10-MPLS
HomeSupportRoutersCR16000-M SeriesDiagnose & MaintainAlarms ReferencesH3C CR16000-M Routers Alarm Reference-R8530Pxx-6W10010-MPLS
12-MPLS-FRR-FACILITY-STD-MIB
12-MPLS-FRR-FACILITY-STD-MIB 63.58 KB
About this MIB
Use this MIB to manage tunnels on the MPLS interfaces configured for FRR protection.
MIB file name
rfc6445-mpls-frr-facility-std.mib
Notifications
mplsFrrFacilityInitialBackupTunnelInvoked
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.2.1.204.0.1
Interface failed and bypass tunnel took over.
Error
Major
1.3.6.1.2.1.204.0.2 (mplsFrrFacilityFinalTunnelRestored)
ON
Notification triggers
This notification is generated when the interface or link protected by a bypass tunnel goes down and the service traffic is switched to the bypass tunnel accordingly.
System impact
The tunnel service is switched to the bypass tunnel. The service traversed path is not the expected primary tunnel, thus risks might increase for the service.
Status control
ON
CLI: Use the snmp-agent trap enable te command.
OFF
CLI: Use the undo snmp-agent trap enable te command.
Object
OID (object name)
Index
Value range
1.3.6.1.2.1.204.1.7.1.7
 (mplsFrrFacilityDBNumProtectingTunnelOnIf)
Number of bypass tunnels on an interface for protection.
1.3.6.1.2.1.204.1.7.1.1
(mplsFrrFacilityProtectedIfIndex)
1.3.6.1.2.1.204.1.7.1.2
(mplsFrrFacilityProtectingTunnelIndex)
1.3.6.1.2.1.204.1.7.1.3
(mplsFrrFacilityBackupTunnelIndex)
1.3.6.1.2.1.204.1.7.1.4
(mplsFrrFacilityBackupTunnelInstance)
1.3.6.1.2.1.204.1.7.1.5
(mplsFrrFacilityBackupTunnelIngressLSRId)
Gauge32
Standard MIB values.
1.3.6.1.2.1.204.1.7.1.8
 (mplsFrrFacilityDBNumProtectedLspOnIf)
Number of CRLSPs protected on the interface.
No1.3.6.1.2.1.204.1.7.1.1
Gauge32
1.3.6.1.2.1.204.1.7.1.9
 (mplsFrrFacilityDBNumProtectedTunnels)
Number of tunnels protected on the interface.
Gauge32
1.3.6.1.2.1.204.1.7.1.10
 (mplsFrrFacilityDBProtectingTunnelStatus)
State of a bypass tunnel on the interface.
INTEGER
active(1), ready(2)
1.3.6.1.2.1.204.1.7.1.11 (mplsFrrFacilityDBProtectingTunnelResvBw)
Amount of bandwidth reserved by a bypass tunnel on the interface.
Unsigned32
Recommended action
To resolve this issue, perform the following tasks:
1.Check the current tunnel interface configuration, RSVP and IGP configuration, and check whether the tunnel path and its bandwidth satisfy the tunnel configuration requirements.
  - If an explicit path is configured, check whether the interfaces on each hop of the explicit path are faulty.
If yes, clear link faults.
If no, go to step 2.
2.If no explicit path is configured, check whether a path that satisfies the tunnel requirements exists. If yes, execute step 2.
3.If the issue persists, collect log messages and configuration data, and then contact H3C Support for help.
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.204.0.2
Interface recovered and primary tunnel recovered.
Recovery
Major
N/A (N/A)
ON
This notification is generated when the state of the interface or link protected by a bypass tunnel changes from down to up and the service traffic is switched from the bypass tunnel back to the primary tunnel accordingly.
System impact
No negative impact on services.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
Number of bypass tunnels for FRR facility backup.
Unsigned32
Number of LSPs protected by FRR facility backup.
Unsigned32
Number of tunnels protected by FRR facility backup.
Unsigned32
State of a bypass tunnel for FRR facility backup.
Integer32
active(1), ready(2)
Amount of bandwidth reserved by the bypass tunnel for FRR facility backup.
Unsigned32
Recommended action
No action is required.
