- 08-IPsec Configuration
- 01-MER Routers Main Mode IPsec VPN Setup Configuration Examples
- 02-MER Routers Aggressive Mode IPsec VPN Setup with ERG3 Router Configuration Examples
- 03-MER Routers Main Mode IPsec VPN Setup with ERG3 Router Configuration Examples
- 04-MSR Routers Main Mode IPsec VPN Setup Configuration Examples
- 05-MSR Routers Establish Aggressive Mode IPsec VPN Between HQ and Multiple Branches
- 06-MSR Routers Main Mode IPsec VPN Setup with ERG3 Router Configuration Examples
- 07-MSR Routers Establish IKEv2-Based IPsec Tunnel for IPv4 Packets Between Phone and Gateway
- 08-MSR Routers Aggressive Mode IPsec VPN Setup with ERG3 Router Configuration Examples
- 09-MSR Routers Aggressive Mode IPsec VPN Setup Configuration Examples
- 10-MSR Routers Aggressive Mode IPsec VPN Setup with MER Router Configuration Examples
| 05-MSR Routers Establish Aggressive Mode IPsec VPN Between HQ and Multiple Branches | 158.67 KB |
MSR Routers
Introduction
The following information provides an example for setting up an IPsec VPN between the headquarters (HQ) and branches by using aggressive mode IKE negotiation.
The following information applies to Comware 7-based MSR router series. Procedures and information in the examples might be slightly different depending on the software or hardware version of the routers.
The following information is provided based on the assumption that you have basic knowledge of IPsec.
Example: Establishing aggressive mode IPsec VPN between HQ and multiple branches
As shown in Figure 1, Device A is the gateway of Branch 1, Device B is the gateway of Branch 2, and Device C is the gateway of the headquarters (HQ). Device A and Device B connect to the Internet using PPPoE dial-up, while Device C connects to the Internet with a fixed IP address of 1.1.1.1/24. The HQ and branches communicate with each other over the public network.
To ensure security, establish an IPsec VPN tunnel between each branch and the HQ. The branches access each other through the tunnels, implementing secure data communication.
Software versions used
The configuration example was created and verified on R6749P15 of the MSR3610-X1 router.
Procedures
Configuring Device A
1. Configure IP addresses for interfaces.
# Configure an IP address for interface GigabitEthernet1/0/1.
[DeviceA-GigabitEthernet1/0/1] ip address 192.168.1.1 255.255.255.0
# Create ACL 3000.
[DeviceA] acl number 3000
# Define rule 0: Permit the data flow from subnet 192.168.1.0/24 of Branch 1 to subnet 192.168.2.0/24 of the HQ.
[DeviceA-acl-adv-3000] rule 0 permit ip source 192.168.1.0 0.0.0.255 destination 192.168.2.0 0.0.0.255
# Define rule 1: Permit the data flow from subnet 192.168.1.0/24 of Branch 1 to subnet 192.168.3.0/24 of Branch 2.
[DeviceA-acl-adv-3000] rule 1 permit ip source 192.168.1.0 0.0.0.255 destination 192.168.3.0 0.0.0.255
[DeviceA-acl-adv-3000] quit
3. Configure an IKE:
# Create IKE proposal 1.
[DeviceA] ike proposal 1
# Specify the authentication algorithm as HMAC-MD5.
[DeviceA-ike-proposal-1] authentication-algorithm md5
# Specify the encryption algorithm as 3DES-CBC.
[DeviceA-ike-proposal-1] encryption-algorithm 3des-cbc
[DeviceA-ike-proposal-1] quit
4. Configure the local identity:
# Configure the local ID as FQDN name RTA.
[DeviceA] ike identity fqdn RTA
5. Configure an IKE keychain:
# Create an IKE keychain named RTA. Specify plaintext 123456TESTplat&! as the pre-shared key for IKE negotiation with peer 1.1.1.1.
[DeviceA] ike keychain RTA
[DeviceA-ike-keychain-RTA] pre-shared-key address 1.1.1.1 key simple 123456TESTplat&!
[DeviceA-ike-keychain-RTA] quit
6. Configure an IKE profile:
# Create an IKE profile named RTA.
[DeviceA] ike profile RTA
# Specify IKE keychain RTA for the IKE profile.
[DeviceA-ike-profile-RTA] keychain RTA
# Specify the IKE negotiation mode in phase 1 as the aggressive mode.
[DeviceA-ike-profile-RTA] exchange-mode aggressive
[DeviceA-ike-profile-RTA] local-identity fqdn RTA
# Configure the peer ID as FQDN name zongbu.
[DeviceA-ike-profile-RTA] match remote identity fqdn zongbu
# Specify IKE proposal 1 for the IKE profile.
[DeviceA-ike-profile-RTA] proposal 1
[DeviceA-ike-profile-RTA] quit
7. Configure an IPsec transform set:
# Create IPsec transform set 1.
[DeviceA] ipsec transform-set 1
# Set the packet encapsulation mode to tunnel.
[DeviceA-ipsec-transform-set-1] encapsulation-mode tunnel
# Use the ESP protocol for the IPsec transform set.
[DeviceA-ipsec-transform-set-1] protocol esp
# Specify the encryption and authentication algorithms used by ESP.
[DeviceA-ipsec-transform-set-1] esp encryption-algorithm 3des-cbc
[DeviceA-ipsec-transform-set-1] esp authentication-algorithm md5
[DeviceA-ipsec-transform-set-1] quit
8. Configure an IPsec policy:
# Create an IKE-based IPsec policy entry. Specify the policy name as RTA and set the sequence number to 1.
[DeviceA] ipsec policy RTA 1 isakmp
[DeviceA-ipsec-policy-isakmp-RTA-1] security acl 3000
[DeviceA-ipsec-policy-isakmp-RTA-1] remote-address 1.1.1.1
[DeviceA-ipsec-policy-isakmp-RTA-1] ike-profile RTA
[DeviceA-ipsec-policy-isakmp-RTA-1] transform-set 1
[DeviceA-ipsec-policy-isakmp-RTA-1] quit
9. Apply the IPsec policy to an interface:
# Apply IPsec policy RTA to interface Dialer10. (Dialer10 here is only an example. Choose a proper interface in your network to apply the IPsec policy.)
[DeviceA] interface Dialer 10
[DeviceA-Dialer10] ipsec apply policy RTA
[DeviceA-Dialer10] quit
Configuring Device B
[DeviceB-GigabitEthernet1/0/1] ip address 192.168.3.1 255.255.255.0
2. Configure an ACL:
Create ACL 3000.
[DeviceB] acl number 3000
# Define rule 0: Permit the data flow from subnet 192.168.3.0/24 of Branch 2 to subnet 192.168.2.0/24 of the HQ.
[DeviceB-acl-adv-3000] rule 0 permit ip source 192.168.3.0 0.0.0.255 destination 192.168.2.0 0.0.0.255
# Define rule 1: Permit the data flow from subnet 192.168.3.0/24 of Branch 2 to subnet 192.168.1.0/24 of Branch 1.
[DeviceB-acl-adv-3000] rule 1 permit ip source 192.168.3.0 0.0.0.255 destination 192.168.1.0 0.0.0.255
[DeviceB-acl-adv-3000] quit
[DeviceB] ike proposal 1
[DeviceB-ike-proposal-1] authentication-algorithm md5
[DeviceB-ike-proposal-1] encryption-algorithm 3des-cbc
[DeviceB-ike-proposal-1] quit
# Configure the local ID as FQDN name RTB.
[DeviceB] ike identity fqdn RTB
# Create an IKE keychain named RTB. Specify plaintext 123456TESTplat&! as the preshared key for IKE negotiation with peer 1.1.1.1.
[DeviceB] ike keychain RTB
[DeviceB-ike-keychain-RTB] pre-shared-key address 1.1.1.1 key simple 123456TESTplat&!
[DeviceB-ike-keychain-RTB] quit
# Create an IKE profile named RTB.
[DeviceB] ike profile RTB
# Specify IKE keychain RTB for the IKE profile.
[DeviceB-ike-profile-RTB] keychain RTB
[DeviceB-ike-profile-RTB] exchange-mode aggressive
# Specify the FQDN name RTB as the local ID.
[DeviceB-ike-profile-RTB] local-identity fqdn RTB
# Specify the FQDN name zongbu as the peer ID.
[DeviceB-ike-profile-RTB] match remote identity fqdn zongbu
[DeviceB-ike-profile-RTB] proposal 1
[DeviceB-ike-profile-RTB] quit
[DeviceB] ipsec transform-set 1
[DeviceB-ipsec-transform-set-1] encapsulation-mode tunnel
[DeviceB-ipsec-transform-set-1] protocol esp
[DeviceB-ipsec-transform-set-1] esp encryption-algorithm 3des-cbc
[DeviceB-ipsec-transform-set-1] esp authentication-algorithm md5
[DeviceB-ipsec-transform-set-1] quit
# Create an IKE-based IPsec policy entry. Specify the policy name as RTB and set the sequence number to 1.
[DeviceB] ipsec policy RTB 1 isakmp
[DeviceB-ipsec-policy-isakmp-RTB-1] security acl 3000
[DeviceB-ipsec-policy-isakmp-RTB-1] remote-address 1.1.1.1
[DeviceB-ipsec-policy-isakmp-RTB-1] ike-profile RTB
[DeviceB-ipsec-policy-isakmp-RTB-1] transform-set 1
[DeviceB-ipsec-policy-isakmp-RTB-1] quit
# Apply IPsec policy RTB to interface Dialer10. (Dialer10 here is only an example. Choose a proper interface in your network to apply the IPsec policy.)
[DeviceB] interface Dialer 10
[DeviceB-Dialer10] ipsec apply policy RTB
[DeviceB-Dialer10] quit
Configuring Device C
# Configure an IP address for interface GigabitEthernet 1/0/1.
<DeviceC> system-view
[DeviceC-GigabitEthernet1/0/1] ip address 192.168.2.1 255.255.255.0
# Configure an IP address for interface GigabitEthernet 1/0/2.
[DeviceC-GigabitEthernet1/0/2] ip address 1.1.1.1 255.255.255.0
2. Configure ACL 3000:
Create ACL 3000.
[DeviceC] acl number 3000
# Define rule 0: Permit the data flow from subnet 192.168.2.0/24 of HQ to subnet 192.168.1.0/24 of Branch 1.
[DeviceC-acl-adv-3000] rule 0 permit ip source 192.168.2.0 0.0.0.255 destination 192.168.1.0 0.0.0.255
[DeviceC-acl-adv-3000] rule 1 permit ip source 192.168.3.0 0.0.0.255 destination 192.168.1.0 0.0.0.255
[DeviceC-acl-adv-3000] quit
3. Configure ACL 3001:
# Create ACL 3001.
[DeviceC] acl number 3001
# Define rule 0: Permit the data flow from subnet 192.168.2.0/24 of HQ to subnet 192.168.3.0/24 of Branch 2.
[DeviceC-acl-adv-3000] rule 0 permit ip source 192.168.2.0 0.0.0.255 destination 192.168.3.0 0.0.0.255
[DeviceC-acl-adv-3000] rule 1 permit ip source 192.168.1.0 0.0.0.255 destination 192.168.3.0 0.0.0.255
4. Configure an IKE:
[DeviceC] ike proposal 1
[DeviceC-ike-proposal-1] authentication-algorithm md5
[DeviceC-ike-proposal-1] encryption-algorithm 3des-cbc
[DeviceC-ike-proposal-1] quit
5. Configure the local identity:
# Configure the local ID as FQDN name zongbu.
[DeviceC] ike identity fqdn zongbu
6. Configure an IKE keychain:
# Create an IKE keychain named RTA. Specify plaintext 123456TESTplat&! as the pre-shared key for IKE negotiation with the peer identified by FQDN RTA.
[DeviceC] ike keychain RTA
[DeviceC-ike-keychain-RTA] pre-shared-key hostname RTA key simple 123456TESTplat&!
[DeviceC-ike-keychain-RTA] quit
# Create an IKE keychain named RTB. Specify plaintext 123456TESTplat&! as the pre-shared key for IKE negotiation with the peer identified by FQDN RTB.
[DeviceC] ike keychain RTB
[DeviceC-ike-keychain-RTB] pre-shared-key hostname RTB key simple 123456TESTplat&!
[DeviceC-ike-keychain-RTB] quit
7. Configure IKE profile RTA:
[DeviceC] ike profile RTA
[DeviceC-ike-profile-RTA] keychain RTA
[DeviceC-ike-profile-RTA] exchange-mode aggressive
# Configure the FQDN name zongbu as the local ID.
[DeviceC-ike-profile-RTA] local-identity fqdn zongbu
# Configure the peer ID as FQDN RTA.
[DeviceC-ike-profile-RTA] match remote identity fqdn RTA
[DeviceC-ike-profile-RTA] proposal 1
[DeviceC-ike-profile-RTA] quit
8. Configure IKE profile RTB:
[DeviceC] ike profile RTB
[DeviceC-ike-profile-RTB] keychain RTB
[DeviceC-ike-profile-RTB] exchange-mode aggressive
[DeviceC-ike-profile-RTB] local-identity fqdn zongbu
# Configure the peer ID as FQDN name RTB.
[DeviceC-ike-profile-RTB] match remote identity fqdn RTB
[DeviceC-ike-profile-RTB] proposal 1
[DeviceC-ike-profile-RTB] quit
9. Configure an IPsec transform set:
[DeviceC] ipsec transform-set 1
[DeviceC-ipsec-transform-set-1] encapsulation-mode tunnel
[DeviceC-ipsec-transform-set-1] protocol esp
[DeviceC-ipsec-transform-set-1] esp encryption-algorithm 3des-cbc
[DeviceC-ipsec-transform-set-1] esp authentication-algorithm md5
[DeviceC-ipsec-transform-set-1] quit
10. Configure an IPsec policy template:
# Create and configure an IPsec policy template named t1 with a sequence number of 1.
[DeviceC] ipsec policy-template t1 1
[DeviceC-ipsec-policy-template-t1-1] security acl 3000
[DeviceC-ipsec-policy-template-t1-1] ike-profile RTA
[DeviceC-ipsec-policy-template-t1-1] transform-set 1
[DeviceC-ipsec-policy-template-t1-1] quit
# Create and configure an IPsec policy template named t2 with a sequence number of 1.
[DeviceC] ipsec policy-template t2 1
[DeviceC-ipsec-policy-template-t2-1] security acl 3001
[DeviceC-ipsec-policy-template-t2-1] ike-profile RTB
[DeviceC-ipsec-policy-template-t2-1] transform-set 1
[DeviceC-ipsec-policy-template-t2-1] quit
11. Configure an IKE-based IPsec policy:
# Create and configure an IPsec policy named zongbu with a sequence number of 1, based on IPsec policy template t1.
[DeviceC] ipsec policy zongbu 1 isakmp template t1
# Create and configure an IPsec policy named zongbu with a sequence number of 2, based on IPsec policy template t2.
[DeviceC] ipsec policy zongbu 2 isakmp template t2
12. Apply the IPsec policy to an interface:
Apply IPsec policy zongbu to GigabitEthernet 1/0/2.
[DeviceC-GigabitEthernet1/0/2] ipsec apply policy zongbu
# Initiate a connection from Host A to Host C to trigger IKE negotiation. Verify that you can successfully ping 192.168.2.2 from 192.168.1.2 after the IPsec tunnel is successfully established.
C:\Users> ping 192.168.2.2
Pinging 192.168.2.2 with 32 bytes of data:
Request timed out.
Reply from 192.168.2.2: bytes=32 time=2ms TTL=254
Reply from 192.168.2.2: bytes=32 time=1ms TTL=254
Ping statistics for 192.168.2.2:
Packets: Sent = 4, Received = 3, Lost = 1 (25% loss),
Minimum = 1ms, Maximum = 2ms, Average = 1ms
# Device A obtains IP address 2.2.2.1 through PPPoE dialup. Use the display ike sa command on Device A to verify that the phase 1 SA is established normally.
<DeviceA> display ike sa
Connection-ID Remote Flag DOI
13 1.1.1.1/500 RD IPsec
Flags:
RD--READY RL--REPLACED FD-FADING
<DeviceA> display ike sa verbose
Connection ID: 13
Outside VPN:
Inside VPN:
Profile: RTA
Transmitting entity: Initiator
Initiator cookie: 1bcf453f0a217259
Responder cookie: 5e32a74dfa66a0a4
Output interface index: 2
Local IP/port: 2.2.2.1/500
Local ID type: FQDN
Local ID: RTA
Remote IP/port: 1.1.1.1/500
Remote ID type: IPV4_ADDR
Remote ID: 1.1.1.1
Authentication-method: PRE-SHARED-KEY
Authentication-algorithm: MD5
Encryption-algorithm: 3DES-CBC
Life duration(sec): 86400
Remaining key duration(sec): 84565
Exchange-mode: Aggressive
Diffie-Hellman group: Group 1
NAT traversal: Detected
Extend authentication: Disabled
Assigned IP address:
Vendor ID index: 0xa1d
Vendor ID sequence number: 0x0
# On Device A, use the display ipsec sa command to view the IPsec SA created by phase 2 IKE negotiation.
<DeviceA> display ipsec sa
Interface: Dialer10
IPsec policy: RTA
Sequence number: 1
Alias: RTA-1
Mode: ISAKMP
Tunnel id: 0
Encapsulation mode: tunnel
Perfect forward secrecy:
Inside VPN:
Extended Sequence Numbers enable: N
Traffic Flow Confidentiality enable: N
Path MTU: 1435
Tunnel:
local address/port: 2.2.2.1/500
remote address/port: 1.1.1.1/500
Flow:
sour addr: 192.168.1.0/255.255.255.0 port: 0 protocol: ip
dest addr: 192.168.2.0/255.255.255.0 port: 0 protocol: ip
[Inbound ESP SAs]
SPI: 830667426 (0x3182faa2)
Connection ID: 90194313219
Transform set: ESP-ENCRYPT-3DES-CBC ESP-AUTH-MD5
SA duration (kilobytes/sec): 1843200/3600
SA remaining duration (kilobytes/sec): 1843200/2313
Max received sequence-number:
Anti-replay check enable: Y
Anti-replay window size: 64
UDP encapsulation used for NAT traversal: Y
Status: Active
[Outbound ESP SAs]
SPI: 3516214669 (0xd1952d8d)
Connection ID: 64424509441
Max sent sequence-number:
Status: Active
Configuration files
· Device A:
interface Dialer10
acl number 3000
protocol esp
ike-profile RTA
security acl 3000
transform-set 1
ike keychain RTA
pre-shared-key address 1.1.1.1 255.255.255.0 key cipher $c$3$n6jdlYtuR+K6mijQ8
qp4hMMjV/iteA==
ike profile RTA
keychain RTA
proposal 1
ike proposal 1
· Device B:
interface Dialer10
acl number 3000
protocol esp
transform-set 1
security acl 3000
ike-profile RTB
ike keychain RTB
qp4hMMjV/iteA==
ike profile RTB
keychain RTB
proposal 1
ike proposal 1
· Device C:
acl number 3000
acl number 3001
protocol esp
security acl 3000
ike-profile RTA
transform-set 1
security acl 3001
ike-profile RTB
transform-set 1
ike keychain RTA
pre-shared-key hostname RTA key cipher $c$3$7tvgEkFh6On3KIybUaywz5NDiHtwJqU=
ike keychain RTB
pre-shared-key hostname RTB key cipher $c$3$3ErJJ2M1lhES32CdsR3ofs5CdLvPJGk=
ike profile RTA
keychain RTA
proposal 1
ike profile RTB
keychain RTB
proposal 1
ike proposal 1
