00-About the Configuration Guides
HomeSupportConfigure & DeployConfiguration GuidesH3C S5580X-EI[HI] & S5580S-EI Switch Series Configuration Guides-R1213P50-6W10000-About the Configuration Guides
Table of Contents
Related Documents
book
book 40.55 MB
About the H3C S5580X-HI[EI] & S5580S-EI configuration guides
The H3C S5580X-HI[EI] & S5580S-EI configuration guides describe the software features for the H3C S5580X-HI[EI] & S5580S-EI Switch Series, and guide you through the software configuration procedures. These configuration guides also provide configuration examples to help you apply the software features to different network scenarios.
Configuration guide
Content
Fundamentals Configuration Guide
Covers information about using the command line interface, logging in to and setting up the switch, and using the basic management features.
This guide includes:
·     CLI (command line interface overview and how to use the CLI).
·     RBAC.
·     Logging in to the switch (login methods such as telnet, and user interface configuration and access control).
·     FTP and TFTP.
·     File system management.
·     Configuration file management.
·     Software upgrade.
·     Automatic configuration.
System Management Configuration Guide
Covers the configuration for device management and monitoring features, such as information center.
·     Basic device management.
·     Device hardening.
·     Hardware resource management.
·     PoE.
·     Process monitoring and maintenance.
·     Information center.
·     OAP module.
Interface Configuration Guide
Covers the configuration of various interfaces.
·     Bulk interface configuration.
·     Ethernet interface.
·     Loopback, null, and inloopback interfaces.
·     Tunnel interface.
Layer 2—LAN Switching Configuration Guide
Covers Layer 2 technologies and features used on a LAN switched network. You can use these features to implement traffic control, remove Layer 2 loops, isolate users within a VLAN, or re-mark VLAN tags.
·     MAC address table.
·     Ethernet link aggregation.
·     M-LAG.
·     Port isolation.
·     VLAN.
·     MVRP.
·     QinQ.
·     VLAN mapping.
·     Loopback detection.
·     Spanning tree.
·     LLDP.
·     PFC.
·     L2TP.
·     Service loopback group.
Layer 3—IP Services Configuration Guide
Covers IP addressing, network performance optimization, ARP, and interoperation between IPv4 and IPv6.
·     ARP.
·     IP addressing.
·     DHCP.
·     DNS.
·     HTTP.
·     IPv6 transition technologies.
·     IP forwarding basics.
·     Fast forwarding.
·     Adjacency table.
·     IRDP.
·     IP performance optimization.
·     UDP helper.
·     IPv6 basics.
·     IPv6 neighbor discovery.
·     DHCPv6.
·     IPv6 fast forwarding.
Layer 3—IP Routing Configuration Guide
Covers the routing technologies for IPv4 and IPv6 networks of different sizes, route filtering, route control, and policy based routing.
·     Basic IP routing.
·     Static routing.
·     RIP.
·     OSPF.
·     IS-IS.
·     Basic BGP.
·     Advanced BGP.
·     Policy-based routing.
·     IPv6 static routing.
·     RIPng.
·     OSPFv3.
·     IPv6 policy-based routing.
·     Routing policy.
·     DCN.
Multicast Configuration Guide
Covers Layer 2 IPv4 multicast protocols (including IGMP snooping, and multicast VLAN), Layer 3 IPv4 multicast protocols (including IGMP and PIM), Layer 2 IPv6 multicast protocols (including MLD snooping and IPv6 multicast VLAN), and Layer 3 IPv6 multicast protocols (including MLD, IPv6 PIM, and MSDP).
·     Multicast overview.
·     IGMP snooping.
·     PIM snooping.
·     Multicast VLAN.
·     Multicast routing and forwarding.
·     IGMP.
·     PIM.
·     MSDP.
·     MLD snooping.
·     IPv6 multicast VLAN.
·     IPv6 multicast routing and forwarding.
·     MLD.
·     IPv6 PIM.
MCE Configuration Guide
Covers MCE and IPv6 fundamentals and configuration.
ACL and QoS Configuration Guide
Covers information about classifying traffic with ACLs, and allocating network resources and managing congestions with QoS technologies to improve network performance and network use efficiency.
·     ACL.
·     QoS.
·     Data buffer.
·     Time range.
IP Tunneling Configuration Guide
Covers fundamentals and configuration for IP tunneling features.
·     IPv4 over IPv4 tunneling.
·     IPv6 over IPv6 tunneling.
·     GRE.
User Access and Authentication Configuration Guide
Covers fundamentals and configuration for user access and authentication features, including identity authentication (AAA) and password control.
·     AAA.
·     802.1X.
·     MAC authentication.
·     Portal authentication.
·     Web authentication.
·     Port security.
·     User profile.
·     Password control.
Security Configuration Guide
Covers security features. The major security features available on the switch include data security (public key management and SSH) and attack protection (ARP attack protection, uRPF, and attack detection and prevention).
·     Key chain.
·     Public key management.
·     PKI.
·     Crypto engine.
·     SSH.
·     SSL.
·     Packet filter.
·     DHCP snooping.
·     DHCPv6 snooping.
·     ARP attack protection.
·     ND attack defense.
·     Attack detection and prevention.
·     IP-based attack prevention.
·     IP source guard.
·     uRPF.
·     MACsec.
·     TC.
High Availability Configuration Guide
Covers high availability technologies and features available on the switch for failure detection and failover. Failure detection technologies focus on fault detection and isolation. Failover technologies focus on network recovery.
·     Ethernet OAM.
·     CFD.
·     DLDP.
·     RRPP.
·     ERPS.
·     Smart Link.
·     Monitor Link.
·     Error code detection.
·     VRRP.
·     BFD.
·     Track.
·     Interface collaboration.
Network Management and Monitoring Configuration Guide
Covers features that help you manage and monitor your network, for example, manage system events, collect traffic statistics, sample packets, assess network performance, and test network connectivity by using ping, tracert, and system debugging.
·     Ping and tracert.
·     System debugging.
·     NQA.
·     NTP.
·     PTP.
·     SNMP.
·     RMON.
·     Event MIB.
·     Mirroring.
·     sFlow.
·     VCF fabric.
·     Cloud connection.
Telemetry Configuration Guide
Covers the gRPC application background, fundamentals, and configuration.
Network Programmability Configuration Guide
Covers the application background, fundamentals, and configuration for RESTful, NETCONF, Tcl, and Python.
OpenFlow Configuration Guide
Covers the OpenFlow application background, fundamentals, and configuration.
VXLAN Configuration Guide
Covers the VXLAN application background, fundamentals, and configuration.
·     Basic VXLAN.
·     VXLAN IP gateway.
·     OVSDB VTEP.
EVPN Configuration Guide
Covers the EVPN application background, fundamentals, and configuration.
·     EVPN overview.
·     EVPN VXLAN.
Intelligent Operations Configuration Guide
Covers the EAA fundamentals and configuration.
Acronyms
Lists the significant acronyms in the configuration guides.
