- 08-IPsec Configuration
- 01-MER Routers Main Mode IPsec VPN Setup Configuration Examples
- 02-MER Routers Aggressive Mode IPsec VPN Setup with ERG3 Router Configuration Examples
- 03-MER Routers Main Mode IPsec VPN Setup with ERG3 Router Configuration Examples
- 04-MSR Routers Main Mode IPsec VPN Setup Configuration Examples
- 05-MSR Routers Establish Aggressive Mode IPsec VPN Between HQ and Multiple Branches
- 06-MSR Routers Main Mode IPsec VPN Setup with ERG3 Router Configuration Examples
- 07-MSR Routers Establish IKEv2-Based IPsec Tunnel for IPv4 Packets Between Phone and Gateway
- 08-MSR Routers Aggressive Mode IPsec VPN Setup with ERG3 Router Configuration Examples
- 09-MSR Routers Aggressive Mode IPsec VPN Setup Configuration Examples
- 10-MSR Routers Aggressive Mode IPsec VPN Setup with MER Router Configuration Examples
02-MER Routers Aggressive Mode IPsec VPN Setup with ERG3 Router Configuration Examples | 388.79 KB |
MER Routers
Example: Setting up an IPsec VPN through aggressive mode IKE negotiation with an ERG3 router
Introduction
The following information provides an example for setting up an IPsec VPN between an H3C MER router and ERG3 router through aggressive mode IKE negotiation. This configuration example is applicable to scenarios where both the WAN interfaces on the headquarters and branch gateway routers use fixed public addresses.
The following information applies to Comware 7-based MER router series and ERG3 routers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the routers.
The following information is provided based on the assumption that you have basic knowledge of IPsec.
As shown in Figure 1, the ERG3 router is the gateway of the headquarters and the MER router is the gateway of the branch. MER uses a single WAN interface, ERG3 uses dual WAN interfaces, and the WAN interfaces each use a fixed public address to connect to the Internet. The headquarters and the branch communicate with each other over the Internet.
To protect data flows between the headquarters and the branch, establish an IPsec tunnel between the gateway routers. The specific requirements are as follows:
· Configure the two gateway routers to use preshared key 123456TESTplat&! for authentication.
· Use the aggressive mode IKE negotiation.
· Specify the encryption algorithm as 3DES-CBC and the authentication algorithm as MD5.
· Specify the encapsulation mode as the tunnel mode and the security protocol as ESP.
Analysis
To configure IPsec VPN, complete the following configurations on the routers:
1. Configure basic WAN and LAN settings.
a. Specify the IP address and gateway of the WAN interface on each router.
b. Edit the default IP address of VLAN-interface 1 on each router.
2. Add an IPsec policy.
Configure the IPsec policy to use aggressive mode for phase 1 IKE negotiation.
Software versions used
· If your network uses dual-WAN or multiple-WAN access, configure a static route on each router to direct the traffic destined for the peer internal network to the WAN interface specified in the IPsec policy.
· Make sure both sides of the IPsec tunnel use the same preshared key, security protocol, encryption algorithm, authentication algorithm, and encapsulation mode.
Procedures
Configuring MER
Editing the IP address of VLAN-interface 1
# Change the IP address of VLAN-interface 1 to 10.1.1.1/24. The configuration steps are as follows:
1. From the left navigation pane, select Network > LAN Settings.
2. Click the LAN Settings tab.
3. Click the edit icon in the Operation column for VLAN1.
4. In the Interface IP address field, enter 10.1.1.1.
5. In the Subnet mask field, enter 255.255.255.0.
6. Use the default settings for the other parameters, and click Apply.
Figure 2 Editing the LAN configuration
Configuring WAN1 to connect to the Internet
# In this example, select the single-WAN scenario for the MER router, and set the connection mode of the selected WAN interface to fixed IP. The configuration steps are as follows:
1. On the Web interface of the device, select Network > WAN Settings from the navigation pane.
2. On the Scene tab, select Single-WAN scenario, select WAN1 for Line1, and then click Apply.
3. Click the WAN Settings tab.
4. Click the Edit icon in the Operation column for WAN1.
5. In the Connection mode field, select Fixed IP.
6. In the IP address field, enter 2.2.2.1.
7. In the Subnet mask field, enter 255.255.255.0.
8. In the Gateway field, enter 2.2.2.254.
9. Use the default settings for other parameters. Click Apply.
Figure 3 Configuring the WAN scenario
Figure 4 Editing WAN settings
Configuring the IPsec policy
# Specify the network mode as the branch gateway and the IKE negotiation mode as the aggressive mode. The configuration steps are as follows:
1. From the navigation pane, select Virtual Network > IPsec VPN.
2. Click Add. On the page that opens, configure the following parameters:
¡ Specify the name as map1.
¡ Select WAN1 in the Interface field.
¡ Select Branch gateway in the Network mode field.
¡ Enter 2.2.3.1 in the Peer gateway address field.
¡ Enter 123456TESTplat&! in the Preshared key field.
¡ In the Protected data flows area, select IP as the protocol to be protected, enter 10.1.1.0/24 in the Local subnet/mask filed and 10.1.2.0/24 in the Peer subnet/mask field, and then click the + icon.
Figure 5 Configuring the IPsec policy
3. Click Show advanced settings. On the page that opens, configure the following parameters:
¡ In the Negotiation mode field, select Aggressive mode.
¡ In the Local ID field, select IP address, and then enter 2.2.2.1.
¡ In the Remote ID field, select IP address, and then enter 2.2.3.1.
¡ In the DPD field, select Enable, and set the DPD retry interval to 30 seconds. (This feature is disabled by default. To monitor the availability of the IPsec tunnel in time, enable this feature.)
¡ In the Algorithm suite field, select Customize.
¡ In the Authentication algorithm field, select MD5.
¡ In the Encryption algorithm field, select 3DES-CBC.
¡ Use the default settings for other parameters.
Figure 6 IKE settings
4. Click the IPsec settings tab, and then configure the following parameters:
¡ In the Algorithm combination field, select Customize.
¡ In the Security protocol field, select ESP.
¡ In the ESP authentication algorithm field, select MD5.
¡ In the encryption algorithm field, select encryption algorithm.
¡ In the Encapsulation mode field, select Tunnel.
5. Click Back to basic settings to go back to the Add IPsec Policy page.
Figure 7 IPsec settings
Configuring ERG3
# Edit the IP address of VLAN-interface 1 to 10.1.2.1/24. The configuration steps are as follows:
1. From the left navigation pane, select Network Settings > LANs.
2. Click the VLAN Settings tab.
3. Click the Edit icon in the Actions column for VLAN1.
4. In the IP Address field, enter 10.1.2.1.
5. In the Subnet Mask field, enter 255.255.255.0.
6. Use the default settings for other parameters, and then click Apply.
Figure 8 Editing LAN settings
# In this example, select the dual-WAN scenario for the ERG3 router, and set the connection mode of the selected WAN interface to fixed IP. The configuration steps are as follows:
1. On the Web interface of the device, select Network Settings > External Networks from the navigation pane.
2. On the Configure Interface Mode tab, select Double-WAN scenario, and then click Apply.
4. Click the Edit icon in the Actions column for WAN1.
5. In the Connection Mode field, select Fixed IP.
6. In the IP Address field, enter 2.2.3.1.
7. In the Subnet Mask field, enter 255.255.255.0.
8. In the Gateway Address field, enter 2.2.3.254.
Figure 9 Configuring the interface mode
Figure 10 Edit WAN Settings
# Specify the network mode as branch gateway and the IKE negotiation mode as aggressive mode. The configuration steps are as follows:
1. From the navigation pane, select VPN > IPsec VPN.
¡ Select HQ Node in the Networking Mode field.
¡ Enter 123456TESTplat&! in the Preshared Key field.
Figure 11 Configuring the IPsec policy
3. Click Advanced Settings. On the page that opens, configure the following parameters:
¡ In the IKE Version field, select V1.
¡ In the Negotiation Mode field, select Aggressive.
¡ In the Local ID field, select IP address, and then enter 2.2.3.1.
¡ In the DPD field, select ON, and set the detection time to 10 and timeout to 30.
¡ In the Algorithm Suite field, select Customize.
¡ In the Authentication Algorithm field, select MD5.
¡ In the Encryption Algorithm field, select 3DES-CBC.
Figure 12 IKE settings
4. Click the IPsec Settings tab, and then configure the following parameters:
¡ In the Security Protocol field, select ESP.
¡ In the ESP Auth Algorithm field, select MD5.
¡ In the ESP Encryption Algorithm field, select 3DES-CBC.
¡ In the Encapsulation Mode field, select Tunnel Mode.
5. Click Back to Basic Settings to go back to the Add IPsec Policy page.
Figure 13 IPsec settings
1. Verify that Host A can ping Host B successfully.
C:\Users\abc>ping 10.1.2.2
Ping 10.1.2.2 (10.1.2.2): 56 data bytes, press CTRL_C to break
56 bytes from 10.1.2.2: icmp_seq=0 ttl=254 time=2.137 ms
56 bytes from 10.1.2.2: icmp_seq=1 ttl=254 time=2.051 ms
56 bytes from 10.1.2.2: icmp_seq=2 ttl=254 time=1.996 ms
56 bytes from 10.1.2.2: icmp_seq=3 ttl=254 time=1.963 ms
56 bytes from 10.1.2.2: icmp_seq=4 ttl=254 time=1.991 ms
--- Ping statistics for 10.1.2.2 ---
round-trip min/avg/max/std-dev = 1.963/2.028/2.137/0.062 ms
C:\Users\abc>
2. On the Web interface of the MER router, navigate to the Virtual Network > IPsec VPN > Monitor information page to view IPsec tunnel information. Status Up indicates successful establishment of the IPsec tunnel.
