Title | Size | Downloads |
99-Fit AP Group Management.rar | 1.86 MB |
7 Fit AP Group Management
To view the video, click download link.
Software Version Used
This video was recorded based on the following versions:
iMC: iMC PLAT 3.20-R2602P08, iMC WSM 3.50-F5201P01
Video Description
Fit AP group management allows you to create groups, classify the Fit APs associated with an AC into the created groups, and assign operators different Fit AP group management privileges, thus greatly facilitating Fit AP management.
This case shows the main functions of Fit AP group management by illustrating how to create a Fit AP group, add an operator to manage the group, and add Fit APs to the group.
Experiment Environment
More than one operator and multiple Fit APs are available in iMC.
Recommended Configuration Flow
Step1 Add two iMC operators. Set their privileges to maintenancer and viewer respectively.
Step2 Create two Fit AP groups and specify an operator for each of them.
Step3 Verify whether privileges are successfully assigned to the operators.
