10-MPLS
HomeSupportRoutersCR16000-M SeriesDiagnose & MaintainAlarms ReferencesH3C CR16000-M Routers Alarm Reference-R8530Pxx-6W10010-MPLS
02-HH3C-L2VPN-MIB
02-HH3C-L2VPN-MIB 199.24 KB
HH3C-L2VPN-MIB
About this MIB
Use this MIB to obtain L2VPN configuration information. This MIB also contains notifications about PW state changes.
MIB file name
hh3c-l2vpn.mib
Notifications
hh3cL2vpnPwSwitchPtoB
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.162.0.1
Traffic is switched from the primary PW to the backup PW.
Error
Warning
1.3.6.1.4.1.25506.2.162.0.2 (hh3cL2vpnPwSwitchBtoP)
OFF
Notification triggers
This notification is generated when the traffic is switched from the primary PW to the backup PW.
System impact
Millisecond-level packet loss will occur when the traffic is switched from the primary PW to the backup PW.
Status control
ON
CLI: Use the snmp-agent trap enable l2vpn pw-switch command.
OFF
CLI: Use the undo snmp-agent trap enable l2vpn pw-switch command.
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.162.3.4.1.1 (hh3cL2vpnXcgPwIndex)
PW index associated with the cross-connect.
hh3cL2vpnXcgPwIndex
hh3cL2vpnXcgName
hh3cL2vpnXcgConnName
Unsigned32
As per the MIB.
1.3.6.1.4.1.25506.2.162.3.4.1.5 (hh3cL2vpnXcgPwPeerIp)
IP address of the PW associated with the cross-connect.
hh3cL2vpnXcgPwIndex
hh3cL2vpnXcgName
IpAddress
As per the MIB.
1.3.6.1.4.1.25506.2.162.3.4.1.6 (hh3cL2vpnXcgPwPwID)
ID of the PW associated with the cross-connect.
hh3cL2vpnXcgPwIndex
hh3cL2vpnXcgName
Unsigned32
As per the MIB.
Recommended action
No action is required.
Basic information
OID
Event
Severity
Default status
Traffic is switched from the backup PW to the primary PW.
Recovery
Warning
N/A (N/A)
OFF
This notification is generated when the traffic is switched from the backup PW to the primary PW.
System impact
Millisecond-level packet loss will occur when the traffic is switched from the backup PW to the primary PW.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
hh3cL2vpnXcgPwIndex
hh3cL2vpnXcgName
Unsigned32
As per the MIB.
hh3cL2vpnXcgPwIndex
hh3cL2vpnXcgName
IpAddress
As per the MIB.
hh3cL2vpnXcgPwIndex
hh3cL2vpnXcgName
Unsigned32
As per the MIB.
Recommended action
hh3cL2vpnMacLimitMaxPw
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.162.0.5
The number of MAC addresses learned on a PW reached the upper threshold value.
Error
Warning
1.3.6.1.4.1.25506.2.162.0.6 (hh3cL2vpnMacLimitMaxPw_Clear)
OFF
This notification is generated when the number of MAC addresses learned on a PW exceeds the limit.
System impact
No new MAC addresses can be learned on the PW.
Status control
ON
CLI: Use the snmp-agent trap enable l2vpn maclimit-pw command.
OFF
CLI: Use the undo snmp-agent trap enable l2vpn maclimit-pw command.
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.162.2.3.1.1 (hh3cL2vpnMacLimitPwVsiIndex)
VSI index.
hh3cL2vpnMacLimitPwVsiIndex hh3cL2vpnMacLimitPwLinkID
Unsigned32
As per the MIB.
1.3.6.1.4.1.25506.2.162.2.3.1.2
 (hh3cL2vpnMacLimitPwLinkID)
PW index.
Unsigned32
As per the MIB.
1.3.6.1.4.1.25506.2.162.2.3.1.3 (hh3cL2vpnMacLimitPwVsiName)
VSI name.
DisplayString
As per the MIB.
Recommended action
To resolve this issue:
1.Use the display l2vpn mac-address vsi vsi-name pw command to display information about MAC address entries learned on the PW.
2.From the command output, identify the unneeded static MAC address entries and then delete them. Alternatively, wait for dynamic MAC address entries to age out.
hh3cL2vpnMacLimitMaxPwClear
Basic information
OID
Event
Severity
Default status
The number of MAC addresses learned on a PW dropped below the lower threshold value.
Recovery
Warning
N/A (N/A)
OFF
This notification is generated when the number of MAC addresses learned on a PW drops below the lower threshold value.
System impact
No impact on services.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
VSI index.
Unsigned32
As per the MIB.
PW index.
Unsigned32
As per the MIB.
VSI name.
DisplayString
As per the MIB.
Recommended action
hh3cL2vpnMacLimitMaxAc
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.162.0.3
The number of MAC addresses learned on an AC reached the maximum.
Error
Warning
1.3.6.1.4.1.25506.2.162.0.4 (hh3cL2vpnMacLimitMaxAcClear)
OFF
This notification is generated when the number of MAC addresses learned on an AC exceeds the maximum.
System impact
The AC has learned the maximum number of MAC addresses. It cannot learn new MAC addresses.
Status control
ON
CLI: Use the snmp-agent trap enable l2vpn maclimit-ac command.
OFF
CLI: Use the undo snmp-agent trap enable l2vpn maclimit-ac command.
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.162.4.1.1.3 (hh3cL2vpnAcIfName)
Name of the interface (AC).
hh3cL2vpnAcIfIndex hh3cL2vpnAcSrvId
DisplayString
As per the MIB.
1.3.6.1.4.1.25506.2.162.4.1.1.4 (hh3cL2vpnAcVsiName)
Name of the VSI bound to the AC.
DisplayString
As per the MIB.
Recommended action
1.Use the display l2vpn mac-address vsi vsi-name ac command to display information about MAC address entries learned on the AC.
2.From the command output, identify the unneeded static MAC address entries and then delete them. Or, wait for dynamic MAC address entries to age out.
Basic information
OID
Event
Severity
Default status
The number of MAC addresses learned on an AC dropped below the lower threshold value.
Recovery
Warning
N/A (N/A)
OFF
This notification is generated when the number of MAC addresses learned on an AC drops below the lower threshold value.
System impact
No negative impact on services.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
DisplayString
As per the MIB.
DisplayString
As per the MIB.
Recommended action
hh3cL2vpnPwParaMisMatch
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.162.0.7
PW parameter settings do not match.
Error
Warning
1.3.6.1.4.1.25506.2.162.0.8 (hh3cL2vpnPwParaMatch)
OFF
This notification is generated when the PW negotiation parameter settings are inconsistent on the two ends of the PW.
System impact
The PW cannot be established or cannot forward service packets correctly.
Status control
ON
CLI: Use the snmp-agent trap enable l2vpn pw-parameter command.
OFF
CLI: Use the undo snmp-agent trap enable l2vpn pw-parameter command.
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.162.5.1.1.6 (hh3cL2vpnPwVsiName)
Name of the VSI to which the PW is bound.
hh3cL2vpnPwPeerIp
hh3cL2vpnPwId
DisplayString
As per the MIB.
1.3.6.1.4.1.25506.2.162.5.1.1.7 (hh3cL2vpnPwXcgName)
Name of the cross-connect group to which the PW is bound.
hh3cL2vpnPwPeerIp
hh3cL2vpnPwId
DisplayString
As per the MIB.
1.3.6.1.4.1.25506.2.162.5.1.1.8 (hh3cL2vpnPwXcgConnName)
Name of the cross-connect to which the PW is bound.
hh3cL2vpnPwPeerIp
hh3cL2vpnPwId
DisplayString
As per the MIB.
Recommended action
1.On the two peers of the PW, use the display l2vpn ldp verbose command to display detailed information about PW labels advertised by LDP.
2.From the command output, check the values for the PW Type, Control Word, and MTU fields.
3.If the values of those fields are inconsistent on the two peers of the PW, edit the settings of the corresponding parameters to make sure the two peers use the same settings.
Basic information
OID
Event
Severity
Default status
PW parameter settings are consistent.
Recovery
Warning
N/A (N/A)
OFF
This notification is generated when the PW negotiation parameter settings are consistent on the two ends of the PW.
System impact
This event has impact on the PW setup status and service forwarding status.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
hh3cL2vpnPwPeerIp
hh3cL2vpnPwId
DisplayString
As per the MIB.
hh3cL2vpnPwPeerIp
hh3cL2vpnPwId
DisplayString
As per the MIB.
hh3cL2vpnPwPeerIp
hh3cL2vpnPwId
DisplayString
As per the MIB.
Recommended action
hh3cL2vpnPwOutAge
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.162.0.9
Both the primary and backup PWs are unavailable.
Error
Warning
1.3.6.1.4.1.25506.2.162.0.10 (hh3cL2vpnPwOutAgeClear)
OFF
This notification is generated when both the primary and backup PWs are unavailable.
System impact
PW service forwarding will be impacted.
Status control
ON
CLI: snmp-agent trap enable l2vpn [pw-up-down]
OFF
CLI: undo snmp-agent trap enable l2vpn [pw-up-down]
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.162.2.4.1.1 (hh3cL2vpnPeerIp)
Peer IP for the PW
hh3cL2vpnPeerIp
hh3cL2vpnPWPwID
IpAddress
As per the MIB.
1.3.6.1.4.1.25506.2.162.2.4.1.2 (hh3cL2vpnPWPwID)
PW ID
hh3cL2vpnPeerIp
hh3cL2vpnPWPwID
Unsigned32
As per the MIB.
1.3.6.1.4.1.25506.2.162.2.4.1.3 (hh3cL2vpnPwType)
PW encapsulation type
hh3cL2vpnPeerIp
hh3cL2vpnPWPwID
INTEGER
As per the MIB.
Recommended action
Basic information
OID
Event
Severity
Default status
Both the primary and backup PWs are available.
Recovery
Warning
OFF
This notification is generated when both the primary and backup PWs become available.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
Peer IP for the PW
hh3cL2vpnPeerIp
hh3cL2vpnPWPwID
IpAddress
As per the MIB.
PW ID
hh3cL2vpnPeerIp
hh3cL2vpnPWPwID
Unsigned32
As per the MIB.
hh3cL2vpnPeerIp
hh3cL2vpnPWPwID
INTEGER
As per the MIB.
Recommended action
hh3cL2vpnSingleCCCVcUp
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.162.0.11
CCC status changed to up in the inbound or outbound direction
Recovery
Warning
OFF
This notification is generated when CCC status changes to up.
System impact
CCC service forwarding will be impacted.
Status control
ON
CLI: snmp-agent trap enable l2vpn [ccc-up-down]
OFF
CLI: undo snmp-agent trap enable l2vpn [ccc-up-down]
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.162.3.5.1.1 (hh3cL2vpnInInterfaceIndex)
Inbound interface index
hh3cL2vpnOutInterfaceIndex
InterfaceIndex
As per the MIB.
1.3.6.1.4.1.25506.2.162.3.5.1.2 (hh3cL2vpnOutInterfaceIndex)
Outbound interface index
InterfaceIndex
As per the MIB.
1.3.6.1.4.1.25506.2.162.3.5.1.3 (hh3cL2vpnChangeReason)
Remote connection status change reason
Unsigned32
As per the MIB.
1.3.6.1.4.1.25506.2.162.3.5.1.4 (hh3cL2vpnInInterfaceName)
Inbound interface name
OCTET STRING
As per the MIB.
1.3.6.1.4.1.25506.2.162.3.5.1.5 (hh3cL2vpnOutInterfaceName)
Outbound interface name
OCTET STRING
As per the MIB.
Recommended action
hh3cL2vpnSingleCCCVcDown
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.162.0.12
CCC status changed to down in the inbound or outbound direction
Error
Warning
1.3.6.1.4.1.25506.2.162.0.11 (hh3cL2vpnSingleCCCVcUp)
OFF
This notification is generated when CCC status changes to down.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
InterfaceIndex
As per the MIB.
InterfaceIndex
As per the MIB.
Unsigned32
As per the MIB.
OCTET STRING
As per the MIB.
OCTET STRING
As per the MIB.
Recommended action
Possible causes for CCC status changes:
11 -- "Label (not) allocated"
8 -- "Local Xconnect-group Up/Down"
5 -- Local AC (not) bind
4 -- Local AC Up/Down
hh3cL2vpnFlowLabelNonSupp
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.162.0.13
The device detected a card that does not support flow labels.
Error
Warning
OFF
This notification is generated when the device detects a card that does not support the flow label feature.
System impact
The flow label feature is impacted.
Status control
ON
CLI: Use the snmp-agent trap enable l2vpn flow-label command.
OFF
CLI: Use the undo snmp-agent trap enable l2vpn flow-label command.
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.162.2.5.1.1 (hh3cL2vpnFlowLabelSlotId)
Interface module number
Unsigned32
As per the MIB.
1.3.6.1.4.1.25506.2.162.2.5.1.2 (hh3cL2vpnFlowLabelOID)
OID ID
OBJECT IDENTIFIER
As per the MIB.
Recommended action
