- 06-Layer 2 - LAN Switching
- 01-BRIDGE-MIB
- 02-EtherLike-MIB
- 03-HH3C-LAG-MIB
- 04-HH3C-LLDP-EXT-MIB
- 05-HH3C-LPBKDT-MIB
- 06-HH3C-LswMAM-MIB
- 07-HH3C-MAC-INFORMATION-MIB
- 08-HH3C-MAC-TRAP-MIB
- 09-HH3C-PVST-MIB
- 10-HH3C-QINQV2-MIB
- 11-HH3C-LswMSTP-MIB
- 12-HH3C-LswVLAN-MIB
- 13-IEEE8021-CFM-MIB
- 14-IEEE8021-CFM-V2-MIB
- 15-IEEE8023-LAG-MIB
- 16-LLDP-EXT-MED-MIB
- 17-LLDP-EXT-DOT3-V2-MIB
- 18-LLDP-EXT-DOT1-EVB-EXTENSIONS-MIB
- 19-LLDP-EXT-DOT1-MIB
- 20-LLDP-EXT-DOT1-V2-MIB
- 21-LLDP-EXT-DOT3-MIB
- 22-LLDP-MIB
- 23-LLDP-V2-MIB
- 24-MAU-MIB
01-BRIDGE-MIB | 68.47 KB |
BRIDGE-MIB
About this MIB
Use this MIB to obtain basic bridge information, collect diagnosis information, and configure the system operating mode.
MIB file name
rfc1493-bridge.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).dot1dBridge(17)
Tabular objects
dot1dBasePortTable
About this table
This table contains generic information about every port that is associated with this bridge.
Support for operations
Create:Not supported
Edit/Modify:Not supported
Delete:Not supported
Read:Supported
Columns
The table index is dot1dBasePort.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
dot1dBasePort (1.3.6.1.2.1.17.1.4.1.1) |
read-only |
INTEGER |
(1..65535) |
Port number of the port for which this entry contains bridge management information. |
As per the MIB. |
dot1dBasePortIfIndex (1.3.6.1.2.1.17.1.4.1.2) |
read-only |
INTEGER |
Standard MIB values. |
Value of the instance of the ifIndex object for the interface corresponding to this port. |
As per the MIB. |
dot1dBasePortCircuit (1.3.6.1.2.1.17.1.4.1.3) |
read-only |
OBJECT IDENTIFIER |
Name of an object instance unique to this port. |
As per the MIB. |
dot1dBasePortDelayExceededDiscards (1.3.6.1.2.1.17.1.4.1.4) |
read-only |
Counter |
Number of frames discarded by this port due to excessive transit delay through the bridge.
As per the MIB. |
dot1dBasePortMtuExceededDiscards (1.3.6.1.2.1.17.1.4.1.5) |
read-only |
Counter |
Number of frames discarded by this port due to an excessive size. |
As per the MIB. |
dot1dStpPortTable
About this table
This table that contains port-specific information for the Spanning Tree Protocol.
Edit/Modify:Supported
Read:Supported
Columns
The table index is dot1dStpPort.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
dot1dStpPort (1.3.6.1.2.1.17.2.15.1.1) |
read-only |
INTEGER |
(1..65535) |
Port number of the port for which this entry contains Spanning Tree Protocol management information. |
As per the MIB. |
dot1dStpPortPriority (1.3.6.1.2.1.17.2.15.1.2) |
read-write |
INTEGER |
(0..240) |
Value of the priority field which is contained in the first (in network byte order) octet of the (2 octet long) Port ID. |
As per the MIB. |
dot1dStpPortState (1.3.6.1.2.1.17.2.15.1.3) |
read-only |
INTEGER |
disabled(1), blocking(2), listening(3), learning(4), forwarding(5), broken(6) |
Port's current state as defined by application of the Spanning Tree Protocol. |
As per the MIB. |
dot1dStpPortEnable (1.3.6.1.2.1.17.2.15.1.4) |
read-write |
INTEGER |
enabled(1), disabled(2) |
Enabled/disabled status of the port. |
As per the MIB. |
dot1dStpPortPathCost (1.3.6.1.2.1.17.2.15.1.5) |
read-write |
INTEGER |
(1..65535) |
Contribution of this port to the path cost of paths towards the spanning tree root which include this port. |
In the current software version, this object supports only the IEEE802.1d-1990 standard, and the value range is 1 to 65535. If the actual value is greater than 65535 in another standard, the object value is 65535. |
dot1dStpPortDesignatedRoot (1.3.6.1.2.1.17.2.15.1.6) |
read-only |
BridgeId |
Unique Bridge Identifier of the Bridge recorded as the Root in the Configuration BPDUs transmitted by the Designated Bridge for the segment to which the port is attached. |
As per the MIB. |
dot1dStpPortDesignatedCost (1.3.6.1.2.1.17.2.15.1.7) |
read-only |
INTEGER |
Path cost. |
As per the MIB. |
dot1dStpPortDesignatedBridge (1.3.6.1.2.1.17.2.15.1.8) |
read-only |
BridgeId |
Bridge identifier. |
As per the MIB. |
dot1dStpPortDesignatedPort (1.3.6.1.2.1.17.2.15.1.9) |
read-only |
OCTET STRING |
(SIZE (2)) |
Port identifier of the port on the Designated Bridge for this port's segment. |
As per the MIB. |
dot1dStpPortForwardTransition (1.3.6.1.2.1.17.2.15.1.10) |
read-only |
Counter |
Number of times this port has transitioned from the Learning state to the Forwarding state. |
As per the MIB. |
