06-Layer 2 - LAN Switching
HomeSupportRoutersCR16000-M SeriesReference GuidesMIB CompanionH3C CR16000-M Routers MIB Reference-R838x-6W10006-Layer 2 - LAN Switching
12-HH3C-LswVLAN-MIB
12-HH3C-LswVLAN-MIB 85.99 KB
HH3C-LswVLAN-MIB
About this MIB
Use this MIB to configure basic VLAN settings and obtain basic VLAN information.
MIB file name
hh3c-splat-vlan.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cRhw(8).hh3clswCommon(35).hh3cLswVlan(2)
Scalar objects
hh3cVLANMibGarpLeaveAllTime (1.3.6.1.4.1.25506.8.35.2.2.14)
Object (OID)
Access
Value range
Implementation
read-write
Time-Interval
Standard MIB values.
GARP timer, in centiseconds.
Not supported
hh3cVLANMibSwitchGMRPRXPkt (1.3.6.1.4.1.25506.8.35.2.2.15.1.1)
Object (OID)
Access
Value range
Implementation
read-only
COUNTER32
Traffic switch.
Not supported
hh3cVLANMibSwitchGVRPRXPkt (1.3.6.1.4.1.25506.8.35.2.2.15.1.2)
Object (OID)
Access
Value range
Implementation
read-only
COUNTER32
Traffic switch.
Not supported
hh3cVLANMibSwitchGMRPTXPkt (1.3.6.1.4.1.25506.8.35.2.2.15.1.3)
Object (OID)
Access
Value range
Implementation
read-only
COUNTER32
Traffic switch.
Not supported
hh3cVLANMibSwitchGVRPTXPkt (1.3.6.1.4.1.25506.8.35.2.2.15.1.4)
Object (OID)
Access
Value range
Implementation
read-only
COUNTER32
Traffic switch.
Not supported
hh3cVLANMibSwitchDiscardedPkt (1.3.6.1.4.1.25506.8.35.2.2.15.1.5)
Object (OID)
Access
Value range
Implementation
read-only
COUNTER32
Traffic switch.
Not supported
hh3cVLANMibSwitchGarpStatClear (1.3.6.1.4.1.25506.8.35.2.2.15.1.6)
Object (OID)
Access
Value range
Implementation
read-write
INTEGER
Traffic switch.
Not supported
hh3cVLANMibHoldTime (1.3.6.1.4.1.25506.8.35.2.2.16.1.1)
Object (OID)
Access
Value range
Implementation
read-write
INTEGER
INTEGER (10..32765)
Interface holdtime.
Not supported
Tabular objects
hh3cVlanInterfaceTable
About this table
Use this table to configure and obtain VLAN interface information.
Support for operations
CreateSupported
Edit/ModifySupported
DeleteSupported
ReadSupported
Columns
The table index is hh3cdot1qVlanID.
Object (OID)
Access
Value range
Implementation
hh3cVlanInterfaceID (1.3.6.1.4.1.25506.8.35.2.1.2.1.1)
read-only
Integer
Index.
As per the MIB.
hh3cdot1qVlanID (1.3.6.1.4.1.25506.8.35.2.1.2.1.2)
read-only
Hh3cVlanIndex
Integer32 (0..2147483647)
VLAN ID
As per the MIB.
hh3cdot1qVlanIpAddress (1.3.6.1.4.1.25506.8.35.2.1.2.1.3)
read-write
IpAddress
OCTET STRING (0..65535)
IP address.
As per the MIB.
hh3cdot1qVlanIpAddressMask (1.3.6.1.4.1.25506.8.35.2.1.2.1.4)
read-write
IpAddress
IP address and its mask.
As per the MIB.
hh3cVlanInterfaceAdminStatus (1.3.6.1.4.1.25506.8.35.2.1.2.1.5)
read-write
Integer
up(1),
down(2)
VLAN interface state.
As per the MIB.
hh3cVlanInterfaceFrameType (1.3.6.1.4.1.25506.8.35.2.1.2.1.6)
read-only
Integer
ethernet-ii(1),
ethernet-snap(2),
ethernet-8022(3),
ethernet-8023(4)
Frame type.
As per the MIB.
hh3cInterfaceRowStatus (1.3.6.1.4.1.25506.8.35.2.1.2.1.7)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Interface row state.
Available values are active(1), createAndgo(4), and destroy(6).
When the row is created together with configuring other attribute objects, the VLAN interface is first created, and then other attribute objects are configured.
If an object fails to be configured, this operation fails.
As a best practice, use the hh3cInterfaceRowStatus (createAndGo(4)) to create a VLAN interface and configure other attribute objects separately.
When the row state is active, the createAndGo operation succeeds.
hh3cVlanInterfaceIpMethod (1.3.6.1.4.1.25506.8.35.2.1.2.1.8)
read-write
Integer
assigned-ip(1),
dhcp-ip(2),
bootp-ip(3)
VLAN interface IP address assignment method.
The object can only be read.
hh3cVlanInterfaceIfIndex (1.3.6.1.4.1.25506.8.35.2.1.2.1.9)
read-only
Integer
Index of the VLAN interface.
As per the MIB.
hh3cVlanInterfaceAddrTable
About this table
Use this table to configure and obtain VLAN interface IP addresses.
CreateSupported
DeleteSupported
ReadSupported
Columns
The table indexes are hh3cVlanInterfaceIpIfIndex and hh3cVlanInterfaceIpAddr.
Object (OID)
Access
Value range
Implementation
hh3cVlanInterfaceIpIfIndex (1.3.6.1.4.1.25506.8.35.2.1.5.1.1)
read-only
Integer
As per the MIB.
hh3cVlanInterfaceIpAddr (1.3.6.1.4.1.25506.8.35.2.1.5.1.2)
read-only
IpAddress
OCTET STRING (4)
VLAN interface IP address.
As per the MIB.
hh3cVlanInterfaceIpMask (1.3.6.1.4.1.25506.8.35.2.1.5.1.3)
read-create
IpAddress
OCTET STRING (4)
VLAN Interface IP address mask.
As per the MIB.
hh3cVlanInterfaceIpType (1.3.6.1.4.1.25506.8.35.2.1.5.1.4)
read-create
Integer
primary(1),
sub(2),
cluster(3),
vrrp(4)
VLAN interface IP type.
As per the MIB.
Available values are primary(1) and sub(2).
hh3cVlanInterfaceIpRowStatus (1.3.6.1.4.1.25506.8.35.2.1.5.1.5)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Interface IP address row state.
Available values are active(1), createAndGo(4), and destroy(6).
hh3cifSuperVlanMappingTable
About this table
Use this table to configure the super VLAN feature and configure and obtain the super VLAN-to-sub VLAN mappings.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table index is hh3cifSuperVlanID.
Object (OID)
Access
Value range
Implementation
hh3cifSuperVlanID (1.3.6.1.4.1.25506.8.35.2.1.7.1.1)
read-only
Hh3cVlanIndex
Super VLAN index.
Not supported
hh3cifSubVlanlistLow (1.3.6.1.4.1.25506.8.35.2.1.7.1.2)
read-write
OCTET STRING
OCTET STRING (0..256)
Low bit in the sub VLAN bitmap.
Not supported
hh3cifSubVlanlistHigh (1.3.6.1.4.1.25506.8.35.2.1.7.1.3)
read-write
OCTET STRING
High bit in the sub VLAN bitmap.
Not supported
