecting a downlink device. The AP can supply power through this port to a device with a maximum power consumption of 15 W.
When the AP operates in fit AP mode, the port is represented by interface number GE1/0/1 in the MAP file and gigabitethernet 1 for configuration on the AC.
USB port
USB2.0-compliant USB port.
Power port (54VDC)
Reset button
WA7320i
AP views
Figure3-7 WA7320i
Ports
·     One GE/PSE port.
·     One 10GE/PoE+ port.
·     One 10GE/P+SFP port.
·     One CONSOLE port.
·     One power port.
·     One USB port.
Figure3-8 Ports on the WA7320i AP (1)
(1) Console port
(2) GE/PSE port
(3) 10GE1/PoE+ port
(4) 10GE2/P+SFP port
(5) Power port
Figure3-9 Ports on the WA7320i AP (2)
(1) USB port
(2) Reset button
(3) Security slot
Table3-3 Technical specifications
Item
Weight
0.8 kg (1.76 lb)
Power consumption
39 W
Antenna
Built-in antenna
Standard compliance
·     IEEE802.3at/af
Powering option
IEEE802.3at/af powering standard-compliant:
·     Power adapter
·     PoE
0°C to 50°C (32°F to 122°F)
Storage temperature
Operating humidity
Storage humidity
Operating altitude
Console port
10GE2/P+SFP port
When the AP operates in fit AP mode, the port is represented by interface number 10GE1/0/2 in the MAP file and Ten-GigabitEthernet 2 for configuration on the AC.
10GE1/PoE+ port
When the AP operates in fit AP mode, the port is represented by interface number 10GE1/0/1 in the MAP file and Ten-GigabitEthernet 1 for configuration on the AC.
GE/PSE port
USB port
Power port (54VDC)
Reset button
WA7330i
AP views
Figure3-10 WA7330i
Ports
·     One 2.5GE/PSE port.
·     One 10GE/PoE++ port.
·     One 10GE/P++SFP port.
·     One console port.
·     One power port.
·     One USB port.
Figure3-11 Ports on the WA7330i AP (1)
(1) Power port
(2) 10GE/P++SFP port
(3) 10GE/PoE++ port
(4) 2.5GE/PSE port
(5) Console port
Figure3-12 Ports on the WA7330i AP (2)
(1) Reset button
(2) USB port
(3) Security slot
Table3-4 Technical specifications
Item
45 × 210× 210 mm (1.77 × 8.27 × 8.27in)
Weight
1 kg (2.2 lb)
Power consumption
42.12 W
Antenna
Built-in antenna
Standard compliance
·     IEEE802.3bt/at
Powering option
IEEE802.3bt/at powering standard-compliant:
·     Power adapter
·     PoE
Storage temperature
Operating humidity
Storage humidity
Operating altitude
Console port
10GE/P++SFP port
100M/1000M/2.5G/5G/10G photoelectric hybrid port,which can also operate as a 10G copper port.
When the AP operates in fit AP mode, the port is represented by interface number XGE1/0/1 in the MAP file and ten-gigabitEthernet 1 for configuration on the AC.
The 10GE/P++SFP fiber port and the 10GE/PoE++ copper port cannot be used simultaneously.
10GE/PoE++ port
When the AP operates in fit AP mode, the port is represented by interface number 10GE1/0/1 in the MAP file and ten-gigabitEthernet 1 for configuration on the AC.
2.5GE/PSE port
100M/1000M/2.5G Ethernet copper port, used for connecting a downlink device. The AP can supply power through this port to a device with a maximum power consumption of 15 W.
When the AP operates in fit AP mode, the port is represented by interface number Smartrate-Ethernet1/0/1 in the MAP file and gigabitethernet 1 for configuration on the AC.
USB port
Power port (54VDC)
Reset button
WA7338-HI
AP views
Figure3-13 WA7338-HI
Ports
·     One GE/PSE port.
·     One CONSOLE port.
·     One power port.
·     One USB port.
Figure3-14 Ports on the WA7338-HI AP (1)
(1) Reset button
(2) Console port
(3) GE/PSE port
(4) 10GE1/PoE++ port
(5) 10GE2/P++SFP port
(6) Power port
(7) Security slot
Figure3-15 Ports on the WA7338-HI AP (2)
(1) USB port
Table3-5 Technical specifications
Item
45 × 225 × 225 mm (1.77 × 8.86 × 8.86 in)
Weight
1.43 kg (3.15 lb)
Power consumption
41.8 W
Antenna
Built-in antenna
Standard compliance
·     IEEE802.3bt/at
Powering option
·     Power adapter
·     PoE
Storage temperature
Operating humidity
Storage humidity
Operating altitude
Console port
10GE2/P++SFP port
10GE1/PoE++ port
GE/PSE port
USB port
Power port (54VDC)
Reset button
WA7539
AP views
Figure3-16 WA7539
Ports
·     One GE/PSE port.
·     One CONSOLE port.
·     One power port.
·     One USB port.
Figure3-17 Ports on the WA7539 AP
(1) Power port
(2) 10GE1/PoE++ port
(3) GE/PSE port
(4) USB port
(6) Console port
(7) Reset button
(8) Security slot
Table3-6 Technical specifications
Item
40 × 225 × 225 mm (1.57 × 8.86 × 8.86 in)
Weight
1.5 kg (3.31 lb)
Power consumption
54 W
Antenna
Built-in antenna
Standard compliance
·     IEEE802.3at/bt
Powering option
IEEE802.3at/bt powering standard-compliant:
·     Power adapter
·     PoE
Storage temperature
Operating humidity
Storage humidity
Operating altitude
Console port
10GE2/P++SFP port
10GE1/PoE++ port
GE/PSE port
USB port
USB-compliant USB port.
Power port (54VDC)
Reset button
WA7638
AP views
Figure3-18 WA7638
Ports
·     One GE/PSE port.
·     One GE/PoE++ port.
·     One CONSOLE port.
·     One power port.
·     One USB port.
Figure3-19 Ports on the WA7638 AP
(1) Power port
(3) GE1/PoE++ port
(4) GE2/PSE port
(6) USB port
(7) Console port
(8) Reset button
(9) Security slot
Table3-7 Technical specifications
Item
48 × 265 × 265 mm (1.89 × 10.43 × 10.43 in)
Weight
1.9 kg (4.19 lb)
Power consumption in standby state
57W
Antenna
Built-in antenna
Standard compliance
·     IEEE802.3bt/at
Powering option
·     Power adapter
·     PoE
Storage temperature
Operating humidity
Storage humidity
Operating altitude
Console port
10GE2/P++SFP
GE1/PoE++
100M/1000M Ethernet copper port, which can act as the uplink interface to connect the device to Internet or the MAN or act as the standard PoE interface.
When the AP operates in fit AP mode, the port is represented by interface number GE1/0/1 in the MAP file and GigabitEthernet 1 for configuration on the AC.
10GE1/PoE++
GE2/PSE
When the AP operates in fit AP mode, the port is represented by interface number GE1/0/2 in the MAP file and GigabitEthernet 2 for configuration on the AC.
USB port
Power port (54VDC)
Reset button
