H3C SeerEngine-DC Controller Converged OpenStack Plug-Ins Installation Guide for Ubuntu-E61xx-5W113
HomeSupportAD-NET(SDN)H3C SeerEngine-DCConfigure & DeployInteroperability GuidesH3C SeerEngine-DC Controller Converged OpenStack Plug-Ins Installation Guide for Ubuntu-E61xx-5W113
01-Text
01-Text 625.11 KB
Overview·· 1
SeerEngine-DC Neutron plug-ins· 1
Nova patch· 1
Openvswitch-agent patch· 1
DHCP failover components· 1
DHCP component 1
Metadata component 2
SeerEngine-DC Neutron security plug-ins· 2
Restrictions and guidelines· 3
Installing OpenStack cloud platforms· 5
Preconfiguring SeerEngine-DC·· 6
Installing SeerEngine-DC Neutron plug-ins and patches on OpenStack· 7
Installing the Python tools· 7
Configuring interoperability in the KVM host-based overlay scenario· 8
Installing and configuring plug-ins on the controller node· 8
Installing configuring plug-ins on a compute node· 19
Verifying interoperability· 22
Configuring interoperability in the KVM network-based overlay scenario· 22
Installing and configuring plug-ins on the controller node· 22
Installing and configuring plug-ins on a compute node· 23
Installing and configuring plug-ins on a network node· 25
Verifying interoperability· 25
Configuring interoperability in the network-based overlay with SR-IOV enabled scenario· 26
Installing and configuring plug-ins on the controller node· 26
Installing and configuring plug-ins on a compute node· 26
Enabling SR-IOV for a vNIC· 26
Editing the configuration file· 26
Verifying interoperability· 26
Configuring interoperability with F5 or third-party load balancers· 26
Installing and configuring plug-ins on the controller node· 27
Installing and configuring plug-ins on a compute node· 27
Setting up the F5 environment 27
Verifying interoperability· 28
Configuring interoperability with third-party firewalls· 29
Installing and configuring plug-ins on the controller node· 29
Installing and configuring plug-ins on a compute node· 29
Setting up the environment 29
Verifying interoperability· 30
Configuring interoperability with Ironic· 30
Installing and configuring plug-ins on the controller node· 30
Deploying Ironic· 30
Metadata solution· 30
Installing and configuring OpenStack plug-ins on the controller node· 30
Installing and configuring OpenStack plug-ins on the compute node· 30
Setting up the environment for the traditional VLAN and VXLAN-based Metadata solution· 31
Setting up the environment for the traditional VLAN and VXLAN hierarchical port binding-based Metadata solution  32
Installing the SeerEngine-DC Neutron security plug-ins on OpenStack· 34
Installing the security plug-ins on the controller node· 34
Obtaining the installation package· 34
Installing the security plug-ins on the OpenStack controller node· 34
Editing the configuration files on the OpenStack controller node· 35
Verifying the installation· 38
Parameters and fields· 38
(Optional.) Upgrading the SeerEngine-DC Neutron security plug-ins· 43
Comparing and synchronizing firewall resource information between the cloud platform and controller 44
Comparing and synchronizing LB resource information between the cloud platform and controller 46
Upgrading non-converged plug-ins to converged plug-ins· 47
Comparing and synchronizing resource information between the controller and cloud platform·· 50
FAQ·· 52
The Python tools cannot be installed using the yum command when a proxy server is used for Internet access. What should I do?· 52
Live migration of a VM to a specified destination host failed because of a service exception on the destination host. What should I do?· 52
The Inter X700 Ethernet network adapter series fails to receive LLDP messages. What should I do?· 53
The trunk function is unavailable after I upgrade a non-converged OpenStack Mitaka plug-in to a converged one and configure h3c_trunk. What should I do?· 54
If information for connecting the Neutron database is encrypted, the Neutron plug-ins might fail to inherit the portforwardings data table because of failure to access the database. What should I do?· 54
Overview
This document describes how to install OpenStack plug-ins for interoperability with OpenStack cloud platforms. Then SeerEngine-DC can process requests from the OpenStack cloud platforms.
OpenStack plug-ins include SeerEngine-DC Neutron plug-ins, Nova patch, openvswitch-agent patch, and DHCP failover components.
Neutron is a type of OpenStack services used to manage all virtual networking infrastructures (VNIs) in an OpenStack environment. It provides virtual network services to the devices managed by OpenStack computing services.
SeerEngine-DC Neutron plug-ins are developed for the SeerEngine-DC controller based on the OpenStack framework. SeerEngine-DC Neutron plug-ins can obtain network configuration from OpenStack through REST APIs and synchronize the configuration to the SeerEngine-DC controllers. They can obtain settings for the tenants' networks, subnets, routers, or ports.
CAUTION
CAUTION:
To avoid service interruptions, do not modify the settings issued by the cloud platform on the controller, such as the virtual link layer network, vRouter, and vSubnet settings after the plug-ins connect to the OpenStack cloud platform.
Nova patch
Nova is an OpenStack computing controller that provides virtual services for users. The virtual services include creating, starting up, shutting down, and migrating virtual machines and setting configuration information for the virtual machines, such as CPU and memory information.
In specific scenarios (such as a host-based overlay or vCenter network-based overlay scenario), you must install the Nova patch to enable virtual machines created by OpenStack to access networks managed by SeerEngine-DC controllers.
The open source openvswitch-agent process on an OpenStack compute node might fail to deploy VLAN flow tables to open source vSwitches when the following conditions exist:
·     The kernel-based virtual machine (KVM) technology is used on the node.
·     The hierarchical port binding feature is configured on the node.
To resolve this issue, you must install the openvswitch-agent patch.
DHCP component
In the network-based overlay scenario, only a controller is currently allowed to assign addresses to virtual machines or bare metal servers as a DHCP server. When the controller is disconnected from the southbound network, the virtual machines or bare metal servers will not be able to renew and reobtain addresses through DHCP. To resolve the issue, you can install a DHCP component on a network node to provide DHCP failover in the network-based overlay scenario. When the controller loses connection to the southbound network, the virtual machines or bare metal servers can renew and reobtain addresses through the independently deployed DHCP server.
Metadata component
In the DHCP failover scenario, you must install a Metadata component on the network node to provide the Metadata function for the DHCP component.
SeerEngine-DC Neutron security plug-ins are developed for the SeerEngine-DC controller based on the OpenStack framework. SeerEngine-DC Neutron security plug-ins can obtain security configuration from OpenStack through REST APIs and synchronize the configuration to the SeerEngine-DC controllers. They can obtain settings for the tenants' FW, LB, or VPN.
This document describes interoperability between SeerEngine-DC with one OpenStack platform that contains one controller node. In other scenarios, follow these restrictions and guidelines:
·     SeerEngine-DC interoperates with one OpenStack platform that contains multiple controller nodes.
Configure all controller nodes on the OpenStack platform in the same way a single controller is configured, and make sure the configuration on all controller nodes is the same.
·     SeerEngine-DC interoperates with multiple OpenStack platforms. Only OpenStack Queens and Rocky are supported.
¡     Install plug-ins on all controller nodes on each OpenStack platform, and configure interoperability parameters, including the cloud_region_name parameter in ml2_conf.ini of the SeerEngine-DC Neutron.
[SDNCONTROLLER]
cloud_region_name = default
cloud_region_name represents the name of the cloud platform. The default value is default. Make sure the value for this parameter is the same as the cloud platform name added on the Automation > Data Center Networks > Virtual Networking > OpenStack page on the SeerEngine-DC controller. Make sure the cloud platform name and VXLAN VNI for each cloud platform and the host name of each node are unique across the OpenStack platforms.
¡     If each OpenStack platform uses an exclusive keystone service, verify that SeerEngine-DC can interoperate with each OpenStack platform and each platform can deploy services to its tenant.
¡     If multiple OpenStack platforms share the same keystone service, verify that SeerEngine-DC can interoperate with each OpenStack platform and all platforms can deploy services to the same tenant.
·     Check the OpenStack version and OSs. Table 1 shows the software requirements for installing the SeerEngine-DC Neutron plug-ins, Nova patch, or openvswitch-agent patch.
Table 1 Software requirements
Item
Supported versions
OpenStack (deployed on CentOS with YUM)
·     OpenStack Kilo 2015.1 on Ubuntu 14.04
·     OpenStack Liberty on Ubuntu 14.04
·     OpenStack Mitaka on Ubuntu 14.04
·     OpenStack Newton on Ubuntu 14.04
·     OpenStack Ocata on Ubuntu 14.04
·     OpenStack Pike on Ubuntu 16.04
·     OpenStack Queens on Ubuntu 18.04
·     OpenStack Rocky on Ubuntu 18.04
·     OpenStack Stein on Ubuntu 18.04
·     OpenStack Train on Ubuntu 18.04
·     OpenStack Ussuri on Ubuntu 20.04
IMPORTANT
IMPORTANT:
·     OpenStack security plug-ins do not support OpenStack Stein, Train, and Ussuri.
·     To install OpenStack Pike, the dnsmasq version must be 2.76. You can use the dnsmasq –v command to display the dnsmasq version number.
·     Make sure your system has a reliable Internet connection before you install the OpenStack plug-ins.
See the installation guide for the specific OpenStack version on the OpenStack official website to install and deploy OpenStack cloud platforms. Verify that the /etc/hosts file on all nodes has the host name-IP address mappings, and the OpenStack Neutron component has been deployed.
SeerEngine-DC preconfiguration provides only basic configuration for SeerEngine-DC. For detailed configuration for different scenarios, see the configuration guides.
Table 2 SeerEngine-DC preconfiguration
Configuration
Path
Fabrics
Automation > Data Center Networks > Fabrics > Fabrics
VDS
Automation > Data Center Networks > Common Network Settings > Virtual Distributed Switch
Address pools
Automation > Data Center Networks > Resource Pools > IP Address Pools
VNID pools (VLANs, VXLANs, and VLAN-VXLAN mappings)
Automation > Data Center Networks > Resource Pools > VNID Pools > VLANs
Automation > Data Center Networks > Resource PoolsVNID Pools > VXLANs
Automation > Data Center Networks > Resource PoolsVNID Pools > VLAN-VXLAN Mappings
Adding access and border devices to a fabric
L4-L7 physical devices, resource pools, and profiles
Automation > Data Center Networks > Resource Pools > Devices > Physical Devices
Automation > Data Center Networks > Resource Pools > Devices > L4-L7 Physical Resource Pools
Gateway
Automation > Data Center Networks > Common Network Settings > Gateways
Domains and hosts
Automation > Data Center Networks > Fabrics > Domains
Automation > Data Center Networks > Fabrics > Domains > Hosts
Interoperability with OpenStack
Automation > Virtual Networking > OpenStack
·     Make sure the cloud platform name (case sensitive) is the same as the value for the cloud_region_name parameter in the ml2_conf.ini file of the Neutron plug-in.
·     Make the VNI range is the same as the VXLAN VNI range on the cloud platform.
The SeerEngine-DC Neutron plug-ins, Nova patch, openvswitch-agent patch, and DHCP failover components can be installed on different OpenStack versions. The installation package varies by OpenStack version. However, you can use the same procedure to install the Neutron plug-ins, Nova patch, or openvswitch-agent patch on different OpenStack versions. This document uses OpenStack Pike as an example.
Install the SeerEngine-DC Neutron plug-ins on an OpenStack controller node, the Nova patch and openvswitch-agent patch on an OpenStack compute node, and the DHCP failover components on a network node. Before installation, you must install the Python tools on the associated node.
Before installing the plug-ins, first you must download the Python tools online and install them.
To download and install the Python tools:
1.     Update the software source list.
sdn@ubuntu:~$ sudo apt-get update
2.     Download and install the Python tools.
Ubuntu 20.04 operating system:
sdn@ubuntu:~$ sudo apt-get install python3-pip python3-setuptools
Other Ubuntu operating systems:
sdn@ubuntu:~$ sudo apt-get install python-pip python-setuptools
3.     Log in to the controller node to edit the /etc/hosts file:
a.     Add the IP and name mappings for all OpenStack hosts on the Automation > Data Center Networks > Fabrics > Domains > Hosts page on SeerEngine-DC.
b.     Add the IP and name mappings of all leaf, spine, and boarder devices on the Automation > Data Center Networks > Resource Pools > Devices > Physical Devices page on SeerEngine-DC.
sdn@ubuntu:~$ sudo vi /etc/hosts
127.0.0.1 localhost
::1         localhost localhost.localdomain localhost6 localhost6.localdomain6
99.0.83.75 controller
99.0.83.76 compute1
99.0.83.77 compute2
99.0.83.78 nfs-server
99.0.83.79 compute3
99.0.83.74 compute4
4.     Install websocket-client on the controller node. Make sure the version is 0.56.
sdn@ubuntu:~$ sudo pip install websocket-client==0.56
sdn@ubuntu:~$ sudo apt-get install python-websocket-client
Obtaining the SeerEngine-DC Neutron plug-in installation package
The SeerEngine-DC Neutron plug-ins are included in the SeerEngine-DC OpenStack package. Obtain the SeerEngine-DC OpenStack package of the required version and then save the package to the target installation directory on the server or virtual machine.
Alternatively, transfer the installation package to the target installation directory through a file transfer protocol such as FTP, TFTP, or SCP. Use the binary transfer mode to prevent the software package from being corrupted during transit.
Installing the SeerEngine-DC Neutron plug-ins on the controller node
CAUTION
CAUTION:
The QoS feature will not operate correctly if you configure the database connection in configuration file neutron.conf as follows:
[database]
connection = mysql://…
This is an open source bug in OpenStack. To prevent this problem, configure the database connection as follows:
[database]
connection = mysql+pymysql://…
The three dots (…) in the command line represents the neutron database link information.
Some parameters must be configured with the required values as described in "Parameters and fields."
To install the SeerEngine-DC Neutron plug-ins:
1.     Access the directory where the SeerEngine-DC OpenStack package (an .egg file) is saved, and install the package on the OpenStack controller node. The name of the SeerEngine-DC OpenStack package is SeerEngine_DC_PLUGIN-version-py2.7.egg. version represents the version of the package.
Ubuntu 20.04:
sdn@ubuntu:~$ sudo python3 -m easy_install --no-deps  SeerEngine_DC_PLUGIN-E6102-py3.6.egg
Ubuntu 18.04:
sdn@ubuntu:~$ sudo python -m easy_install SeerEngine_DC_PLUGIN-E3608-py2.7.egg
Other versions:
sdn@ubuntu:~$ sudo easy_install SeerEngine_DC_PLUGIN-E3608-py2.7.egg
2.     Change the user group and permissions of the plug-in file to be consistent with those of the Neutron file.
Ubuntu 20.04:
sdn@ubuntu:~$ sudo cd /usr/local/lib/python3.6/dist-packages
sdn@ubuntu:~$ sudo chown -R --reference==/usr/lib/python3.6/dist-packages/neutron SeerEngine*
sdn@ubuntu:~$ sudo chmod -R --reference=/usr/lib/python3.6/dist-packages/neutron SeerEngine*
sdn@ubuntu:~$ sudo cd /usr/bin
sdn@ubuntu:~$ sudo chown -R --reference=neutron-server h3c*
sdn@ubuntu:~$ sudo chmod -R --reference=neutron-server h3c*
Other versions:
sdn@ubuntu:~$ sudo cd /usr/local/lib/python2.7/dist-packages
sdn@ubuntu:~$ sudo chown -R --reference==/usr/lib/python2.7/dist-packages/neutron SeerEngine*
sdn@ubuntu:~$ sudo chmod -R --reference=/usr/lib/python2.7/dist-packages/neutron SeerEngine*
3.     Install the SeerEngine-DC Neutron plug-ins.
sdn@ubuntu:~$ sudo h3c-sdnplugin controller install
¡     If Neutron is developed based on OpenStack Newton, execute the following command to install the SeerEngine-DC Neutron plug-ins:
sdn@ubuntu:~$ sudo h3c-sdnplugin controller install --neutron_version newton
¡     If Neutron is developed based on OpenStack Pike execute the following command to install the SeerEngine-DC Neutron plug-ins:
sdn@ubuntu:~$ sudo h3c-sdnplugin controller install --neutron_version pike
IMPORTANT
IMPORTANT:
Before executing the sudo h3c-sdnplugin controller install command, make sure no neutron.conf file exists in the /root directory. If such a file exists, delete it or move it to another location.
1.     Modify the neutron.conf configuration file.
a.     Use the vi editor to open the neutron.conf configuration file.
sdn@ubuntu:~$ sudo vi /etc/neutron/neutron.conf
b.     Press I to switch to insert mode, and modify the configuration file. For information about the parameters, see "neutron.conf."
For OpenStack Train and Ussuri:
[DEFAULT]
core_plugin = ml2
service_plugins =
h3c_l3_router,qos,h3c_port_forwarding,h3c_bgp_neighbor,h3c_taas,h3c_trunk
[service_providers]
service_provider= BGP_NEIGHBOR:H3C:networking_h3c.l3_router.h3c_bgp_neighbors_driver.H3CBgpNeighborsDriver:default
service_provider= TAAS:H3C:networking_h3c.l3_router.h3c_tap_services.H3CTapServicesDriver:default
service_provider=EXROUTE:H3C:networking_h3c.l3_router.h3c_exroutes_driver.H3CExroutesDriver:default
For OpenStack Queens, Rocky, and Stein:
[DEFAULT]
core_plugin = ml2
service_plugins = h3c_l3_router,qos,h3c_port_forwarding
For OpenStack:
[DEFAULT]
core_plugin = ml2
For OpenStack Mitaka (QoS services deployed in OpenStack):
[DEFAULT]
core_plugin = ml2
service_plugins = h3c_l3_router,qos,h3c_bgp_neighbor,h3c_taas,h3c_trunk
[qos]
notification_drivers = message_queue,qos_h3c
[service_providers]
For OpenStack Liberty, Newton, and Ocata (QoS services deployed in OpenStack):
[DEFAULT]
core_plugin = ml2
[qos]
For OpenStack Kilo 2015.1:
[DEFAULT]
core_plugin = ml2
IMPORTANT
IMPORTANT:
·     OpenStack Kilo does not support QoS. You do not need to specify QoS in the service_plugins parameter.
·     The open source port forwarding software has known problems and is not compatible with the Neutron plug-in L3 Plugin. As a best practice, use h3c_port_forwarding Plugin in the Neutron plug-in, and make sure the Neutron community version has resolved the known BUG #1799135.
IMPORTANT
IMPORTANT:
OpenStack Mitaka, Pike, Queens, Rocky, Stein, Train, and Ussuri support VPC interworking traffic through firewall, but additional configuration is required in the neutron.conf configuration file, see Table 3.
Table 3 Additional configuration in neutron.conf
OpenStack
Mitaka
Network Cloud Scenario
DEFAULT]
service_plugins = h3c_vpc_connection
[service_providers]
service_provider=VPC_CONNECTION:H3C:networking_h3c.vpc_connection.h3c_vpc_connection_driver.H3CVpcConnectionDriver:default
Pike
Non-Network Cloud Scenarios
[DEFAULT]
service_plugins = h3c_vpc_connection_general
api_extensions_path = /usr/lib/python2.7/site-packages/SeerEngine_DC_PLUGIN-E3608-py2.7.egg/neutron_vpc_h3c/extensions/vpcconnection_general
[service_providers]
Before the upgrade, if service_plugins = h3c_vpc_connection_pikeIt is recommended to change to service_plugins = h3c_vpc_connection_general
The api_extensions_path setting can be obtained as follows
sdn@ubuntu:~$ python
>>> from neutron_vpc_h3c.extensions import vpcconnection_general
>>> vpcconnection_general.__path__
['/usr/lib/python2.7/site-packages/SeerEngine_DC_PLUGIN-E3608-py2.7.egg/neutron_vpc_h3c/extensions/vpcconnection_general']
Queens,Rocky, and Stein
[DEFAULT]
[service_providers]
Train and Ussuri
[DEFAULT]
[service_providers]
[DEFAULT]
api_extensions_path = /usr/local/lib/python3.6/site-packages/SeerEngine_DC_PLUGIN-E3608-py3.6.egg/neutron_vpc_h3c/extensions/vpcconnection_general
[service_providers]
[root@controller ~]# python3
['/usr/local/lib/python3.6/site-packages/SeerEngine_DC_PLUGIN-E3608-3.6.egg/neutron_vpc_h3c/extensions/vpcconnection_general']
a.     Press Esc to quit insert mode, and enter :wq to exit the vi editor and save the neutron.conf file.
2.     Modify the ml2_conf.ini configuration file.
a.     Use the vi editor to open the ml2_conf.ini configuration file.
sdn@ubuntu:~$ sudo vi /etc/neutron/plugins/ml2/ml2_conf.ini
b.     Press I to switch to insert mode, and set the parameters in the ml2_conf.ini configuration file. For information about the parameters, see "ml2_conf.ini."
[ml2]
type_drivers = vxlan,vlan
tenant_network_types = vxlan,vlan
mechanism_drivers = ml2_h3c
extension_drivers = ml2_extension_h3c,qos
[ml2_type_vlan]
network_vlan_ranges = physicnet1:1000:2999,port_security
[ml2_type_vxlan]
vni_ranges = 1:500
c.     Press Esc to quit insert mode, and enter :wq to exit the vi editor and save the ml2_conf.ini file.
3.     Modify the ml2_conf.ini configuration file after the SeerEngine-DC Neutron plug-in is installed.
b.     Press I to switch to insert mode, and set the following parameters in the ml2_conf.ini configuration file. For information about the parameters, see "ml2_conf_h3c.ini."
[SDNCONTROLLER]
url = http://127.0.0.1:30000
username = admin
password = Pwd@12345
domain = sdn
timeout = 1800
retry = 10
vhostuser_mode = server
white_list = False
use_neutron_credential = False
output_json_log = False
vendor_rpc_topic = VENDOR_PLUGIN
hierarchical_port_binding_physicnets  =  ANY
hierarchical_port_binding_physicnets_prefix  =  physicnet
enable_dhcp_hierarchical_port_binding = False
enable_security_group = True
enable_https = False
neutron_plugin_ca_file =
neutron_plugin_cert_file =
neutron_plugin_key_file =
enable_iam_auth = False
sdnc_rpc_url = ws://127.0.0.1:30000
sdnc_rpc_ping_interval = 60
websocket_fragment_size = 102400
enable_l3_router_rpc_notify = False
qos_rx_limit_min = 0
enable_h3c_l3_exroute = False
neutron_black_list =
black_list_matching =
force_vlan_port_details_qvo = True
neutron_version =
neutron_domain_name =
enable_binding_fip_dnat = False
4.     If you have set the white_list parameter to True, perform the following tasks:
¡     Delete the username, password, and domain parameters in the ml2_conf.ini configuration file.
¡     Add an authentication-free user to the controller.
-     Enter the IP address of the host where the Neutron server resides.
-     Specify the role as Admin.
5.     If you have set the use_neutron_credential parameter to True, perform the following steps:
a.     Modify the neutron.conf configuration file.
# Use the vi editor to open the neutron.conf configuration file.
# Press I to switch to insert mode, and add the following configuration. For information about the parameters, see "neutron.conf."
[keystone_authtoken]
admin_user = neutron
admin_password = 123456
# Press Esc to quit insert mode, and enter :wq to exit the vi editor and save the neutron.conf file.
b.     Add an admin user to the controller.
# Configure the username as neutron.
# Specify the role as Admin.
# Enter the password of the neutron user in OpenStack.
6.     Restart the neutron-server service.
sdn@ubuntu:~$ sudo service neutron-server restart
neutron-server stop/waiting
neutron-server start/running, process 4583
1.     Verify that the SeerEngine-DC OpenStack package is correctly installed. If the correct software and OpenStack versions are displayed, the package is successfully installed.
¡     Ubuntu 20.04 operating system:
sdn@ubuntu:~$ sudo pip3 freeze | grep PLUGIN
SeerEngine-DC-PLUGIN===E6102
¡     Other Ubuntu operating systems:
sdn@ubuntu:~$ sudo pip freeze | grep PLUGIN
SeerEngine-DC-PLUGIN===E3608
2.     Verify that the neutron-server service is enabled. The service is enabled if its state is running.
sdn@ubuntu:~$ sudo service neutron-server status
neutron-server start/running, process 1849
This section describes parameters in configuration files and fields included in parameters.
neutron.conf
Parameter
Required value
core_plugin
ml2
Used for loading the core plug-in ml2 to OpenStack.
service_plugins
Used for loading the extension plug-ins to OpenStack.
service_provider
N/A
Directory where the extension plug-ins are saved.
Name of the QoS notification driver.
admin_user
N/A
Admin username for Keystone authentication in OpenStack, for example, neutron.
admin_password
N/A
Admin password for Keystone authentication in OpenStack, for example, 123456.
ml2_conf.ini
Parameter
Required value
type_drivers
vxlan,vlan
Driver type.
vxlan must be specified as the first driver type.
vxlan,vlan
Type of the networks to which the tenants belong. For intranet, only vxlan is available. For extranet, only vlan is available.
·     In the host overlay scenario and network overlay with hierarchical port binding scenario, vxlan must be specified as the first network type.
·     In the network overlay without hierarchical port binding scenario, vlan must be specified as the first network type.
·     In the host overlay, network overlay with hierarchical port binding, and network overlay without hierarchical port binding hybrid scenario, vxlan must be specified as the first network type. In this scenario, you can create a VLAN only from the background CLI, REST API, or Web administration interface.
mechanism_drivers
ml2_h3c
Name of the ml2 driver.
To create SR-IOV instances for VLAN networks, set this parameter to sriovnicswitch, ml2_h3c.
To create hierarchy-supported instances, set this parameter to ml2_h3c,openvswitch.
extension_drivers
Names of the ml2 extension drivers. Available names include ml2_extension_h3c, qos, and port_security. If the QoS feature is not enabled on OpenStack, you do not need to specify the value qos for this parameter. To not enable port security on OpenStack, you do not need to specify the port_security value for this parameter (The OpenStack Kilo 2015.1, Liberty 2015.2, and Ocata 2017.1 do not support the port_security value.)
OpenStack Kilo 2015.1 do not support the QoS driver.
network_vlan_ranges
N/A
Value range for the VLAN ID of the extranet, for example, physicnet1:1000:2999.
vni_ranges
N/A
Value range for the VXLAN ID of the intranet, for example, 1:500.
ml2_conf_h3c.ini
Parameter
url
URL address for logging in to Unified Platform, http://ip_address:30000, for example, http://127.0.0.1:3000.
username
Username for logging in to Unified Platform, for example, admin. You do not need to configure a username when the use_neutron_credential parameter is set to True.
password
Password for logging in to Unified Platform, for example, Pwd@12345. You do not need to configure a password when the use_neutron_credential parameter is set to True. If the password contains a dollar sign ($), enter a backward slash (\) before the dollar sign.
domain
Name of the domain where the controller resides, for example, sdn.
timeout
The amount of time that the Neutron server waits for a response from the controller in seconds, for example, 1800 seconds.
As a best practice, set the waiting time greater than or equal to 1800 seconds.
retry
Maximum times for sending connection requests from the Neutron server to the controller, for example, 10.
vif_type
Default vNIC type:
·     ovs
·     vhostuser (applied to the OVS DPDK solution)
·     None (only supported by Mitaka)
You can set the vhostuser_mode parameter when the value of this parameter is vhostuser.
For Mitaka plug-ins, if you set the value to None, you must make sure the host name is consistent with the host name of the compute node when you add a compute node on the compute domain page. When the value is None, the vNIC type can be automatically identified in a host-based overlay environment.
Only OpenStack Mitaka, Newton, and Pike support this parameter.
vhostuser_mode
Default DPDK vHost-user mode:
·     server
·     client
The default value is server.
This setting takes effect only when the value of the vif_type parameter is vhostuser.
white_list
Whether to enable or disable the authentication-free user feature on OpenStack.
·     True—Enable.
·     False—Disable.
Whether to use the OpenStack Neutron username and password to communicate with the controller.
·     True—Use.
·     False—Do not use.
output_json_log
Whether to output REST API messages to the OpenStack operating logs in JSON format for communication between the SeerEngine-DC Neutron plug-ins and the controller.
·     True—Enable.
·     False—Disable.
vendor_rpc_topic
RPC topic of the vendor. This parameter is required when the vendor needs to obtain Neutron data from the SeerEngine-DC Neutron plug-ins. The available values are as follows:
·     VENDOR_PLUGIN—Default value, which means that the parameter does not take effect.
·     DP_PLUGIN—RPC topic of DPtech.
The value of this parameter must be negotiated by the vendor and H3C.
Policy for OpenStack to select a physical VLAN when performing hierarchical port binding. The default value is ANY.
·     ANY—A VLAN is selected from all physical VLANs for VLAN ID assignment.
·     PREFIX—A VLAN is selected from all physical VLANs matching the specified prefix for VLAN ID assignment.
Only OpenStack Mitaka, Newton, Ocata, Pike, Queens, Rocky, Stein, and Train support this parameter.
Prefix for matching physical VLANs. The default value is physicnet. This parameter is available only when you set the value of the hierarchical_port_binding_physicnets parameter to PREFIX.
Whether to enable DHCP hierarchical port binding. The default value is False.
·     True—Enable.
·     False—Disable.
Only OpenStack Pike supports this parameter.
Whether to deploy OpenStack security group rules to SeerEngine-DC. The default value is False.
enable_https
Whether to enable HTTPS bidirectional authentication. The default value is False.
·     True—Enable.
·     False—Disable.
Save location for the CA certificate of the controller, for example, /etc/neutron/ca.crt. As a best practice, save the CA certificate in the /usr/share/neutron directory.
Only the Pike support this parameter.
Save location for the Cert certificate of the controller, for example, /etc/neutron/sna.pem. As a best practice, save the Cert certificate in the /usr/share/neutron directory.
Save location for the Key certificate of the controller, for example, /etc/neutron/sna.key. As a best practice, save the Cert certificate in the /usr/share/neutron directory.
enable_iam_auth
Whether to enable IAM interface authentication.
·     True—Enable.
·     False—Disable.
When connecting to Unified Platform, you can set the value to True to use the IAM interface for authentication.
This parameter is obsolete.
Only OpenStack Mitaka and Newton support this parameter.
sdnc_rpc_url
RPC interface URL of the controller. Only a WebSocket type interface is supported, for example, ws://127.0.0.1:30000. If the Unified Platform uses an HTTPS URL, the controller must uses the WebSocket Secure (wss) URL scheme.
Configure this parameter based on the URL of the Unified Platform. For example, if the URL of the Unified Platform is http://127.0.0.1:30000, set this parameter to ws://127.0.0.1: 30000.
Interval at which an RPC ICMP echo request message is sent to the controller, in seconds.
Int type. The default value is 60 seconds.
Size of a WebSocket fragment sent from the plug-in to the controller in the DHCP failover scenario, in bytes.
Int type. The value is an integer equal to or larger than 1024. The default value is 102400. If the value is 1024, the message is not fragmented.
Whether to enable or disable the feature of sending Layer 3 routing events through RPC.
·     True—Enable.
·     False—Disable.
qos_rx_limit_min
Minimum inbound bandwidth, in kbps. If the QoS minimum inbound bandwidth configured on OpenStack is smaller than this parameter value, this parameter value takes effect.
Only OpenStack Kilo 2015.1 supports this parameter.
cloud_region_name
Name of the cloud platform. String type. The default value is default. Make sure the value of this parameter is the same as the cloud platform name configured on the Automation > Data Center Networks > Virtual Networking > OpenStack page on SeerEngine-DC.
Whether to enable routing extension. The default value is False.
Only OpenStack Mitaka and Train support this parameter.
When the value is True, configure the api_extensions_path parameter in the neutron.conf file as follows:
·     Ubuntu 20.04 operating system:
sdn@ubuntu:~$ python3
>>>from neutron_exroute_h3c import extensions
>>>extensions.__path__
['/usr/local/lib/python3.6/site-packages/SeerEngine_DC_PLUGIN-E6102-py3.6.egg/neutron_exroute_h3c/extensions']
·     Other Ubuntu operating systems:
>>>extensions.__path__
neutron_black_list
Neutron network denylist function. This parameter must be used together with the black_list_matching parameter. No default value exists.
If the value for this parameter is flat and no denylist matching rule is specified, the denylist feature takes effect only on flat-type internal networks.
black_list_matching
Denylist matching rule. Options are prefix and suffix. When the value is prefix, the network is added to the denylist if the network name prefix is within the value range for the neutron_black_list parameter. When the value is suffix, the network is added to the denylist if the network name suffix is within the value range for the neutron_black_list parameter. After a network resource is added to the denylist, that network resource will not be deployed to the controller after being created on the cloud platform. The default value is not configured, which means the denylist function is disabled.
Whether to forcibly create a qvo-type vPort on the OVS bridge after a VM in a VLAN network comes online. If the value is true, the system forcibly creates a qvo-type vPort. If the value is false, the system automatically creates a tap-type or qvo-type vPort as configured. As a best practice, set the value to false for interoperability with the cloud platform for the first time.
neutron_version
Neutron version. Options include pike and newton. You can also leave the parameter unconfigured. By default, this parameter is unconfigured. If Neutron is developed based on open source OpenStack Pike or Newton, specify the value as pike or newton.
neutron_domain_name
If the Neutron permission is insufficient for obtaining the tenant or domain names from Keystone, you can use the current domain name to configure this field for Neutron to obtain sufficient permission. By default, this field is not configured. You can obtain the current domain name from the cloud platform.
Whether to enable port forwarding for the port bound to floating IP. The default value is false.
Upgrading the SeerEngine-DC Neutron plug-ins
CAUTION
CAUTION:
·     Services might be interrupted during the SeerEngine-DC Neutron plug-ins upgrade procedure.
·     The default parameter settings for SeerEngine-DC Neutron plug-ins might vary by OpenStack version (Kilo 2015.1, Liberty, Mitaka, and Ocata). Modify the default parameter settings for SeerEngine-DC Neutron plug-ins when upgrading the OpenStack version to ensure that the plug-ins have the same configurations before and after the upgrade.
To upgrade the SeerEngine-DC Neutron plug-ins:
1.     Remove the SeerEngine-DC Neutron plug-ins.
sdn@ubuntu:~$ sudo h3c-sdnplugin controller uninstall
Restore config files
Uninstallation complete.
¡     If Neutron is developed based on open source OpenStack Newton, execute the following command to remove the SeerEngine-DC Neutron plug-ins:
sdn@ubuntu:~$ sudo h3c-sdnplugin controller uninstall --neutron_version newton
¡     If Neutron is developed based on open source OpenStack Pike, execute the following command to remove the SeerEngine-DC Neutron plug-ins:
sdn@ubuntu:~$ sudo h3c-sdnplugin controller uninstall --neutron_version pike
2.     Remove the SeerEngine-DC OpenStack package.
sdn@ubuntu:~$ sudo pip3 uninstall seerengine-dc-plugin
Uninstalling SeerEngine-DC-PLUGIN-E6102
Proceed (y/n)? y
  Successfully uninstalled SeerEngine-DC-PLUGIN-E6102
sdn@ubuntu:~$ sudo pip uninstall seerengine-dc-plugin
Uninstalling SeerEngine-DC-PLUGIN-E3608
  /usr/bin/h3c-sdnplugin
Proceed (y/n)? y
Successfully uninstalled SeerEngine-DC-PLUGIN-E3608
3.     Install plug-ins of the new version. For more information, see "Installing and configuring plug-ins on the controller node."
You must install the Nova patch only in the following scenarios:
·     In KVM host-based overlay or network-based overlay scenario, virtual machines are load balancer members, and the load balancer must be aware of the member status.
·     vCenter network-based overlay scenario.
Obtaining the Nova patch installation package
The Nova patch is included in the SeerEngine-DC OpenStack package. Perform the following steps to download the SeerEngine-DC OpenStack package from the H3C website:
1.     Obtain the SeerEngine-DC OpenStack package of the required version.
2.     Copy the SeerEngine-DC OpenStack package to the installation directory on the server or virtual machine, or upload it to the installation directory through FTP, TFTP, or SCP.
If you decide to upload the SeerEngine-DC OpenStack package through FTP or TFTP, use the binary mode to avoid damage to the package.
Installing the Nova patch
Based on your network environment, choose one step between step 3 and step 4.
To install the Nova patch on the OpenStack compute node:
1.     Access the directory where the SeerEngine-DC OpenStack package (an .egg file) is saved, and install the package on the OpenStack compute node. The name of the SeerEngine-DC OpenStack package is SeerEngine_DC_PLUGIN-version1-py2.7.egg. version represents the version of the package.
In this example, the SeerEngine-DC OpenStack package is saved to the /root directory.
2.     Install the Nova patch.
sdn@ubuntu:~$ sudo h3c-sdnplugin compute install
Install the nova patch
modifying:
/usr/lib/python2.7/dist-packages/nova/virt/vmwareapi/vmops.py
modify success, backuped at: /usr/lib/python2.7/dist-packages/nova/virt/vmwareapi/vmops.py.h3c_bak
The contents below the modifying: line indicate the modified open source Neutron file and the backup path of the file before modification.
3.     Perform the following steps:
a.     Stop the neutron-openvswitch-agent service on the compute node and disable the system from starting the service at startup.
sdn@ubuntu:~$ sudo service neutron-openvswitch-agent stop
sdn@ubuntu:~$ sudo systemctl disable neutron-openvswitch-agent.service
b.     Execute the neutron agent-list command on the controller node to identify whether the agent of the compute node exists in the database.
-     If the agent of the compute node does not exist in the database, go to the next step.
-     If the agent of the compute node exists in the database, execute the neutron agent-delete id command to delete the agent. The id argument represents the agent ID.
sdn@ubuntu:~$ sudo neutron agent-list
| id                                   | agent_type         | host     |
| 25c3d3ac-5158-4123-b505-ed619b741a52 | Open vSwitch agent | compute3
sdn@ubuntu:~$ sudo neutron agent-delete 25c3d3ac-5158-4123-b505-ed619b741a52
Deleted agent: 25c3d3ac-5158-4123-b505-ed619b741a52
c.     Use the vi editor on the compute node to open the nova.conf configuration file.
sdn@ubuntu:~$ sudo vi /etc/nova/nova.conf
d.     Press I to switch to insert mode, and set the parameters in the nova.conf configuration file as follows. For descriptions of the parameters, see Table 4.
If the hypervisor type of the compute node is KVM, modify the nova.conf configuration file as follows:
[s1020v]
s1020v = False
member_status = True
[neutron]
ovs_bridge = vds1-br
If the hypervisor type of the compute node is VMware vCenter, modify the nova.conf configuration file as follows:
[DEFAULT]
compute_driver = vmwareapi.VMwareVCDriver
[vmware]
host_ip = 127.0.0.1
host_username = sdn
host_password = skyline123
cluster_name = vcenter
insecure = True
[s1020v]
s1020v = False
vds = VDS2
e.     Press Esc to quit insert mode, and enter :wq to exit the vi editor and save the nova.conf file.
Table 4 Parameters in the configuration file
Parameter
s1020v
Whether to use the S1020V vSwitch to forward the traffic between vSwitches and the traffic between the vSwitches and the external network.
·     True—Use the S1020V vSwitch.
·     False—Do not use the S1020V vSwitch.
This parameter is obsoleted.
member_status
Whether to enable or disable the feature of modifying the status of members on OpenStack load balancers.
·     True—Enable.
·     False—Disable.
vds
VDS to which the host in the vCenter belongs. In this example, the host belongs to VDS2. In the host-based overlay networking, you can only specify the VDS that the controller synchronizes to the vCenter. In the network-based overlay networking, you can specify an existing VDS on demand.
ovs_bridge
Name of the bridge for the H3C S1020V vSwitch. Make sure the bridges created on all H3C S1020V vSwitches use the same name.
compute_driver
Name of the driver used by the compute node for virtualization.
host_ip
IP address used to log in to the vCenter, for example, 127.0.0.1.
host_username
Username for logging in to the vCenter, for example, sdn.
host_password
Password for logging in to the vCenter, for example, skyline123. If the password contains a dollar sign ($), enter a backward slash (\) before the dollar sign.
cluster_name
Name of the team in the vCenter environment, for example, vcenter.
insecure
Whether to enable or disable security check.
·     True—Do not perform security check.
·     False—Perform security check. This value is not supported in the current software version.
4.     Restart the openstack-nova-compute service.
sdn@ubuntu:~$ sudo service openstack-nova-compute restart
# Verify that the SeerEngine-DC OpenStack package is correctly installed. If the correct software and OpenStack versions are displayed, the package is successfully installed.
# Verify that the openstack-nova-compute service is enabled. The service is enabled if its state is running.
sdn@ubuntu:~$ sudo service openstack-nova-compute status
nova-compute start/running, process 184
Upgrading the Nova patch
CAUTION
CAUTION:
Services might be interrupted during the Nova patch upgrade procedure.
You must remove the Nova patch before upgrading the Nova patch.
To upgrade the Nova patch:
1.     Remove the Nova patch.
sdn@ubuntu:~$ sudo h3c-sdnplugin compute uninstall
Uninstall the nova patch
Uninstalling SeerEngine-DC-PLUGIN-E3608:
  /usr/lib/python2.7/dist-packages/SeerEngine_DC_PLUGIN-E368-py2.7.egg
Proceed (y/n)? y
3.     Install the new-version Nova patch. For more information, see "Installing configuring plug-ins on a compute node."
1.     Create a VXLAN network and a VM on OpenStack.
2.     Log in to SeerEngine-DC, and access the Automation > Data Center Networks > All Tenant Networks > vPorts page to identify whether the vPort exists. If the vPort information is correct and the vPort is up, the interoperation has succeeded.
See "Installing the SeerEngine-DC Neutron plug-ins ."
IMPORTANT
IMPORTANT:
You must configure a physical network name and VLAN range for all compute nodes in the network_vlan_ranges parameter in the ml2_conf.ini file. Make sure the physical network name in the bridge_mappings parameter in the openvswitch_agent.ini file is unique for a compute node.
To edit the configuration file:
1.     Log in to a controller node as a root user.
2.     Edit the network_vlan_ranges parameter in the /etc/neutron/plugins/ml2/openvswitch_agent.ini file. The value to the left of the colon represents the physical network name, and the value to the right of the colon represents the VLAN range.
[ml2]
mechanism_drivers = ml2_h3c,openvswitch
[ml2_type_vlan]
network_vlan_ranges = physicnet1:1000:1999,physicnet2:2000:2999
[ml2_type_vxlan]
vni_ranges = 1:500
3.     Restart the neutron-server service.
Installing the lldpad service
In a KVM network-based overlay scenario, you are required to install the lldpad service on each compute node.
1.     Install and start the lldpad service on the compute node.
sdn@ubuntu:~$ sudo apt-get install lldpad
sdn@ubuntu:~$ sudo service lldpad enable
sdn@ubuntu:~$ sudo service lldpad start
2.     Enable the uplink interface to send LLDP messages. eno2 is the uplink interface in this example.
sdn@ubuntu:~$ sudo lldptool set-lldp -i eno2 adminStatus=rxtx
sdn@ubuntu:~$ sudo lldptool -T -i eno2 -V sysName enableTx=yes
sdn@ubuntu:~$ sudo lldptool -T -i eno2 -V portDesc enableTx=yes
sdn@ubuntu:~$ sudo lldptool -T -i eno2 -V sysDesc enableTx=yes
sdn@ubuntu:~$ sudo lldptool -T -i eno2 -V sysCap enableTx=yes
For the installation procedure, see "Installing configuring plug-ins on a compute node."
Installing the openvswitch-agent patch
IMPORTANT
IMPORTANT:
·     The openvswitch-agent patch applies only to open source scenarios. It cannot be installed on a third-party cloud platform on which openvswitch-agent has been modified.
·     The openvswitch-agent patch is required only in the VXLAN environment. The OpenStack Rocky and Stein do not require installation of the openvswitch-agent patch.
To install the openvswitch-agent patch:
1.     Access the directory where the SeerEngine-DC OpenStack package (an .egg file) is saved, and install the package on the OpenStack compute node. The name of the SeerEngine-DC OpenStack package is SeerEngine_DC_PLUGIN-version -py2.7.egg. version represents the version of the package.
2.     Install the openvswitch-agent patch.
sdn@ubuntu:~$ sudo h3c-sdnplugin openvswitch install
3.     Restart the openvswitch-agent service.
sdn@ubuntu:~$ sudo service neutron-openvswitch-agent restart
# Verify that the openvswitch-agent service is enabled. The service is enabled if its state is running.
sdn@ubuntu:~$ sudo service neutron-openvswitch-agent status
Redirecting to /bin/systemctl status  neutron-openvswitch-agent.service
neutron-openvswitch-agent.service - OpenStack Neutron Open vSwitch Agent
   Loaded: loaded (/usr/lib/systemd/system/neutron-openvswitch-agent.service; enabled; vendor preset: disabled)
   Active: active (running) since Mon 2016-12-05 16:58:18 CST; 18h ago
Main PID: 807 (neutron-openvsw)
Upgrading the openvswitch-agent patch
CAUTION
CAUTION:
Services might be interrupted during the openvswitch-agent patch upgrade procedure.
To upgrade the openvswitch-agent patch, you must remove the current version first, and install a new version.
To upgrade the openvswitch-agent patch:
1.     Remove the openvswitch-agent patch.
sdn@ubuntu:~$ sudo h3c-sdnplugin openvswitch uninstall
  /usr/bin/h3c-agent
Proceed (y/n)? y
3.     Install the new patch. For more information, see"Installing configuring plug-ins on a compute node."
IMPORTANT
IMPORTANT:
2.     Edit the bridge_mappings parameter in the /etc/neutron/plugins/ml2/openvswitch_agent.ini file. The value to the left of the colon represents the physical network name, and the value to the right of the colon represents the manually created OVS bridge name.
Make sure the physical network name is the same as the physical network name of the bound NIC.
[ovs]
bridge_mappings = physicnet1:br-ens33
3.     Create a bridge named br-ens33.
sdn@ubuntu:~$ sudo ovs-vsctl add-br br-ens33
4.     Map the bridge to the physical port.
sdn@ubuntu:~$ sudo ovs-vsctl add-port br-ens33 ens33
5.     Verify that the bridge was created successfully.
sdn@ubuntu:~$ sudo ovs-vsctl show
6.     Delete the default bridge.
sdn@ubuntu:~$ sudo ovs-vsctl del-br br-tun
7.     Edit the /etc/neutron/plugins/ml2/openvswitch_agent.ini file to comment out all tunnel-related parameters.
[agent]
# tunnel_types = vxlan
# vxlan_udp_port = 4789
# l2_population = true
[ovs]
# tunnel_bridge = br-tun
# local_ip = 192.168.1.100
8.     Restart the openvswicth-agent and neutron-openvswitch-agent services to verify that the br-tun bridge has been deleted successfully.
sdn@ubuntu:~$ sudo systemctl restart neutron-openvswitch-agent.service
sdn@ubuntu:~$ sudo systemctl restart openvswitch-agent.service
To provide DHCP failover in the network-based overlay scenario, you must install DHCP failover and Metadata components.
IMPORTANT
IMPORTANT:
The DHCP failover components can operate only on the CentOS 7.2.1511 operating system with a kernel version of 3.10.0-327.el7.x86_64. If the kernel version does not match that of the S1020V, install the kernel patch first .
Installing, removing, and upgrading the DHCP component
For more information, see H3C SeerEngine-DC Controller Converged OpenStack Plug-Ins Installation Guide for CentOS.
Installing, removing, and upgrading the Metadata component
OpenStack allows a VM to obtain metadata from a network node either through DHCP or a Layer gateway. The H3C implementation supports only obtaining metadata from a network node either through DHCP. For more information, see H3C SeerEngine-DC Controller Converged OpenStack Plug-Ins Installation Guide for CentOS.
2.     Log in to SeerEngine-DC, and access the Automation > Data Center Networks > All Tenants > vPorts page to identify whether the vPort exists. If the vPort information is correct and the vPort is up, the interoperation has succeeded.
IMPORTANT
IMPORTANT:
Because of the restrictions by the OpenStack community, only VLAN but not VXLAN is supported in this scenario.
See "Installing configuring plug-ins on a compute node."
See the SR-IOV configuration guide at the official website of OpenStack.
2.     Edit the mechanism_drivers parameter in the Ml2 conf.ini file.
[ml2]
mechanism_drivers = sriovnicswitch,ml2_h3c,openvswitch
1.     Create a VLAN network and a direct-type port on OpenStack.
2.     Create a VM with this type of port.
3.     Log in to SeerEngine-DC, and access the Automation > Data Center Networks > All Tenants > vPorts page to identify whether the vPort exists. If the vPort information is correct and the vPort is up, the interoperation has succeeded.
IMPORTANT
IMPORTANT:
For how to configure interoperability with a third-party load balancer, see the interoperation guide. This section is for reference only.
Installing the openvswitch patch
For the VXLAN or network overlay environment, see openvswich patch installation in "Installing configuring plug-ins on a compute node."
Log in to a controller node as a root user, and place the F5 plug-ins in a directory on the controller node, for example, /var/log/neutron. The installation package is provided by F5. Please contact the corresponding personnel to obtain the F5 installation package.
Installing the git tool kit
To obtain the networking-f5 package, you must install the git tool kit before installing F5 plug-ins and patches. To download and install the git tool kit, execute the sdn@ubuntu:~$ sudo yum install –y git command.
Installing F5 plug-ins
1.     Install base F5 packages.
[root@neutron ~]# rpm -ivh f5-icontrol-rest-1.3.9-1.el7.noarch.rpm
[root@neutron ~]# rpm -ivh f5-sdk-3.0.11-1.el7.noarch.rpm
2.     Install the F5 LBv2 plugin driver.
[root@neutron ~]# tar xvf f5.tgz -C /usr/lib/python2.7/site-packages/neutron_lbaas/drivers/
3.     Install the F5 LBv2 plugin driver.
4.     Install the F5 agent.
[root@neutron ~]# rpm -ivh f5-openstack-agent-9.7.0-35.el7.noarch.rpm
5.     Install the F5 ML2 Plugin driver f5networks.
[root@neutron ~]# git clone https://github.com/F5Networks/networking-f5.git
[root@neutron ~]# cd networking-f5/
[root@networking-f5 ~]# python setup.py install
1.     Edit the /etc/neutron/neutron.conf file.
a.     If LBaaSV1 configuration exists in the service_plugins parameter, remove the configuration, and add the LBaaSV2 configuration. Keep other configuration unchanged.
[DEFAULT]
core_plugin = ml2
service_plugins = …,neutron_lbaas.services.loadbalancer.plugin.LoadBalancerPluginv2
b.     Configure F5 service_providers.
[service_providers]
service_provider=LOADBALANCERV2:F5Networks:neutron_lbaas.drivers.f5.driver_v2.F5LBaaSV2Driver:default
c.     Add the following configuration:
[DEFAULT]
unlegacy_setting_placeholder_driver_side = special_driver_side
debug = true
port_normal_or_baremetal = baremetal
to_delete_last_port = False
2.     Edit the /etc/neutron/plugins/ml2/ml2_con.ini file.
[ml2]
mechanism_drivers = ml2_h3c,...,f5networks  //Make sure f5networks is to the right of ml2_h3c
[ml2_type_vlan]
//Separate VLAN ranges with commas (,)
network_vlan_ranges = physicnet1:1000:2999,f5network:3000:3200
[ml2_type_vxlan]
vni_ranges = 1:500  //Specify a VXLAN range
3.     Edit the /etc/neutron/services/f5/f5-openstack-agent.ini file.
a.     Edit the configuration as follows:
[DEFAULT]
debug = True
// F5 HA modes include standalone and pair
f5_ha_type = standalone
// f5network is the network egress. 5.0 is the name of the trunk created on F5
f5_external_physical_mappings = f5network:5.0:True,default:5.0:True
icontrol_hostname = 31.1.1.135   //F5 management interface address
icontrol_username = admin   //F5 account
icontrol_password = admin    //F5 password
f5_network_segment_physical_network = f5network   //F5 network egress
f5_global_routed_mode = False
agent_id = f5_cluster1    //F5 agent host ID
b.     Comment out the following configuration:
#f5_vtep_folder = None
#f5_vtep_selfip_name = None
4.     Restart the services.
sdn@ubuntu:~$ sudo systemctl enable f5-openstack-agent
sdn@ubuntu:~$ sudo systemctl restart f5-openstack-agent
sdn@ubuntu:~$ sudo systemctl restart neutron-server
1.     Create a LoadBalancer v2 resource on OpenStack.
3.     Log in to SeerEngine-DC, and access the Automation > Data Center Networks > All Tenants > Load Balancers page to identify whether the load balancer exists. If the load balancer information is correct, the interoperation has succeeded.
IMPORTANT
IMPORTANT:
·     For more information about interoperability with third-party firewalls, see the interoperation guide. This section uses a DP firewall as an example.
·     SeerEngine-DC Neutron plug-ins support using callbacks to process router events. Resources used are h3c_router and h3c_router_interface.
For the VXLAN or network overlay scenario, see openvswich patch installation in "Installing configuring plug-ins on a compute node."
1.     Configure the basic environment based on the third-party interoperability guide.
2.     Log in to a controller node as a root user, and edit the ml2_conf.ini file to load DP RPC topic.
[SDNCONTROLLER]
vendor_rpc_topic = DP_PLUGIN
3.     Edit the Neutron firewall configuration file to load DP Driver.
vim /etc/neutron/fwaas_driver.ini
[fwaas]
driver= neutron.services.firewall.drivers.linux.dp_fwaas.FwaasDriver
enabled = True
4.     Restart the Neutron server.
Configuring third-party interoperability on SeerEngine-DC
Enable predeployment of third-party interconnect address through REST API:
nem/v1.0/reserve_option
  "reserve_option": {
    "thirdparty_security_service_option": true
1.     Create a firewall resource on OpenStack and bind it to a router.
3.     Log in to SeerEngine-DC, and access the Automation > Data Center Networks > All Tenant Networks > Firewalls page to identify whether the firewall exists. If the firewall information is correct, the interoperation has succeeded.
IMPORTANT
IMPORTANT:
This section describes only basic installation and configuration procedures. For more information, see the configuration examples.
Deploying Ironic
See the relevant Ironic deployment guide.
Metadata solution
For the detailed installation procedure, see "Installing and configuring plug-ins on the controller node"
(Optional.) Installing the Nova patch
For the detailed installation procedure, see "Installing configuring plug-ins on a compute node."
(Optional.) Installing the openvswitch patch
Perform the following procedure on all nodes where a DHCP agent resides. The node that hosts a DHCP agent requires three physical interfaces: one for management services, one for VLAN data services, and one for VXLAN data services.
To set up the environment for the traditional VLAN and VXLAN-based metadata solution:
1.     Configure an IP address for the VXLAN uplink interface.
ens192: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 100.101.0.10  netmask 255.255.255.0  broadcast 100.101.0.255
        inet6 fe80::250:56ff:fe89:6b8a  prefixlen 64  scopeid 0x20<link>
        ether 00:50:56:89:6b:8a  txqueuelen 1000  (Ethernet)
        RX packets 5612  bytes 452681 (442.0 KiB)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 142  bytes 14443 (14.1 KiB)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
2.     Enable all VLAN and VXLAN uplink interfaces to send LLDP messages and assign IP address mngAddr to the uplink interfaces.
# In this example, ens192 is the VXLAN uplink interface and ens193 is the VLAN uplink interface. Configure the same settings for the two uplink interfaces.
sdn@ubuntu:~$ sudo lldptool set-lldp -i ens192 adminStatus=rxtx;
sdn@ubuntu:~$ sudo lldptool -T -i ens192 -V sysName enableTx=yes;
sdn@ubuntu:~$ sudo lldptool -T -i ens192 -V portDesc enableTx=yes;
sdn@ubuntu:~$ sudo lldptool -T -i ens192 -V sysDesc enableTx=yes;
sdn@ubuntu:~$ sudo ldptool -T -i ens192 -V sysCap enableTx=yes;
sdn@ubuntu:~$ sudo lldptool -T -i ens192 -V mngAddr enableTx=yes;
sdn@ubuntu:~$ sudo lldptool -T -i ens192 -V mngAddr ipv4=100.101.0.10   //Configure an IP address for the VXLAN uplink interface.
sdn@ubuntu:~$ sudo lldptool -t -i ens193
sdn@ubuntu:~$ sudo lldptool set-lldp -i ens193 adminStatus=rxtx;
sdn@ubuntu:~$ sudo lldptool -T -i ens193 -V sysName enableTx=yes;
sdn@ubuntu:~$ sudo lldptool -T -i ens193 -V portDesc enableTx=yes;
sdn@ubuntu:~$ sudo lldptool -T -i ens193 -V sysDesc enableTx=yes;
sdn@ubuntu:~$ sudo lldptool -T -i ens193 -V sysCap enableTx=yes;
sdn@ubuntu:~$ sudo lldptool -T -i ens193 -V mngAddr enableTx=yes;
sdn@ubuntu:~$ sudo lldptool -T -i ens193 -V mngAddr ipv4=100.101.0.10   //Configure the IP address for the VLAN uplink interface to be the same as that of the VXLAN interface.
3.     Add the following settings for the neutron openvswitch agent process.
sdn@ubuntu:~$ sudo vi /etc/neutron/plugins/ml2/openvswitch_agent.ini
[agent]
[ovs]
local_ip = 100.101.0.10  //Configure an IP address for the uplink interface.
4.     Restart the neutron-openvswitch-agent process.
Controller node
1.     Modify the ml2_conf.ini file.
[SDNCONTROLLER]
enable_dhcp_hierarchical_port_binding = True
2.     Restart the service.
sdn@ubuntu:~$ sudo systemctl restart neutron-server.service
Network node
1.     Access the /etc/neutron/plugins/ml2/openvswitch_agent.ini file and edit the bridge_mappings parameter for OVS.
¡     The value before the colon is the physical network name bound to the network card.
¡     The value after the colon is the name of the OVS bridge to be created manually. You can define the name as required.
[ovs]
bridge_mappings = physicnet1:br-ens192
2.     Create a network bridge.
In this example, the network bridge is named br-ens192.
sdn@ubuntu:~$ sudo ovs-vsctl add-br br-ens192
3.     Bind the network bridge to the physical interface.
sdn@ubuntu:~$ sudo ovs-vsctl add-port br-ens192 ens192
4.     Verify that the OVS settings are correct.
5.     Delete the default network bridge.
In this example, the network bridge br-tun is deleted.
6.     Enable all VLAN uplink interfaces to send LLDP messages and assign IP address mngAddr to the uplink interface.
In this example, the VLAN uplink interface is ens193. You are not required to specify an IP address for it.
7.     Access the /etc/neutron/plugins/ml2/openvswitch_agent.ini file to delete all tunnel-related parameters.
[agent]
[ovs]
8.     Edit the /etc/neutron/dhcp_agent.ini configuration file.
[DEFAULT]
interface_driver = neutron.agent.linux.interface.OVSInterfaceDriver
dhcp_driver = neutron.agent.linux.dhcp.Dnsmasq
enable_isolated_metadata = true
force_metadata = true
9.     Restart the service.
sdn@ubuntu:~$ sudo systemctl restart neutron-dhcp-agent.service
The SeerEngine-DC Neutron security plug-ins can be installed on multiple OpenStack versions. This section uses OpenStack Pike as an example to describe the security plug-ins installation.
The SeerEngine-DC Neutron security plug-ins are installed on the OpenStack controller node. Before installation, set up the base environment on the node.
Obtain and copy the security plug-ins installation package of the required version to the target installation directory on the server or virtual machine.
IMPORTANT
IMPORTANT:
To avoid damaging the installation packages, select binary mode if you are to transfer the package through FTP or TFTP.
1.     Access the directory where the security plug-ins installation package is saved. The name of installation package is in the SeerEngine_DC_SEC_PLUGIN-version-py2.7.egg format.
In this example, the package is saved in the /root directory.
sdn@ubuntu:~$ sudo easy_install SeerEngine_DC_SEC_PLUGIN-E3603P01-py2.7.egg
2.     Edit the user group and permissions for the plug-ins installation package to be the same as those of the Neutron component installation package.
3.     Install the SeerEngine-DC Neutron security plug-ins.
sdn@ubuntu:~$ sudo h3c-secplugin controller install
IMPORTANT
IMPORTANT:
Before executing the sudo h3c-secplugin controller install command, make sure no neutron.conf file exists in the /root directory. If such a file exists, delete it or move it to another location.
1.     Edit the neutron.conf configuration file.
b.     Press I to switch to insert mode, and then edit the configuration file. For more information about the parameters, see "neutron.conf."
For OpenStack Pike, Queens, and Rocky, edit the neutron.conf configuration file as follows:
[DEFAULT]
service_plugins = firewall,h3c_security_core,lbaasv2,vpnaas
[service_providers]
service_provider=FIREWALL:H3C:networking_sec_h3c.fw.h3c_fwplugin_driver.H3CFwaasDriver:default
service_provider=LOADBALANCERV2:H3C:networking_sec_h3c.lb.h3c_lbplugin_driver_v2.H3CLbaasv2PluginDriver:default
service_provider=VPN:H3C:networking_sec_h3c.vpn.h3c_vpnplugin_driver.H3CVpnPluginDriver:default
IMPORTANT
IMPORTANT:
For OpenStack Pike, when the load balancer supports multiple resource pools of the Context type, you must preprovision a resource pool named dmz or core on the controller, and then change the value of the service provider parameter to LOADBALANCERV2:DMZ:networking_sec_h3c.lb.h3c_lbplugin_driver_v2.H3CLbaasv2PluginDMZDriver:default or LOADBALANCERV2:CORE:networking_sec_h3c.lb.h3c_lbplugin_driver_v2.H3CLbaasv2PluginCOREDriver:default accordingly.
¡     For OpenStack Kilo2015.1, Liberty, and Mitaka, configure the neutron.conf configuration file as follows when Load balancer V1 is configured in OpenStack:
[DEFAULT]
service_plugins = firewall,lbaas,vpnaas
[service_providers]
service_provider=LOADBALANCER:H3C:networking_sec_h3c.lb.h3c_lbplugin_driver.H3CLbaasPluginDriver:default
service_provider=VPN:H3C:networking_sec_h3c.vpn.h3c_vpnplugin_ko_driver.H3CVpnPluginDriver:default
¡     For OpenStack Newton and Ocata, you can specify only Load balancer V2 and edit the service_provider parameter for the VPN service as follows:
IMPORTANT
IMPORTANT:
The service_provider parameter value for the VPN services is different between OpenStack Pike, Queens, and Rocky and OpenStack Kilo2015.1, Liberty, Mitaka, Newton, and Ocata. Be clear about the differences.
c.     Press Esc to quit insert mode, and enter :wq to exit the vi editor and save the neutron.conf file.
2.     Edit the local_settings configuration file.
a.     Use the vi editor to open the local_settings configuration file.
sdn@ubuntu:~$ sudo vi /etc/openstack-dashboard/local_settings
b.     Press I to switch to insert mode. Edit the OPENSTACK_NEUTRON_NETWORK parameter to enable LB, FW, and VPN configuration pages in OpenStack Web.
OPENSTACK_NEUTRON_NETWORK = {
'enable_lb': True,
'enable_firewall': True,
'enable_quotas': True,
'enable_vpn': True,
# The profile_support option is used to detect if an external router can be
# configured via the dashboard. When using specific plugins the
# profile_support can be turned on if needed.
'profile_support': None,
#'profile_support': 'cisco',
c.     Press Esc to quit insert mode, and enter :wq to exit the vi editor and save the local_settings file.
3.     Edit the ml2_sec_conf_h3c.ini configuration file.
a.     Use the vi editor to open the ml2_sec_conf_h3c.ini configuration file.
sdn@ubuntu:~$ sudo vi /etc/neutron/plugins/ml2/ml2_sec_conf_h3c.ini
b.     Press I to switch to insert mode and configure the parameters in the configuration file as follows. For more information about the parameters, see "ml2_sec_conf_h3c.ini"
[SEC_SDNCONTROLLER]
url = https://127.0.0.1:10443
username = admin
domain = sdn
timeout = 1800
retry = 10
white_list = False
firewall_type = CGSR
fw_share_by_tenant = False
lb_type = CGSR
resource_mode = CORE_GATEWAY
resource_share_count = 1
auto_create_resource = True
nfv_ha = True
firewall_force_audit = False
sec_output_json_log = False
lb_enable_snat = False
cgsr_fw_context_limit = 0
enable_firewall_metadata = False
lb_member_slow_shutdown = False
enable_multi_gateways = False
enable_multi_segments = False
tenant_gateway_name = None
tenant_gw_selection_strategy = match_first
enable_router_nat_without_firewall = False
directly_external = OFF
directly_external_suffix = DMZ
sec_agent_enable = True
lb_resource_mode = SP
enable_lb_xff = False
enable_lb_certchain = True
enable_firewall_object_group = False
c.     Press Esc to quit insert mode, and enter :wq to exit the vi editor and save the ml2_sec_conf_h3c.ini file.
¡     Delete the username, password, and domain parameters for SEC_SDNCONTROLLER in the ml2_conf_h3c.ini configuration file.
7.     (Optional.) For the firewall to operate in h3c-sec-agent mode, you can restart the h3c-sec-agent process.
sdn@ubuntu:~$ sudo service h3c-sec-agent restart
h3c-sec-agent stop/waiting
h3c-sec-agent start/running, process 4585
Verifying the installation
1.     Verify that the SeerEngine-DC OpenStack security plug-ins is installed correctly. If the version number of the plug-ins is displayed correctly, the installation is successful.
SeerEngine-DC-SEC-PLUGIN===E3603P01
2.     Verify that the neutron-server service has been enabled. If the service is in running state, the service is enabled successfully.
IMPORTANT
IMPORTANT:
Before verifying the enabling status of the neutral-server service, check whether the security plug-in configuration directory (--config-dir /usr/share/neutron/server) is contained in the neutron-server service startup path. If that directory is not contained in the neutron-server service startup path, contact the technical engineer to modify the startup file of the neutral-server service.
3.     (Optional.) For the firewall to operate in h3c-sec-agent mode, verify that the h3c-sec-agent service is enabled. If the service is running state, the service is enabled.
sdn@ubuntu:~$ sudo service h3c-sec-agent status
h3c-sec-agent start/running, process 1855
neutron.conf
Parameter
service_plugins
Extension plug-ins loaded to OpenStack.
The security plug-in supports the following firewall services, and you can change the values as follows:
·     For the open-source firewall plug-in agent mode, change firewall in the value to firewall.
·     If deployment of firewall policies and rules takes a long time, change firewall in the value to fwaas_h3c.
·     For the open-source firewall plug-in not in agent mode, change firewall in the value to firewall_h3c. (After you execute the h3c-secplugin controller install command to install the security plug-in, the h3c-sec-agent process will automatically run. When the security plug-in is configured to operate in agentless mode, you must execute the systemctl stop h3c-sec-agent and systemctl disable h3c-sec-agent commands to stop the h3c-sec-agent process and disable automatic startup for the process, respectively.)
To configure firewall services, add h3c_security_core to the value.
service_provider
admin_user
admin_password
Parameter
url
URL address for accessing Unified Platform, for example, https://127.0.0.1:10443.
username
password
domain
Name of the domain where the SeerEngine-DC controller resides, for example, sdn.
timeout
The amount of time that the Neutron server waits for a response from the SeerEngine-DC controller in seconds, for example, 1800 seconds.
retry
Times of sending connection requests, for example, 10.
white_list
·     True—Enable.
·     False—Disable.
firewall_type
Type of the firewalls created on the controller:
·     CGSR—Context-based gateway service type firewall, each using an independent context. This firewall type is available only when the value of the resource_mode parameter is CORE_GATEWAY.
·     CGSR_SHARE—Context-based gateway service type firewall, all using the same context even if they belong to different tenants. This firewall type is available only when the value of the resource_mode parameter is CORE_GATEWAY.
·     CGSR_SHARE_BY_COUNT—Context-based gateway service type firewall, all using the same context when the number of contexts reaches the threshold set by the cgsr_fw_context_limit parameter. This firewall type is available only when the value of the resource_mode parameter is CORE_GATEWAY. Only the Pike plug-ins support this firewall type.
·     NFV_CGSR—VNF-based gateway service type firewall, each using an independent VNF. This firewall type is available only when the value of the resource_mode parameter is CORE_GATEWAY.
fw_share_by_tenant
Whether to enable exclusive use of a gateway service type firewall context by a single tenant and allow the context to be shared by service resources of the tenant when the firewall type is CGSR_SHARE.
lb_type
Type of the load balancers created on the controller.
·     CGSRGateway service type load balancer on a context. This type of load balancers are available only when the value of the resource_mode parameter is set to CORE_GATEWAY. When the value of the lb_resource_mode parameter is SP, CGSR type load balancers that belong to one tenant use the same context. CGSR type load balancers that belong to different tenants use different contexts. When the value of the lb_resource_mode parameter is MP, CGSR type load balancers that belong to one tenant and are bound to the same gateway use the same context. CGSR type load balancers that belong to different tenants use different contexts.
·     CGSR_SHAREGateway service type load balancer on a context. This type of load balancers are available only when the value for the resource_mode parameter is set to CORE_GATEWAY. When the value for the lb_resource_mode parameter is SP, all CGSR_SHARE type load balancers use the same context even if they belong to different tenants. When the value for the lb_resource_mode parameter is MP, CGSR_SHARE type load balancers bound to the same gateway use the same context and CGSR_SHARE type load balancers bound to different gateways use different contexts regardless of the tenants to which the CGSR_SHARE type load balancers belong.
·     NFV_CGSRGateway service type load balancer on a VNF. This type of load balancers are available only when the value of the resource_mode parameter is set to CORE_GATEWAY. When the value of the lb_resource_mode parameter is SP, NFV_CGSR type load balancers that belong to one tenant use the same VNF. NFV_CGSR type load balancers that belong to different tenants use different VNFs. When the value of the lb_resource_mode parameter is MP, NFV_CGSR type load balancers that belong to one tenant and are bound to the same gateway use the same VNF. NFV_CGSR type load balancers that belong to different tenants use different VNFs.
resource_mode
Type of the resource created on the controller. The available values are as follows:
·     CORE_GATEWAY—Gateway service resource.
·     NFV—VNF resource. This parameter has been obsoleted.
Maximum times that the resource node can be shared by resources.
The value is in the range of 1 to 65535. The default value is 1, indicating that the resources cannot be shared.
Whether to enable or disable the automatic resources creation feature.
·     True—Enable.
·     False—Disable.
nfv_ha
Whether the NFV and NFV_SHARE resources support stack.
·     True—Support.
·     False—Do not support.
Whether to use the OpenStack Neutron username and password to communicate with the SeerEngine-DC controller.
·     True—Use.
·     False—Do not use.
Whether to audit firewall policies synchronized to the controller by OpenStack. The default value is True for OpenStack Kilo 2015.1 and False for other OpenStack versions.
·     TrueAudits firewall policies synchronized to the controller by OpenStack. The auditing state of the synchronized policies on the controller is True (audited).
·     FalseDoes not audit firewall policies synchronized to the controller by OpenStack. The synchronized policies on the controller retain their previous auditing state.
sec_output_json_log
Whether to output REST API messages between the SeerEngine-DC Neutron security plugins and SeerEngine-DC controller to the OpenStack operating logs in JSON format.
·     True—Enable.
·     False—Disable.
lb_enable_snat
Whether to enable or disable Source Network Address Translation (SNAT) for load balancers on the SeerEngine-DC controller.
·     True—Enable.
·     False—Disable.
As a best practice, set the parameter value to False if you deploy the plug-in on CloudOS.
vendor_rpc_topic
enable_https
·     True—Enable.
·     False—Disable.
Save location for the CA certificate of the controller. As a best practice, save the CA certificate in the /usr/share/neutron directory.
Save location for the Cert certificate of the controller. As a best practice, save the Cert certificate in the /usr/share/neutron directory.
Save location for the Key certificate of the controller. As a best practice, save the Cert certificate in the /usr/share/neutron directory.
Context threshold for context-based gateway service type firewalls. The value is an integer. When the threshold is reached, all the context-based gateway service type firewalls use the same context.
This parameter takes effect only when the value of the firewall_type parameter is CGSR_SHARE_BY_COUNT.
enable_iam_auth
·     True—Enable.
·     False—Disable.
Only the Mitaka and Newton plug-ins support this parameter.
Whether to allow the CloudOS platform to issue firewall-related fields such as the resource pool name to the controller.
This parameter is used only for communication with the CloudOS platform.
Whether to enable slow shutdown when creating an LB real server.
·     True—Enable.
·     False—Disable.
Whether to enable the multi-gateway mode for the tenant.
·     True—Enable the multi-gateway mode for the tenant. In an OpenStack environment without the Segments configuration, this setting enables different vRouters to access the external network over different gateways.
·     False—Not enable the multi-gateway mode for the tenant.
Only OpenStack Pike, Queens, and Rocky support this parameter.
For this parameter to take effect, add h3c_security_core to the value of the service_plugins parameter.
Whether to enable multiple outbound interfaces, allowing the vRouter to access the external network from multiple outbound interfaces. The default value is False.
To enable multiple outbound interfaces, configure the following settings:
·     Set the value of this parameter to True.
·     Set the value of the network_force_flat parameter to False.
·     Access the /etc/neutron/plugins/ml2/ml2_conf.ini file on the controller node and specify the controller's gateway name for the network_vlan_ranges parameter.
tenant_gateway_name
Name of the gateway to which the tenant is bound. The default value is None.
When the value of the tenant_gw_selection_strategy parameter is match_gateway_name. You must specify the name of an existing gateway on the controller side.
Gateway selection strategy for the tenant.
·     match_first—Select the first gateway.
·     match_gateway_name—Take effect together with the tenant_gateway_name parameter.
Whether to enable NAT when no firewall is configured for the tenant.
·     True—Enable NAT when no firewall is configured. This setting automatically creates default firewall resources to implement NAT if the vRouter has been bound to an external network.
·     False—Not enable NAT when no firewall is configured.
directly_external
Whether traffic to the external network is directly forwarded by the gateway. The default value is OFF.
·     ANY—Traffic to the external network is directly forwarded by the gateway to the external network.
·     OFF—Traffic to the external network is forwarded by the gateway to the firewall and then to the external network.
·     SUFFIX—Traffic that matches the vRouter name suffix is forwarded by the gateway to the firewall and then to the external network.
vRouter name suffix (DMZ for example). This parameter is available only when you set the value of the directly_external parameter to SUFFIX.
When you change the vRouter name, make sure you understand the impact on this parameter.
sec_agent_enable
Whether to enable the h3c-sec-agent process. The default value is True.
This parameter is used and takes effect only for security plug-in upgrade.
Value change of this parameter does not take effect immediately. After you set the value to True, you must install the security plug-in and execute the h3c-secplugin controller install command to enable the process.
lb_resource_mode
Resource pool mode of LB service resources.
·     SP—All gateways share the same LB resource pool.
·     MP—Each gateway uses an LB resource pool.
The default value is SP.
enable_lb_xff
Whether to enable XFF transparent transmission for LB listeners.
·     True—Enable.
·     False—Disable.
When the value is True and the listener protocol is HTTP or TERMINATED_HTTPS, a newly created listener is enabled with XFF transparent transmission by default, and the client's IP address is transparently transmitted to the server encapsulated in the X-Forward-For field of the HTTP header.
enable_lb_certchain
Whether to enable the SSL server end to send the complete certificate chain for SSL negotiation.
·     true—Enable.
·     false—Disable.
The default value is true.
Whether to enable the firewall object group feature of the plug-in. The default value is False. If you set the value to True, a firewall object group can be created on the cloud platform through the plug-in.
Only OpenStack Rocky supports this parameter.
To use this feature, configure compatibility settings on the cloud platform. For information about how to configure the compatibility settings, contact Technical Support.
(Optional.) Upgrading the SeerEngine-DC Neutron security plug-ins
To upgrade the SeerEngine-DC Neutron security plug-ins, first remove the old version and then install the new version.
CAUTION
CAUTION:
Service might be interrupted during the upgrade. Before performing an upgrade, be sure you fully understand its impact on services.
IMPORTANT
IMPORTANT:
The default parameter settings vary depending on the version of SeerEngine-DC Neutron security plug-ins. Modify the default parameter settings for SeerEngine-DC Neutron security plug-ins to ensure that the plug-ins have the same parameter settings before and after the upgrade.
To upgrade SeerEngine-DC Neutron security plug-ins:
1.     Uninstall the SeerEngine-DC Neutron security plug-ins.
sdn@ubuntu:~$ sudo h3c-secplugin controller uninstall
2.     Uninstall the SeerEngine-DC OpenStack software package.
sdn@ubuntu:~$ sudo pip uninstall seerengine-dc-sec-plugin
Uninstalling SeerEngine-DC-SEC-PLUGIN-E3603P01:
  /usr/bin/h3c-secplugin
  /usr/lib/python2.7/site-packages/SeerEngine_DC_SEC_PLUGIN-E3603P01-py2.7.egg
Proceed (y/n)? y
  Successfully uninstalled SeerEngine-DC-SEC-PLUGIN-E3603P01
3.     Install the new version of SeerEngine-DC Neutron security plug-ins.
For more information, see "Installing the security plug-ins on the controller node."
Comparing and synchronizing firewall resource information between the cloud platform and controller
Only OpenStack Pike supports this task.
This function is supported on OpenStack scenario only.
To compare and synchronize firewall resource information between the cloud platform and controller:
1.     Execute the h3c-secplugin-fw-extension compare --file [absolute path] file name.csv command to compare firewall resource information between the cloud platform and controller.
¡     If you do not specify the --file [absolute path] file name.csv option the comparison result is saved to the /var/log/neutron/compare_sec_data-time.csv file, where time indicates the comparison start time.
¡     If you specify the --file [absolute path] file name.csv option, the comparison result is saved to the specified file. If you do not specify an absolute path, the result is saved to /var/log/neutron/file name.csv.
The comparison result file contains the following fields:
¡     Resource—Resource type.
¡     Name—Resource name.
¡     Id—Resource ID.
¡     Tenant_id—Tenant ID of the resource.
¡     Tenant_name—Tenant name of the resource.
¡     Status—Comparison result.
-     lost—Less resources on the controller. You must add resources to the controller.
-     different—Different resources on the controller than the cloud platform. You must update resources on the controller.
-     surplus—More resources on the controller. You must remove excessive resources from the controller.
2.     Execute the h3c-secplugin-fw-extension sync –file comparison result file name.csv command. If the comparison result file is in the /var/log/neutron/ path, enter the file name directly. If the comparison result file is in another path, enter the absolute file path.
After the synchronization is complete, a synchronization result file /var/log/neutron/sync_sec_data-time.csv is generated, where time indicates the synchronization start time.
CAUTION
CAUTION:
Do not add or edit information in the synchronize result file.
Comparing and synchronizing LB resource information between the cloud platform and controller
Only OpenStack Pike, Queens, and Rocky support this task.
To compare and synchronize LB resource information between the cloud platform and controller:
1.     Execute the h3c-secplugin-lb-extension compare --file [absolute path] file name.csv command to compare LB resource information between the cloud platform and controller.
¡     If you do not specify the file [absolute path] file name.csv option, the comparison result is saved to the /var/log/neutron/compare_sec_lbv2_data-time.csv file, where time indicates the comparison start time.
¡     If you specify the file [absolute path] file name.csv option, the comparison result is saved to the specified file. If you do not specify an absolute path, the result is saved to /var/log/neutron/file name.csv.
¡     Id—Resource ID.
2.     Execute the h3c-secplugin-lb-extension  sync --file comparison result file name.csv command to synchronize LB resource information on the controller with that on the cloud platform. If the comparison result file is in the /var/log/neutron/ path, enter the file name directly. If the comparison result file is in another path, enter the absolute file path.
After the synchronization is complete, a synchronization result file /var/log/neutron/sync_sec_lb_data-time.csv is generated, where time indicates the synchronization start time.
CAUTION
CAUTION:
Do not add or edit information in the synchronization result file.
Upgrading non-converged plug-ins to converged plug-ins
1.     Upgrade the controller to a version that supports converged plug-ins.
2.     Remove non-converged plug-ins:
a.     Remove the plug-ins on the controller node:
-     Versions earlier than E3702
sdn@ubuntu:~$ sudo h3c-vcfplugin controller uninstall
-     E3702 and its later versions
b.     Remove the plug-ins on the compute node:
sdn@ubuntu:~$ sudo h3c-vcfplugin compute uninstall
sdn@ubuntu:~$ sudo h3c-vcfplugin openvswitch uninstall
c.     Remove the plug-ins on the network node:
sdn@ubuntu:~$ sudo h3c-vcfplugin dhcp uninstall
sdn@ubuntu:~$ sudo h3c-vcfplugin metadata uninstall
sdn@ubuntu:~$ sudo h3c-sdnplugin dhcp uninstall
sdn@ubuntu:~$ sudo h3c-sdnplugin metadata uninstall
d.     Remove the software packages from all nodes:
IMPORTANT
IMPORTANT:
Commands for removing plug-ins vary depending on the software version.
3.     Install converged plug-ins:
a.     Install converged plug-ins and security plug-ins as described in "Installing SeerEngine-DC Neutron plug-ins and patches on OpenStack" and "Installing the SeerEngine-DC Neutron security plug-ins on OpenStack," respectively.
b.     Use the vi editor to open the ml2_conf.ini configuration file.
sdn@ubuntu:~$ sudo vi /etc/neutron/plugins/ml2/ml2_conf.ini
c.     Press I to switch to insert mode, and set the parameters in the ml2_conf.ini configuration file. Press Esc to quit insert mode, and enter :wq to exit the vi editor and save the ml2_conf.ini file.
[SDNCONTROLLER]
enable_sdnc_rpc = False
sdnc_rpc_url = ws://127.0.0.1:1080
sdnc_rpc_ping_interval = 60
websocket_fragment_size = 102400
cloud_region_name = default
ml2_conf.ini
enable_sdnc_rpc
Set the value to True when Metadata is enabled or DHCP fail-safe is supported.
sdnc_rpc_url
Set the value to the IP address and WebSocket type interface number of Unified Platform when Metadata is enabled or DHCP fail-safe is supported.
cloud_region_name
If one cloud platform is connected to the controller, you can modify this parameter when the cloud platform is connected to the controller for the first time after upgrade and no tenant resources are newly created on the controller. Make sure the value of this parameter is the same as the name configured on the controller and configure the cloud platform as the default platform.
If multiple cloud platforms are connected to the controller, the rules for the single cloud platform interoperability scenario applies for the first cloud platform. For the other cloud platforms, you must change the value of this parameter to be the same as the value for these cloud platforms, and make sure they are the same as those configured on the controller.
This parameter cannot be modified after the cloud platforms are connected to the controller. You must specify different values for the vxlan vni_ranges parameter for different cloud platforms.
d.     Delete the backup file of a non-converged plug-in (for example, ml2_conf_h3c.ini.bak or ml2_conf_h3c.ini.h3c_bak) or edit its extension. This practice can prevent the system from editing or initializing some parameters for the security plug-in next time the security plug-in is upgraded.
4.     Configure parameters on the controller:
Some parameters in the ml2_conf_h3c.ini configuration file for non-converged plug-ins have been moved to the Web interface on the controller. After installing converged plug-ins, you must change the values of the parameters to the values before upgrade.
a.     Save the ml2_conf_h3c.ini.bak or ml2_conf_h3c.ini.h3c_bak file in the /etc/neutron/plugins/ml2 directory of the controller node.
b.     Log in to the controller, click Automation on the top navigation bar, and then select Virtual Networking > OpenStack from the left navigation pane. Click Add OpenStack-Based Cloud Platform, and then click the Parameter Settings tab to edit the parameters based on the information in the ml2_conf_h3c.ini.bak or ml2_conf_h3c.ini.h3c_bak file.
Table 5 Mapping between parameters on the controller and in the configuration file
Parameters in the ml2_conf_h3c.ini file before upgrade
Parameters on the controller after upgrade
cloud_region_name
Name. After the configuration is complete, you must configure the name of the first connected cloud platform as the default cloud platform on the Web interface of the controller.
hybrid_vnic
VLAN to VXLAN Conversion
enable_metadata: True
enable_dhcp_hierarchical_port_binding: True
Network Node Access Policy: VLAN
enable_dhcp_hierarchical_port_binding: False
Network Node Access Policy: VXLAN
enable_metadata: False
Network Node Access Policy: No Access
ip_mac_binding
IP-MAC Anti-Spoofing
directly_external: OFF
Firewall: On for All
directly_external: ANY
Firewall: Off for All
directly_external: SUFFIX
directly_external_suffix: name where name represents the suffix of the name of the vRouter.
Firewall: Off for vRouters Matching Suffix
tenant_gw_selection_strategy: match_gateway_name
tenant_gateway_name: name, where name represents the name of the boarder gateway.
External Connectivity Settings: Single-Segment
Tenant Border Gateway Policy: Match Boarder Gateway Name
enable_multi_gateway: True
Tenant Border Gateway Policy: Match External Network Name of vRouter
enable_multi_segments: True
External Connectivity Settings: Multi-Segment
Tenant Border Gateway Policy: Match Physical Network Name of vRouter External Network
network_force_flat
Forcibly Convert External Network to Flat Network
dhcp_lease_time
DHCP Lease Duration
generate_vrf_based_on_router_name: False
VRF Name Generation Method on vRouter: Auto
generate_vrf_based_on_router_name=True
VRF Name Generation Method on vRouter: Use vRouter Name
vds_name
Default VDS name, required. Configuration path: Automation > Data Center Network > Common Network Settings > Virtual Distributed Switch page, click Settings
empty_rule_action
Empty Rule Action of Security Policy
enable_network_l3vni
Automatic Allocation of L3VNIs for External Networks
deploy_network_resource_gateway
Preconfigure Border Gateway for External Network
IMPORTANT
IMPORTANT:
Make sure a VXLAN pool exists on the controller after the upgrade. If no VXLAN pools exist or the VXLAN pool resources are insufficient, add a new VXLAN pool and make sure the VXLAN pool range does not contain the segment IDs of the existing vRouters.
5.     Restart the neutron-server service.
sdn@ubuntu:~$ sudo service neutron-server restart
Comparing and synchronizing resource information between the controller and cloud platform
This function is not supported in the following scenarios:
·     H3C CloudOS network-based overlay VXLAN environment.
·     Third-party cloud platforms except for the Ericsson cloud and OpenStack.
This feature is not applicable to extended resources (vpc-connection, bgpneighbor, exroute, trunk, and taas) except for those provided by H3C proprietary plug-ins and Ericsson cloud plug-ins
Only Rocky, Queens, Pike, Newton, and Mitaka plug-ins support this task. And OpenStack Kilo and Liberty do not support this task
To compare and synchronize resource information between the controller and cloud platform:
1.     Execute the h3c-sdnplugin-extension compare --file [absolute path] file name.csv command to compare resource information between the controller and cloud platform.
¡     If you do not specify --file [absolute path] filename.csv, the comparison result is saved to the /var/log/neutron/'compare_data-time.csv file, where time indicates the comparison start time.
¡     If you specify --file [absolute path] filename.csv, the comparison result is saved to the specified file. If you do not specify an absolute path, the result is saved to /var/log/neutron/file name.csv.
¡     Id—Resource ID.
If virtual router link is created on the CloudOS, when the plug-ins compare resource information, there will be VPC data only on the controller side, which is a normal phenomenon.
2.     Execute the h3c-sdnplugin-extension sync --file comparison result file name.csv command. If the comparison result file is in the /var/log/neutron/ path, enter the file name directly. If the comparison result file is in another path, enter the absolute file path.
If you need to specify the synchronization result file storage path, you can use the command h3c-sdnplugin-extension sync --file comparison result file name.csv --sync_result_file synchronization result file name.csv. If you want to save the synchronization result file under /var/log/neutron/, you can directly enter the file name, otherwise please enter the absolute path file name.
After you set the value of the enable_security_group parameter to False, security groups and security groups bound to vPorts might exist on the controller when you perform the comparison operation. To resolve the issue, perform the synchronization twice.
After the command is executed, the system displays resource statistics and prompts for your confirmation to start the synchronization. The system starts the synchronization only after receiving your confirmation for twice.
After synchronization is completed, if the --sync_result_file is specified, the synchronization result will be saved to the specified file in .csv format. Otherwise, the default synchronization result file will be generated: /var/log/neutron/sync_data-time.csv, where time indicating the synchronization start time.
CAUTION
CAUTION:
·     Do not add or edit information in the synchronize result file.
·     To avoid anomaly caused by misoperations, examine and compare the result file and resource statistics carefully.
FAQ
The Python tools cannot be installed using the yum command when a proxy server is used for Internet access. What should I do?
Configure HTTP proxy by performing the following steps:
1.     Make sure the server or the virtual machine can correctly access the HTTP proxy server.
2.     At the CLI of the Ubuntu, use the vi editor to open the apt.conf configuration file. If the apt.conf configuration file does not exist, this step creates the file.
sdn@ubuntu:~$ sudo vi /etc/apt/apt.conf
3.     Press I to switch to insert mode, and provide HTTP proxy information as follows:
¡     If the server does not require authentication, enter HTTP proxy information in the following format:
Acquire::http::proxy = http://yourproxyaddress:proxyport
¡     If the server requires authentication, enter HTTP proxy information in the following format:
Acquire::http::proxy = http:// username:password@yourproxyaddress:proxyport, for example, Acquire::http::proxy "http://sdn:[email protected]:8080
Table 6 describes the arguments in HTTP proxy information.
Table 6 Arguments in HTTP proxy information
username
Username for logging in to the proxy server, for example, sdn.
password
Password for logging in to the proxy server, for example, 123456.
yourproxyaddress
IP address of the proxy server, for example, 172.25.1.1.
proxyport
Port number of the proxy server, for example, 8080.
4.     Press Esc to quit insert mode, and enter :wq to exit the vi editor and save the apt.conf file.
Live migration of a VM to a specified destination host failed because of a service exception on the destination host. What should I do?
To resolve the issue:
1.     View the VM state. If the live migration operation has been rolled back, the VM is in normal state, and services are not affected, you can perform live migration again after the destination host recovers.
2.     Compare resource information to identify whether residual configuration exists on the destination host. If residual configuration exists, determine whether services will be affected.
¡     If services will not be affected, retain the residual configuration.
¡     If services will be affected, contact the technical support to delete the residual configuration.
The Inter X700 Ethernet network adapter series fails to receive LLDP messages. What should I do?
Use the following procedure to resolve the issue. An enp61s0f3 Ethernet network adapter is used as an example.
1.     View detailed information about the Ethernet network adapter and record the value for the bus-info field.
sdn@ubuntu:~$ ethtool -i enp61s0f3
driver: i40e
version: 2.8.20-k
firmware-version: 3.33 0x80000f0c 1.1767.0
expansion-rom-version:
bus-info: 0000:3d:00.3
supports-statistics: yes
supports-test: yes
supports-eeprom-access: yes
supports-register-dump: yes
supports-priv-flags: yes
2.     Use one of the following solutions:
¡     Solution 1. If this solution fails, use solution 2.
# Execute the following command:
sdn@ubuntu:~$ sudo ethtool --set-priv-flags enp61s0f3  disable-fw-lldp on
# Identify whether the value for the disable-fw-lldp field is on.
sdn@ubuntu:~$ ethtool --show-priv-flags enp61s0f3  | grep lldp
disable-fw-lldp       : on
If the value is on, the network adapter then can receive LLDP messages. For this command to remain effective after a system restart, you must write this command into the user-defined startup program file.
# Open the self-defined startup program file.
sdn@ubuntu:~$ sudo vi /etc/rc.local
# Press I to switch to insert mode, and add this command to the file. Then press Esc to quit insert mode, and enter :wq to exit the vi editor and save the file.
Make sure this command line is configured before the exit 0 line.
¡     Solution 2.
# Execute the echo "lldp stop" > /sys/kernel/debug/i40e/bus-info/command command. Enter the recorded bus info value for the network adapter, and add a backslash (\) before each ":".
sdn@ubuntu:~$ sudo -i
sdn@ubuntu:~$ echo "lldp stop" > /sys/kernel/debug/i40e/0000\:3d\:00.3/command
The network adapter can receive LLDP messages after this command is executed. For this command to remain effective after a system restart, you must write this command into the user-defined startup program file.
# Press I to switch to insert mode, and add this command to the file. Then Press Esc to quit insert mode, and enter :wq to exit the vi editor and save the file.
The trunk function is unavailable after I upgrade a non-converged OpenStack Mitaka plug-in to a converged one and configure h3c_trunk. What should I do?
1.     Access the database.
[root@controller ~]# mysql u<useraname> -p
Enter password:
MariaDB [(none)]> USE neutron;
2.     Disable foreign key constraints.
MariaDB [neutron]> SET FOREIGN_KEY_CHECKS=0;
Query OK, 0 rows affected (0.00 sec)
3.     Move the data in h3c_trunk to h3c_trunks.
MariaDB [neutron]> INSERT INTO h3c_trunks (SELECT * FROM h3c_trunk);
Query OK, 1 row affected (0.01 sec)
Records: 1 Duplicates: 0 Warnings: 0
4.     Verify that the data in h3c_trunk has been added to h3c_trunks.
MariaDB [neutron]> SELECT * FROM h3c_trunks;
5.     Delete the foreign key in h3c_subports.
ALTER TABLE h3c_subports DROP FOREIGN KEY h3c_subports_ibfk_1;
6.     Add a new foreign key in h3c_subports.
MariaDB [neutron]> ALTER TABLE `h3c_subports` ADD CONSTRAINT `h3c_subports_ibfk_1`  FOREIGN KEY  (`trunk_id`) REFERENCES `h3c_trunks`(`id`) ON DELETE CASCADE;
Query OK, 0 rows affected (0.04 sec)
Records: 0 Duplicates: 0 Warnings: 0
7.     Enable foreign key constraints.
MariaDB [neutron]> SET FOREIGN_KEY_CHECKS=1;
If information for connecting the Neutron database is encrypted, the Neutron plug-ins might fail to inherit the portforwardings data table because of failure to access the database. What should I do?
1.     Uninstall the Neutron plug-ins. For information about uninstalling the Neutron plug-ins, see "Remove the SeerEngine-DC Neutron plug-ins.."
2.     Reinstall the Neutron plug-ins and specify the db_connection parameter.
To obtain the value of the db_connection parameter, access the neutron.conf file and identify the value of the connection parameter under the database group. The password for accessing the Neutron database is encrypted in the value. Change it to the unencrypted password.
[root@localhost ~]# h3c-sdnplugin controller install --db_connection mysql+pymysql://neutron:123456@controller/neutron
connection = mysql+pymysql://neutron:123456@controller/neutron
