- 06-Layer 2 - LAN Switching
- 01-BRIDGE-MIB
- 02-EtherLike-MIB
- 03-HH3C-LAG-MIB
- 04-HH3C-LLDP-EXT-MIB
- 05-HH3C-LPBKDT-MIB
- 06-HH3C-LswMAM-MIB
- 07-HH3C-MAC-INFORMATION-MIB
- 08-HH3C-MAC-TRAP-MIB
- 09-HH3C-PVST-MIB
- 10-HH3C-QINQV2-MIB
- 11-HH3C-LswMSTP-MIB
- 12-HH3C-LswVLAN-MIB
- 13-IEEE8021-CFM-MIB
- 14-IEEE8021-CFM-V2-MIB
- 15-IEEE8023-LAG-MIB
- 16-LLDP-EXT-MED-MIB
- 17-LLDP-EXT-DOT3-V2-MIB
- 18-LLDP-EXT-DOT1-EVB-EXTENSIONS-MIB
- 19-LLDP-EXT-DOT1-MIB
- 20-LLDP-EXT-DOT1-V2-MIB
- 21-LLDP-EXT-DOT3-MIB
- 22-LLDP-MIB
- 23-LLDP-V2-MIB
- 24-MAU-MIB
18-LLDP-EXT-DOT1-EVB-EXTENSIONS-MIB | 75.60 KB |
About this MIB
Use this MIB to obtain information about EVB TLV configuration.
MIB file name
lldp-ext-dot1-evb-extensions.mib
Root object
iso(1).org(3).ieee(111).standards-association-numbers-series-standards(2).lan-man-stds(802).ieee802dot1mibs(1).lldpV2MIB(13).lldpV2Objects(1).lldpV2Extensions(5).lldpV2Xdot1MIB(32962).lldpXdot1StandAloneExtensions(7).lldpXDot1EvbExtensions(1)
Tabular objects
lldpXdot1EvbConfigEvbTable
About this table
This table configures the transmission of EVB TLVs on a set of ports.
Support for operations
Create:Not supported
Edit/Modify:Supported
Delete:Not supported
Read:Supported
Columns
The table indexes are lldpV2PortConfigIfIndex and lldpV2PortConfigDestAddressIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpXdot1EvbConfigEvbTxEnable(1.3.111.2.802.1.1.13.1.5.32962.7.1.1.1.1.1.1.1) |
read-write |
TruthValue |
true(1), false(2) |
Selects whether to enable EVB TLV transmission. |
As per the MIB. |
lldpXdot1EvbConfigCdcpTable
About this table
This table configures the transmission of CDCP TLVs on a set of ports.
Read:Supported
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpXdot1EvbConfigCdcpTxEnable(1.3.111.2.802.1.1.13.1.5.32962.7.1.1.1.1.2.1.1) |
read-write |
TruthValue |
true(1), false(2) |
Selects whether to enable CDCP TLV transmission. |
As per the MIB. |
lldpV2Xdot1LocEvbTlvTable
About this table
This table contains information about local EVB TLVs.
Edit/Modify:Not supported
Read:Supported
Columns
The table index is lldpV2LocPortIfIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpV2Xdot1LocEvbTlvString (1.3.111.2.802.1.1.13.1.5.32962.7.1.1.1.2.1.1.1) |
read-only |
OCTET STRING |
OCTET STRING (0..514) |
Local EVB TLV information. |
As per the MIB. |
lldpV2Xdot1LocCdcpTlvTable
About this table
This table contains information about local CDCP TLVs.
Read:Supported
Columns
The table index islldpV2LocPortIfIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpV2Xdot1LocCdcpTlvString (1.3.111.2.802.1.1.13.1.5.32962.7.1.1.1.2.2.1.1) |
read-only |
OCTET STRING |
Local CDCP TLV information. |
As per the MIB. |
lldpV2Xdot1RemEvbTlvTable
About this table
This table contains information about EVB TLVs received from the neighboring devices.
Read:Supported
Columns
The table indexes are lldpV2RemTimeMark, lldpV2RemLocalIfIndex, lldpV2RemLocalDestMACAddress, and lldpV2RemIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpV2Xdot1RemEvbTlvString (1.3.111.2.802.1.1.13.1.5.32962.7.1.1.1.3.1.1.1) |
read-only |
OCTET STRING |
Information about EVB TLVs from neighboring devices. |
As per the MIB. |
lldpV2Xdot1RemCdcpTlvTable
About this table
This table contains information about CDCP TLVs received from the neighboring devices.
Read:Supported
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpV2Xdot1RemCdcpTlvString (1.3.111.2.802.1.1.13.1.5.32962.7.1.1.1.3.2.1.1) |
read-only |
OCTET STRING |
Information about CDCP TLVs from neighboring devices. |
As per the MIB. |
